4 Running NF Test Cases Using ATS
4.1 Running BSF Test Cases using ATS
This section describes how to run BSF test cases using ATS.
Restart the NRF-client pod of BSF for UDR and CHF discovery as part of each test case.
4.1.1 Prerequisites
To run Binding Support Function test cases, ensure that the following prerequisites are met:
  • Deploy BSF 25.1.200 with default helm configurations using helm charts to run all test cases. The ATS version must be compatible with BSF 25.1.200.
    For more information on how to install BSF, see Oracle Communications Cloud Native Core, Binding Support Function Installation, Upgrade, and Fault Recovery Guide.
  • Go-STUB must be installed in the same namespace where ocbsf is installed.
  • Add the following to Kubernetes namespace to grant role access:
    PolicyRule:
      Resources               Non-Resource URLs  Resource Names  Verbs
      pods/log                []                 []              [get list]
      configmaps              []                 []              [watch get list delete update create]
      pods                    []                 []              [watch get list delete update create]
      secrets                 []                 []              [watch get list delete update create]
      services                []                 []              [watch get list delete update create]
      deployments.apps        []                 []              [watch get list update]
      replicasets.apps        []                 []              [watch get list update]
      deployments.extensions  []                 []              [watch get list update]
      replicasets.extensions  []                 []              [watch get list update]
  • ATS Prometheus metrics validation works only when:
    • the metrics suffixes are not configured
    • installation has a single pod for each microservice in the BSF deployment
  • You can customize test cases in the custom test case folders (cust_newfeatures, cust_regression and cust_performance). You can add new test cases, remove unwanted test cases and modify existing test cases. It does not impact the original product packaged test cases available in the newfeatures, regression and performance folders respectively. For more details about custom test case folders, see Custom Folder Implementation.
  • Install Prometheus server in the cluster.
  • Database cluster is in the running state with all required tables. Verify that there are no previous entries in the database before running test cases.
  • Do not initiate a job in two different pipelines at the same time.
  • For running ATS features, ensure to update the following mandatory parameters in ocbsf_custom_values_25.1.200.yaml file only when you are not using the minimal custom values.yaml file.
    logging:
      burst:
        rate: 500
        max: 3000
        onMismatch: DENY
        logLevel: DEBUG
    Please ensure that you use the latest version of the Custom Values file when installing BSF initially.
  • For using Controlled Shutdown feature, ensure that enableControlledShutdown parameter is enabled on BSF during installation. If this parameter is not enabled, the test case for this feature will fail.
  • In the application-config configmap, configure the following parameters with the respective values:
    • primaryNrfApiRoot=nf1stub.<namespace_gostubs_are_deployed_in>.svc:8080
      For example:
      primaryNrfApiRoot=nf1stub.ocats.svc:8080
    • secondaryNrfApiRoot=nf11stub.<namespace_gostubs_are_deployed_in>.svc:8080
      For example:
      secondaryNrfApiRoot=nf11stub.ocats.svc:8080
    • virtualNrfFqdn = nf1stub.<namespace_gostubs_are_deployed_in>.svc
      For example:
      virtualNrfFqdn=nf1stub.ocats.svc
    • retryAfterTime=PT30S
  • To enable ATS BSF GUI with the HTTPS protocol, the above mentioned application-config configmap related following parameters should be configured with the respective values:
    # Please edit the object below. Lines beginning with '#' will be ignored,
    # and an empty file will abort the edit. If an error occurs while saving this file will be
    # reopened with the relevant failures.
    apiVersion: v1
    data:
      profile: | -
        [appcfg]
        primaryNrfApiRoot=nf1stub.ocats.svc:8443
        secondaryNrfApiRoot=nf11stub.ocats.svc:8443
        nrfScheme=https
        virtualNrfPort=8443
        virtualNrfScheme=https
  • Before running ATS Test suite, restart nrf-client-nfdiscovery and nrf-client-nfmanagement pods.
    • Run the following command to get all the configmaps in your namespace.
      kubectl get configmaps -n <BSF_namespace>
    • Edit the alternate route service deployment pointing towards DNS Stub.
      Run the following command to get searches information from dns-bind pod to enable communication between Alternate Route and dns-bind service.
      kubectl exec -it <dns-bind pod> -n <NAMESPACE> -- /bin/bash -c 'cat /etc/resolv.conf' | grep search | tr ' ' '\n' | grep -v 'search'
      Example:
      Figure 4-1 Editing Alternate Route Service deployment pointing towards DNS Stub
      By default, Alternate Route Service points to CoreDNS.
      Figure 4-2 Alternate Route Service settings in deployment file
      Change the deployment file to add following content in alternate service to query DNS stub.
      kubectl edit deployment ocbsf-occnp-alternate-route -n ocbsf
      • Add the nameservers IPaddress.
      • Add all the search information.
      • Set dnsPolicy to None.
        dnsConfig:
          nameservers:
           - <dns_stub_cluster_ip_address>
           searches:
           - dns-bind search
           - dns-bind search
           - dns-bind search
           dnsPolicy: None
        Figure 4-3 dnsConfig
        dnsConfig
    • If Service Mesh check is enabled, create a destination rule to fetch the metrics from the Prometheus. For destination rule to communicate between TLS enabled entity (ATS) and non-TLS entity (Prometheus), Prometheus is kept outside of the service mesh. The rule can be created as follows:
      kubectl apply -f - <<EOF
      apiVersion:networking.istio.io/v1alpha3
      kind:DestinationRule
      metadata:
        namespace:ocats
      spec:
        host:oso-prometheus-server.ocbsf.svc.cluster.local
        trafficPolicy:
          tls:
            mode:DISABLE
      EOF
      • name: indicates the name of destination rule.
      • namespace: indicates where the ATS is deployed.
      • host: indicates the hostname of the prometheus server.
  • For Bsf_To_Nrf_Late_Arrival feature file to be executed, nfInstanceId should be configured in Bsf_To_Nrf_Late_Arrival.yaml parameterization file. This nfInstanceId must be the same as the one under BSF nfInstanceId, that is configured during BSF installation. The nfInstanceId must to be configured in ATS UI under pipeline configuration (BSF_NFINSTANCE_ID).
  • To ensure consistent functioning of ATS related to the audit service, modify the Audit deployment by reducing the value of AUDIT_NOTIFY_SCHEDULER_POLLING_INTERVAL_MILLISEC from 30000 to 1000 (changing from 30 seconds to 1 second).
    $ kubectl get deploy -n ocbsf | grep 'audit' ocbsf-ocpm-audit-service     1/1     1      1     10h
    $ kubectl edit deploy ocbsf-ocpm-audit-service -n ocbsf
    The deployment will open. Scroll down until below fields are seen
    - name:  AUDIT_NOTIFY_SCHEDULER_POLLING_INTERVAL_MILLISEC value: "30000"
    Update the value of AUDIT_NOTIFY_SCHEDULER_POLLING_INTERVAL_MILLISEC to 1000 if it isn't already.
Application Config map changes for BSF registrations over TLS
To enable TLS communication make the following changes by editing the config map of application-config:
  • NRF port from 8080 to 8443
  • nrfScheme to https
Sample:
apiVersion: v1
data:
  profile: |-
    [appcfg]
    nrfScheme=https
    virtualNrfPort=8443
In the config map of application-config, delete the lines which has supportedDataSetId or secondaryNrfApiRoot strings.
4.1.2 Logging into ATS
Before logging into ATS GUI, it is important to get the worker node external IP and node port of the service, 'ocats-bsf'.
Run the following command to get the external IP for the worker node:
Example:
kubectl get nodes -owide
The output of the command is:
ocbsf-k8s-node-1        Ready    <none>   111d   v1.16.7   192.168.200.26   10.75.152.111   Oracle Linux Server 7.8   4.14.35-1902.303.5.3.el7uek.x86_64   containerd://1.2.10
Run the following command to get the nodeport:
kubectl get svc -n <BSF_namespace>
Example:
kubectl get svc -n ocbsf
ocbsf-ocats-ocats-bsf     LoadBalancer   10.233.53.144   10.75.225.49     8080:31944/TCP      19h
To log in to ATS, open the web browser and type the following URL:
http://<Worker-Node-IP>:<Node-Port-of-ATS>
If the 'ocats-bsf' Service has an external IP available, <SVC external IP> can also be used to log in to ATS.
http://<External IP of ATS Service>:8080
Example:
http://10.75.225.49:8080
Running ATS
To run ATS test cases, perform the following steps:
  1. Enter the username as bsfuser and Password as bsfpasswd.
  2. Click Sign in.
    To modify default login password, see Modifying Login Password.
    Figure 4-4 Pre-configured Pipelines
    On successful log in, users should see the following pipelines:
    • BSF-NewFeatures: This pipeline has all the new test cases delivered for BSF 25.1.200.
    • BSF-Performance: This pipeline is not operational as of now. It is reserved for future releases of ATS.
    • BSF-HealthCheck: This pipeline checks if BSF and ATS are deployed correctly. This shows only when the user has enabled this feature at the time of installing BSF ATS.
    • BSF-Regression: This pipeline has all the test cases delivered in BSF ATS - 25.1.200.
4.1.3 Running BSF_NewFeatures Pipeline
This is a pre-configured pipeline where users can run all the BSF new test cases. To configure its parameters, which is a one time activity, perform the following steps:
  1. Click BSF_NewFeatures in the Name column and then, click Configure in the left navigation pane as shown below:
    Figure 4-5 BSF New Feature Pipeline
  2. The BSF_NewFeatures, General tab appears. Make sure that the screen loads completely.
  3. Scroll-down to the end. The control moves from General tab to the Pipeline tab as shown below:
    Figure 4-6 BSF New Features Pipeline Configuration
    You can change the parameter values from "a" - to - "x" as per user requirement. The parameter details are available as comments from line number 2 - to - 7. In the Script area of the Pipeline section, you can change the values of the following parameters:
    • a: Name of the NF to be tested in capital (BSF)
    • b: Change this parameter to update the namespace where BSF was deployed in your bastion.
    • c: Name of Prometheus service namespace (occne-prometheus-server)
    • d: Change this parameter to update the namespace where your gostubs are deployed in your bastion.
    • e: Set this parameter as 'unsecure', if you intend to run ATS in TLS disabled mode. Else, set this parameter as 'secure'.
    • f: Configure this parameter to set BSF_NFINSTANCE_ID.
    • g: Set a value more than 45 seconds for this parameter. The default wait time for the pod to come up is 45 seconds. Every TC requires restart of the nrf-client-management pod.
    • h: Set a value more than 60 seconds for this parameter. The default wait time to add a configurations to the database is 60 secs.
    • i: Set this parameter to more than 140 secs. The default wait time for Nf_Notification Test Cases is given as 140 secs.
    • k: Use this parameter to set the waiting time to initialize Test Suite.
    • l: Use this parameter to set the waiting time to get response from Stub.
    • m: Use this parameter to set the waiting time after adding BSF Configuration.
    • n: Use this parameter to set the waiting time for Peer connection establishment.
    • o: Use this parameter to set the waiting time before sending next message.
    • p: Use this parameter to set Prometheus Server IP.
    • q: Use this parameter to set Prometheus Server Port.
    • r: Use this parameter to set the interval after which the POD status is checked when it is down.
    • s: Use this parameter to set number of retry attempt in which will check the pod down status
    • t: Use this parameter to set the interval after which we check the POD status if its UP.
    • u: Use this parameter to set number of retry attempt in which will check the pod up status.
    • v: Use this parameter to set Wait time to connect to Elastic Search.
    • w: Use this parameter to set Elastic Search HostName.
    • x: Use this parameter to set Elastic Search Port.
    • y: Use this parameter to set To Enable/Disable Stub logs collection.
    • z: Use this parameter to set Log collection endpoint either Elasticsearch or Kubernetes.
    • A: Use this parameter to set Timer to wait for importing service configurations.
    • B: Use bulk_import_to_complete to add custom time in Jenkins post bulk imports.
    • C: Use this parameter to set TLS version (1.2 or 1.3). The default value is 1.2.
    (Optional)To collect application logs per failed scenario, user can configure the values for the following parameters:
    • z: If you want log collection to happen through Elastic search, set the value for this parameter as Elasticsearch. If not, specify the value as Kubernetes.
      If you want to collect logs through Elastic search, it is required to configure the values for the following parameters:
      • v: Specifies the wait time to connect to Elastic search (ELK_WAIT_TIME).
      • w: Specifies the host name of Elastic search (ELK_HOST). For example, occne-elastic-elasticsearch-master.occne-infra/
      • x: Specifies the port for Elastic search (ELK_PORT). For example, 9200.
    • y: If you want to collect stub logs, set the value for this parameter as yes. If not, specify the value as no.
  4. Click Save after updating the parameter values. The BSF_NewFeatures Pipeline page appears.
    It is recommended to save a copy of the pipeline script in your local machine that you may refer while restarting ATS pods.
    Attention:
    Do not modify anything other than the parameter values described in this section.
Extracting Application Logs
If any scenarios fail after running the pipeline job, perform the following steps:
  1. Log in to the ATS pod:
    kubectl exec -it pod/ocats-bsf-6f6dfc76b5-jbgzt -n ocbsf bash
  2. Go to Jenkins build directory:
    cd $JENKINS_HOME/jobs/$JOB_NAME/builds/$BUILD_NUMBER/
    For example:
    cd /var/lib/jenkins/.jenkins/jobs/BSF_Regression/builds/2
  3. Extract the applogs.zip file:
    unzip applogs.zip
  4. After successfully unzipping the file, open the applog folder to view the pod logs for failed scenarios:
    (env) [jenkins@ocats-bsf-6f6dfc76b5-jbgzt applog]$ pwd
    /var/lib/jenkins/.jenkins/jobs/BSF_Regression/builds/2/applog
    (env) [jenkins@ocats-bsf-6f6dfc76b5-jbgzt applog]$ ls -ltrh
    total 760K
    -rw-r--r--. 1 jenkins jenkins 250K Nov 19 11:08 Initial_Run-Register_BSF_With_NFSetIDList.log
    -rw-r--r--. 1 jenkins jenkins 249K Nov 19 11:08 1st_Rerun-Register_BSF_With_NFSetIDList.log
    -rw-r--r--. 1 jenkins jenkins 255K Nov 19 11:09 2nd_Rerun-Register_BSF_With_NFSetIDList.log
To run BSF test cases, perform the following steps:
  1. Click the Build with Parameters link available in the left navigation pane of the BSF_NewFeatures Pipeline screen. The following page appears.
    Figure 4-7 BSF New Features Build with Parameters
    BSF New Features Builde with Parameters
    Make sure that the value of FilterWithTags and Include_NewFeatures is selected as NO.
  2. If you want to collect logs for any given build, select YES from the drop-down menu of Fetch_Log_Upon_Failure.
  3. Click Build and select Console Output to view the test results. The following is a sample test result ouput:
    Figure 4-8 Sample: Test Result Output in Console
For more details on consolidated test report, see Managing Final Summary Report, Build Color, and Application Log.
Queuing Jenkins Jobs
Using this feature, you can queue a second job even when current job is still running. The second job can be triggered either from the same or a different pipeline.
The following table lists various scenarios on how queuing works:
Table 4-1 Queuing Jenkins Jobs
Concurrent Builds New FeaturesCurrent Build New FeaturesNew Build RegressionCurrent Build RegressionNew Build Build Result
Enabled Running Triggered NA NA New-Build of New-Features is added to queue.
Enabled Running NA NA Triggered New-Build of Regression is added to queue.
Disabled NA NA Running Triggered New-Build of Regression is added to queue.
Disabled NA Triggered Running NA New-Build of New-Features is added to queue.
4.1.4 Running BSF_HealthCheck Pipeline
This is a pre-configured pipeline where ATS performs a test probe with SUT. It triggers helm test and provides the results in Jenkins Console Logs.
You can run BSF_HealthCheck pipeline to check if all BSF pods are up and running. If yes, it provides the status as successful. If any pod is down due to any reason, then the pipeline fails.
To configure the parameters for BSF_HealthCheck pipeline, perform the following steps:
  1. Click BSF_HealthCheck in the Name column.
  2. Click Configure in the left navigation pane.
  3. When you scroll-down, the General tab becomes active. Be sure that the screen loads completely.
  4. Continue scrolling down until the Pipeline tab becomes active. The following is a screen capture that shows the Pipeline script:
    Figure 4-9 Helm Test Script
    Helm Test Script
  5. In the Script area under the Pipeline section, users may customize the values for the following parameters:
    Attention:
    Do not modify values of parameters other than the ones described in this section.
    • a: Change this parameter to update the helm release name where BSF is deployed in your bastion.
    • b: Change this parameter to update the namespace where BSF is deployed in your bastion.
  6. Click Save to update the values.
Running Helm Test
To run BSF test cases, click Build Now.
4.1.5 BSF_NewFeatures Documentation
To view BSF functionalities, go to BSF_NewFeatures pipeline. and click Documentation link in the left navigation pane.
Figure 4-10 BSF_NewFeatures Feature List Documentation
Click any functionality to view its test cases and scenarios of each test case. For example, when you click FEATURE - BSF_Error_Response_Enhancements, the following test description appears:
Figure 4-11 Test Cases and Scenarios of Feature - BSF_Error_Response_Enhancements
Based on the functionalities covered under Documentation, the Build Requires Parameters screen displays test cases. To navigate back to the pipeline BSF-NewFeatures screen, click Back to BSF_NewFeatures link available on top left corner of the screen.
Test Result Analyzer
Using the Test Result Analyzer plug-in available in ATS, user can view consolidated and detailed reports. For more information, see Test Results Analyzer section.
