Configuring Session Management Settings
The Maximum Session Timeout setting is the maximum length of time that a user can connect to the application server (regardless of activity) before P6 EPPM times it out.
To set your session timeout:
  1. Open the Primavera P6 Administrator.
  2. In the Configurations drop-down list, select your configuration.
  3. In the sidebar select Session Management.
  4. In Maximum Session Timeout, enter the amount of time a user session can remain open before it times out.
    The default value is 1d.
    Enter a value between 1m and 24d.
Note: Changes to this setting require you to restart the P6 server.
Related Topics
About the Configurations Tab in the Primavera P6 Administrator
Configuring Localization Settings
Configuring Database Instance Settings for On-Premises
Configuring Thread Pool Settings
Configuring AutoVue without VueLink
Configuring Outside In
Configuring Log Settings
Configuring Client Properties Settings
Configuring Web Proxy Settings
About Application Settings in the Primavera P6 Administrator
About the Primavera P6 Administrator Services Settings
Configuring P6ProCloudConnect Settings
Configuring GeoCodeProvider Settings
Configuring Integration API Server Settings
About Configuring P6 EPPM Web Services in the Primavera P6 Administrator
Configuring P6 Team Member Settings
Configuring Diagnostics Settings
Last Published Friday, February 2, 2024
