Running the Consolidated Pro Forma, Finalization, Print, and Reprint Processes
You run consolidated pro formas and consolidated invoices separately from all other invoice activity using the Preprocess and Finalization process.
Consolidated bills only print as invoices if the invoice layout IDs are the same. For example, you cannot consolidate bills if one has portrait layout and the other is landscape. If you have difficulty printing consolidated invoices, detach the bills, change the invoice layout IDs to a common value, and then attach the bills to the consolidated header again.
Likewise, if any bills attached to a consolidated header have a line with a summarization template, then all bills must have lines with summarization templates.
Pages Used to Run the Consolidated Pro Forma, Finalization, Print, and Reprint Processes
Consolidated Pro Forma Page
RUN_BI_PRNTIVC_CON
Establish parameters for printing consolidated pro forma invoices and actual invoices.
Consolidated Final and Print Page
RUN_BI_PROFORM_OPT
Define parameters for printing or reprinting a pro forma invoice.
Consolidated Final and Print - Print Options Page
RUN_BI_ADV_OPT
Define parameters for printing or reprinting an invoice.
Consolidated Reprint Invoices Page
RUN_BI_PRNTIVC
Establish parameters for reprinting consolidated pro forma invoices and actual invoices.
Consolidated Reprint Invoices - Print Options Page
RUN_BI_ADV_OPT_PRE
Define parameters for reprinting a consolidated invoice.
Bills To Be Processed Page
BI_BILL_LIST_SBP
View all bills in the range selection. The bills reflect the options that you define on the main page. Depending on how you access the page, some fields may not appear.
Use the Consolidated Final and Print, and Consolidated Pro Forma page (RUN_BI_PRNTIVC_CON) to establish parameters for printing consolidated pro forma invoices and actual invoices.
Navigation:
  • Billing, and then Generate Invoices, and then Consolidated, and then Finalize & Prnt Consoldtd Bill, and then Consolidated Final and Print
  • Billing, and then Generate Invoices, and then Consolidated, and then Print Consolidated Pro Forma, and then Consolidated Pro Forma
  • Billing, and then Generate Invoices, and then Consolidated, and then Single Action Consolidation
Select the parameters in the Range Selection group box. These parameters are the same for consolidated pro forma invoices and consolidated invoices, and they control the range of consolidated bills that you want to print at this time.
When you select the consolidated bill header, all attached bills are processed regardless of whether they fall in the range. The system processes all non-INV or FNL status bills for running pro forma invoices.
Navigation:
When you select the consolidated bill header, all related bills are processed regardless of whether they fall in the range. The system also retrieves only bills with the status RDY for running the Consolidated Final and Print process. During the printing process, any invoices that are marked for delivery with Email Invoice as Attachment will be emailed. Also, if an invoice image is to be retained, the image will be produced as a PDF and attached to the invoice header at printing time. Both the email and the invoice image attachment processing are performed by the BI_XMLPBURST program that is run with the printing jobs.
Use the Consolidated Reprint Invoices page (RUN_BI_PRNTIVC) to establish parameters for reprinting consolidated pro forma invoices and actual invoices.
Navigation:
Billing, and then Generate Invoices, and then Consolidated, and then Reprint Consolidated Invoice, and then Consolidated Reprint Invoices
When you reprint consolidated invoices using this page, the consolidated invoices look like the originals and the system does not run the finalization process again. Invoices that are marked for Email Invoice as Attachment delivery, can be emailed again from the reprint component.