Test Case Mapping to Features and Display Total Counts
With this feature, users can view Total Count of Features, TestCases/Scenarios and TestCase mapping to each Feature of BSF in ATS View. For more information, see Support for Test Case Mapping and Count section.
Stub Predefined_priming Support
Stub Predefined_priming configuration in ATS enables ATS to respond back with the payload message instead of default message when prime configuration does not match with the feature level priming or when the sub is not primed.
When the Predefined_priming is not configured and when a request is received at the stub that mimics NRF:
  1. Stub checks against the feature level prime configuration.
  2. If a match is found in feature level prime, stub replies with the payload message.
  3. If there is no match found, stub replies with the default response.
    stub_log: No match found in prime configuration for sending the response. Sending default - 200
    ATS log: {default_response}
When the Predefined_priming is configured and when a request is received at the stub that mimics NRF:
  2. If a match is found in feature level prime, feature level prime is used for responding to the request.
  3. If a match is not found in the feature level prime, but found in the pre-configured prime, pre-configured prime is used for responding to the request.
  4. If a match is found in both pre-primed as well as feature level prime, feature level prime configuration is given priority and the same is used for responding to the request.
  5. If a match is not found in both pre-primed as well as feature level prime, stub sends a default response.
4.1.6 Running BSF Regression Pipeline
This section describes how to run test cases for Binding Support Function (BSF) Regression pipeline.
The BSF_Regression pipeline is a pre-configured pipeline where all the test cases of previous releases are available. For example, for BSF 25.1.200, this pipeline has all the test cases released till BSF 25.1.200.
To view BSF_Regression pipeline details, perform the following steps:
  1. Click BSF_Regression in the Name column.
  2. Click Build with Parameters in the left navigation pane.
  3. Copy the required test cases that are available in the BSF folder and place them appropriately within the custom folder for BSF_Regression.
  4. Reload the page to view the test cases available in the custom Regression folder.
  5. Click Build.
Figure 4-12 BSF_Regression Pipeline
Regression Pipeline
The Regression pipeline does not have any sanity option. However, users must perform all the steps performed in the BSF_NewFeatures pipeline. Ensure that the pipeline script is configured according to the environment variables.
4.1.7 BSF_Regression Documentation
This section describes the documentation for BSF_Regression pipeline.
To view the documentation for any of the BSF features, on the ATS home page, click BSF_Regression. Then, click Documentation in the left navigation pane.
This page shows features of only those test cases that are released in previous releases.
Figure 4-13 BSF_Regression Features Documentation
4.2 Running NRF Test Cases using ATS
4.2.1 Prerequisites
To run NRF test cases using NRF ATS 25.1.200, you need to ensure that following prerequisites are fulfilled.
  • For running three-site georedundancy test cases, NRF 25.1.200 should be deployed on three sites with DB replication enabled. Georedundancy feature must be enabled on all the NRF sites before running these test cases.
  • For running two-site georedundancy test cases, NRF 25.1.200 should be deployed on two sites with DB replication enabled. These test cases are executed separately as it requires two different NRFs. These can be executed on a three-site georedundancy setup as well. Georedundancy feature must be enabled on all the NRF sites before running these test cases.
  • For running NRF-Growth test cases, two standalone NRF 25.1.200 instances should be deployed. These test cases are executed separately as it requires two different NRFs.
  • All the ATS pipelines other than georedundancy, three-site georedundancy, and NRF Growth must be executed with only one NRF deployment (standalone NRF).
  • The following NRF database tables should not have any entries:
    • nrfApplicationDB.NfInstances
    • nrfApplicationDB.NfStatusMonitor
    • nrfApplicationDB.NfSubscriptions
  • NRF/s should be deployed with the default Helm and REST configurations, other than ocnrfHost and ocnrfPort.
  • To run NF-FQDN-Authentication-Feature test cases, deploy NRF and NRF ATS, both with NF Authentication feature changes.
  • All microservices of NRF must be up and running including Alternate route and Artisan microservice.
  • For running Alerts test cases, configure NRF Alerts on the AlertManager on the Prometheus Server. For more details on configuring alerts, see Oracle Communications Cloud Native Core, Network Repository Function Installation, Upgrade, and Fault Recovery Guide.
  • Before deploying NRF, user should create RSA and ECDSA certificates and keys (public and private) for AccessToken microservice.
  • Deploy NRF 25.1.200 with default helm configurations using helm charts to run all test cases except NF-FQDN-Authentication-Feature cases.
  • Ensure all microservices of NRF should be up and running including Accesstoken microservice. A key with RSA and another with ECDSA algorithm is mandatory.
  • Copy the public keys (RSA and ECDSA) to the ATS pod at the /var/lib/jenkins/ocnrf_tests/public_keys location, with the names ec_public.pem and rs_public.pem respectively for ECDSA and RSA public keys. Create a copy of rs_public.pem and save it as new_public.pem in the same location.
  • Create JSON files for key and certificate details and copy them to ATS at /var/lib/jenkins/ocnrf_tests/ location. Refer to KID feature specific Prerequisite.
  • Deploy ATS using helm charts.
  • For NRF 25.1.200, deploy five stub servers for running Roaming, SLF, Forwarding, and SLF via SCP functionality test cases. The service name for the stub servers must be notify-stub-service, notify-stub-service02, notify-stub-service03, amf1-cluster1-net2-amf-5gc-mnc016-mcc310-3gppnetwork-org, and slf-stub-service01.
  • The slf-stub-service01 stub must be deployed with service port as 80. For more information, see Installing ATS for NRF.
  • Replace the existing content with the following content in the alternate-route section of the ocnrf_custom_values.yaml file:
    The following configuration changes are required to accommodate alternate routing test cases based on the latest configuration.
    staticVirtualFqdns:
        - name: https://abc.test.com
          alternateFqdns:
            - target: notify-stub-service03
              port: 8080
              priority: 10
              weight: 20
              port: 8080
              priority: 20
              weight: 30
        - name: http://xyz.test.com
          alternateFqdns:
              port: 8080
              priority: 10
              weight: 20
              port: 8080
              priority: 20
              weight: 30
      dnsSrvEnabled: false
  • Ensure Prometheus service is up and running.
  • Deploy ATS and Stubs in the same namespace as NRF, as default ATS deployment is with role binding. In addition, deploy test stubs in the same namespace as NRF.
  • User must not initiate a job in two different pipelines at the same time.
  • User must not abort a running job, this may lead to data corruption in database.
  • For getting PVC support to retain NRF ATS environment variables and pipeline console histories, follow the installation step. By default PVC support is disabled.
  • If installation is done with Service mesh, the NRF must be deployed with below annotation in lbDeployments and nonlbDeployments section:
    oracle.com/cnc: "true"
    traffic.sidecar.istio.io/excludeInboundPorts: "9090,8095,8096,7,53"
    traffic.sidecar.istio.io/excludeOutboundPorts: "9090,8095,8096,7,53"
    where, first one is for connecting to Operations Services Overlay (OSO) for Alerts test cases. Second one is for connecting to ATS for fetching the metrics from pods.
  • If Service Mesh is enabled, then create a destination rule to fetch the metrics from the Prometheus. In most of the deployments, Prometheus is kept outside the service mesh and a destination rule is required to communicate between TLS enabled entity (ATS) and non-TLS enabled entity (Prometheus).
    To create a rule:
    metadata:
      namespace:ocnrf
    spec:
      host:oso-prometheus-server.ocnrf.svc.cluster.local
      trafficPolicy:
        tls:
          mode:DISABLE
    EOF
    In the above rule,
    • name indicates the name of destination rule.
    • namespace indicates where the ATS is deployed.
    • host indicates the hostname of the Prometheus server.
  • In case of NRF is deployed with network policy enabled, then before NRF-ATS execution a new network policy must be created to access NRF-ATS Jenkins GUI. Following is the sample:
    kubectl apply -f nodePort.yaml -n ocnrf
    apiVersion: networking.k8s.io/v1
    kind: NetworkPolicy
    metadata:
    spec:
      podSelector:
        matchLabels:
          app: ocats-nrf
      policyTypes:
      - Ingress
      ingress:
      - ports:
        - protocol: TCP
          port: 8080
  • To run with CNE HA Prometheus, update the prom_type value in product_config/global.yaml and custom_config/global.yaml file to "cne".
ATS provides custom test case folders (cust_newfeatures, cust_regression, and cust_performance) using which you can add new test cases, remove unwanted test cases, and modify existing test cases. It does not impact the original product packaged test cases available in the newfeatures, regression and performance folders. For more details, refer to Custom Folder Implementation.
Apart from cust_newfeatures and cust_regression, NRF ATS has cust_FQDNauthentication, cust_GeoRedundancy, and cust_3SiteGeo directories that contains test cases related to NF-FQDN and georedundancy respectively.
Key Identifier (KID) feature specific Prerequisite
User should create the following files with exact names and update the file content as per the naming convention used for keys and certificate along with secret name and namespace. The file names are:
  • set_keyDetailsList.json
  • set_currenKeyId.json
  • tokenSigningDetails.json
Sample Files
$ cat set_keyDetailsList.json
        "tokenSigningDetails": {
                "defaultK8SecretDetails": {
                        "k8SecretNameSpace": "ocnrf",
                        "k8SecretName": "ocnrfaccesstoken-secret"
                "keyDetailsList": [{
                                "keyID": "EcdsaKid",
                                "algorithm": "ES256",
                                "privateKey": {
                                        "k8SecretName": "ocnrfaccesstoken-secret",
                                        "fileName": "ecdsa_private_key.pem"
                                "certificate": {
                                        "fileName": "ecdsa_certificate.crt"
                                "keyID": "RsaKid",
                                "algorithm": "RS256",
                                "privateKey": {
                                        "fileName": "rsa_private_key.pem"
                                "certificate": {
                                        "fileName": "rsa_certificate.crt"
                                "keyID": "newKey",
                                "privateKey": {
                                "certificate": {
Update the following parameters in the above files:
  • k8SecretName
  • k8SecretNameSpace
  • fileName (name of the private keys and corresponding certificates)
For more information about parameter values, see Oracle Communications Cloud Native Core, Network Repository Function Installation, Upgrade, and Fault Recovery Guide.
After updating the files, copy them under the /var/lib/jenkins/ocnrf_tests/ directory.
$ cat set_currenKeyId.json
                {"currentKeyID":"EcdsaKid"
User need not update the currentKeyID name (for example: EcdsaKid), if the same file name as in keyID is used while configuring the set_currenKeyId.json file.
$ cat tokenSigningDetails.json
 "presentCurrentKey" : {
    "algorithm" : "ES256",
    "privateKey" : {
        "k8sSecretName" : "ocnrfaccesstoken-secret",
        "fileName" : "ecdsa_private_key.pem"
    "certificate" : {
        "fileName" : "ecdsa_certificate.crt"
 "newCurrentKey" : {
    "algorithm" : "RS256",
    "privateKey" : {
        "fileName" : "rsa_private_key.pem"
    "certificate" : {
        "fileName" : "rsa_certificate.crt"
User doesn't want to update the name of the key if the same name was used while configuring.
    "privateKey" : {
    "certificate" : {
 "newCurrentKey" : {
    "privateKey" : {
    "certificate" : {
Here, user should update k8SecretName fileName (name of private keys and the corresponding certificates.
Update the following parameters in the above code snippet:
  • k8SecretName
After updating all the files, copy them to the ATS pod using "kubectl cp" command. Refer to the following sample commands:
$ kubectl cp tokenSigningDetails.json ocats-ocats-nrf-58fc5dcbb9-zjsks:/var/lib/jenkins/ocnrf_tests/tokenSigningDetails.json -n ocnrf
$ kubectl cp set_keyDetailsList.json ocats-ocats-nrf-58fc5dcbb9-zjsks:/var/lib/jenkins/ocnrf_tests/set_keyDetailsList.json -n ocnrf
$ kubectl cp set_currenKeyId.json ocats-ocats-nrf-58fc5dcbb9-zjsks:/var/lib/jenkins/ocnrf_tests/set_currenKeyId.json -n ocnrf
$ kubectl cp ec_public.pem ocats-ocats-nrf-58fc5dcbb9-zjsks:/var/lib/jenkins/ocnrf_tests/public_keys/ec_public.pem -n ocnrf
$ kubectl cp rs_public.pem ocats-ocats-nrf-58fc5dcbb9-zjsks:/var/lib/jenkins/ocnrf_tests/public_keys/rs_public.pem -n ocnrf
$ kubectl cp rs_public.pem ocats-ocats-nrf-58fc5dcbb9-zjsks:/var/lib/jenkins/ocnrf_tests/public_keys/new_public.pem -n ocnrf
Prerequisites to Run Testcases for the CCA-Header Feature
To run the pipeline for the CCA-Header feature, NRF must be deployed with the following changes:
  1. During installation of NRF, the namespace, secret name and the caroot.cer file name must be provided in NRF's custom values, in ingress-gateway section, as follows:
    ingress-gateway:
      ccaHeaderValidation:
        k8SecretName: ocingress-secret
        k8NameSpace: ocnrf
        fileName: caroot.cer
  2. In NRF's custom values, metadata.ccaHeaderValidation.enabled should be set to true in the 'accesstoken_mapping' object from the ingress-gateway.routesConfig list.
    If ccaHeaderValidation is enabled in NRF, only CCA-Header pipeline should be run. The other pipelines (Newfeatures, Regression, 2SiteGeo, 3SiteGeo, or FQDN-Authentication) will not work with the feature enabled.
    ingress-gateway:
      routesConfig:
      - id: accesstoken_mapping
        uri: http://{{ template "accesstoken.service.fullname" . }}:{{ template "accesstoken.service.port" . }}
        path: /oauth2/token
        order: 4
        filters:
          controlledShutdownFilter:
            applicableShutdownStates:
                - COMPLETE_SHUTDOWN
        metadata:
              enabled: true
  3. Create a secret with the caroot.cer file provided in the ocats_ocnrf_tests_jenkinsjobs_25.1.200.tgz, using the following command. This same caroot.cer file is required to be configured in the secret to run the CCA-Header cases.
    kubectl create secret generic <secret name> --from-file=<ca root file name> -n <namespace>
    For example:
    kubectl create secret generic ocingress-secret --from-file=caroot.cer -n ocnrf
  4. Update the secret name from step 3 in global.yaml file in either /var/lib/jenkins/ocnrf_tests/product_config or /var/lib/jenkins/ocnrf_tests/custom_config based on the whether the pipeline will be run with Product_Config option or Custom_Config option, under the ccaHeaderSecretName parameter.
Prerequisites to Run Testcases for the NRF Growth Features
To run the pipeline for the NRF Growth feature, the following prerequisites have to be done.
  1. Install two NRFs that are not georedundant with each other.
  2. The pipeline configuration has to be set to the below before running the pipeline. The values of options "u" to "x" have to be set to 0.1.
    node ('master'){
        //a = SELECTED_NF    b = NF_NAMESPACE        c = FT_ENDPOINT      d = GATEWAY_IP        e = GATEWAY_PORT
        //f = CONFIG_IP      g = CONFIG_PORT         h = STUB_IP          i = STUB_PORT         j = NFINSTANCEID
        //k = PROMETHEUS_IP  l = PROMETHEUS_PORT     m = RERUN_COUNT      n = PROMETHEUS_URI    o = HELM_RELEASE_NAME
        //p = MYSQL_HOST     q = PRIVILEGED_USER_SECRET_NAME              r = DISCOVERY_WAIT_TIME
        //s = REPLICATION_STATUS_URI                 t = CLUSTER_DOMAIN   u = REGISTER_WRITE_WAIT_TIME
        //v = SUBSCRIPTION_WAIT_TIME                 w = ACCESSTOKEN_WAIT_TIME                  x = REGISTER_READ_WAIT_TIME
        sh '''
            sh /var/lib/jenkins/ocnrf_tests/preTestConfig.sh \
            -a NRF \
            -b occne-cndbtierone,occne-cndbtiertwo \
            -c ocnrf-ingressgateway.ocnrf.svc.cluster.local:80,ocnrf-1-ingressgateway.ocnrf.svc.cluster.local:80 \
            -d ocnrf-ingressgateway.occne-cndbtierone,ocnrf-1-ingressgateway.occne-cndbtiertwo \
            -e 80,80 \
            -f ocnrf-nrfconfiguration.occne-cndbtierone,ocnrf-1-nrfconfiguration.occne-cndbtiertwo \
            -g 8080,8080 \
            -h notify-stub-service.occne-cndbtierone,notify-stub-service02.occne-cndbtierone \
            -i 8080,8080 \
            -j 6faf1bbc-6e4a-4454-a507-a14ef8e1bc5c,6faf1bbc-6e4a-4454-a507-a14ef8e1bc5d \
            -k oso-prom-svr.oso \
            -l 80 \
            -m 2 \
            -n /prometheus/api/ \
            -o ocnrf,ocnrf-1 \
            -p mysql-connectivity-service.occne-cndbtierone,mysql-connectivity-service.occne-cndbtiertwo \
            -q privilegeduser-secret     \
            -r 0.5 \
            -s http://ocnrf-ocnrf-app-info:5906/status/category/replicationstatus,http://ocnrf-1-ocnrf-app-info:5906/status/category/replicationstatus \
            -t svc.cluster.local \
            -u 0.1 \
            -v 0.1 \
            -w 0.1 \
            -x 0.1
        if(env.Include_NewFeatures && "${Include_NewFeatures}" == "YES"){
            sh '''sh /var/lib/jenkins/common_scripts/merge_jenkinsfile.sh'''
            load "/var/lib/jenkins/ocnrf_tests/jenkinsData/Jenkinsfile-Merged"
        else{
            load "/var/lib/jenkins/ocnrf_tests/jenkinsData/Jenkinsfile-Regression"
4.2.2 Logging into ATS
Running ATS
Before logging into ATS, you need to ensure that ATS is deployed successfully using Helm charts as shown below:
To modify default log in password, refer to Modifying Login Password.
