Application Engine Implementation
This section provides information to consider before you begin to use Application Engine.
Implementation of Application Engine can be divided into these activities:
Set up properties.
Specify actions.
Create temporary table instances.
Set up debugging options.
Enable Application Engine tracing.
Setting Up Properties
To set up Application Engine properties, perform these steps:
| Step | Reference |
1. Set up program properties. |
2. Set up section properties. |
3. Set up step properties. |
4. Set up action properties. |
See Specifying Actions. |
Specifying Actions
To modify action properties, perform these steps:
| Step | Reference |
1. Specify SQL actions. |
2. Specify Do actions. |
3. Specify PeopleCode actions. |
4. Specify Call Section actions. |
5. Specify Log Message actions. |
Creating Temporary Table Instances
To set up temporary tables to improve performance, perform these steps:
| Step | Reference |
1. Define temporary tables. |
2. Set up the number of temporary table instances. |
3. Build table instances. |
Setting Up Debugging Options
To set up debugging options for Application Engine programs, perform these steps:
| Step | Reference |
1. Enable the Application Engine debugger. |
2. Set up debugging options. |
Enabling Application Engine Tracing
To trace Application Engine programs, perform these steps:
| Step | Reference |
1. Set command line options. |
2. Set parameters in server configuration files. |
3. Set options in Configuration Manager. |
See Setting Client Options in PeopleSoft Configuration Manager. |
Other Sources of Information
In addition to implementation considerations presented in this topic, take advantage of all PeopleSoft sources of information, including the installation guides, release notes, and PeopleBooks.
Related Topics
