Configuring P6 Team Member Settings
  1. Open the Primavera P6 Administrator.
  2. In the Configurations drop-down list, select your configuration.
  3. In the sidebar select Team Member if you want to alter the following default values:
    Note: Changes to these settings require you to restart the P6 Team Member server.
    • Initial connection pool size: 10
    • Maximum active database connections: 150
    • Maximum idle database connections: -1
    • Minimum idle database connections: 10
    • Enabled: Selected
    • Severity Level: Error
      Note: Other Severity Level options include the following:
      • off
      • fatal
      • warn
      • info
      • debug
      • trace
      • all
    • Log File Name: p6tmweb.log
Related Topics
About the Configurations Tab in the Primavera P6 Administrator
Configuring Localization Settings
Configuring Session Management Settings
Configuring Database Instance Settings for On-Premises
Configuring Thread Pool Settings
Configuring AutoVue without VueLink
Configuring Outside In
Configuring Log Settings
Configuring Client Properties Settings
Configuring Web Proxy Settings
About Application Settings in the Primavera P6 Administrator
About the Primavera P6 Administrator Services Settings
Configuring P6ProCloudConnect Settings
Configuring GeoCodeProvider Settings
Configuring Integration API Server Settings
About Configuring P6 EPPM Web Services in the Primavera P6 Administrator
Configuring Diagnostics Settings
Last Published Friday, February 2, 2024