Figure 4-14 Verifying ATS Pod
Verifying ATS Pod
For more information on verifying ATS deployment, see Verifying ATS Deployment.
In the Verifying ATS Pod screen, slave2 is the node where ATS is deployed, 30348 is the ATS nodeport and 10.75.225.227 is the worker node IP, highlighted in red. For more details on ATS deployment, refer to Installing ATS for NRF.
To log in to ATS, open a browser and provide the IP Address and port details as <Worker-Node-IP>:<Node-Port-of-ATS>. As per above screen, it is 10.75.225.227:30348.
Figure 4-15 ATS Login
ATS Login
To run ATS:
  1. Enter the login credentials. Click Sign in. The following screen appears.
    Figure 4-16 NRF Pre-Configured Pipelines
    NRF ATS has two pre-configured pipelines.
    • NRF-NewFeatures: This pipeline has all the test cases delivered as part of NRF ATS - 25.1.200.
    • NRF-Regression: This pipeline has all the test cases delivered so far in the previous releases.
4.2.3 NRF-NewFeatures Pipeline
After identifying the NRF pipelines, configure ATS as one-time activity as per NRF deployment. In this pipeline, all the new testcases related to NRF are deployed. To configure its parameters:
  1. Click NRF-NewFeatures in the Name column. The following screen appears:
    Figure 4-17 Configuring NRF-NewFeatures
    Configuring NRF-New Features
    In the above screen:
    • Click Configure to configure NRF-New Features.
    • Click Documentation to view the documented test cases, which are part of this NRF release.
    • Click the blue dots inside Build History box to view the success console logs of the "Sanity", "All-NewFeatures" respectively.
    • The Stage View represents the already deployed pipeline for the customer reference.
    • The Test Results Analyzer is the new plugin integrated in the NRF-ATS. This option can be used to display the previous history of all the execution build-wise. It will provide a graphical representation of the past execution together.
  2. Click Configure. User must wait for the page to load completely. Once the page loads completely, click the Pipeline tab:
    Make sure that the following page loads completely before you perform any action on it. Also, do not modify any configuration other than shown below.
    Figure 4-18 Pipeline Tab
    Pipeline Option
    The Pipeline section of the configuration page appears as follows:
    Figure 4-19 Pipeline Section
    Pipeline Section
    In the above screenshot, change the values of the 'Pipeline script'. The content of the pipeline script is as follows:
    Figure 4-20 Pipeline Script
    Pipeline Script
    The user must not change any other value apart from line number 15 to line 37.
    • a: Name of the NF to be tested in capital (NRF).
    • b: Namespace in which the NRF is deployed.
    • c: endPointIP: endPointPort value used while deploying NRF with the help of helm chart.
    • d: Comma separated values of NRF1 and NRF2 ingress gateway service (For example: ocnrf-ingressgateway.ocnrf,1.1.1.1). It is also known as cluster_domain.
    • e: Comma separated values of NRF1 and NRF2 port of ingressgateway service (For example: 80,31000).
    • f: Comma separated values of NRF1 and NRF2 configuration service (For example: ocnrf-nrfconfiguration.ocnrf,1.1.1.1). It is also known as cluster_domain.
    • g: Comma separated values of NRF1 and NRF2 port of configuration service (For example: 8080, 31001).
    • h: Name_of_stub_service.namespace (notify-stub-service.ocnrf).
    • i: Port of stub service (8080).
    • j: NRF_Instance ID (6faf1bbc-6e4a-4454-a507-a14ef8e1bc5c).
    • k: Name_of_Prometheus_service.namespace (occne-prometheus-server.occne-infra).
    • l: Port of Prometheus service (80).
    • m: Number of times the re-run of failed case is allowed (default as 2).
    • n: URI of Prometheus service (/api/) -
      • Use "/api/" for CNE version till 1.6.0 and "/prometheus/api/" for CNE version 1.7.0 and 1.8.0.
      • For, CNE 1.9.x, CNE 1.10.x, and CNE 22.1.0, cluster name is needed in the URI. The URI must be <cluster_name>/prometheus/api. For example: /bmw/prometheus/api (For more details on the Prometheus URI, check corresponding CNE version's user guide.)
      • If OSO is being used, use "/api/" for OSO-1.6.1 or earlier and use "/prometheus/api/" for OSO-1.6.2 or later.
      • For OSO-1.10.0, the URI must be <cluster_name>/prometheus/api. For example: /bmw/prometheus/api (For more details on the Prometheus URI, check corresponding OSO version's user guide)
    • o: Helm_release_name used to deploy NRF
    • p: Host name of MySQL (For example: mysql-connectivity-service)
    • q: Privileged User secret name (For example: privilegeduser-secret)
    • r: wait time before sending discovery request (0.5)
    • s: comma-separated values of replicationStatusUri(s) of the appinfo(s).
    • t: the cluster domain
    • u: wait time before sending registration requests for write operations
    • v: wait time before sending subscription requests
    • w: wait time before sending accesstoken requests
    • x: wait time before sending registration requests for read operation
    • If the 2-Site-Geo cases are run, the user has to provide values for NRF2 in corresponding environment variables in the above script as per the deployment. A sample configuration is given as below:
      node ('master'){
          sh '''
              -a NRF \
              -e 80,80 \
              -g 8080,8080 \
              -i 8080,8080 \
              -l 80 \
              -m 2 \
              -o ocnrf,ocnrf-1 \
              -p mysql-connectivity-service \
              -r 0.5 \
              -u 0 \
              -v 0 \
              -w 0 \
              -x 0
          else{
    • If 3SiteGeo and georedundancy suite in Regression pipeline cases are run, the user has to provide values for NRF2, NRF3 in corresponding environment variables in the above script as per the deployment. A sample configuration is given as below:
      node ('master'){
          sh '''
              -a NRF \
              -b occne-cndbtierone,occne-cndbtiertwo,occne-cndbtierthree \
              -c ocnrf-ingressgateway.ocnrf.svc.cluster.local:80,ocnrf-1-ingressgateway.ocnrf.svc.cluster.local:80,ocnrf-2-ingressgateway.ocnrf.svc.cluster.local:80 \
              -d ocnrf-ingressgateway.occne-cndbtierone,ocnrf-1-ingressgateway.occne-cndbtiertwo,ocnrf-2-ingressgateway.occne-cndbtierthree \
              -e 80,80,80 \
              -f ocnrf-nrfconfiguration.occne-cndbtierone,ocnrf-1-nrfconfiguration.occne-cndbtiertwo,ocnrf-2-nrfconfiguration.occne-cndbtierthree \
              -g 8080,8080,8080 \
              -h notify-stub-service.occne-cndbtierone,notify-stub-service02.occne-cndbtierone,notify-stub-service03.occne-cndbtierone \
              -i 8080,8080,8080 \
              -j 6faf1bbc-6e4a-4454-a507-a14ef8e1bc5c,6faf1bbc-6e4a-4454-a507-a14ef8e1bc5d,6faf1bbc-6e4a-4454-a507-a14ef8e1bc5e \
              -l 80 \
              -m 2 \
              -o ocnrf,ocnrf-1,ocnrf-2 \
              -r 0.5 \
              -s http://ocnrf-ocnrf-app-info:5906/status/category/replicationstatus,http://ocnrf-1-ocnrf-app-info:5906/status/category/replicationstatus,http://ocnrf-2-ocnrf-app-info:5906/status/category/replicationstatus \
              -u 0 \
              -v 0 \
              -w 0 \
              -x 0
          else{
    If user is using CNE1.6 or OSO 1.6.1 or earlier, change the Prometheus service URI (-n) to "/api/" and Prometheus service name and port to appropriate values. For CNE 1.7.0 or OSO 1.6.2 or later, retain the default value "/prometheus/api/". If OSO 1.10.0 is used, use the URI along with the cluster_name (for example: /bmw/prometheus/api).
  3. Click Save after making necessary changes. The NRF-NewFeatures screen appears. Click the Build with Parameters link available in the left navigation pane of the NRF-NewFeatures Pipeline screen.
    In the Pipeline screen, there are three Select_Option(s), which are:
    • All: This is the default option. It runs all the NRF test cases. Scroll down and click Build to execute all the test cases.
    • Sanity: It is recommended to run sanity before running any test case. It ensures all the deployments are done properly.
    • Single/MultipleFeatures: This option allows you to select any number of test cases that you want to run from the list of total test cases available for execution.
      After selecting the test cases, scroll down and click Build to run the selected NRF test cases.
  4. Select one of the following configuration types:
    • Product_Config: On selecting this option, test cases from product folders are populated on ATS UI and product configuration is applied to them via the key-value pair and yaml files defined or present in the "Product Config" folder.
    • Custom_Config: On selecting this option, test cases from custom folders are populated on ATS UI and custom configuration is applied to them via the key-value pair and yaml files defined or present in the "Custom Config" folder. To use the Parameterization feature, always select the Custom_Config option. User can copy, add, or delete the required test cases that are available for the NRF and place them appropriately within the custom folder for NRF-NewFeatures. Reload the page to view the test cases available in the custom NewFeatures folder.
      For more information, see Parameterized approach for SUT custom configuration.
Based on the requirement, user can select any of the above option and click on "Build". The NRF testcases are divided into NRF Service operations. The classification is as follows:
  • NRF Sanity - This feature file contains all the basic sanity cases for NRF ATS to validate the deployment is correct or not. It is advisable for user to run these cases before starting a complete suite.
  • Discovery - These feature files are listed with a prefix as "Disc". All the discovery microservice related cases will be listed once this option is selected.
  • NRF Functional - These feature files are listed with a prefix as "Feat". All the functional cases will be listed once this option is selected.
  • Registration - These feature files are listed with a prefix as "Upd". These are related to update operation of registered profiles. All the registration cases will be listed once this option is selected.
  • Subscription- These feature files are listed with a prefix as "Subs". All the subscription microservice related cases will be listed once this option is selected.
  • Roaming -These feature files are listed with a prefix as "Roaming". All the roaming cases will be listed once this option is selected.
Figure 4-21 Sample Screen: NRF-ATS Full Execution
A sample consolidated test report is shown below, when rerun is set to 2:
Figure 4-22 Test Cases Result - Sanity
Figure 4-23 Test Cases Result - All-NewFeatures
Using this feature, user can make the following customizations to custom folders
  • Add new test cases by adding datafiles
  • Remove test cases
  • Modify the parameters and their values in the key-value pair or <feature>.yaml files
To run ATS test cases, user can maintain as many versions of Custom_Config folder by using the following naming convention:
Cust ConfigN
where N can be any number
At the time of execution, ensure to rename the required folder to Cust Config folder as Jenkins always retrieves data from this folder when user selects Custom_Config.
Updating Global Parameters
To use Custom_Config, it is required to change the value of cust_folder from data to cust_data in global.yaml file. In addition, you can customize the parameters and their respective values in the global.yaml as per the requirements.
Updating Feature Parameters
Consider the following points when customizing <feature>.yaml files for parameterized feature:
  • In addition to global.yaml parameters, feature files may also contain parameters for which user can update values at the time of running pipelines.
  • Changing the values of parameters tagged as "Feature Specific Value" may cause failures at the time of running pipelines.
  • Values for parameters tagged with #START_GLOBAL and #END_GLOBAL tags take values from global.yaml.
For NRF-ATS release 25.1.200, parameterization is supported for NRF NewFeatures pipeline only.
4.2.4 NRF-NewFeatures Documentation
To view NRF test cases, go to NRF-NewFeatures pipeline and click the Documentation link in the left navigation pane. It lists all the test cases provided as part of NRF ATS -25.1.200 along with sanity cases.
The NRF test cases are divided into multiple groups based on the functionality.
  • NF_CONFIGURATION_CASES- All the cases related to NRF configuration will be listed once this option is selected.
  • NF_DISCOVERY_CASES - All the discovery microservice related cases will be listed once this option is selected.
  • NRF_FORWARDING_CASES - All the forwarding related cases will be listed once this option is selected.
  • NF_FUNCTIONAL_CASES - All the functional cases will be listed once this option is selected.
  • NF_REGISTRATION_CASES- All the registration cases will be listed once this option is selected.
  • NF_SANITY_CASES- All the sanity cases will be listed once this option is selected.
  • NF_SLF_CASES - All the SLF related cases will be listed once this option is selected.
The following screenshot shows all the NRF features:
Figure 4-24 NRF-NewFeatures Documentation
Click any functionality to view its test cases and scenarios of each test case as shown below:
Figure 4-25 Sample Feature: NF_BASIC_SANITY_CASES
Based on the functionalities covered under Documentation, the Build Requires Parameters screen displays test cases. To navigate back to the Pipeline NRF-NewFeatures screen, click the Back to NRF-NewFeatures link available on top left corner of the screen.
4.2.5 NRF-Regression Pipeline
This pre-configured pipeline contains all the test cases delivered till NRF ATS 25.1.200. However, some test cases are updated as per new implementation of NRF.
The configuration method and parameters are same as the NewFeatures pipeline.
Only difference in this pipeline is, while executing 2-Site-Geo and 3-Site-Geo test cases, user has to provide appropriate values for NRF2 and NRF3 in the Pipeline script. In this pipeline, user will not get option to run Sanity.
The NRF-Regression test cases are divided into following service operations:
  • 2-Site-Geo - These feature files are listed with a prefix as "Geo_Redundancy".
  • 3-Site-Geo- These feature files contain all the cases which are executed on 3 Site GEO NRF.
  • CCA-Header- These feature files contain all cases related to CCA Header feature.
  • NF-FQDN-Authentication - These feature files are listed with a prefix as "NfAuthentication".
  • AccessToken - These feature files are listed with a prefix as "oAuth" and "AccessToken".
  • Alerts - These feature files are list with a prefix as "Alert".
  • Configuration - These feature files are listed with a prefix as "Config" and "SystemOptions".
  • NRF Forwarding - These feature files are listed with a prefix as "Forwarding".
  • Key-ID - These feature files are listed with a prefix as "Kid".
  • NRF State Data - These feature files are listed with a prefix as "State".
  • Preferred Locality - These feature files are listed with a prefix as "Pref".
  • Registration - These feature files are listed with a prefix as "HBTimerEnhancement", "Reg" and "Upd". These are related to update operation of registered profiles.
  • NRF SLF - These feature files are listed with a prefix as "SLF".
  • Subscription - These feature files are listed with a prefix as "Subs".
  • NRF Growth - These feature files contain all cases related to NRF Growth feature.
The following screenshot shows the NRF-Regression.
Figure 4-26 NRF-Regression
NRF-Regression
The following screenshot shows successful execution as part of ATS image.
Figure 4-27 NRF-Regression - All-default-Regression
4.2.6 NRF-Regression Documentation
Click Documentation in the left navigation pane of the NRF-Regression pipeline to view all the test cases provided till NRF ATS 25.1.200.
The NRF test cases are divided into multiple groups based on following functionalities:
  • NF_3SITEGEO_CASES- All the 3-Site Geo-Redundancy related cases will be listed once this option is selected.
  • NF_ACCESSTOKEN_CASES - All the test cases for validating accesstoken operation will be listed once this option is selected.
  • NF_ALERTS_CASES - Test case for validating alerts will be listed once this option is selected.
  • NF_ALTERNATEROUTE_CASES- All the alternate route microservice related cases will be listed once this option is selected.
  • NF_ARTISAN_CASES- All the NRF artisan microservice related cases will be listed once this option is selected.
  • NF_CCAHEADER_CASES - Cases related to CCAHeader feature will be listed once this option is selected.
  • NF_CHFINFO_CASES - All the ChfInfo enhancement cases will be listed once this option is selected.
  • NF_CONFIGURATION_CASES - Cases related to NRF configuration will be listed once this option is selected.
  • NF_FORWARDING_CASES - All the forwarding related cases will be listed once this option is selected.
  • NF_FQDNAUTHENTICATION_CASES - All the NF FQDN authentication cases will be listed once this option is selected.
  • NF_GEOREDUNDANCY_CASES - All the Geo-Redundancy related cases (2-Site-GEO and 3-Site-GEO both) will be listed once this option is selected.
  • NF_KID_CASES - All the K-ID feature related cases will be listed once this option is selected.
  • NF_NRFGROWTH_CASES - All growth related cases will be listed once this option is selected.
  • NF_NRFSTATE_DATA_CASES - All the nfStateData related cases will be listed once this option is selected.
  • NF_PREFERRED_LOCALITY_CASES - All the preferred locality feature related cases will be listed once this option is selected.
  • NF_REGISTRATION_CASES - All the registration related cases will be listed once this option is selected.
  • NF_ROAMING_CASES - All the roaming related cases will be listed once this option is selected.
  • NF_SUBSCRIPTION_CASES - All subscription related cases will be listed once this option is selected.
Figure 4-28 NRF-Regression Documentation
The following sample screen shows documentation of Regression pipeline for NRF ATS.
Figure 4-29 Sample Screen: NRF-Regression Documentation
4.3 Running NSSF Test Cases using ATS
This section describes how to run NSSF test cases using ATS.
4.3.1 Prerequisites
The prerequisites to run NSSF Test Cases using NSSF ATS 25.1.200 are:
  • Deploy NSSF 25.1.200 with default helm configurations using helm charts.
  • All NSSF microservices must be up and running.
  • Both NSSF ATS and ATS Deployment needs to be same namespace.
