Running the Payment Predictor Application Engine Process
Pages Used to Run the Payment Predictor Application Engine Process
Payment Predictor Page
PP_REQUEST
Define run parameters for the Payment Predictor process.
Process Reset Page
AR_RESET
Reset the Payment Predictor process. Unlock and rerun the process.
Process List Page
PMN_PRCSLIST
Review the multiple processes in a job.
See Restarting the Payment Predictor Process.
See the product documentation for PeopleTools: Process Scheduler for more information.
Process Detail Page
PMN_PRCSLISTREE
Restart a failed process.
Understanding Payment Predictor Processing
The Payment Predictor process automatically matches payments with open items for a customer based on a predefined payment predictor method. When you set up Payment Predictor, you define algorithms, algorithm groups, and methods. You specify in each payment predictor method how to handle the exceptional conditions, such as overpayments or underpayments, for the algorithm group that you associate with the method.
The algorithm groups #DETAIL and #DTL_TLR do not allow you to define exception handling.
The Payment Predictor process either matches the payment and sets it to post or sends the payment matching results to a payment worksheet for review. If the payment predictor method designated that the process create a payment worksheet, the worksheet shows how Payment Predictor applied the payment and made adjustments based on the instructions in the method.
If the system sends the payment matching results to a payment worksheet, you must review the worksheet. You must decide whether to accept the matching results as they are or make other adjustments. When you finish working with the payment worksheet, you set the payment to post.
If the process does not generate a worksheet, it creates a payment group and sets it to post.
Run the Receivables Update Application Engine process to post any new items that the process created and to create accounting entries.
Payment Predictor Abends
If the Payment Predictor process ends abnormally, you have two alternatives:
  • Reset and rerun the process instance on items locked by the Payment Predictor process and other associated tables that may need to be rolled back to their original state.
  • Restart and resume processing after you have resolved the cause of the abnormal ending.
Oracle recommends that you reset and rerun from the beginning if your are not certain which approach to take.
Prerequisites
Perform the following tasks before you run the Payment Predictor process:
  1. Define payment predictor methods.
  2. Assign a payment predictor method to a business unit.
  3. Override the payment predictor method for individual customers if needed.
  4. Enter balanced deposits with reference information for payments.
  5. Select the Payment Predictor check box for the payments.
    Each payment must have a magnetic ink character recognition (MICR) ID, a customer ID, or some other type of reference information. If the payment does not have reference information, use a payment predictor method that has a step to route the unidentified payment to a control account and generate a worksheet.
  6. Verify that the deposits are in balance.
  7. If you import vendor rebates from PeopleSoft Purchasing or claimbacks from PeopleSoft Order Management, you must activate the CHKREBAT step in the PREPARE section of the AR_PREDICT1 Application Engine process.
Use the Payment Predictor page (PP_REQUEST) to define run parameters for the Payment Predictor process.
Navigation:
Accounts Receivable, and then Payments, and then Apply Payments, and then Request Payment Predictor, and then Payment Predictor
Process Reset Page
Use the Process Reset page (AR_RESET) to reset the Payment Predictor process.
Navigation:
Accounts Receivable, and then Receivables Update, and then Archive Receivables, and then Reset Process, and then Process Reset
Enter your search criteria for the process instance and click Refresh.
Not Successful Process Requests, select the process instance that you want to reset.
Field or Control Description
Reset
Click to unlock and reset the process instance.
After the process instance is reset, you can rerun the process.
Use the Process List page (PMN_PRCSLIST) to review the multiple processes in a job.
Navigation:
PeopleTools, and then Process Scheduler, and then Process Monitor, and then Process List
Click Process Monitor on the Payment Predictor page.
Because Payment Predictor is a job (a collection of multiple processes), you may need to restart multiple processes. Find the processes that you need to restart.
Process Detail
Click the Details link on the Process List page to access the Process Detail page.
Use the Process Detail page (PMN_PRCSLISTREE) to restart a failed process. Select a failed process from the process list. Select Restart Request.
