Setting Up Shell Data for Analytics
You can select the Shells that you want to use for analyses. Shells are called projects in Primavera Analytics.
To add Shell data for Primavera Analytics:
- Sign in to Unifier with administration privileges.
- In the navigation pane, select Analytics.
- In the Name column, select Shells and then click Open.
- In the top section of the Data Mapping tab, specify the following information:
- In the Data Source column, select the Data Element (DE) for each predefined, read-only field listed in the Name column.
The Name column, displays which represent the fields used in Primavera Analytics.
- In the User Defined Attributes section of the Data Mapping tab, click Add.
- In the Add User Defined Attribute window specify values for the following properties of the attribute:
- Data Type: Select the data type of the attribute as any one of the following: String (default), Date, Numeric
- Source: Select the data source as Main Form or Details Form.
- Name: Select the user defined string to be associated with the name. You can add up to 100 names (User Defined String Fields 1 - 30)
- Data Source: Select the data source to be associated with the custom field.
- Label: Defaults to the data element label selected in the Data Source list. Modify the label if necessary.
- Notes:
- Analytics displays the value, if the label is absent.
- Analytics displays the label, which has the Value/Label pair, in the case of Data Elements (DEs).
- Click OK.
For more details, see the Unifier General Administration Guide (https://docs.oracle.com/cd/F50962_01/English/User_Guides/user_general/index.html).
Related Topics
Configuring Primavera Unifier for Primavera Data Warehouse
Configuring and Running Primavera Unifier Publication Services
Creating History Data for Primavera Unifier
Setting Up Business Processes for Analytics
Setting Up Cash Flow Data for Analytics
Setting Up Cost Sheet Data for Analytics
Setting Up Generic Cost Sheet Data for Analytics
Setting Up P6 Summary Sheets Data for Analytics
Setting Up Space Manager Data for Analytics
Setting Up Vendor Data for Analytics
Last Published Tuesday, January 7, 2025
