Configuring P6ProCloudConnect Settings
To configure settings for P6 Pro Cloud Connect:
  1. Open the Primavera P6 Administrator.
  2. In the Configurations drop-down list, select your configuration.
  3. In the sidebar select P6ProCloudConnect.
    Note: Changes to these settings require you to restart the P6 server.
  4. In the FetchSize field, enter the maximum number of rows gathered in a database block. The default value is 254. You can enter a value between 0 and 2147483647.
  5. In the TaskMaxTime field, enter the maximum time allowed for a P6 Pro task to complete. A job consists of one or more P6 Pro tasks. The default value is 5m.
  6. In the TransactionMaxInactiveInterval field, enter the timeout interval for an inactive session that has a pending database transaction. The default value is 15m.
  7. In the SessionMaxInactiveInterval field, enter the timeout interval for an inactive session. The default value is 2h.
  8. In the Mode drop-down menu, you can select Username Token Profile or SAML Token Profile. The default value is Username Token Profile.
Related Topics
About the Configurations Tab in the Primavera P6 Administrator
Configuring Localization Settings
Configuring Session Management Settings
Configuring Database Instance Settings for On-Premises
Configuring Thread Pool Settings
Configuring AutoVue without VueLink
Configuring Outside In
Configuring Log Settings
Configuring Client Properties Settings
Configuring Web Proxy Settings
About Application Settings in the Primavera P6 Administrator
About the Primavera P6 Administrator Services Settings
Configuring GeoCodeProvider Settings
Configuring Integration API Server Settings
About Configuring P6 EPPM Web Services in the Primavera P6 Administrator
Configuring P6 Team Member Settings
Configuring Diagnostics Settings
Last Published Friday, February 2, 2024
