| 1.
Copy the Necessary Files from the Utility
USB to Support the OS Install
This procedure is used to provide the steps
for copying all supporting files from the Utility USB to the appropriate
directories so that the Provision Container successfully installs OL7 onto
RMS2.
The
cluster_name field is
derived from the
occne_cluster_name field in
the hosts.ini file.
- Create the
directories needed on the Installer Bootstrap Host.
$ mkdir /var/occne
$ mkdir /var/occne/<cluster_name>
$ mkdir /var/occne/<cluster_name>/yum.repos.d
- Mount the Utility
USB.
Note: Instructions for
mounting a USB in Linux are at:
Installation of Oracle Linux 7.5 on Bootstrap Host : Install Additional
Packages. Only follow steps 1-4 to mount the USB.
- Copy the hosts.ini
file (created using procedure:
OCCNE Inventory File Preparation) into the
directory. This hosts.ini file defines RMS2 to the Provision Container running
the provision image downloaded from the repo.
$ cp /media/usb/hosts.ini /var/occne/<cluster_name>/hosts.ini
Copy the customer specific
ol7-mirror.repo and the
docker-ce-stable repo on the
Utility USB to the Installer Bootstrap Host.
This is the .repo file created by the customer that
provides access to the onsite (within their network) repositories needed to
complete the full deployment of OCCNE 1.2 and to install docker-ce onto the
$ cp /media/usb/ol7-mirror.repo /var/occne/<cluster_name>/yum.repos.d/ol7-mirror.repo
$ cp /media/usb/ol7-mirror.repo /etc/yum.repos.d/ol7-mirror.repo
$ cp /media/usb/docker-ce-stable.repo /etc/yum.repos.d/docker-ce-stable.repo
If still enabled from procedure:
OCCNE Installation of Oracle Linux 7.5 on Bootstrap Host, the
/etc/yum.repos.d/Media.repo is to be disabled.
$ mv /etc/yum.repos.d/Media.repo /etc/yum.repos.d/Media.repo.disable
| 2.
Copy the OL7 ISO to the Installer Bootstrap
Host
The iso file should be accessible from a Customer Site
Specific repository. This file should be accessible because the ToR switch
configurations were completed in procedure:
OCCNE Configure Top of Rack 93180YC-EX Switches.
Copy from RMS1, the OL7 ISO file to the /var/occne directory.
The example below uses OracleLinux-7.5-x86_64-disc1.iso.
Note: If
the user copies this ISO from their laptop then they must use an application
like WinSCP pointing to the Management Interface IP.
$ scp <usr>@<site_specific_address>:/<path_to_iso>/OracleLinux-7.5-x86_64-disc1.iso /var/occne/OracleLinux-7.5-x86_64-disc1.iso
| 3.
Install Docker onto the Installer Bootstrap
Host
Use YUM to install docker-ce onto the installer Bootstrap
Host. YUM should use the existing <customer_specific_repo_file>.repo in
the /etc/yum.repos.d directory.
$ yum install docker-ce-18.06.1.ce-3.el7.x86_64
| 4.
Set up access to the Docker Registry on the
- Add an entry to
the
/etc/hosts file on the
Installer Bootstrap Host to provide a name mapping for the docker registry
using the hosts.ini file fields
occne_private_registry
and
occne_private_registry_address
in
OCCNE
Inventory File Preparation.
<occne_private_registry_address>
<occne_private_registry>
Example:10.75.200.217 reg-1
- Create the
/etc/docker/daemon.json file
on the Installer Bootstrap Host. Add an entry for the insecure-registries for
the docker registry.
$ mkdir /etc/docker
$ vi /etc/docker/daemon.json
Enter the following:
"insecure-registries": ["<occne_private_registry>:<occne_private_registry_port>"]
Example:
cat /etc/docker/daemon.json
"insecure-registries": ["reg-1:5000"]
To Verify:
ping <occne_private_registry>
Example:
# ping reg-1
PING reg-1 (10.75.200.217) 56(84) bytes of data.
64 bytes from reg-1 (10.75.200.217): icmp_seq=1 ttl=61 time=0.248 ms
64 bytes from reg-1 (10.75.200.217): icmp_seq=2 ttl=61 time=0.221 ms
64 bytes from reg-1 (10.75.200.217): icmp_seq=3 ttl=61 time=0.239 ms
- Create the docker
service http-proxy.conf file.
$ mkdir -p /etc/systemd/system/docker.service.d/
$ vi /etc/systemd/system/docker.service.d/http-proxy.conf
Add the following:
[Service]
Environment="NO_PROXY=<occne_private_registry_address>,<occne_private_registry>,127.0.0.1,localhost"
Example:
[Service]
Environment="NO_PROXY=10.75.200.217,reg-1,127.0.0.1,localhost"
- Start the docker
daemon
$ systemctl daemon-reload
$ systemctl restart docker
$ systemctl enable docker
Verify docker is running:
$ ps -elf | grep docker
$ systemctl status docker
| 5.
Setup NFS on the Installer Bootstrap Host
Run the following commands (assumes nfs-utils has already been
installed in procedure:
OCCNE Installation of Oracle Linux 7.5 on Bootstrap Host : Install Additional
Packages).
Note: The
IP address used in the echo command is the Platform VLAN IP Address (VLAN 3) of
the Bootstrap Host (RMS 1) as given in:
Installation PreFlight Checklist : Complete Site Survey Host Table.
