Flow Scheme Project User Interface
Intelligent Advisor Flows was only made available to select customers, and will not be made Generally Available.
When you open a flow scheme project from the Projects page, you will see the project details page. (Note that users with only the Viewer role will only be able to view the flow scheme project, not edit it.)
The project details view for a flow scheme project in Intelligent Advisor Hub
The project details page has a top toolbar, known as the project header. In the project header there is:
  • an up arrow. This navigates back to the Projects page.
  • the name of the flow scheme project. This can be edited.
  • a button under the project name for the currently viewed version. This opens the Version history panel.
  • a Run button (if the flow scheme project uses a scheme that has a Debug URL specified). This opens the flow in a new browser window for you to test it.
  • an edit button (Edit, Edit latest version or Continue editing) when viewing an older version of the flow scheme project. This allows you to switch back to editing the draft version of the project (see Edit a Project).
  • an Actions menu. This menu has the following options:
    • Discard draft - This discards any unpublished changes in the draft version of the flow scheme project (see Edit a Project).
    • Revert to this version - This allows you to make your draft version a copy of the currently opened older version of the flow scheme project (see Edit a Project).
    • Version history - This opens the Version History panel allowing you to open any version of the flow scheme project (see View the Project History).
    • Export - This downloads a JSON file of the flow scheme project (see Export a Project).
    • Delete - This deletes all versions of the flow scheme project.
  • a Commit button. This creates a new numbered version of the flow scheme project (see Commit a Version of a Project).
  • an indication of the save status of the flow scheme project. This is shown as Saving, Saved or Save failed (see Save the Project).
Below the project header are one or two panes, depending on the tab selected:
  • a left hand pane, with five tabs:
    • Controls
    • Data
    • Formatters
    • Language
    • General
  • a right hand pane, known as the properties panel, shown when the Controls tab and Formatters tab are selected