  • For NSSF ATS 25.1.200, deploy one stub server and the service name should be "amf-stubserver". It is required to run AMF-subscription Notification functionality test cases.
  • For NSSF ATS 25.1.200, deploy one stub server and the service name should be "nrf-stubserver". It is required to run NRF-subscription Notification functionality test cases.
  • For NSSF ATS 25.1.200, deploy one stub server and the service name should be "nrf-stubserver1". It is required to run NRF-selection based on DNS SRV.
  • For NSSF ATS 25.1.200, deploy one stub server and the service name should be "nrf-stubserver2". It is required to run NRF-selection based on DNS SRV.
  • For NSSF 25.1.200, deploy one DNS stub server and the service name should be "ocdns-bind". It is required to run NRF-selection based on DNS SRV.
4.3.2 Logging into ATS
Before logging into ATS, deploy ATS using HELM charts as shown below:
Verify ATS deployment
[opc@ocnssf-oci-phx-einstein-bastion-01 ~]$ helm status ocats
LAST DEPLOYED: Thu May 30 10:21:40 2024
NAMESPACE: cicdnssf-240530102024
STATUS: deployed
REVISION: 1
TEST SUITE: None
There are two ways to log in to ATS GUI.
  • When an external load balancer (metalLB in case of OCCNE) is available and you provide an external IP to the ATS service, the user can log in to ATS GUI using <External-IP>:8080.
  • When you do not provide an external IP to the ATS service, open the browser and enter the external IP of the worker node and nodeport of the ATS service to log in to the ATS GUI.
    In the Verifying ATS Deployment screenshot, the ATS nodeport is highlighted in red as 32013. For more details on ATS deployment, refer to NSSF ATS Installation Procedure.
Open a browser and enter the IP Address and port details as <Worker-Node-IP>:<NodePort-of-ATS> (In the above example, the Worker-Node-IP and NodePort-of-ATS are 10.98.101.177:32013, which are shown as highlighted in the screenshot above).
The ATS login screen appears.
ATS Login Page
To run ATS:
  1. Enter the username as 'nssfuser' and password as 'nssfpasswd'. Click Sign in. A page with preconfigured pipelines appears.
    To modify the default login password, refer to Modifying Login Password.
    NSSF preconfigured pipelines
    • NSSF-New-Features: This pipeline has all the test cases delivered as part of NSSF ATS - 25.1.200.
    • NSSF-Regression: This pipeline has the test cases of all the previous releases.
4.3.3 NSSF-NewFeatures Pipeline
In this pipeline, you can configure ATS, which is a one-time activity as per System Under Test (SUT) deployment. You can also run all the new NSSF test cases using the pipeline. To configure its parameters:
  1. Click NSSF-NewFeatures in the Name column. The following screen appears:
    1. Click Configure to access the configuration screen.
    2. Click Documentation to view the documented test cases.
    3. Click blue dots inside the Build History box to view the success console logs of the "All" and "Sanity" respectively.
    4. The Stage View represents the already run pipeline for customer reference.
  2. Click Configure. Users MUST wait for the page to load completely. Once the page loads completely, click the Pipeline tab to reach the Pipeline configuration as shown below:
    WARNING:
    Make sure that the screen shown above loads completely before you perform any action on it. Also, do not modify any configuration other than that discussed below.
    New Feature Configuration
  3. You can modify script pipeline parameters from "a" to "B" on the basis of your deployment environment and click Save. The content of the pipeline script is as follows:
    node ('built-in'){
        //a = SELECTED_NF           b = NF_NAMESPACE    c = INGRESS_GATEWAY_IP     d = EGRESS_GATEWAY_IP
        //e = PROMETHEUS_SVC_IP     f = STUB_IP         g = PROMETHEUS_PORT        h = RERUN_COUNT
        //i = NF_DB                 j = NF_DB_SECRET    k = NSCONFIG_IP            l = NRF_STUB_IP
        //m = HELM_RELEASE_NAME     n = ATS_RELEASE_NAME             o = NSSF_INGRESS_GATEWAY_PORT
        //p = NSSF_EGW_PORT         q = NSSF_CONFIG_PORT             r = NSSF_SELECTION_SVC_NAME
        //s = NSSF_AUDITOR_SVC      t = NSSF_AVAILABILITY_SVC_NAME   u = NSSF_SUBSCRIPTION_SVC_NAME
        //v = NSSF_APP_INFO_SVC     w = NSSF_PERFINFO_SVC            x = NSSF_INSTANCEID
        //y = NRF_STUB_1_SVC_NAME   z = NRF_STUB_2_SVC_NAME          A = NSSF_NRF_CLIENT_SVC_NAME
        //B = SUPPORTED_PLMN_LIST_MCC_MNC
        withEnv([
        sh '''
            sh /var/lib/jenkins/ocnssf_tests/preTestConfig.sh \
            -a NSSF \
            -b ocnssf \
            -c ocnssf-ingress-gateway.ocnssf \
            -d ocnssf-egress-gateway.ocnssf \
            -e occne-prometheus-server.occne-infra \
            -f amf-stubserver.ocnssf \
            -g 80 \
            -h 2 \
            -i ocnssf-nsdb.ocnssf \
            -j ocnssf-db-creds \
            -k ocnssf-nsconfig.ocnssf \
            -l nrf-stubserver.ocnssf \
            -m ocnssf \
            -n ocats \
            -o 8081 \
            -p 8080 \
            -q 8080 \
            -r ocnssf-nsselection.ocnssf \
            -s ocnssf-nsauditor.ocnssf \
            -t ocnssf-nsavailability.ocnssf \
            -u ocnssf-nssubscription.ocnssf \
            -v ocnssf-ocnssf-app-info.ocnssf \
            -w ocnssf-ocnssf-perf-info.ocnssf \
            -x 9faf1bbc-6e4a-4454-a507-aef01a101a01 \
            -y nrf-stubserver1.ocnssf \
            -z nrf-stubserver2.ocnssf \
            -A ocnssf-ocnssf-nrf-client-nfmanagement.ocnssf \
            -B 311 480 \
        if(env.Include_Regression && "${Include_Regression}" == "YES"){
            load "/var/lib/jenkins/ocnssf_tests/jenkinsData/Jenkinsfile-Merged"
        else{
            load "/var/lib/jenkins/ocnssf_tests/jenkinsData/Jenkinsfile-NewFeatures"
    The User MUST NOT change any other value apart from these parameters.
    The description of these parameters is as follows:
    • a: Name of the NF to be tested in capital (NSSF).
    • b: Namespace in which the NSSF is deployed (default is ocnssf)
    • c: Ingress Gateway IP address (default is ocnssf-ingress-gateway.ocnssf)
    • d: Egress Gateway IP address (default is ocnssf-egress-gateway.ocnssf)
    • e: Prometheus service IP address (default is prometheus.cne-infra)
    • f: Stub service IP address (default is ocats-amf-stubserver.ocnssf)
    • g: Port of Prometheus service (default is 80)
    • h: Number of times the re-run of failed case is allowed (default is 2).
    • i: Database name (default is ocnssf-nsdb.ocnssf)
    • j Database secrets (default ocnssf-db-creds)
    • k: NSSF config ip address (ocnssf-nsconfig.ocnssf)
    • l: NRF stub server IP address (ocats-nrf-stubserver.ocnssf)
    • m: NSSF release name (ocnssf)
    • n: ATS release name (ocats)
    • o: NSSF Ingress Gateway Port
    • p: NSSF Egress Gateway Port
    • q: NSSF Config Port
    • r: NSSF Selection Service Name
    • s: NSSF Auditor Service Name
    • t: NSSF Availability Service Name
    • u: NSSF Subscription Service Name
    • v: APP Info Service Name
    • w:Perf info Service Name
    • x: NSSF Supported PLMN
    • A: NRF Client Managment Service Name (ocnssf-ocnssf-nrf-client-nfmanagement.ocnssf)
    • B: NSSF PLMN List (311 480 )
    • Do not change any value if the OCCNE cluster is used and NSSF, ATS, and STUB are deployed in the ocnssf namespace.
    • In the above image NSSF Helm release name is "ocnssf", ATS Helm Release Name is "ocats" and namespace is "ocnssf". If any change in helm release name of NSSF, ATS and namespace needs to be updated accordingly.
      For example, NSSF Helm release name is "ocnssfats" and ATS Helm release name is "ocatsnssf" and namespace is "ocnssf2510", then above Pipeline Configuration should be edited as shown below.
    • NSSF Helm release name should be updated in "c d i k m r s t u v w" if any change in NSSF helm release name apart from "ocnssf".
    • The NSSF Instance ID needs to be updated in the ATS Jenkins pipeline parameters if there are any changes in the NSSF custom values (CV) file. By default, the NSSF Instance ID is set to "9faf1bbc-6e4a-4454-a507-aef01a101a01". If the Instance ID is modified in the NSSF CV file, the same changes must be reflected in the Jenkins pipeline parameters.
      By default, NSSF Instance ID in NSSF custom values file as below:
      #InstanceId of NSSF used in case of GR
      nfInstanceId: &nfInstanceId "9faf1bbc-6e4a-4454-a507-aef01a101a01"
      For example, if the nfInstanceId in the NSSF custom values file is modified from "9faf1bbc-6e4a-4454-a507-aef01a101a01" to "9faf1bbc-6e4a-4454-a507-aef01a101a20", the same change must be updated in the "x" Jenkins pipeline parameters as shown below:
      node ('built-in'){
          withEnv([
          sh '''
              -a NSSF \
              -b ocnssf2510 \
              -c ocnssfats-ingress-gateway.ocnssf2510 \
              -d ocnssfats-egress-gateway.ocnssf2510 \
              -f amf-stubserver.ocnssf2510 \
              -g 80 \
              -h 2 \
              -k ocnssfats-nsconfig.ocnssf2510 \
              -l nrf-stubserver.ocnssf2510 \
              -m ocnssfats \
              -n ocats \
              -o 8081 \
              -p 8080 \
              -q 8080 \
              -r ocnssfats-nsselection.ocnssf2510 \
              -s ocnssfats-nsauditor.ocnssf2510 \
              -t ocnssfats-nsavailability.ocnssf2510 \
              -u ocnssfats-nssubscription.ocnssf2510 \
              -v ocnssfats-ocnssf-app-info.ocnssf2510 \
              -w ocnssfats-ocnssf-perf-info.ocnssf2510 \
              -x 9faf1bbc-6e4a-4454-a507-aef01a101a20 \
              -y nrf-stubserver1.ocnssf2510 \
              -z nrf-stubserver2.ocnssf2510 \
              -A ocnssfats-ocnssf-nrf-client-nfmanagement.ocnssf2510 \
              -B 311 480 \
          else{
  4. Click Save after making necessary changes. The Pipeline NSSF-NewFeatures screen appears.
Running NSSF New Features Test Cases
To run NSSF New Features test cases:
  1. Go back to new features and Click Build with Parameters present on the NSSF-NewFeatures screen in the extreme left column corresponding to NSSF-NewFeatures row as shown below:
  2. The following screen appears:
    In the above screen, there are three Select_Option(s), which are:
    • By default, features 'ALL', configuration type 'Product_config', include regression 'NO' will be selected, and all test cases will be executed once clicked on BUILD, as shown above.
    • Features: ALL. Once you click on ALL, a dropdown 'Select' option will appear. After selecting 'Select,' options will appear to choose feature files. To run the selected feature files, click on 'Build,' as shown below.
      ATS Test Cases for NSSF
      ATS Test Cases for NSSF-2
  3. Select one of the following configuration types:
    • Product_Config: On selecting this option, test cases from product folders are populated on ATS UI and product configuration is applied to them via the keyvalue pair and yaml files defined or present in the "Product Config" folder.
    • Custom_Config: On selecting this option, test cases from custom folders are populated on ATS UI and custom configuration is applied to them via the keyvalue pair and yaml files defined or present in the "Custom Config" folder. To use the Parameterization feature, always select the Custom_Config option. User can copy, add, or delete the required test cases that are available for the NSSF and place them appropriately within the custom folder for NSSF-NewFeatures. Reload the page to view the test cases available in the custom NewFeatures folder. For more information, see Parameterized approach for SUT custom configuration.
    The NSSF test cases are divided into NSSF Service operations as follows:
    • NSSF_204NoContent_NsAvailability_PATCH_REMOVE- This feature file contains test cases related to PATCH or PUT request for deleting all slices.
    • Virtual_Host_NRF_Resolution_By_NSSF_Using_DNSSRV- This feature file contains test cases related to DNS SRV based selection of NRF in NSSF.
    If you want to run custom_config, select below parameter as custom_config, where the framework automatically points out to custom_config and cust_data.
    custom_config
    3 features passed, 0 failed, 0 skipped
    25 scenarios passed, 0 failed, 0 skipped
    546 steps passed, 0 failed, 0 skipped, 0 undefined
    Took 36m30.275s
Using this feature, user can make the following customizations to custom folders:
  • Remove test cases
Cust ConfigN
At the time of execution, ensure to rename the required folder to Custom Config folder as Jenkins always retrieves data from this folder when user selects Custom_Config.
For NSSF-ATS release 25.1.200, parameterization is supported for NSSF NewFeatures pipeline only.
4.3.4 NSSF-NewFeatures Documentation
To view NSSF functionalities, go to NSSF-NewFeatures pipeline latest build and click the Documentation link in the left navigation pane. The following screen appears. Click any functionality to view its test cases and scenarios of each test case as shown in the sample screenshot below:
NSSF - Documentation
A sample of a few documentation features are as follows:
NSSF - Documentation sample
Once the run of new features done successfully, click on the build number whose logs are to be viewed and then click on Console Output on left side navigation.
Wait till the page is loaded completely, then click Download to download the new features logs.
NSSF new features pipeline status
NSSF new features log download
4.3.5 NSSF-Regression Pipeline
This pipeline contains test cases from the previous versions.
Some of the test cases are updated as per the new implementation of NSSF.
The configuration method and parameters are the same as the NewFeatures pipeline.
The NSSF test cases are divided into NSSF Service operations. The classification is as follows:
  • Availability Update: These feature files are listed with a prefix as "Update".
  • Configuration: These feature files are listed with a prefix as "failure".
  • Registration: These feature files are listed with a prefix as "NsSelection_Registration".
  • PDU Session: These feature files are listed with a prefix as "NsSelection_PDU".
  • SuportedFeatures: This feature file has Feature Negotiation test cases.
  • subscription_patch: This feature file has SUBMOD test cases.
  • eanan: This feature file has EANAN test cases.
  • TAI Range: This feature file has TAI Range supported NsAvailability and NsSelection test cases.
  • NSSF_Sending_Notification_via_ARS_SCP: This feature file has test cases related to NRF discovery and subscription.
  • NSSF Sanity: This feature file contains all the basic sanity cases for NSSF ATS 24.3.0.
  • NSSF_Allowed_NSSAI_computation_RegUeConf: This feature file contains test cases related to NSSF Allowed SNSSAI Computation based on enabling and disabling of System Options PLMN based.
  • NSSF_Allowed_NSSAI_computation_ueconfig_update: This feature file contains test cases related to NSSF Allowed SNSSAI Computation based on enabling and disabling of System Options PLMN based.
  • NSSF_Authorization_NonTrustedAMF_NsAvailPATCH: This feature file contains test cases related to PATCH request for Update operation of NSSAI Availability in cases of Non Trusted AMFs.
  • NSSF_Authorization_NonTrustedAMF_NsAvailPUT: This feature file contains test cases related to PUT request for Update operation of NSSAI Availability in cases of Non Trusted AMFs.
  • AMF_TrustedListing: This feature file contains test cases related to Trusted of AMFs and Configuration of NsAvailability PUT request.
Regression homepage
  1. In the above screen:
    • Click Configure to access the configuration screen.
    • Click Documentation to view the documented test cases.
    • Click blue dots inside the Build History box to view the success console logs of the "All" and "Sanity" respectively.
    • The Stage View represents the already run pipeline for customer reference.
    WARNING:
    NSSF-Regression Configuration
    node ('built-in'){
        withEnv([
        sh '''
            -a NSSF \
            -b ocnssf \
            -g 80 \
            -h 2 \
            -m ocnssf \
            -n ocats \
            -o 8081 \
            -p 8080 \
            -q 8080 \
            -B 311 480 \
        else{
            load "/var/lib/jenkins/ocnssf_tests/jenkinsData/Jenkinsfile-Regression"
    • x: NSSF NF Instance ID
    • y: NRF stub Server Service name(nrf-stubserver1.ocnssf)
    • z: NRF stub Server Service name(nrf-stubserver1.ocnssf)
    • Do not change any value if the OCCNE cluster is used, and NSSF, ATS, and STUB are deployed in the ocnssf namespace.
    • In the above image, the NSSF Helm Release Name is "ocnssf", ATS Helm Release Name is "ocats", and Namespace is "ocnssf". If any change in the helm release name of NSSF, ATS, and namespace needs to be updated accordingly.
    • For example, if the NSSF Helm Release Name is "ocnssfats" and ATS Helm Release Name is "ocatsnssf", and Namespace is "ocnssf2510", then the above Pipeline Configuration should be edited as shown below:
      • NSSF Helm Release Name should be updated in "c d i k m r s t u v w" if any change in NSSF helm release name apart from "ocnssf".
