Configuring Localization Settings
Your localization settings specify the language you see when you log in to P6 and the country for server string constants. The Java application uses this setting to ensure all instances of P6 EPPM will use the same localization settings.
Notes:
To set your language and country:
  1. Open the Primavera P6 Administrator.
  2. In the Configurations drop-down list, select your configuration.
  3. In the sidebar select Localization.
    1. In the System Language drop-down list, select your language. The default value is English (en).
    2. In the System Country drop-down list, select your country. The default value is US.
Tip: Go to http://download.oracle.com/javase/1.5.0/docs/guide/intl/locale.doc.html or the Tested Configurations document for a list of supported languages and countries.
Related Topics
About the Configurations Tab in the Primavera P6 Administrator
Configuring Session Management Settings
Configuring Database Instance Settings for On-Premises
Configuring Thread Pool Settings
Configuring AutoVue without VueLink
Configuring Outside In
Configuring Log Settings
Configuring Client Properties Settings
Configuring Web Proxy Settings
About Application Settings in the Primavera P6 Administrator
About the Primavera P6 Administrator Services Settings
Configuring P6ProCloudConnect Settings
Configuring GeoCodeProvider Settings
Configuring Integration API Server Settings
About Configuring P6 EPPM Web Services in the Primavera P6 Administrator
Configuring P6 Team Member Settings
Configuring Diagnostics Settings
Last Published Friday, February 2, 2024