$ echo'/var/occne 172.16.3.4/24(ro,no_root_squash)'>> /etc/exports
$ systemctl start nfs-server
$ systemctl enable nfs-server
Verify nfs is running:
$ ps -elf | grep nfs
$ systemctl status nfs-server
| 6.
Set up the Boot Loader on the Installer
Bootstrap Host
Execute the following commands:
$ mkdir -p /var/occne/pxelinux
$ mount -t iso9660 -o loop /var/occne/OracleLinux-7.5-x86_64-disc1.iso /mnt
$ cp /mnt/isolinux/initrd.img /var/occne/pxelinux
$ cp /mnt/isolinux/vmlinuz /var/occne/pxelinux
| 7.
Verify and Set the PXE Configuration File
Permissions on the Installer Bootstrap Host
Each file configured in the step above must be open for read
and write permissions.
$ chmod 777 /var/occne/pxelinux
$ chmod 777 /var/occne/pxelinux/vmlinuz
$ chmod 777 /var/occne/pxelinux/initrd.img
| 8.
Disable DHCP and TFTP on the Installer
Bootstrap Host
The TFTP and DHCP services running on the Installer Bootstrap
Host may still be running. These services must be disabled.
$ systemctl stop dhcpd
$ systemctl disable dhcpd
$ systemctl stop tftp
$ systemctl disable tftp
| 9.
Disable SELINUX
SELINUX must be set to permissive mode. In order to
successfully set the SELINUX mode, a reboot of the system is required. The
getenforce command is used
to determine the status of SELINUX.
$ getenforce
active
If the output of this command displays active, change it to permissive by editing the /etc/selinux/config file.
$ vi /etc/selinux/config
Change the SELINUX variable to passive: SELINUX=permissive
save the file
Reboot the system: reboot
| 10.
Execute the OS Install on RMS2 from the
- Run the docker
commands below to perform the OS install.
docker run --rm --network host --cap-add=NET_ADMIN -v /var/occne/<cluster_name>/:/host -v /var/occne/:/var/occne:rw -e "OCCNEARGS=--limit <db-2_node_name>, localhost --skip-tags "datastore,vms_provision,yum_configure" <image_name>:<image_tag>
docker run --rm --network host --cap-add=NET_ADMIN -v /var/occne/<cluster_name>/:/host -v /var/occne/:/var/occne:rw -e "OCCNEARGS=--limit <db-2_node_name>,localhost --tags yum_configure" <image_name>:<image_tag>
docker run --rm --network host --cap-add=NET_ADMIN -v /var/occne/<cluster_name>/:/host -v /var/occne/:/var/occne:rw -e "OCCNEARGS=--limit <db-2_node_name>,localhost --tags datastore" <image_name>:<image_tag>
docker run --rm --network host --cap-add=NET_ADMIN -v /var/occne/<cluster_name>/:/host -v /var/occne/:/var/occne:rw -e "OCCNEARGS=--limit <db-2_node_name>,localhost --tags vms_provision" <image_name>:<image_tag>
Example:
docker run -it --rm --network host --cap-add=NET_ADMIN -v /var/occne/rainbow.lab.us.oracle.com/:/host -v /var/occne/:/var/occne:rw -e "OCCNEARGS=--limit db-2.rainbow.lab.us.oracle.com,localhost --skip-tags "datastore,vms_provision,yum_configure"" 10.75.200.217:5000/occne/provision:1.2.0
docker run -it --rm --network host --cap-add=NET_ADMIN -v /var/occne/rainbow.lab.us.oracle.com/:/host -v /var/occne/:/var/occne:rw -e "OCCNEARGS=--limit db-2.rainbow.lab.us.oracle.com,localhost --tags yum_configure" 10.75.200.217:5000/occne/provision:1.2.0
docker run -it --rm --network host --cap-add=NET_ADMIN -v /var/occne/rainbow.lab.us.oracle.com/:/host -v /var/occne/:/var/occne:rw -e "OCCNEARGS=--limit db-2.rainbow.lab.us.oracle.com,localhost --tags datastore" 10.75.200.217:5000/occne/provision:1.2.0
docker run --rm --network host --cap-add=NET_ADMIN -v /var/occne/<cluster_name>/:/host -v /var/occne/:/var/occne:rw -e "OCCNEARGS=--limit db-2.rainbow.lab.us.oracle.com,localhost --tags vms_provision" 10.75.200.217:5000/occne/provision:1.2.0
- Verify that
Bastion host vm is installed by logging into RMS2. Run the following in case of
failure to Login ONLY:
$ virsh list
Output Example-
Id Name State
11 bastion-1.rainbow.lab.us.oracle.com running
$ virsh destroy bastion-1.rainbow.lab.us.oracle.com
$ virsh undefine bastion-1.rainbow.lab.us.oracle.com
$ virsh list
Note: virsh list after destroy and undefine should not return any name in the list
- Execute the
virt-install command on RMS2
virt-install --name bastion_host --memory 8192 --vcpus 2 --metadata description="Bastion Host" \
--autostart --location /var/occne/OracleLinux-7.5-x86_64-disc1.iso \
--initrd-inject=/tmp/bastion_host.ks --os-variant ol7.5 \
--extra-args "ks=file:/bastion_host.ks console=tty0 console=ttyS0,115200" \
--disk path=/var/lib/libvirt/images/bastion_host.qcow2,size=300 \
--network bridge=teambr0 --network bridge=vlan2-br --network bridge=vlan4-br --graphics none
After the VM creation completes, the login prompt appears
which allows the user to login to the Bastion Host.