      By default NSSF Instance ID in NSSF custom values file as below:
      For example, if the nfInstanceId in the NSSF custom values file is modified from "9faf1bbc-6e4a-4454-a507-aef01a101a01" to "9faf1bbc-6e4a-4454-a507-aef01a101a20", the same change must be updated in the "x" Jenkins pipeline parameters as shown below.
    node ('built-in'){
        withEnv([
        sh '''
            -a NSSF \
            -b ocnssf2510 \
            -g 80 \
            -h 2 \
            -m ocnssfats \
            -n ocats \
            -o 8081 \
            -p 8080 \
            -q 8080 \
            -B 311 480 \
        else{
  4. Click Save after making necessary changes. The Pipeline NSSF-Regression screen appears.
NSSF-Regression - Build with Parameters
NSSF-Regression - Build with Parameters-2
  • By default, features "ALL," configuration type "Product_config," and include new features "NO" will be selected. All test cases will be executed once you click on BUILD, as shown above.
  • Features: ALL. Once you click on ALL, a dropdown "Select" option will appear. After selecting the "Select" option, as shown below, options will appear to select feature files. To run the selected feature files, click on "Build," as shown below.
    NSSF-Regression - Build with Parameters-3
80 features passed, 1 failed, 0 skipped
812 scenarios passed, 1 failed, 0 skipped
10129 steps passed, 1 failed, 4 skipped, 0 undefined
4.3.6 NSSF-Regression Documentation
To view NSSF Regression cases, go to NSSF-Regression latest pipeline build and click the Documentation link in the left navigation pane. The following screen appears. Click any functionality to view its test cases and scenarios of each test case as shown below:
NSSF - Documentation Sample
Regression - Documentation Sample
Once the run of regression features is done successfully, click on the build number whose logs are to be viewed and then click on Console Output on left side navigation.
Wait till the page is loaded completely, then click Download to download the regression features logs.
reconsole
RegLogs
4.4 Running Policy Test Cases using ATS
This section describes how to run CNC Policy test cases using ATS.
For this ATS-Policy release, scenarios or test cases are included for the following three deployment modes:
  • Converged Policy
  • PCF only for both TLS enabled (server side) and disabled mode
  • PCRF only
Restart the NRF-client pod of CNC Policy for UDR and CHF discovery as part of each test case.
4.4.1 Prerequisites
PCF only deployment
To run CNC Policy test cases in PCF mode, ensure that the following prerequisites are met:
  • Deploy CNC Policy 25.1.200 with default helm configurations using helm charts to run all test cases. The ATS version must be compatible with CNC Policy 25.1.200. For more information on how to install CNC Policy, see Oracle Communications Cloud Native Core Policy Installation, Upgrade and Fault Recovery Guide.
  • For running ATS features for optional services such as LDAP, Notifier, and Usage Monitoring, ensure that the respective service is enabled on CNC Policy. If this service is not enabled, the test case for this feature will fail.
  • For running SOAP notification service, ensure that the SOAP connector service is enabled on CNC Policy. If this service is not enabled, the test case for this feature will fail.
  • For running ATS features, ensure to update the following mandatory parameters in ocpcf_custom_values_25.1.200.yaml file only when you are not using the minimal custom values.yaml file.
    logging:
      burst:
        rate: 500
        max: 3000
        onMismatch: DENY
        logLevel: DEBUG
    Please ensure that you use the latest version of the Custom Values file when installing Policy initially.
  • For using Controlled Shutdown feature, ensure that enableControlledShutdown parameter is enabled on CNC Policy. If this parameter is not enabled, the test case for this feature will fail.
  • Install py-stub, ocamf-stub, ocdns-bind stub, and oc-ldap stub for Converged Policy and PCF deployment modes.
  • Ensure there is a single pod for each microservice in the CNC Policy deployment for ATS Prometheus metrics validation to work.
  • Users can add new test cases, remove unwanted test cases, and modify existing test cases in the custom test case folders (cust_newfeatures, cust_regression, and cust_performance). It does not impact the original test cases packaged with the product under newfeatures, regression, and performance folders. For more details about custom test case folders, see Custom Folder Implementation.
  • The ATS prometheus metrics validation works only when:
    • the metrics suffixes are not configured
    • installation has a single pod for each microservice in the BSF deployment
  • For PRE and Policy_addition timer, Update PRE deployment to reduce the value of POLLING_INTERVAL from 10s to 5s and POLLING_INTERVAL_POLICYTABLE from 30s to 10s.
    Figure 4-30 PRE and Policy_addition timer
    Run the following command to reduce the value of polling deployment:
    [cloud-user@platform-bastion-1 ~]$ kubectl edit deploy ocpcf-ocpm-pre -n ocpcf
  • The following deployment is displayed:
    Figure 4-31 POLLING_INTERVAL and POLLING_INTERVAL_POLICYTABLE Deployment
    The value of POLLING_INTERVAL can be updated to 5000 and POLLING_INTERVAL_POLICYTABLE to 10000 if it is not updated.
    For the policy_additon timer, the following changes have been made in the config.xml file for NewFeatures, Performance, and Regression.
    Figure 4-32 Policy Addition Timer
    For every SUT, change the of value of -n from 15 to 7, as follows:
    Figure 4-33 Change in SUT Value
    Change in SUT Value
  • In the application-config configmap, configure the following parameters with the respective values:
    • Set the value of primaryNrfApiRoot as primaryNrfApiRoot=nf1stub.<namespace_pystubs_are_deployed_in>.svc:8080.
      For example:
      primaryNrfApiRoot=nf1stub.ocats.svc:8080
    • Remove secondaryNrfApiRoot.
      For example: secondaryNrfApiRoot=nf1stub.ocats.svc:8080
    • Set the value of nrfClientSubscribeTypes to UDR,CHF,NWDAF.
    • Remove supportedDataSetId.
      For example: supportedDataSetId=POLICY
      These values can also be configured during Policy deployment.
      Run the following command to get all configmaps in your namespace:
      kubectl get configmaps -n <Policy_namespace>
    • Set the value of retryAfterTime equal to PT30S.
  • Before running Policy test cases using ATS, restart nrf-client-nfdiscovery and nrf-client-nfmanagement pods.
  • Edit the Alternate Route Service deployment pointing towards DNS Stub.
    1. Run the following command to get searches information from dns-bind pod to enable communication between Alternate Route and dns-bind service:
      kubectl exec -it <dns-bind pod> -n <NAMESPACE> -- /bin/bash -c 'cat /etc/resolv.conf' | grep search | tr ' ' '\n' | grep -v 'search'
      The following output is displayed after running the command:
      Figure 4-34 Sample Output
      Sample Output
      By default alternate service will point to CoreDNS and you will see following settings in deployment file:
      Figure 4-35 Alternate Route Service Deployment File
      Screen capture to show alternate route service points to CoreDNS
    2. Run the following command to edit the deployment file and add the following content in alternate service to query DNS stub:
      $kubectl edit deployment ocpcf-occnp-alternate-route -n ocpcf
      1. Add the IP Address of the nameserver that you have recorded after installing the DNS stub (cluster IP Address of DNS Stub).
      2. Add the search information one by one which you recorded earlier.
      3. Set dnsPolicy to "None".
        dnsConfig:
          nameservers:
          - 10.233.33.169      // cluster IP of DNS Stub
          searches:
          - ocpcf.svc.occne15-ocpcf-ats
          - svc.occne15-ocpcf-ats
          - occne15-ocpcf-ats
        dnsPolicy: None
      Figure 4-36 Example
      Example
PCRF only deployment
To run CNC Policy test cases in PCRF mode, ensure that the following prerequisites are met:
  • Run the following command to set the log level to Debug in Diam-GW statefulset:
    kubectl edit statefulset <diam-gw statefulset name> -n <namespace>
    value: DEBUG
  • Set the peer Configuration using configuration map for backend peers.
    Edit and set the default configuration of Diameter peer in the diam configuration map and set responseOnly flag to true.
    kubectl edit cm oc-diam-gateway-config-peers -n <namespace>
    nodes:
      - name: 'ocpcf-occnp-pcrf-core'
        type: 'pcrf'
        responseOnly: true
        host: ocpcf-occnp-pcrf-core-headless
        port: 3868
        realm: ''
        identity: ''
Converged mode deployment
To run CNC Policy test cases in Converged mode, ensure that the following prerequisites are also met:
  • Deploy CNC Policy 25.1.200 with default helm configurations using helm charts to run all test cases. The ATS version must be compatible with CNC Policy 25.1.200. For more information on how to install CNC Policy, see Oracle Native Core, Converged Policy Installation, Upgrade, and Fault Recovery Guide.
  • Install Prometheus server in cluster.
  • Database cluster should be in a running state with all the required tables. Ensure there are no previous entries in database before executing test cases.
  • Deploy ATS in the same namespace as Policy using Helm Charts.
  • The installation should have only one pod for each microservice related to ATS Prometheus Metrics validation to work in the CNC Policy deployment.
  • If Service Mesh check is enabled, apply the below settings:
    For fetching the metrics from the Prometheus, create a destination rule. In most deployments, Prometheus is kept outside of the service mesh. Hence, a destination rule is required to communicate between TLS enabled entity (ATS) and non-TLS entity (Prometheus). Created the rule as follows:
    kubectl apply -f - <<EOF
    apiVersion:networking.istio.io/v1alpha3
    kind:DestinationRule
    metadata:
      namespace:ocats
    spec:
      host:oso-prometheus-server.pcf.svc.cluster.local
      trafficPolicy:
        tls:
          mode:DISABLE
    EOF
    Here,
    1.) name,indicates the name of destination rule.
    2.) namespace,indicates where the ATS is deployed.
    3.) host,this indicates the hostname of the prometheus server.
  • For running ATS features for Model D Indirect Communication Model, ensure that the custom values yaml of CNC Policy has the following parameters with the specified values:
    routeConfigMode: REST
    configureDefaultRoute: true
  • Update the occnp-servicemesh-config-custom-values-25.1.200.yaml of CNC Policy with the following virtualService configuration for Egress Gateway:
    virtualService:
    #  - name: nrfvirtual1
    #    host: ocpcf-occnp-egress-gateway
    #    destinationhost: ocpcf-occnp-egress-gateway
    #    port: 8000
    #    exportTo: |-
    #    attempts: "0"
  • Restart the ocpm-ldap-gateway pod manually before running the LDAP-specific ATS test cases.
  • To ensure the consistent functioning of ATS related to the audit service, modify the audit deployment by reducing the value of AUDIT_NOTIFY_SCHEDULER_POLLING_INTERVAL_MILLISEC from 30000 to 1000 (changing from 30 seconds to 1 second).
    $ kubectl get deploy -n ocpcf | grep 'audit' ocpcf-ocpm-audit-service     1/1     1      1      10h
    $ kubectl edit deploy ocpcf-ocpm-audit-service -n ocpcf
    The deployment will open. Scroll down until below fields are seen.
    - name:  AUDIT_NOTIFY_SCHEDULER_POLLING_INTERVAL_MILLISEC value: "30000"
    Update the value of AUDIT_NOTIFY_SCHEDULER_POLLING_INTERVAL_MILLISEC to 1000 if it isn't already.
In order to run stage2 or stage3 cases using configuration_type of custom_config, replace the "data" folder with "cust_data" folder in stage<x>.txt under /var/lib/jenkins/ocpcf_tests/cust_data/common/stage_hooks/stage<x>. directory.
Application Config map changes for Policy registrations over TLS
To enable TLS communication make the following changes by editing the config map of application-config:
  • NRF port from 8080 to 8443
  • nrfScheme to https
Sample:
apiVersion: v1
data:
  profile: |-
    [appcfg]
    primaryNrfApiRoot=nf1stub.ocats.svc:8443
    nrfScheme=https
In the config map of application-config, delete the lines which has supportedDataSetId or secondaryNrfApiRoot strings.
4.4.2 Logging into ATS
Before logging into ATS GUI, it is important to get the nodeport of the service, 'ocats-policy'.
To get the nodeport, perform the following steps:
kubectl get svc -n <Policy_namespace>
Example:
kubectl get svc -n ocpcf
The output of the command is:
ocats-ocats-pcf     LoadBalancer   10.233.56.56   10.75.225.49     8080:31944/TCP      19h
To log in to ATS, open the web browser and type the following URL:
http://<Worker-Node-IP>:<Node-Port-of-ATS>
If the ocats-policy Service has an external IP available, <SVC external IP> can also be used to log in to ATS.
http://<SVC external IP>:8080
Example: http://10.75.225.49:8080
Running ATS
To run ATS test cases, perform the following steps:
  1. Enter the username as policyuser and password as policypasswd.
  2. Click Sign in.
    To modify default login password, see Modifying Login Password.
    Figure 4-37 Pre-configured Pipelines
    The description of each pipeline is as follows:
    • Policy-HealthCheck: This pipeline checks if CNC Policy and ATS are deployed correctly. This shows only when the user has enabled this feature at the time of installing CNC Policy ATS.
    • Policy-NewFeatures: This pipeline has all the new test cases delivered for CNC Policy 25.1.200.
    • Policy-Regression: This pipeline has all the test cases delivered in Policy ATS - 24.3.x.
    • Policy-Performance: This pipeline is not operational as of now. It is reserved for future releases of ATS.
4.4.3 Running Policy-HealthCheck Pipeline
This is a pre-configured pipeline where ATS performs a test probe with SUT. It triggers helm test & provides the results in Jenkins Console Logs.
You can run Policy-HealthCheck pipeline to check if all CNC Policy pods are up and running. If yes, it provides the status as successful. If any pod is down due to any reason, then the pipeline fails.
To configure the parameters for Policy-HealthCheck pipeline, perform the following steps:
  1. Click Policy-HealthCheck in the Name column.
  2. Click Configure in the left navigation pane.
  3. When you scroll-down, the General tab becomes active. Be sure that the screen loads completely.
  4. Continue scrolling down until the Pipeline tab becomes active. The following is a screen capture that shows the Pipeline script:
    Figure 4-38 Helm Test Script
    Helm Test Script
  5. In the Script area under the Pipeline section, users may customize the values for the following parameters:
    Attention:
    Do not modify values of parameters other than the ones described in this section.
    • a: Change this parameter to update the helm release name where Policy is deployed in your bastion.
    • b: Change this parameter to update the namespace where Policy is deployed in your bastion.
  6. Click Save to update the values.
Running Helm Test
To run CNC Policy test cases, click Build Now.
4.4.4 Running Policy-NewFeatures Pipeline
Policy-New Features Pipeline
This is a pre-configured pipeline where all the Policy new test cases are executed.
To configure the parameters for Policy-NewFeatures pipeline, perform the following steps:
Configuring the parameters is a one-time activity.
  1. Click Policy-NewFeatures in the Name column.
  4. (Optional) If you want to retain a specified number of builds in the persistent volume, select the check box for Discard old Builds. It is recommended to configure this option; otherwise, Persistent Volume may fail when the builds are exceedingly high.
    Enter values for the following parameters:
    • Days to keep builds: Specifies the number of days for which build records are stored.
    • Max # of builds to keep: Specifies the number of build records to store.
  5. Continue scrolling down until the Pipeline tab becomes active. The following is a screen capture that shows the Pipeline script:
    Figure 4-39 Policy New Pipeline Configuration
  6. In the Script area under the Pipeline section, users may customize the values for the following parameters:
    Attention:
    • a: Name of the NF to be tested in capital (PCF).
    • c: Name of Prometheus service namespace (occne-prometheus-server)
    • d: Change this parameter to update the namespace where gostubs are deployed in your bastion.
    • e: Set this parameter as 'unsecure', if you intend to run ATS in TLS disabled mode. Else, set this parameter as 'secure'.
    • g: Set this parameter to more than 45 secs. The default wait time for the pod is 45 secs. Every TC requires restart of the nrf-client-management pod.
    • h: Set this parameter to more than 60 secs. The default wait time to add a configured policy to the database is 60 secs.
    • i: Set this parameter to more than 140 secs. The default wait time for Nf_Notification Test Cases is given as 140 secs.
    • k: Use this parameter to set the waiting time to initialize Test Suite.
    • l: Use this parameter to set the waiting time to get response from Stub.
    • m: Use this parameter to set the waiting time after adding Policy Configuration.
    • n: Use this parameter to set the waiting time after adding Policy.
    • o: Use this parameter to set the waiting time before sending next message.
    • p: Use this parameter to set Prometheus Server IP.
    • q: Use this parameter to set Prometheus Server Port.
    • r: Use this parameter to set the interval after which the POD status is checked when it is down.
    • s: Use this parameter to set number of retry attempt in which will check the pod down status
    • t: Use this parameter to set the interval after which we check the POD status if its UP.
    • u: Use this parameter to set number of retry attempt in which will check the pod up status.
    • v: Use this parameter to set Wait time to connect to Elastic Search
    • w: Use this parameter to set Elastic Search HostName
    • x: Use this parameter to set Elastic Search Port
    • y: Use this parameter to set To Enable/Disable Stub logs collection
    • z: Use this parameter to set Log collection endpoint either Elasticsearch or Kubernetes
    • A: Use this parameter to enable or disable snapshots that are created at the start and restored at the end of each test run
    • B: Use this parameter to for timer to wait for importing service configurations
    • C: Use this parameter to set PCF_API_ROOT information for Ingress gateway service name and port.
    • D: Use this parameter to set bulk_import_to_complete to add custom time in Jenkins post bulk imports.
    • E: Use this parameterto configure TLS_VERSION to define the supported TLS version (1.2 or 1.3).
    (Optional)To collect application logs per failed scenario, user can configure the values for the following parameter:
    • z: If you want log collection to happen through Elastic search, set the value for this parameter as Elasticsearch. If not, specify the value as Kubernetes.
      If you want to collect logs Elastic search, it is required to configure the values for the following parameters:
      • v: Specifies the wait time to connect to Elastic search (ELK_WAIT_TIME).
