Performing Mobile Inventory Inquiry by All Units Using the PeopleSoft Fluid User Interface
This topic discusses how to perform Mobile Inventory Inquiry by All Units.
Page Used to Perform Mobile Inventory Inquiry by All Units Using the PeopleSoft Fluid User Interface
Inquiry By All Units Page
MIN_ITMALLBU_SR_FL
Display the stock availability of an item across business units.
Use the Inquiry By All Units page to display the stock availability of an item across business units for different Set IDs.
Navigation:
Mobile Inventory, and then Inquiry By All Units
This example illustrates the fields and controls on the Inquiry By All Units Page.
This example illustrates the fields and controls on the Inquiry By All Units Search Results Page.
Inquiry by all units page - Search Result
Click the Business unit link to view the item balance by location page.
This example illustrates the fields and controls on the Item Balance by Location page
Item balance by location Mobile Inventory
Field or Control Description
Item ID
Enter the PeopleSoft inventory item ID for the stock you want to check availability.
Note: You can view stock availability of an item across business units for different Set IDs.
Exclude Zero Qty Business Unit
Select the check box to exclude the following:
  • Business unit rows with quantity 0 for all columns
  • SetIDs with no business units
  • SetIDs with all business units with quantity 0 in all columns
Business Unit
Click a PeopleSoft Inventory business unit to view location specific stock available in a particular business unit.
