Reviewing Profit Margins and Unbilled Cost Using PeopleSoft Fluid
Pages Used to Review Profit Margins and Unbilled Cost Using PeopleSoft Fluid
Project Profit Margin (pivot) Page
(none)
View profit margins for your projects.
Contract Profit Margin (pivot) Page
(none)
View profit margins for the contracts where the project is listed on your My Projects List.
Project Unbilled Cost WIP (pivot) Page
(none)
View project costs that have not been billed or are work in progress for your projects.
Use the Project Profit Margin (pivot) page to view profit margins for your projects.
Navigation:
Fluid Home, and then Project Management, and then Project Profit Margin
This example illustrates the fields and controls on the Project Profit Margin (pivot) page.
Project Profit Margin page
This page displays the profit margins for the projects that are on your Projects List Page. The Profit Margin groupings are determined on the Reporting Options - Reporting Groups Page.
Field or Control Description
Options Menu icon (options menu)
Select the Options Menu icon to access these options:
  • View Pivot Grid
  • Update Filters
  • Export Data
  • Chart Options
  • Save
(item on chart)
Select a project on the chart to view the grid below the chart for only the project selected.
Related Actions icon (related actions icon)
Select the Related Actions icon to access these options:
Use the Contract Profit Margin (pivot) page to view profit margins for the contracts where the project is listed on your My Projects List.
This information is only available if you have PeopleSoft Contracts installed on your system.
Navigation:
Fluid Home, and then Project Management, and then Contract Profit Margin
This example illustrates the fields and controls on the Contract Profit Margin (pivot) page.
Contract Profit Margin page
This page displays the profit margins for the contract projects on your Projects List Page. The profit margin groupings are determined on the Reporting Options - Reporting Groups Page.
  • View Pivot Grid
  • Update Filters
  • Export Data
  • Chart Options
  • Save
(item on chart)
Select a project contract on the chart to view the grid below the chart for only the contract selected.
Select the Related Actions icon to access the Notify Contract Administrator page, if one is entered for the contract.
Use the Project Unbilled Cost WIP (pivot) page to view project costs that have not been billed or are work in progress for your projects.
Navigation:
Fluid Home, and then Project Management, and then Project Unbilled Cost WIP
This example illustrates the fields and controls on the Project Unbilled Cost WIP (pivot) page.
Project Unbilled Cost WIP page
This page displays the projects that are on your Projects List Page. It is limited to the Project Costing business unit and currency specified on the Employee Self Service -My Preferences - Report Business Unit Page. The Aging Group is determined on the Reporting Options - Reporting Groups Page.
This page does not show transactions that have been sent to PeopleSoft Billing.
  • View Pivot Grid
  • Update Filters
  • Export Data
  • Chart Options
  • Save
(item on chart)
Select a project on the chart to view the grid below the chart for only the project selected. Multiple rows for a project are based on the aging group specified on the Reporting Options - Reporting Groups Page.
Days Unbilled
Displays the number of days based on reporting options setup.
Note: If your summarization template has a transaction date roll-up, then this is the dates that is considered for the Days Unbilled calculation.