      • w: Specifies the host name of Elastic search (ELK_HOST). For example, occne-elastic-elasticsearch-master.occne-infra/
      • x: Specifies the port for Elastic search (ELK_PORT). For example, 9200.
    • y: If you want to collect stub logs, set the value for this parameter as yes. If not, specify the value as no.
  7. A: To enable or disable snapshots that are created at the start and restored at the end of each test run.
  8. Click Save to update the values. The Policy_NewFeatures Pipeline page appears.
    It is recommended to save the pipeline script in your local machine as it is needed at the time of ATS pod restart.
Extracting Application Logs
If any scenarios failed after running the pipeline job, perform the following steps:
  1. Log in to the ATS pod:
    kubectl exec -it pod/occnp1-ocats-ocats-policy-xxxxxxxx -n ocpcf bash
  2. Go to build directory:
    cd $JENKINS_HOME/jobs/$JOB_NAME/builds/$BUILD_NUMBER/
    For example:
    cd /var/lib/jenkins/.jenkins/jobs/Policy-Regression/builds/1
  3. Extract the applogs.zip file:
    unzip applogs.zip
  4. After successfully unzipping the file, open the applog folder to view pod logs for failed scenarios:
    (env) [jenkins@gapcf-ocats-ocats-policy-6df5cd84c-c6cm4 applog]$ pwd
    /var/lib/jenkins/.jenkins/jobs/Policy-Regression/builds/3/applog
    (env) [jenkins@gapcf-ocats-ocats-policy-6df5cd84c-c6cm4 applog]$ ls -ltrh
    total 1.4M
    -rw-r--r--. 1 jenkins jenkins 461K Sep  1 14:49 Initial_Run-Send_Npcf_SMPolicyControl_Create_request_message_to_PCF_and_verify_the_praInfos_structure_is_downloaded_in_the_response_message_to_SMF_also_check_requests_total_metric_incremented_in_the_PCF.log
    -rw-r--r--. 1 jenkins jenkins 459K Sep  1 14:49 1st_Rerun-Send_Npcf_SMPolicyControl_Create_request_message_to_PCF_and_verify_the_praInfos_structure_is_downloaded_in_the_response_message_to_SMF_also_check_requests_total_metric_incremented_in_the_PCF.log
    -rw-r--r--. 1 jenkins jenkins 459K Sep  1 14:49 2nd_Rerun-Send_Npcf_SMPolicyControl_Create_request_message_to_PCF_and_verify_the_praInfos_structure_is_downloaded_in_the_response_message_to_SMF_also_check_requests_total_metric_incremented_in_the_PCF.log
To run CNC Policy test cases, perform the following steps:
  1. Click the Build with Parameters link available in the left navigation pane of the Policy-NewFeatures Pipeline screen. The following screen appears.
    Figure 4-40 Pipeline Policy-NewFeatures
  2. Select any of following valid values from the drop-down for SUT:
    • PCF
    • cnPCRF
    • Converged Policy
  3. Select any of following valid values from the drop-down for Configuration_Type:
      To use the parameterization feature, always select the Custom_Config option. User can copy, add, or delete the required test cases that are available for the Converged Policy, PCF or PCRF and place them appropriately within the custom folder for Policy-NewFeatures. Reload the page to view the test cases available in the custom NewFeatures folder.
  4. For the Select_Option field, select any of the following drop-down values:
    • All: By default, all the Policy test cases are selected for execution.
    • Single/MultipleFeatures: This option allows you to select any number of test cases you want to run from the list of total test cases. Select the check-box for each feature you want to run.
    Based on your selection, related Test Cases appear on the page.
  5. To collect logs for any given build, select YES from the drop-down menu of Fetch_Log_Upon_Failure.
  6. Click Build and select Console Output to view the test results. The following is a sample test result ouput:
    Figure 4-41 Test Result Output in Console
For more details on consolidated test report, see Managing Final Summary Report, Build Color, and Application Log.
  • Remove test cases
To run ATS test cases, user can maintain as many versions of Custom Config folder by using the following naming convention:
Cust ConfigN
To use custom diameter identity, update the value of parameter "diam_gw_id" under global.yaml file to the one configured for "DIAMETER_Identity" under diam-gw's statefulset.
For CNC Policy-ATS release 25.1.200, parameterization is supported for PCF features only.
Incorrect Values
If the value to be parameterized is incorrect or not updated correctly, the following error is generated:
2021-12-17 09:02:43,908[32m     INFO LOG.featureHooks:14 [0m| [32mInside before_feature[0m
2021-12-17 09:02:43,908[32m     INFO LOG.goldenConfig:305 [0m| [32mInside goldenConfig.py[0m
2021-12-17 09:02:43,912[31m    ERROR LOG.goldenConfig:93 [0m| [31mPlease check if the key metricsEnabled is valid or if it is present under correct section[0m
2021-12-17 09:02:43,913[32m     INFO LOG.goldenConfig:324 [0m| [32mExiting goldenConfig.py[0m
2021-12-17 09:02:43,913[32m     INFO LOG.featureHooks:27 [0m| [32mExiting before_feature[0m
The execution continues to happen without any changes to the data files.
Config-Rollback (Snapshot Backup and Restore)
Using this feature, user can take a snapshot of initial configuration of the system, and then restore it at a later stage. On enabling this feature, a snapshot of system configurations is taken before ATS run starts and is reverted on completion of ATS job.
Queuing Jenkins Jobs
Using this feature, you can queue a second job even when current job is still running. The second job can be triggered either from the same or a different pipeline.
The following table lists various scenarios on how queuing works:
Table 4-2 Queuing Jenkins Jobs
Concurrent Builds New FeaturesCurrent Build New FeaturesNew Build RegressionCurrent Build RegressionNew Build Build Result
Enabled Running Triggered NA NA New-Build of New-Features is added to queue.
Enabled Running NA NA Triggered New-Build of Regression is added to queue.
Disabled NA NA Running Triggered New-Build of Regression is added to queue.
Disabled NA Triggered Running NA New-Build of New-Features is added to queue.
Test Result Analyzer
Using the Test Result Analyzer plug-in, user can view consolidated and detailed reports. For more information, see Test Results Analyzer section.
Test Case Mapping to Features and Display Total Counts
With this feature, users can view total count of features, test cases, and TestCase mapping for each feature of CNC Policy on ATS GUI. For more information, see Support for Test Case Mapping and Count.
4.4.5 Policy-NewFeatures Documentation
This section describes the documentation for Policy-NewFeatures pipeline.
To view the documentation for any of the CNC Policy features, on the ATS home page, click Policy-NewFeatures. Then, click Documentation in the left navigation pane.
On clicking Documentation, the following page opens with the list of new features:
Figure 4-42 Policy-NewFeatures Feature List
Example: On clicking Feature - Consolidation_with_T3501_Expiry, the following screen opens:
Figure 4-43 Feature - Consolidation_with_T3501_Expiry
Based on the features covered under Documentation, the Build Requires Parameters screen displays test cases.
To navigate back to the Policy-NewFeatures pipeline, click Back to Policy-NewFeatures link available on the top left corner of the screen.
4.4.6 Running Policy-Regression Pipeline
This section describes how to run test cases for CNC Policy Regression pipeline.
The Policy-Regression pipeline is a pre-configured pipeline where all the test cases of previous releases are available. For an example, for Policy 25.1.200, this pipeline has all the test cases released till Policy 24.3.x.
To run CNC Policy test cases in regression pipeline, perform the following steps:
  1. Click Policy-Regression in the Name column.
  2. Click the Build with Parameters link available in the left navigation pane of the Policy-Regression Pipeline screen. The following screen appears.
    Figure 4-44 Regression Pipeline
    Regression Pipeline
    ATS display empty list for test cases as it is referring to the custom folder for Policy-Regression pipeline.
  3. Select any of following valid values from the drop-down for SUT:
    • PCF
    • CN-PCRF
    • Converged Policy
  4. Select any of following valid values from the drop-down for Configuration_Type:
  5. For the Select_Option field, select any of the following drop-down values:
  6. To collect logs for any given build, select YES from the drop-down menu of Fetch_Log_Upon_Failure.
  7. Click Build and select Console Output to view the test results. The following is a sample test result ouput:
    Figure 4-45 Policy-Regression Console Output
    The Regression pipeline does not have any sanity option. However, users must perform all the steps performed in the Policy-NewFeatures pipeline. Ensure that the pipeline script is configured according to the environment variables.
4.4.7 Policy-Regression Documentation
This section describes the documentation for Policy-Regression pipeline.
To view the documentation for any of the CNC Policy features, on the ATS home page, click PolicyRegression. Then, click Documentation in the left navigation pane.
Figure 4-46 Policy-Regression Feature List
Example: On clicking FEATURE - Add_NFSetIDList, the following screen opens:
Figure 4-47 FEATURE - Add_NFSetIDList
This page shows features of only those test cases that are released in previous releases.
4.5 Running SCP Test Cases using ATS
This section describes how to run SCP test cases using ATS.
4.5.1 Logging in to ATS
Logging in to ATS GUI in Non-OCI Setup
Before logging in to ATS, ensure that ATS and Stubs are deployed using Helm charts. A sample screenshot is provided as follows:
Figure 4-48 Verifying ATS Pod
Verifying ATS Pod
In the Verifying ATS Pod image, the ATS nodeport is highlighted in red as 30345. For more information about ATS deployment, see Deploying ATS and Stub in the Kubernetes Cluster. Similarly, verify Stub deployments.
To log in to the ATS GUI, open the browser and either provide the external IP address of the worker node and nodeport of the ATS service as <Worker-Node-IP>:<Node-Port-of-ATS> or provide the IP address of the load balancer and serviceport of the ATS service as <ATS-LB-IP>:<Service-Port-of-ATS>.
Figure 4-49 Logging in to ATS GUI
Running ATS
It is recommended to keep the rerun count to minimum 1 for running ATS testcases.
To run ATS:
  1. Enter the login credentials and click Sign in.
    The following screens appear to display preconfigured pipelines for SCP individually.
    Figure 4-50 ATS SCP First Login Screen
The different pre-configured pipelines for SCP are as follows:
  • SCP-NewFeatures: This pipeline has all the test cases delivered as part of this release.
  • SCP-Regression: This pipeline covers all the test cases from the previous releases.
Logging in to ATS GUI in OCI Setup
To access the ATS GUI in OCI, see the Accessing ATS GUI in OCI section.
Logging in to ATS GUI with HTTPS Enabled
To access the ATS GUI, see the Enable ATS GUI with HTTPS section.
For more information, see the Support for Transport Layer Security.
4.5.2 SCP-NewFeatures Pipeline
This section describes how to configure new feature pipeline parameters, run SCP test cases, and view functionalities.
4.5.2.1 Configuring New Feature Pipelines
This is a pre-configured pipeline where all the SCP test cases are run.
To configure its parameters, do the following:
  1. Click SCP-NewFeatures in the Name column.
    The SCP-NewFeatures screen appears.
    Figure 4-51 SCP-NewFeatures
    SCP-NewFeatures
    According to the installation guide, the configuration parameters can be modified in the ocats_ocscp_values.yaml file before deployment. If you are running SCP test cases for the first time without enabling the parameters in the deployment file, then you have to set the input parameters before running any test case. There is no need to set these parameters again unless there is a change in the configuration.
  2. In the left navigation pane, click Configure to provide input parameters and scroll down to the pipeline script as shown in the following image:
    The General tab appears.
    Ensure that the following screen loads completely before you perform any action on it. Also, do not modify any other configuration than what is specified in the subsequent steps.
    The control moves from the General tab to the Pipeline tab, as shown in the following screenshot:
    Figure 4-52 Pipeline Tab
    Pipeline Tab
  3. Modify the values of the pipeline script as required, and then click Save.
    Parameter "-I" must be changed as part of "Pipeline script". The content of the pipeline script is as follows:
    node ('built-in'){
        //a = SELECTED_NF  b = NFNAMESPACE  c = CLUSTERDOMAIN  d = DESTNAMESPACE
        //e = ATSREGISTRY  f = AUDITINTERVAL  g = GUARDTIME  h = SCPSVCNAME
        //i = SCPCONFIGSVCNAME  j = SCPNOTIFYSVCNAME  k = SCPSUBSVCNAME  l = DBSECRETNAME
        //m = MYSQLHOST  n = ATSSTUBIMAGE  o = ATSSTUBCPU  p = ATSSTUBMEMORY  q = SCPAUDITSVCNAME
        //r = RERUN_COUNT  s = SCPSVCPORT  t = PROMSVCNAME  u = PROMSVCPORT  v = STUBWAITTIME
        //w = PROMSVC_URI  x = SUBVALIDITYTIME z = OPENSEARCH_WAIT_TIME A = OPENSEARCH_HOST
        //B = OPENSEARCH_PORT C = STUB_LOG_COLLECTION D = OPENSEARCH_LOGS E = SCPSVCHTTPSPORT F = SCPNRFPROXYSVCNAME
        //G = KUBERNETES_HOST H = KAFKANAMESPACE I = SCPDDCLIENTSVCNAME J = SCPGLBRATELIMITSTUBSVCNAME K = SCPCONFIGSVCPORT
        //L = SCP_METRICS_VERSION M = SCPSVCIP
        withEnv([
        sh '''
            sh /var/lib/jenkins/ocscp_tests/preTestConfig.sh \    -a SCP \
            -b scp-73999881-dev \
            -c cluster.local \
            -d scp-73999881-dev \
            -e cgbu-ocscp-dev-docker.dockerhub-phx.oci.oraclecorp.com/ocats \
            -f 60 \
            -g 10 \
            -h cicdocscp-scp-worker \
            -i cicdocscp-scpc-configuration \
            -j cicdocscp-scpc-notification \
            -k cicdocscp-scpc-subscription \
            -l appuser-secret \
            -m mysql.scp-73999881-dev.svc.cluster.local \
            -n ocats-pystub:25.1.100-beta.35 \
            -o 0.5 \
            -p 0.5G \
            -q cicdocscp-scpc-audit \
            -r 0 \
            -s 8000 \
            -t occne-prometheus-73999881-server.scp-73999881-dev-infra \
            -u 80 \
            -v 300 \
            -w /api/ \
            -x 120 \
            -z 0 \
            -A occne-opensearch-cluster-master.scp-73999881-dev-infra \
            -B 9200 \
            -C yes \
            -D opensearch \
            -E 9443 \
            -F cicdocscp-scp-nrfproxy \
            -G kubernetes.default \
            -H scp-73999881-devkafka \
            -I ocats-ocscp-ocats-ddclientstub \
            -J ocats-ocscp-ocats-scpglbratelimitstub \
            -K 8081 \
            -L v1 \
            -M scpSignallingFqdn \
            sh '''sh /var/lib/jenkins/common_scripts/merge_jenkinsfile.sh'''
            load "/var/lib/jenkins/ocscp_tests/jenkinsData/Jenkinsfile-Merged"
        else{
            load "/var/lib/jenkins/ocscp_tests/jenkinsData/Jenkinsfile-NewFeatures"
    Do not modify anything other than these parameters.
    • a: Selected NF
    • b: NameSpace in which SCP is deployed
    • c: K8s Cluster Domain where SCP is deployed
    • d: Test Stubs NameSpace - Must be same as SCP Namespace
    • e: Docker registry where test stub image is available
    • f: Audit Interval provided in SCP Deployment file
    • g: Guard Time provided SCP Deployment file
    • h: SCP-Worker microservice name as provided during deployment
    • i: SCPC-Configuration microservice name as provided during deployment
    • j: SCPC-Notification microservice name as provided during deployment
    • k: SCPC-Subscription microservice name as provided during deployment
    • l: DB Secret name as provided during deployment
    • m: Mysql Host name as provided during deployment
    • n: Test Stub Image Name with tag
    • o: Test Stub CPU requests and limit
    • p: Test Stub Memory requests and limit
    • q: SCPC-Audit microservice name as provided during deployment
    • r: re-run count
    • s: SCPSVCPORT with which SCP is deployed
    • t: PROMSVCNAME with which Prometheus server is deployed. Note: Prometheus service name is followed by namepsace in which Prometheus service is existing. Prometheus service is in a different namespace related to deployed SCP namespace.
    • u: PROMSVCPORT with which Prometheus server is deployed
    • v: Time to wait for Stub Creation. Default value of STUBWAITTIME is 240s.Note: A user needs to update the STUBWAITTIME in increments or multiples of 30 seconds. The minimum allowable value for STUBWAITTIME is 30 seconds.
    • w: API URI of Prometheus (/api/) - For examples, use /api/or /prometheus/api/
    • x: Subscription Validity Time to set by ATS in response to subscription request from SCP
    • y: Application Debug Logs collection on Rerun if set to true. The default value is false
    • z: Opensearch connection timeout
    • A: Opensearch host/service name
    • B: Opensearch port
    • C: Stub log collection
    • D: Provide Kubernetes or OpenSearch for ATS for app log collection (Fetch_Log_Upon_Failure should be enabled)
    • E: SCP HTTPS Signaling Port
    • F: SCP NRF Proxy service name
    • G: Kubernetes Host
    • I: scpddclientstub name as provided during deployment
    • J: scpglobalratelimitstub name as provided during deployment
    • K: port of configuration pod in SCP deployment
    • L: scp metrics version
    • M: scp worker FQDN or cluster IP: The default value is scpSignallingFqdn, which forwards requests to the worker using the worker's FQDN. Alternatively, an IPv4 or IPv6 address (enclosed in square brackets) can also be provided.
