Approving Journal Entries for Posting Using PeopleSoft Fluid User Interface
General information about Mobile Approvals is available in FSCM Application Fundamentals documentation. See
Pages Used to Approve Journal Entries for Posting in the PeopleSoft Fluid User Interface
| Page Name | Definition Name | Usage |
EOAWMA_MAIN_FL |
Review and approve multiple journal entries. Access summary details for a specific journal entry. For general information, see the Application Fundamentals: Pending Approvals Page. |
EOAWMA_TXNHDTL_FL |
Review and approve a single journal entry. Access line item details for a specific line. For general information, see the Application Fundamentals: Approval Header Detail Page. |
EOAWMA_APPC_SCF |
Review display-only line details. |
EOAWMA_MAIN_FL |
Review a list of journal entry approvals. Access the approval history for a specific journal entry. For general information, see the Application Fundamentals: Approvals History Page. |
EOAWMA_TXNHDTL_FL |
Review the approvals history for a single journal entry. Access line item details for a specific line. |
Setting Up General Ledger to Approve Journal Entries for Posting
To set up General Ledger to approve journal entries using the Approval Framework:
Select Approval Framework In the Journal Approval Method field on the Application Fundamentals: Installation Options - General Ledger Page.
In the Approval Framework, set up push notifications and define the internal URL for the GL Journal Approval Process. Go to the Approval Framework: Register Transactions Page Enterprise Components, Approvals, Approvals, Transaction Registry) for this Process ID: GLJournalApproval.
Select the Push check box in the Notification Options, Enable Notifications field.
Enter values in the Internal URL Definition section.
For more information about the Register Transactions page, see Approval Framework: Setting Up the Transaction Registry.
Verify the settings on the Enterprise Components: CAVF Configuration Setup Page, for the GL_JRNL_ATTACHMENT Configuration ID to allow attachments.
On the Application Fundamentals: ChartField Display Template Page, create a new (or use an existing) template so that the ChartField Option and the ChartField Display Option is determined for Fluid Approvals.
For journal entry approvals, the system only checks Hide option on the template. In addition, the system can only show the first 9 ChartFields, even if the template has 15.
If a journal approval template cannot be found, the system uses the default ChartField Display Template.
If you created a new template in the previous step, on the Application Fundamentals: Assign by Key Field Values page, for Component Name Approval Transaction Registry and Process ID GLJournalApproval assign permissions to your ChartField Display Template for journal approvals.
If your organization is using the Enterprise Components Notification Composer framework, set up the Journal Posting business process. See Enterprise Components: Understanding Notification Composer.
Pending Approvals (summary) Page
Use the Pending Approvals (summary) page (EOAWMA_MAIN_FL) to review and approve multiple journal entries. Access header details for a specific journal entry.
Navigation:
Select the Approvals tile and then select Journal Entry.
This example illustrates the fields and controls on the Pending Approvals (summary) page.
Review header information for the journal entries currently routed for approval. To access journal entry details, select the row. You can select one or more journal entries on this page and perform a mass action on the selected journal entries. You can also use the filter to narrow results on the page. For general information about using the filter, see the Application Fundamentals: Filters Page.
| Field or Control | Description |
Approve, Deny, or More |
Perform a mass action by selecting multiple transactions, then one of the action buttons. Select More to display additional options such as Pushback or Hold. If your organization uses the auto post after approval feature, and you are the final approver, then the system automatically runs the journal post process (GL_JP) for the journal IDs that are approved. This feature is configured on the Application Fundamentals: Installation Options - General Ledger Page. Keep in mind that if multiple journal IDs are selected, this feature could impact performance. Note: You must select at least one row to activate the action buttons. |
Pending Approvals - Journal Entry Page
Use the Pending Approvals - Journal Entry page (EOAWMA_TXNHDTL_FL) to review and approve a single journal entry.
Navigation:
Select a journal entry from the list on the Pending Approvals summary page.
This example illustrates the fields and controls on the Pending Approvals - Journal Entry pare.
When viewing journal entry details in small form factor (SFF), the Summary section only displays key fields and you must scroll down to view approver comments and the approval chain.
The approval chain reflects approval status generated by the Approval Framework. For more information, see the product documentation for the PeopleSoft Approval Framework. See also Approval Framework: Understanding Transaction Approval Flows.
Perform an action on this journal entry by selecting an approval action button. Select More to display additional options such as Pushback or Hold. If your organization uses the auto post after approval feature, and you are the final approver, then the system automatically runs the journal post process (GL_JP) for the journal ID that is approved. This feature is configured on the Application Fundamentals: Installation Options - General Ledger Page. Upon selecting an action, you have the option to select Submit to continue the action, or Cancel to back out of the action. Upon submitting the action, the system generates a message that the action is successful. |
Edit Journal |
Select to access the Create/Update Journal Entries - Lines Page, where you can edit the journal entry. If you make changes to the journal, you must go through the Edit and Approval process again. |
Approver Comments |
Enter comments in the text entry field. |
Approval Chain |
Review approval chain information. You can expand or collapse approver information for each line by selecting the glyph icon. You can also select the approver name to view approver details. |
Pending Approvals - Journal Entry - Approval Chain Page
Use the Pending Approvals -Journal Entry - Approval Chain page (EOAWMA_APPC_SCF) to review approver information.
Navigation:
Select Approval Chain from the Pending Approvals - Journal Entry page.
This example illustrates the fields and controls on the Pending Approvals - Journal Entry - Approval Chain page.
Approvals History (summary) Page
Use the Approvals History (summary) page (EOAWMA_MAIN_FL) to review a list of journal entry approvals. Access the approval history for a specific journal entry. Approval history is retained even for those journals that are resubmitted for approval after any modification.
Navigation:
Select the Actions icon on the page banner. Select Approvals History.
This example illustrates the fields and controls on the Approvals History (summary) page.
Review the list of journal entries with an approvals history. Select a journal entry to view the approvals history details for a particular journal entry.
Approvals History - Journal Entry Page
Use the Approvals History - Journal Entry header approval page (EOAWMA_TXNHDTL_FL) to review the approvals history for a single journal entry. Access line item details for a specific line.
Navigation:
Select a journal entry in the list on the Approvals History (summary) page.
This example illustrates the fields and controls on the Approvals History - Journal Entry page.
