Managing Assets Not Reporting
This topic provides an overview of assets not reporting and discusses how to define inventory age, IT subtypes, and manage assets not reporting.
Pages Used to Manage Assets Not Reporting
Inventory Age Page
IT_TSPAN_DEFN_01
Associate the inventory age with the userID.
Defining IT Subtypes
IT_MNT_IT_SUBTYPE
Define IT subtypes.
Managing Assets Not Reporting Page
IT_UNDISC_DTL
View assets with overdue inventory reports and specify resolutions.
Understanding Assets Not Reporting
The ability to track assets not reporting enables the IT Asset Manager to audit IT devices for reporting failures. This feature provides tighter control over the organization's equipment.
Non-reporting asset audit reports are based on the user-defined inventory age; that is the age of the last report that the asset made to the third-party inventory system. For example, an inventory age of three weeks may be defined for desktops. This means that if a desktop has not reported to the third–party inventory system for three weeks or more, it appears on the audit report. A different inventory age can be specified for each type of equipment, if necessary.
The system displays audit reports in two formats:
  • The online reporting page Manage Assets Not Reporting, where you can view assets with overdue inventory reports and specify resolutions.
  • The Assets Not Reporting portal pagelet, which provides counts of reporting failures for each type of device.
Using the online reporting page, you can choose from a number of available actions:
  • Send detailed email notifications to the custodian or the user, or both, or their managers.
    The email addresses prompt from the emails that exist for the associated role. The email subject line and default text are predefined messages stored in the message catalog.
  • Route a proposed retirement transaction to Finance for financial assets.
    This requires approval from the Financial Asset Manager, so choosing this action creates a worklist item for a finance user. Finance users click on this item in their worklists to bring up the Retirements page. This action is only available for financial assets.
  • Complete a retirement transaction for nonfinancial assets.
    Nonfinancial retirement is triggered immediately. These transactions are processed on a row-by-row basis and passed through the RETIRE_NF component interface This action is only available for nonfinancial assets
  • Move to inventory.
    This triggers a transfer into inventory for nonfinancial assets. This action is unavailable for financial assets.
Inventory Age
Inventory age is the age of last inventory beyond which the device requires investigation or action. The inventory age can be defined differently for different types of devices. For example, laptops may report inventory less often as they are physically connected to the network less often, so the age of the last inventory will often be higher than that of servers which are always reporting.
Inventory age time periods accrue, so longer time periods are included in shorter time periods. A device that has an inventory age of nine weeks will be included in six and three week sequences as well.
The inventory age sequence includes all discovered devices unless the IT Subtype is specified. Reporting on specific subtypes is only done if the Aging Inventory check box is selected on the Define IT Subtypes page.
Inventory Age Page
Use the Inventory Age page (IT_TSPAN_DEFN_01) to associate the inventory age with the userID.
Navigation:
Setup Financials/Supply Chain, and then Product Related, and then IT Asset Management, and then Inventory Age
See Setting Up Inventory Age.
Use the IT Subtypes page (IT_MNT_IT_SUBTYPE) to define IT subtypes.
Navigation:
Set Up Financials/Supply Chain, and then Product Related, and then IT Asset Management, and then IT Subtypes, and then Define IT Subtypes
See Defining IT Subtypes.
Reporting will only be done on subtypes with the Aging Inventory check box selected.
  • Search for assets not reporting.
  • Review machine information.
  • Review responsible parties.
  • Review location information.
  • Review financial information.
  • Work with actions.
  • Add retirement comments.
Searching for Assets Not Reporting Page
Use the Manage Assets Not Reporting page (IT_UNDISC_DTL) to view assets with overdue inventory reports and specify resolutions.
Navigation:
IT Asset Management, and then Asset Discovery and Validation, and then Manage Assets Not Reporting, and then Manage Assets Not Reporting
See Manage Exceptions Page.
This example illustrates the fields and controls on the Manage Assets Not Reporting page.
Reviewing Machine Information
Access the Machine Information tab on the Manage Assets Not Reporting page.
This example illustrates the fields and controls on the Assets Not Reporting - Machine Information. You can find definitions for the fields and controls later on this page.