4.5.2.2 Running SCP New Feature Pipelines
To run SCP test cases, perform the following steps
  1. Click Build with Parameters link available in the left navigation pane of the Pipeline SCP-NewFeatures screen.
  2. Select the R16 option from the Execute_Suite drop-down menu to run Release 16 test cases for SCP.
  3. Select the required option from the Features drop-down menu to run the test cases:
    • All: To run all the test cases for SCP based on Release15 or Release16 selection.
    • Sanity: Enabled for SCP. Sanity cases are run to do a quick sanity check on SCP SUT features.
    • Select: This option allows users to separately select specific features for separate execution. Additionally, users can select the run for an entire stage or group instead of running all feature files.
  4. Select one of the following configuration types from the Configuration_Type drop-down menu:
    • Product_Config: To run test cases from the features or regression directory. Test cases in this directory should not be modified.
    • Custom_Config: To run test cases from the features or cust_regression directory. Any test case customization required should be done in this directory.
  5. Select an appropriate option and click Build to perform the test.
    Figure 4-53 Build
    Build
  6. Click Full Stage View in the left navigation pane to view the status of the run.
  7. Hover over values of Execute Tests, and then click Logs to check test results and logs.
    A sample consolidated test report is shown in the following image when rerun is set to 2, which is the default value. All the features passed within the first rerun, therefore, the second rerun stage has not been run in this case.
    Figure 4-54 Sample consolidated report
    For more information about consolidated test report, see Managing Final Summary Report, Build Color, and Application Log.
    • The New Feature tests in this release have been written according to SCP-ATS parameterization method (Golden Configuration). The individual features are not populated with direct values for the parameters, however, with variable names. While performing the tests, these variables are mapped according to the data provided adjacent to them in the feature specific <feature_name>.yaml and global.yaml that can be found in the product_config directory. This method allows the decoupling of data that can be customer specific from the features. Fore more information about parameterization (Golden Configuration), see Parameterization.
    To view the detail view of the respective group, rerun logs, and the consolidated report summary:
    1. Click Open Blue Ocean Homepage from the left navigation pane.
    2. Click the build number in the run column to view the consolidated output of all the feature that are run.
    3. Click Download icon to download the log files.
4.5.3 SCP-NewFeatures Documentation
This pipeline has an HTML report of all the feature files that you can test as part of the SCP ATS release.
  1. To view SCP functionalities, go to the SCP-NewFeatures pipeline and click the Documentation option in the left navigation pane. It lists all the test cases provided as part of SCP ATS -25.1.201.
    The Documentation option appears only if the SCP-NewFeatures pipeline test cases are run at least once.
    Figure 4-55 SCP-NewFeatures Documentation
  2. Click any functionality to view its test cases and scenarios for each test case.
    Figure 4-56 Sample Scenario
    Sample Scenario
    Based on the functionalities covered under Documentation, the screen displays test cases.
  3. To navigate back to the Pipeline SCP-NewFeatures screen, click the Back to SCP-NewFeatures link available in the upper left corner of the screen.
4.5.4 SCP-Regression Pipeline
This section describes how to configure regression pipeline parameters, run SCP test cases, and view functionalities.
4.5.4.1 Configuring Regression Pipelines
This pre-configured pipeline has all the test cases from previous releases.
  1. Click SCP-Regression Pipeline:
    Figure 4-57 SCP-Regression Pipeline
    According to the installation guide, the configuration parameters can be modified in the ocats_ocscp_values.yaml file before deployment. If you are running SCP-Regression pipeline test cases for the first time without enabling the parameters in the deployment file, you have to set the input parameters before running the test cases. Subsequent test case run does not require any input unless there is a need to change any configuration.
  2. In the left navigation pane, click Configure to provide input parameters and scroll-down to the pipeline script as shown in the following image:
    Figure 4-58 Regression - Pipeline Script
  3. Modify the values of the Pipeline script as required, and then click Save.
    Parameter "-I" should be changed as part of "Pipeline script". The content of the pipeline script is as follows:
    node ('built-in'){
            withEnv([
        sh '''
            -a SCP \
            -b scpsvc \
            -c cluster.local \
            -d scpsvc \
            -f 60 \
            -g 10 \
            -h ocscp-scp-worker \
            -i ocscp-scpc-configuration \
            -j ocscp-scpc-notification \
            -k ocscp-scpc-subscription \
            -l appuser-secret \
            -m mysql.default.svc.cluster.local \
            -n ocats-pystub:tag \
            -o 0.5 \
            -p 0.5G \
            -q ocscp-scpc-audit \
            -r 0 \
            -s 8000 \
            -t occne-prometheus-server.occne-infra \
            -u 80 \
            -v 300 \
            -w /api/ \
            -x 120 \
            -z 0 \
            -A occne-opensearch-cluster-master.occne-infra \
            -B 9200 \
            -C no \
            -D opensearch \
            -E 9443 \
            -F ocscp-scp-nrfproxy \
            -H scpsvc \
            -K 8081 \
            -L v1 \
        if(env.Include_NewFeatures && "${Include_NewFeatures}" == "YES"){
        else{
            load "/var/lib/jenkins/ocscp_tests/jenkinsData/Jenkinsfile-Regression"
    • a: Selected NF
    • r: re-run count
    • t: PROMSVCNAME with which prometheus server is deployed. Note: Prometheus service name is followed by namepsace in which Prometheus service is existing. Prometheus service is in a different namespace related to deployed SCP namespace.
    • u: PROMSVCPORT with which prometheus server is deployed
    • w: API URI of Prometheus (/api/) - Use "/api/" or "/prometheus/api/"
    • D: Opensearch API Path Prefix
    • K: port of configuration pod in scp deployment
    • M: scp worker FQDN or cluster IP. The default value is scpSignallingFqdn, which forwards requests to the worker using the worker FQDN. Alternatively, an IPv4 or IPv6 address (enclosed in square brackets) can also be provided.
4.5.4.2 Running Regression Pipelines
This section describes how to run test cases for SCP Regression pipeline.
  1. To run the pipeline, click Build with Parameters in the left navigation pane.
  3. Select the required regression option from the Features drop-down menu to run the test cases:
    • All: To run all the test cases for SCP based on Release15 or Release16 selection. This runs all the cases except SCP_Audit_nnrf_disc. If SCP is deployed with nnrf-disc for audit or registration with NRF is disabled, then the All option should not be used and instead Single or MultipleFeatures option can be used to select appropriate cases.
    • Sanity: Enabled for SCP. Sanity cases are run to do a quick sanity check on SCP SUT features. Sanity cases are included in the regression suite and are tagged with @sanity.
    • Select: This option allows users to separately select specific features for separate test case run. Additionally, users can select the run for an entire stage or group instead of running all feature files.
  5. Select an appropriate option and click Build to run the test case.
  7. Hover over the Execute-Tests stage of the pipeline, and then click Logs to check test case results and logs.
4.5.5 SCP-Regression Documentation
  1. To view SCP functionalities, go to the SCP-Regression pipeline and click the Documentation option in the left navigation pane. It lists all the test cases provided as part of SCP ATS -25.1.201.
    The Documentation option appears only if the SCP-Regression pipeline test cases are run at least once.
    In SCP 24.1.0, the feature files are renamed as per the naming convention. For more information, see Renaming of Regression Feature Files
    Figure 4-59 SCP-Regression Documentation
    Figure 4-60 Sample Scenario
    Sample Scenario
  3. To navigate back to the Pipeline SCP-Regression screen, click the Back to SCP-Regression link available in the upper left corner of the screen.
4.5.5.1 Renaming of Regression Feature Files
The following tables detail the feature file that has been renamed in alignment with the naming convention:
Table 4-3 Regression Feature File
Feature Names prior to SCP 24.1.0 New Feature Names for SCP 24.1.0
Route_group_static_config_api_validation SCP_AlternateRoutingUsingStaticConfig_API_P0
Alternate_Routing_Using_Static_Config_EgressRL_SMF SCP_AlternateRoutingUsingStaticConfig_EgressRL_SMF_P0
Alternate_Routing_Using_Static_Configuration_Https_SMF SCP_AlternateRoutingUsingStaticConfig_HTTPS_SMF_P0
Alternate_Routing_Using_Static_Configuration_Notification_CircuitBreaking. SCP_AlternateRoutingUsingStaticConfig_NotificationMessageCircuitBreaking_P0
Alternate_Routing_Using_Static_Configuration_SMF SCP_AlternateRoutingUsingStaticConfig_SMF_P0
Alternate_Routing_Using_Static_Config_Overload_Control SCP_AlternateRoutingUsingStaticConfig_OverloadControl_P0
SCP_Audit_nnrf_disc_SMF SCP_Audit_nnrf-disc_SMF_P0
SCP_Audit_nnrf_nfm_SMF SCP_Audit_nnrf-nfm_SMF_P0
SCP_Audit_nnrf_nfm_SMF_user_agent SCP_Audit_nnrfnfmSCPsUserAgentHeaderValidation_P0
Dns_Srv_Call_Back_Notification_CD_OD_Cases SCP_CallBackNotification_DNSSRVbasedCBOD_P0
Callback_And_Notification SCP_CallBackNotification_P0
SCP_CCA_Header_Validation_API_P0 SCP_CCAvalidation_API_P0
CCA_validation_AUSF_P0 SCP_CCAvalidation_AUSF_P0
CCA_validation_AUSF_P1 SCP_CCAvalidation_AUSF_P1
CCA_validation_InterPLMN_CHF_P0 SCP_CCAvalidation_InterPLMNRouting_CHF_P0
CCA_validation_InterSCP_CHF_P0 SCP_CCAvalidation_InterSCP_CHF_P0
CCA_validation_ModelD_CHF_P0 SCP_CCAvalidation_ModelD_CHF_P0
CCA_validation_ModelD_CHF_P1 SCP_CCAvalidation_ModelD_CHF_P1
SCP_Circuit_Breaking_Config_API SCP_CircuitBreaking_ConfigAPI_P0
Circuit_Breaking_PCF SCP_CircuitBreaking_PCF_P0
Circuit_Breaking_SMF SCP_CircuitBreaking_SMF_P0
SCP_Congestion_Control_Config_API SCP_CongestionControl_ConfigAPI_P0
S_Correlation_Header_interplmn_model_C SCP_CorrelationHeader_InterPLMNModelC_P0
Correlation_Headersepp_model_D_Inter_PLMN_and_Mediation SCP_CorrelationHeader_InterPLMNRoutingBasedOnModelDandMediation_P0
Interscp_Correlation_Header_model_C SCP_CorrelationHeader_InterSCP_P0
Correlation_Header_model_C_cases SCP_CorrelationHeader_ModelC_P0
Notification_Correlation_Header_model_C SCP_CorrelationHeader_ModelCNotificationRequest_P0
Correlation_Header_SCP_generated_error SCP_CorrelationHeader_SCPGeneratedError_P0
DefaultNotificationCallbackInitialRouteAndDiscovery_p0 SCP_DefaultNotificationCallback_InitialRouteAndDiscovery_P0
Dns_Srv_Call_Back_Notification_Https SCP_DefaultNotificationCallbackUri_DNSSRV_HTTPS_P0
Dns_Srv_Call_Back_Notification SCP_DefaultNotificationCallbackUri_DNSSRV_P0
DefaultNotificationCallbackUriModelC_Https_p1 SCP_DefaultNotificationCallbackUri_ModelC_HTTPS_P1
DefaultNotificationCallbackUriModelC_p0 SCP_DefaultNotificationCallbackUri_ModelC_P0
DefaultNotificationCallbackUriModelC_p1 SCP_DefaultNotificationCallbackUri_ModelC_P1
DefaultNotificationCallbackUriModelC_CB_p0 SCP_DefaultNotificationCallbackUri_ModelCCB_P0
DefaultNotificationCallbackUriModelC_SEPP_p1 SCP_DefaultNotificationCallbackUri_ModelCInterPLMNRouting_P1
Alternate_resolution_api_validation SCP_DNSSRV_AlternateResolution_API_P0
Dns_Srv_Based_Routing_For_ModelC_Headers_PCF_cases SCP_DNSSRV_ModelCHeaders_PCF_P0
Dns_Srv_Based_Routing_For_ModelC_Headers_UDM_cases SCP_DNSSRV_ModelCHeaders_UDM_P0
Dns_Srv_Producer_Overload_Control SCP_DNSSRV_ProducerBasedOverloadControl_P0
Alert_egress_congestion_based_on_producer_load_and_message_priority_CHF SCP_EgressCongestionBasedOnProducerLoad_AlertMessagePriority_CHF_P0
Egress_congestion_based_on_producer_load_and_message_priority_PCF SCP_EgressCongestionBasedOnProducerLoad_MessagePriority_PCF_P0
Egress_congestion_based_on_producer_load_and_message_priority_UDM SCP_EgressCongestionBasedOnProducerLoad_MessagePriority_UDM_P0
SCP_Egress_Host_Preference_alternate_routing_SMF_P0_P1 SCP_EgressHostPreference_AlternateRouting_SMF_P1
SCP_Egress_Host_Preference_alternate_routing_withoutHeader_AUSF_P1 SCP_EgressHostPreference_AlternateRoutingWithoutHeader_AUSF_P1
SCP_Egress_Host_Preference_API_P0 SCP_EgressHostPreference_API_P0
SCP_Egress_Host_Preference_CHF_P0 SCP_EgressHostPreference_CHF_P0
SCP_Egress_Host_Preference_CHF_P1 SCP_EgressHostPreference_CHF_P1
SCP_Egress_Host_Preference_InterPLMN_Routing_P0 SCP_EgressHostPreference_InterPLMNRouting_P0
SCP_Egress_Host_Preference_InterPLMN_Routing_P1 SCP_EgressHostPreference_InterPLMNRouting_P1
SCP_Egress_Host_Preference_InterPLMN_Routing_Non_ASM_P0 SCP_EgressHostPreference_InterPLMNRoutingNonASM_P0
SCP_Egress_Host_Preference_InterSCP_Routing_CHF_P0 SCP_EgressHostPreference_InterSCPRouting_CHF_P0
SCP_Egress_Host_Preference_InterSCP_Routing_CHF_P1 SCP_EgressHostPreference_InterSCPRouting_CHF_P1
SCP_Egress_Host_Preference_InterSCP_Routing_CHF_Non_ASM_P0 SCP_EgressHostPreference_InterSCPRoutingNonASM_CHF_P0
SCP_Egress_Host_Preference_ModelD_routing_CHF_NRF_P0 SCP_EgressHostPreference_ModelDRoutingCHF_NRF_P0
