Voucher Build Process Flow
The Voucher Build process comprises two subprocesses, pre-edit and voucher edit. The pre-edit subprocess builds skeleton voucher record sets from limited information that you enter online using the Quick Invoice Entry component (VCHR_QUICK_PNL) or the Summary Invoice Entry component (VCHR_SUMM_PNL), or that it retrieves from other sources. After the pre-edit subprocess builds voucher record sets successfully, it calls the voucher edit subprocess to complete these record sets.
If financial sanctions validation is enabled, the Voucher Build process does not consider the financial sanctions status of the supplier, nor does it validate the supplier against any financial sanctions lists (for example, the Specially Designated Nationals (SDN) list). Therefore, you can build vouchers for any supplier with a financial sanctions status of Review or Blocked. However, the Pay Cycle Application Engine process (AP_APY2015) does not select vouchers for a supplier that has a financial sanctions status of Review or Blocked. You cannot pay these vouchers until the financial sanctions status of the supplier is set to Cleared or Valid.
See Understanding Financial Sanctions Validation.
Pre-Edit Process Flow
The pre-edit subprocess works in the following way:
It accesses and retrieves invoice data from the source transaction tables or staging tables, and it uses the data to populate the Voucher Build temporary tables.
The specific source tables and data that the subprocess retrieves depends on the run control selection criteria that you specify on the Voucher Build Request page.
Vouchers from prior Voucher Build process instances that have been staged for review and released for processing, as well as vouchers with corrected pre-edit errors, can also be selected for reprocessing and are inserted into the temporary tables with the new transactions.
When loading invoices into the Voucher staging tables using an external source (for example: from a legacy or third-party system) any extra spaces at the end of character fields need to be trimmed, otherwise this extra space can cause a voucher edit error and the voucher will be created in a Recycle status.
It performs header error processing by checking for a valid business unit, invoice ID, invoice date, supplier ID, supplier location, address sequence number, and voucher origin.
The invoice data from some source transactions receive additional error checks.
The subprocess verifies that voucher headers have voucher lines and that voucher lines have distribution lines.
If applicable, the subprocess creates control groups, builds miscellaneous charge records if absent (based on business unit defaults), and creates payment records.
The pre-edit subprocess can create payment schedule records only if payment schedule information such as the bank or a payment message is entered through the source transaction component. Quick invoices and voucher data that is staged to the voucher staging tables enable the entry of payment schedule information. For all other source transaction types, the payment records must be created by the voucher edit subprocess using the PeopleSoft Payables control hierarchy defaults.
The subprocess copies purchase order and receiver fields to voucher lines and creates distribution lines, based on either the default voucher build criteria or the voucher build code that is specified in the voucher header.
This applies when voucher lines reference a purchase order, receiver, packing slip, or bill of lading, and contain no distribution lines.
If a voucher line has ChartField information and no associated distribution lines, the subprocess creates distribution lines for the voucher line.
You define voucher build codes in the Voucher Build Criteria component (VCHR_BLD_DEFN).
See Voucher Build Processing Logic for Associating Voucher Lines with Purchase Order and Receiver Lines.
It stores successfully built voucher record sets in the voucher build temporary tables and calls the voucher edit subprocess.
If the skeleton voucher fails any of the header error checks, or if the purchase order and receiver association for a quick invoice, summary invoice, or spreadsheet voucher fails, the subprocess marks the voucher as having a pre-edit error. Such errors prevent the vouchers from being processed by the voucher edit subprocess, and the pre-edit subprocess writes these vouchers with pre-edit errors to the quick invoice tables.
You can review vouchers with pre-edit errors using the Build Errors page and the Voucher Build Error Detail page. From these pages you can link directly to the Quick Invoice Entry component, where you can correct the vouchers and release them for reprocessing.
Voucher contracts, evaluated receipt settlement (ERS) vouchers, and return to vendor (RTV) vouchers can be designated as staged for review. The pre-edit subprocess also writes these to the quick invoice tables instead of passing them to the voucher edit subprocess. You review and release these vouchers for further voucher build processing by using the Quick Invoice Entry component.
Voucher Edit Process Flow
The voucher edit subprocess works in the following way:
It loads newly built voucher data from the Voucher Build temporary processing tables to the Voucher Edit work tables.
If specifically requested on the run control, the voucher edit subprocess also loads any vouchers in the online voucher tables that match the run control criteria. These could be recycled vouchers or vouchers that were modified using the Voucher Mass Maintenance component (VCHR_MASS_MAINT) or the Voucher Maintenance component (VCHR_CORRECTION).
It performs the following tasks:
Uses the PeopleSoft Payables control hierarchy to determine the default values with which to populate voucher fields that don't contain data.
Performs field-level, relational, and balancing edits for the voucher header, voucher line, voucher distribution line, and scheduled payment records.
Calculates net payment due dates, discount due dates, and discount amounts according to the payment terms.
Prorates freight, miscellaneous charges, sales tax, use tax, value-added tax (VAT), and discounts across distribution lines for applicable voucher lines.
Schedules one or more payments according to payment terms and user-entered control data.
Voucher Edit process validates the Same Day Layout codes SPSVNDRSDA, SPSTRVLSDA, SPSMISCSDA, PAMVNDRSDA, PAMTRVLSDA, or PAMMISCSDA entered on Voucher build sources for Payment Method EFT with the Payment Schedule Restriction page. The process sets the Vouchers to Recycle status if the layout codes does not exists on the Payment schedule Restriction page.
Voucher Edit process validates the each payment schedule with the Amount Per Payment limit set on Payment schedule Restriction page for Payment Method EFT and Same Day Layout codes SPSVNDRSDA, SPSTRVLSDA, SPSMISCSDA, PAMVNDRSDA, PAMTRVLSDA, or PAMMISCSDA. The process sets the Vouchers to Recycle status if Payment exceeds the Amount Per Payment limit.
Validates the vouchers, assigning document sequencing numbers and updating the status of one-time suppliers, where appropriate.
It moves the voucher data from the voucher edit work tables to the online voucher tables.
At the end of the voucher edit subprocess, error-free vouchers are set to the status Postable. Vouchers that are flagged with errors during the voucher edit subprocess are assigned the status Recycle. You can inquire on and correct batch-processed vouchers with voucher edit errors by using the Build Errors page, the Voucher Build Error Detail page, the Voucher Maintenance Search component, the Voucher Maintenance component, and the Voucher component.
It publishes an XML message with voucher details if you select the Publish Voucher Messages option on the Voucher Build page.
You can notify suppliers that you have received their invoices for any sources transactions. The XML message structure is defined in the message AP_VCHR_MESSAGE_OUT.