Field or Control Description
Select
Select the check box to perform the selected Action to the selected assets, ignore selected exceptions, or add assets to a financial impact list.
Inventory Age
Displays the Inventory Age from the asset repository.
Serial ID
Displays the Serial ID from the asset repository.
Manufacturer Name
Displays the name of the manufacturer from the asset repository.
ARM Model
Displays the ARM model from the asset repository.
Tag Number
Displays the tag number from the asset repository.
Last Inventory Date
Displays the date of the last inventory report that the asset sent.
Log Log
Click the Log icon to access the Asset Comment page and add relevant details. These comments can be viewed from the View Asset Log page.
Submit Actions
Click this button to launch the actions specified.
Ignore Exceptions
Click this button to ignore exceptions for the selected assets. You are directed to the Ignore Exceptions page where you can add the selected exceptions to an ignore list.
Note: You should not select to ignore software exceptions. If the software exceptions are ignored, it could present you with a lower count of the licenses that you have distributed, thereby subjecting you to potential license compliance issues.
See Managing Ignored Exceptions.
Notify
Click the Notify icon to send email notification to appropriate personnel.
Reviewing Responsible Parties
Access the Responsible Party tab on the Manage Assets Not Reporting page.
This example illustrates the fields and controls on the Manage Assets Not Reporting page: Responsible Parties tab.
Click the Custodian (ARM) and Custodian Manager links to access custodian detail information.
Reviewing Location Information
Access the Location Information tab on the Manage Assets Not Reporting page.
This example illustrates the fields and controls on the Manage Assets Not Reporting page: Location Information tab. You can find definitions for the fields and controls later on this page.
ARM Location Code and Location
Displays the location shown in the asset repository.
IP Address
Displays the last logged IP address reported by the third-party inventory database.
Working with Financial Information
Access the Financial Information tab on the Manage Assets Not Reporting page.
The Financial Information tab is displayed when the Financial Impact check box is selected from the Installation Options - Asset Management page and one or more of the financial search criteria are selected.
This example illustrates the fields and controls on the Manage Assets Not Reporting page - Financial Information tab 1 of 2.
This example illustrates the fields and controls on the Manage Assets Not Reporting page - Financial Information tab 2 of 2.
See Managing Exceptions.
Working with Actions
Access the Action tab on the Manage Assets Not Reporting page.
This example illustrates the fields and controls on the Manage Assets Not Reporting page: Action tab. You can find definitions for the fields and controls later on this page.
Financial Asset
This field indicates if an asset is a financial asset. If the asset is marked as a financial asset, the Retire a Non-Financial Asset action is not available. If the asset is not a financial asset, the Route to Finance action is not available. This prevents users from trying to retire a financial asset or routing a nonfinancial asset to the Finance department through workflow.
Action
When you select an action that sends an email, the system displays the Preview Email link. Click this link to view the email content.
When you select Retire a Non-Financial Asset, the Retirement Type and Reference Code fields become visible for entry, as does the Retirement Comments tab.
Preview Email
This column is displayed with links when an email action is selected. Click the link to preview the email content.
Retirement Type
Select a retirement type. Values are: Abandoned, Auto-Ret, Cannibal, Casualty, Disappear, Donated, Inventory, Like Kind, Missing, Sale, Scrap, Theft, and Trade-In.
Reference Code
Enter a reference code for the retirement, if applicable.
Adding Retirement Comments
Access the Retirement Comments tab on the Manage Assets Not Reporting page.
The Retirement Comments page is available only if Retire a Non-Financial Asset is selected on the Action page.
This example illustrates the fields and controls on the Manage Assets Not Reporting page: Retirement Comments tab. You can find definitions for the fields and controls later on this page.
Apply
Click to apply the selected action to each row that is selected in the grid. The system intelligently applies actions to assets based off of the financial status of the asset and the financial implication of the action selected for application. For example, Retire a Non-Financial Asset will not be applied to a financial asset.
Note: TheSubmit Actions button must be invoked in order to execute the actions that are associated with each line in the grid.
Submit Actions
Click to submit all selected assets' actions.
Note: This action saves the changes.
Ignore Exceptions
Click to ignore exceptions for selected assets.
Add retirement specific comments for any assets that are being retired.
