Setting Up Options for the Inquiry by All Units Task Flow
This topic discusses how to setup options for the Inquiry by All Units task flow.
Pages Used to Set up Options for the Inquiry by All Units Task Flow
Installation Options - Mobile Inventory - Fluid Page
INSTALLATION_MIN_N
Define installation options for the Inquiry by All Units task flow.
User Preferences - Mobile Inventory - Fluid Page
OPR_DEF_TABLE_MIN
Define user preferences for the Inquiry by All Units task flow.
Use the Installation Options - Mobile Inventory - Fluid page (INSTALLATION_MIN_N) to define installation options for the Inquiry by All Units task flow.
Navigation:
Set Up Financials/Supply Chain, and then Install, and then Installation Options, and then Mobile Inventory- Fluid
Select Inquiry by All Units in the Task Flow field.
This example illustrates the fields and controls on the Installation Options - Mobile Inventory - Fluid page for the Inquiry by All Units task flow.
Mobile Inventory Installation Options Inquiry by All Units
Use this page to set up default options for Inquiry by All Units at the installation level.
Use the User Preferences - Mobile Inventory - Fluid page to define user preferences for the Inquiry by All Units task flow.
Navigation:
Set Up Financials/Supply Chain, and then Common Definitions, and then User Preferences, and then Define User Preferences, and then Mobile Inventory - Fluid.
Use this page to define Inquiry by All Units options for an individual user. The fields on this page are the same as the Installation Options - Mobile Inventory page for the same task flow. This page is optional; the Installation Options - Mobile Inventory - Fluid page for the same task flow is used when a user ID does not have this page defined or when the Use Installation Values check box is selected.
For additional information, see Setting Up Installation Options and User Preferences
