Setting Up Generic Cost Sheet Data for Analytics
Primavera Analytics> supports reporting and analyses of data from the various cost attributes in the Generic Cost Sheet of Shells with Generic Cost Codes. You can map the Analytics fields to the corresponding Generic Cost Sheet columns.
To select business processes:
  1. Sign in to Unifier with administration privileges.
  2. In the navigation pane, select Analytics.
  3. In the Name column, select Generic Cost Sheet and then click Open.
  4. In the Data Mapping tab, map the Generic Cost sheet Analytic fields to the corresponding Generic Cost Sheet columns, defined in Unifier:
    1. In the Data Source field, select the data source for each user defined column.
      Data source values are the single sources and logical sources existing in the Generic Cost Sheets of all the Generic type Shells. You can pick the same data source for multiple fields.
    2. In the Label field, modify the display name for the data source based on your business needs. Defaults to the Name column for the data source, as set in the Generic Cost sheet column definition
    3. Click OK.
For more details, see the Primavera Unifier General Administration Guide.
Related Topics
Configuring Primavera Unifier for Primavera Data Warehouse
Configuring and Running Primavera Unifier Publication Services
Creating History Data for Primavera Unifier
Setting Up Business Processes for Analytics
Setting Up Cash Flow Data for Analytics
Setting Up Cost Sheet Data for Analytics
Setting Up P6 Summary Sheets Data for Analytics
Setting Up Shell Data for Analytics
Setting Up Space Manager Data for Analytics
Setting Up Vendor Data for Analytics
Last Published Tuesday, January 7, 2025
