Setting Up Space Manager Data for Analytics
You can select the Space Manager data that you want to use in Primavera Analytics.
To add a new space manager data for Primavera Analytics:
  1. Sign in to Unifier with administration privileges.
In the navigation pane, select Analytics.
  1. In the Name column, select Space Manager and then click Open.
  2. In the Space Manager Setup window:
    1. Select the Space Types tab and choose any of the following actions:
      • Click Add to add a space type for analysis.
      • Click Modify to update a space type data for analysis
      • Click Remove to remove space type from analysis.
  3. To add space types for analysis, click Add.
  4. In the Space Types window select one or more space types and then click OK.
    Tip: Use the CTRL or Shift keys to select multiple space types.
  5. Click Apply and then click OK.
  6. Select the Data Mapping -Space Types tab and click Add to add custom fields from various Space Types to use in Analytics.
    1. In the Add User Defined Attribute window specify values for the following properties for the attribute.
      • Data Type: Select the data type of the attribute as any one of the following: String (default), Date, Numeric
      • Source: Select the data source as Main Form or Details Form.
      • Name: Select the user defined string to be associated with the name.
      • Data Source: Select the data source to be associated with the custom field.
      • Label: Defaults to the data element label selected in the Data Source list. Modify the label if necessary.
    2. Click OK.
  7. Select the Data Mapping -Level tab and click Add to add custom level/floor fields from various levels to map the Analytics field to the corresponding Levels field.
    1. In the Add User Defined Attribute window specify values for the following properties of the attribute.
    2. Click OK.
      Notes:
      • Analytics displays the value, if the label is absent.
      • Analytics displays the label, which has the Value / Label pair, in the case of Data Elements (DEs).
For more details, see the Primavera Unifier General Administration Guide.
Related Topics
Configuring Primavera Unifier for Primavera Data Warehouse
Configuring and Running Primavera Unifier Publication Services
Creating History Data for Primavera Unifier
Setting Up Business Processes for Analytics
Setting Up Cash Flow Data for Analytics
Setting Up Cost Sheet Data for Analytics
Setting Up Generic Cost Sheet Data for Analytics
Setting Up P6 Summary Sheets Data for Analytics
Setting Up Shell Data for Analytics
Setting Up Vendor Data for Analytics
Last Published Tuesday, January 7, 2025
