Manage Company Addresses (Address Tab)
At a minimum, a Headquarters address must be entered in the Edit Company window. The Headquarters address will be the default company address. The default address displays on the Company Home page and is used to generate an online company location map. You can add up to six additional company addresses.
To manage company addresses:
- Go to the Company Workspace tab and switch to Admin mode.
- In the right pane, click Open. The Edit Company window opens.
- Click the Address tab.
- Complete all fields marked as required (red asterisk *). To enter additional addresses, click Address Type and choose another address to enter. See the table below for details.
- Click Apply to save changes, or OK to save and close the Edit Company window.
In this field: | Do this: |
Address Type | Click the field and select from the drop-down list. At a minimum, an address for Headquarters is required, which is used as the default company address in the system. You can enter up to seven company addresses (for example, billing). |
Attention | Click the Select button and select a user from the picker. |
Address and phone fields | These are text fields. No validation will be performed on these fields. All fields with a red asterisk are required. Select the Country/Region from the drop-down list. |
See Also
Title and Copyright Information
Signing In the First Time and Confirming the Base Currency
Company Workspace Landing Page (Admin)
Selecting and Configuring a Default System for E-Signatures
Adding and Managing Partner Companies
Viewing and Managing Cash Flow Jobs and Auto Snapshots
Using the BP Visualizer to View Business Processes
Unifier Essentials and Oracle Primavera Cloud
About Consent Notices (Administrator)
Translating Custom Strings (Internationalization)
Configuring and Publishing Oracle Analytics Server Custom Templates (Custom Prints and Reports)
Configuring and Generating Custom Reports using the Report Utility BP
Configuring Project Numbering and Status
Configuring the User Mode Navigator
Last Published Tuesday, April 15, 2025
