Configuring Journal Edit and Post Requests for Autopilot
To configure the journal edit and post requests for Autopilot, use the Edit Journal Request (JOURNAL_EDIT_REQ), and Post Journals Request (JOURNAL_POST_REQ) components.
Pages Used to Configure Journal Edit and Post for Autopilot
| Page Name | Definition Name | Usage |
JOURNAL_EDIT_REQ |
Specify the process request parameters on the run control page for the journal edit request that is to run in Autopilot. |
JOURNAL_POST_REQ |
Specify the process request parameters on the run control page for the journal post request that is to run in Autopilot. |
Edit Journals Request Page
Use the Edit Journal Request page (JOURNAL_EDIT_REQ) to specify the process request parameters on the run control page for the journal edit request that is to run in Autopilot.
Navigation:
General Ledger, Journals, Process Journals, Edit Journals, Edit Journals Request
| Field or Control | Description |
Process Frequency |
Select Always. |
Autopilot Run Control |
Select the check box to make the process available to the Autopilot. When this check box is selected the system issues a warning if the process frequency selected is other than Always. The Re-Edit option cannot be selected for an Autopilot Run Control. |
Post Journals Request Page
Use the Post Journals Request page (JOURNAL_POST_REQ) to specify the process request parameters on the run control page for the journal post request that is to run in Autopilot.
Navigation:
General Ledger, Process Journals, Post Journals, Post Journals Request
Process Frequency |
Select Always. |
Select the check box to make the process available to the Autopilot. When this check box is selected the system issues a warning if the process frequency selected is other than Always. |
