Setting Up Vendor Data for Analytics
You can select Unifier's vendor data that you want to use in Primavera Analytics.
To setup vendor data for Primavera Analytics:
  1. Sign in to Unifier with administration privileges.
  2. In the navigation pane, select Analytics.
  3. In the Name column, select Vendors and then click Open.
  4. In the Vendors Setup window, choose any of the following actions:
    • Click Add to add vendor data for analysis.
    • Click Remove to remove vendor data from analysis.
  5. To add vendor data, click Add.
  6. In the Vendors tab, select one or more vendors and then click OK.
    Tip: Use CTRL or Shift keys to select multiple space types.
  7. Click Apply and then click OK.
  8. In the Data Mapping tab, map the predefined Analytic Vendor related fields to a corresponding Unifier Data Element (DE) in the Business Process as follows:
    1. In the Data Source list, select the upper form DEs, for the selected Vendor in the Vendors tab for the following fields:
      • Vendor ID
      • Name
      • Type
    2. Click Apply and then click OK.
For more details, see the Primavera Unifier General Administration Guide.
Related Topics
Configuring Primavera Unifier for Primavera Data Warehouse
Configuring and Running Primavera Unifier Publication Services
Creating History Data for Primavera Unifier
Setting Up Business Processes for Analytics
Setting Up Cash Flow Data for Analytics
Setting Up Cost Sheet Data for Analytics
Setting Up Generic Cost Sheet Data for Analytics
Setting Up P6 Summary Sheets Data for Analytics
Setting Up Shell Data for Analytics
Setting Up Space Manager Data for Analytics
Last Published Tuesday, January 7, 2025