SCP_Egress_Host_Preference_ModelD_routing_CHF_NRF_P1 SCP_EgressHostPreference_ModelDRoutingCHF_NRF_P1
SCP_Egress_Host_Preference_ModelD_routing_without_apiRootHdr_CHF_NRF_P1 SCP_EgressHostPreference_ModelDRoutingWithoutAPIRootHdrCHFandNRF_P1
SCP_Egress_Host_Preference_Notification_PCF SCP_EgressHostPreference_NotificationRequest_PCF_P0
SCP_Egress_Host_Preference_SCP_Generated_Audit_SMF_NRF_P1 SCP_EgressHostPreference_SCPGeneratedAuditSMF_NRF_P1
SCP_Egress_Host_Preference_SMF_P0_P1 SCP_EgressHostPreference_SMF_P1
SCP_Egress_Host_Prefrence_SCP_Generated_Subscription_SCP_NRF_P1 SCP_EgressHostPrefrence_SCPgeneratedSubscription_NRF_P1
Alert_SCPEgressTrafficRateExceededConfiguredLimit_AUSF SCP_EgressRateLimiting_AlertTrafficRateExceededConfiguredLimit_AUSF_P0
Alert_SCPEgressTrafficRoutedWithoutRateLimitTreatment_AUSF SCP_EgressRateLimiting_AlertTrafficRoutedWithoutRateLimitTreatment_AUSF_P0
Egress_Rate_Limiting_Config_API SCP_EgressRateLimiting_Config_API_P0
EgressRateLimiting_INTERSCP SCP_EgressRateLimiting_InterSCP_P0
EgressRateLimiting SCP_EgressRateLimiting_P0
EgressRateLimiting_UDM_Cases SCP_EgressRateLimiting_UDM_P0
RateLimitingRelease16_AUSF SCP_EgressRateLimitingRelease16_AUSF_P0
SCP_EgressRateLimiting_DNSSRV.feature SCP_EgressRateLimiting_DNSSRV_P0.feature
Enhanced_Suspended_State_Routing_API_Validation SCP_EnhancedSuspendedStateRouting_API_P0
Enhanced_Suspended_State_Routing_Alternate_Routing_Using_Static_Config_DNS_SRV SCP_EnhancedSuspendedStateRouting_ARusingStaticConfigandDNSSRV_P0
Enhanced_Suspended_State_Routing_Inter_PLMN SCP_EnhancedSuspendedStateRouting_InterPLMNRouting_P0
Enhanced_Suspended_State_Routing_Mode2_API_Validation_P0 SCP_EnhancedSuspendedStateRouting_Mode2_API_P0
Enhanced_Suspended_State_Routing_Mode2_Alternate_Routing_Using_Static_Config_DNS_SRV_P0 SCP_EnhancedSuspendedStateRouting_Mode2AlternateRoutingStaticConfigDNSSRV_P0
Enhanced_Suspended_State_Routing_Mode2_ModelC_SMF_P1 SCP_EnhancedSuspendedStateRouting_Mode2ModelC_SMF_P1
Enhanced_Suspended_State_Routing_Mode2_ModelC_Inter_PLMN_P0 SCP_EnhancedSuspendedStateRouting_Mode2ModelCInterPLMN_P0
Enhanced_Suspended_State_Routing_Mode2_ModelC_InterSCP_P0 SCP_EnhancedSuspendedStateRouting_Mode2ModelCInterSCP_P0
Enhanced_Suspended_State_Routing_Mode2_ModelC_Overload_Congestion_SMF_P1 SCP_EnhancedSuspendedStateRouting_Mode2ModelCOverloadCongestion_SMF_P1
Enhanced_Suspended_State_Routing_Mode2_ModelD_P0 SCP_EnhancedSuspendedStateRouting_Mode2ModelD_P0
Enhanced_Suspended_State_Routing_Mode2_ModelD_Inter_PLMN_P0 SCP_EnhancedSuspendedStateRouting_Mode2ModelDInterPLMNRoutin_P0
Enhanced_Suspended_State_Routing_Mode2_ModelD_InterSCP_P0 SCP_EnhancedSuspendedStateRouting_Mode2ModelDInterSCP_P0
Enhanced_Suspended_State_Routing_ModelC_SMF SCP_EnhancedSuspendedStateRouting_ModelC_SMF_P0
Enhanced_Suspended_State_Routing_Parallel_ModelC_SMF_UDM_P0 SCP_EnhancedSuspendedStateRouting_ModelC_SMFandUDM_P0
Enhanced_Suspended_State_Routing_ModelC_UDM SCP_EnhancedSuspendedStateRouting_ModelC_UDM_P0
Enhanced_Suspended_State_Routing_Model_C_Inter_SCP SCP_EnhancedSuspendedStateRouting_ModelCInterSCP_P0
Enhanced_Suspended_State_Routing_ModelD SCP_EnhancedSuspendedStateRouting_ModelD_P0
Enhanced_Suspended_State_Routing_ModelD_InterSCP SCP_EnhancedSuspendedStateRouting_ModelDInterSCP_P0
Enhanced_NF_Status_Processing_SUSPENDED SCP_EnhancedSuspendedStateRouting_SuspendedMode2_P0
Enhanced_NF_Status_Processing_SUSPENDED_SMF SCP_EnhancedSuspendedStateRouting_SuspendedMode2_SMF_P0
Enhanced_NF_Status_Processing_UNDISCOVERABLE SCP_EnhancedSuspendedStateRouting_UNDISCOVERABLE_P0
SCP_Error_Profile_Config_API_P0 SCP_ErrorProfile_ConfigAPI_P0
SCPFailureHandling_default_behavior_serverheader_AUSF SCP_FailureHandling_DefaultBehaviorServerHeader_AUSF_P0
SCPFailureHandling_default_behavior_serverheader SCP_FailureHandling_DefaultBehaviorServerHeader_P0
SCPFailureHandling_DNSSRV_based_EnhancedServerHeaderV2_NEF_p0 SCP_FailureHandling_DNSSRVbasedEnhancedServerHeaderV2_NEF_P0
SCPFailureHandling_EnhancedServerHeader SCP_FailureHandling_EnhancedServerHeader_P0
SCPFailureHandling_EnhancedServerHeaderV2_API SCP_FailureHandling_EnhancedServerHeaderV2_API_P0
SCPFailureHandling_EnhancedServerHeaderV2_p0 SCP_FailureHandling_EnhancedServerHeaderV2_P0
SCPFailureHandling_EnhancedServerHeaderV2_p1 SCP_FailureHandling_EnhancedServerHeaderV2_P1
FailureHandling_InterSCP_EnhancedServerHeader SCP_FailureHandling_InterSCPEnhancedServerHeader.P0
FormUrlEncoded SCP_FormUrlEncoded_P0
Global_Egress_Rate_Limiting_Config_API SCP_GlobalEgressRateLimiting_API_P0
GlobalEgressRateLimiting_P0 SCP_GlobalEgressRateLimiting_P0
SCP_HealthCheck_Support_API_P0 SCP_HealthCheckSupport_API_P0
SCP_HealthCheck_Support_HTTPS_P0 SCP_HealthCheckSupport_HTTPS_P0
SCP_HealthCheckInterSCPModelC_HTTPS_P0 SCP_HealthCheckSupport_InterSCPModelC_HTTPS_P0
SCP_HealthCheckInterSCPModelC_P0 SCP_HealthCheckSupport_InterSCPModelC_P0
SCP_HealthCheckInterSCPModelD_P0 SCP_HealthCheckSupport_InterSCPModelD_P0
Alert_SCPIngressTrafficRateExceededConfiguredLimit SCP_IngressRateLimiting_AlertTrafficRateExceededConfiguredLimit_P
Alert_SCPIngressTrafficRoutedWithoutRateLimitTreatment SCP_IngressRateLimiting_AlertTrafficRoutedWithoutRateLimitTreatment_P0
Ingress_Rate_Limiting_Config_API SCP_IngressRateLimiting_API_P0
Ingress_Rate_Limiting_Config_API_SC1 SCP_IngressRateLimiting_ConfigAPI_P0
Ingress_Rate_Limiting_Config_API_enhancement_for_nfInstanceId SCP_IngressRateLimiting_ConfigAPIenhancementNFInstanceId_P0
Ingress_Rate_Limiting_enhancement_for_nfInstanceId_to_support_UserAgentHeader SCP_IngressRateLimiting_NFInstanceIdEnhancementUserAgentHeader_P0
SEPP_Audit_nnrf_nfm SCP_InterPLMNRouting_Audit_nnrf-nfm_P0
SCP-SEPP_ModelD_Routing SCP_InterPLMNRouting_ModelDBased_P0
SEPP_Routing_NRF SCP_InterPLMNRouting_NRF_P0
OutlierDetectionSepp_P0 SCP_InterPLMNRouting_OutlierDetection_P0
SCP-SEPP_Routing SCP_InterPLMNRouting_P0
SEPP_plmnInfo_DELETE_API SCP_InterPLMNRouting_PLMNInfoDeleteAPI_P0
SEPP_plmnInfo_GET_API SCP_InterPLMNRouting_PLMNInfoGetAPI_P0
SEPP_plmnInfo_PATCH_API SCP_InterPLMNRouting_PLMNInfoPatchAPI_P0
SEPP_plmnInfo_PUT_API SCP_InterPLMNRouting_PLMNInfoPutAPI_P0
SCP-SEPP_Routing_UDM SCP_InterPLMNRouting_UDM_P0
Rel16_Inter_SCP_Audit_nnrf_nfm_p0 SCP_InterSCP_Audit_nnrf-nfm_P0
InterSCP_MateInfoListRouting SCP_InterSCP_MateInfoListRouting_P0
Inter_SCP_Routing_NplusK_p0 SCP_InterSCP_NplusKRouting_P0
Inter_SCP_Subscription_SMF_NRF SCP_InterSCP_SubscriptionWithForeignNRFforNfTypeSMF_P0
Inter_SCP_Routing SCP_InterSCPRouting_P0
Jaeger_Api_Validation SCP_Jaeger_API_P0
SCP_LCI_Support_Config_API SCP_LCIsupport_API_P0
Scp_Lci_Support_InterPLMN SCP_LCIsupport_InterPLMNRouting_P0
SCP_Lci_Support_InterSCP SCP_LCIsupport_InterSCP_P0
SCP_Lci_Support_InterSCP_PCF_SCP SCP_LCIsupport_InterSCP_PCF_P0
SCP_Lci_Support_InterSCP_UDM SCP_LCIsupport_InterSCP_UDM_P0
SCP_Lci_Support_Miscellaneous SCP_LCIsupport_Miscellaneous_P0
Scp_Lci_Support_ModelD SCP_LCIsupport_ModelD_P0
Scp_Lci_Support_ModelD_notification_cases SCP_LCIsupport_ModelDNotificationRequest_P0
SCP_Lci_Support SCP_LCIsupport_P0
Local_N_Plus_K SCP_LocalNplusK_P0
Location_hdr_update_for_host_mismatch_API_validation Location_hdr_update_for_host_mismatch_API_validation
App_Routing_Options_Config_API SCP_Mediation_AppRoutingOptionsConfig_API_P0
SCP_Mediation_Config_API SCP_Mediation_ConfigAPI_P0
SCP_Mediation_Worker_side_cases_PCF_Cases SCP_Mediation_FunctionalCases_PCF_P0
SCP_Mediation_Cases_AUSF SCP_Mediation_FunctionalCasesPart1_AUSF_P0
SCP_Mediation_Worker_side_cases_AUSF SCP_Mediation_FunctionalCasesPart2_AUSF_P0
SCP_Mediation_Worker_side_cases_UDM_SMF SCP_Mediation_FunctionalTestCases_UDMandSMF_P0
SCP_Mediation_Worker_side_cases_UDM_AUSF_SMF_Notification_cases SCP_Mediation_FunctionalTestCasesForUDMnAUSFnSMFnNotificationRequest_P0
SCP_Mediation_Cases_PCF SCP_Mediation_PCF_P0
Alert_SCPRoutingFailedForProducer_CHF SCP_ModelC_AlertSCPRoutingFailedForProducer_CHF_P0
ModelC_allheaderRequest SCP_ModelC_AllHeaderRequest_P0
PCF_AMPolicy_forwardRoute_Target_apiRoot SCP_ModelC_AMPolicyTargetAPIRoot_PCF_P0
ModelC_CatchAll_Routing_Configuration_AUSF SCP_ModelC_CatchAllRoutingConfiguration_AUSF_P0
ModelC_Direct_Routing_Configuration_AUSF SCP_ModelC_DirectRoutingConfiguration_AUSF_P0
ModelC_ProducerOverloadControl SCP_ModelC_EgressCongestionBasedOnProducerLoad_P0
Egress_Congestion_based_on_load_PCF_SMPolicy_forwardRoute_Target_apiRoot SCP_ModelC_EgressCongestionBasedOnProducerLoad_PCF_P0
Https_Routing_For_ModelC_Headers SCP_ModelC_HTTPS_P0
ModelC_IngressRateLimiting SCP_ModelC_IngressRateLimiting_P0
Model-C_based_Inter_SCP_Routing SCP_ModelC_InterSCProuting_P0
ModelC_Inter_SCP_Routing_Options_Notification_Cases SCP_ModelC_InterSCPRoutingOptionsNotificationCases_P0
InterSCP_VersionSupport SCP_ModelC_InterSCPVersionSupport_P0
ModelC_NFInstance_AUSF_Cases SCP_ModelC_NFInstance_AUSF_P0
ModelC_NFInstance_NEF_Cases SCP_ModelC_NFInstance_NEF_P0
NF_Notification SCP_ModelC_NFprofileNotificationWithMultipleVersions_P
ModelC_NFSet_NEF_Cases SCP_ModelC_NFSet_NEF_P0
ModelC_NFSet_PCF_Cases SCP_ModelC_NFSet_PCF_P0
ModelC_NFSet_SMF_Cases SCP_ModelC_NFSet_SMF_P0
ModelC_ReverseLookup_CHF_Cases SCP_ModelC_ReverseLookup_CHF_P0
ModelC_ReverseLookup_UDM_Cases SCP_ModelC_ReverseLookup_UDM_P0
ModelC_ReverseLookup_UDR_Cases SCP_ModelC_ReverseLookup_UDR_P0
ModelC_Inter_SCP_Routing_Options SCP_ModelC_RoutingOptionsInterSCP_P0
AUSF_AUTH_forwardRoute_Target_apiRoot SCP_ModelC_TargetAPIRoot_AUSF_P0
CHF_SLC_forwardRoute_Target_apiRoot SCP_ModelC_TargetAPIRoot_CHF_P0
SMF_forwardRoute_Target_apiRoot SCP_ModelC_TargetAPIRoot_SMF_P0
UDM_SDM_forwardRoute_Target_apiRoot SCP_ModelC_TargetAPIRootSDM_UDM_P0
UDM_UECM_forwardRoute_Target_apiRoot SCP_ModelC_TargetAPIRootUECM_UDM_P0
Version_support SCP_ModelC_VersionSupport_P0
ModelD_Config_API SCP_ModelD_API_P0
ModelD_enforceReqSpecificSvcDiscovery SCP_ModelD_EnforceReqSpecificSvcDiscovery_P0
ModelD_based_Routing_implicit_notification_p0 SCP_ModelD_ImplicitNotificationRouting_P0
ModelD_based_Routing SCP_ModelD_Routing_P0
Notification_Patch_Profile_Support_SMF SCP_NotificationRequest_PatchProfileSupport_SMF_P0
SCP_Oauth2_Access_Token_Granularity_Config_API_P0 SCP_Oauth2Support_AccessTokenGranularity_API_P0
SCP_Oauth2_Support_Alternative_Config_ModelD_SMF_NRF_P0 SCP_Oauth2Support_AlternativeConfigModelD_SMFandNRF_P0
SCP_Oauth2_Granularity_config_ModelD_SMF_NRF_P0 SCP_Oauth2Support_GranularityConfigModelD_SMFandNRF_P0
SCP_Oauth2_Local-PLMN-required-config_API_P0 SCP_Oauth2Support_LocalPLMNRequiredConfig_API_P0
SCP_OAuth2_support_ModelC_CHF_P0 SCP_Oauth2Support_ModelC_CHF_P0
Scp_Oauth2_Support_ModelC_SMF_NRF_P0 SCP_Oauth2Support_ModelC_SMFandNRF_P0
SCP_OAuth2_Support_Config_API_P0 SCP_OAuth2Support_ConfigAPI_P0
SCP_Oauth2_Support_ModelC_Error_Handling_CHF_NRF_P1 SCP_Oauth2Support_ModelCErrorHandling_CHFandNRF_P1
SCP_Oauth2_Support_ModelD_SMF_NRF_P0_P1 SCP_Oauth2Support_ModelD_SMFandNRF_P1
SCP_Oauth2_Support_ModelD_interSCP_P0 SCP_Oauth2Support_ModelDinterSCP_P0
SCP_Oauth2_NRF_Configuration_Config_API_P0 SCP_Oauth2Support_NRFConfiguration_API_P0
SCP_Observability_And_Inter_Microservice_Resilience_P0 SCP_ObservabilityAndInterMicroserviceResilience_P0
SCP_OutlierDetection_API SCP_OutlierDetection_API_P0
OutlierDetectionInterSCP_P0 SCP_OutlierDetection_InterSCP_P0
OutlierDetectionProducer_AUSF_P0 SCP_OutlierDetection_ProducerAUSF_P0
PseudoHeadersModification SCP_PseudoHeadersModification_P0
PseudoHeadersModificationHttps SCP_PseudoHeadersModification_HTTPS_P0
NRF_Registration SCP_RegistrationWithNRF_P0
SCP_Registration_With_PLMNList SCP_RegistrationWithNRF_PLMNList_P0
Scp_profile_mateScpInfo_update SCP_RegistrationWithNRF_ProfileMateSCPInfoUpdate_P0
Rel16_Canary_support_PCF_Cases SCP_Rel16CanarySupport_PCF_P0
Rel16_Canary_support_SMF_Cases SCP_Rel16CanarySupport_SMF_P0
Rel16_Canary_support_UDM_Cases SCP_Rel16CanarySupport_UDM_P0
Re_routing_based_on_configurable_http_status_codes_api_validation_p0 SCP_ReroutingBasedonConfigurableHttpStatusCodes_API_P0
Re_routing_based_on_configurable_http_status_codes_p0 SCP_ReRoutingBasedOnConfigurableHttpStatusCodes_P0
SCP_Ro_Enhancments_For_CB_CC_SMF_P0 SCP_RoutingOptionEnhancements_CBAndCongestionControl_SMF_P0
SCP_Ro_Enhancments_For_CB_CC_InterSCP_InterPLMN_SMF_PCF_P0 SCP_RoutingOptionEnhancements_CBAndCongestionControlForInterPLMNandSCPRouting_SMFandPCF_P0
SCP_Ro_Enahancment_For_CC_CB_Notification_PCF_P0 SCP_RoutingOptionEnhancements_CBAndCongestionControlForNotificationReq_PCF_P0
SCP_Notification_Routing_Option_Config_API SCP_RoutingOptionForNotificationReq_API_P0
SCP_Routing_Option_Set_API SCP_RoutingOptionForNotificationReq_RoutingConfigSet_API_P0
Routing_Rules_API_R16 SCP_RoutingRules_R16_API_P0
Sbi_Message_Priority_Config_API SCP_SBImessagePriority_ConfigAPI_P0
SbiMessagePriority CP_SBImessagePriority_P0
SCP_Features_API SCP_SCPFeatures_API_P0
SCP_Generated_Error_Codes_SMF SCPGeneratedErrorCodes_SMF_P0
SCP_Generated_Error_Codes_UDM SCP_SCPGeneratedErrorCodes_UDM_P0
NRF_Subscription SCP_Subscription_SubscriptionWithNRFforNfTypeUDM_P0
Configurataion_Support_For_NEF_services_NEF_P1 SCP_SupportForNEFservices_Configuration_APIs_P1
Support_For_NEF_services_NEF_Enhanced_NF_Status_P0 SCP_SupportForNEFservices_EnhancedSuspendedStateRouting_P0
Support_For_NEF_services_NEF_SEPP_P0 SCP_SupportForNEFservices_InterPLMNRouting_P0
Support_For_NEF_services_NEF_P0 SCP_SupportForNEFservices_NEF_P0
Support_For_NEF_services_NEF_NRF_SCP_p0 SCP_SupportForNEFservices_NRF_P0
Traffic_Feed_REST_API SCP_TrafficFeed_API_P0
TrafficFeed_CB SCP_TrafficFeed_CB_P0
TrafficFeed_Notification SCP_TrafficFeed_NotificationRequest_P0
TrafficFeed_PCF SCP_TrafficFeed_PCF_P0
TrafficFeed_UDM SCP_TrafficFeed_UDM_P0
Consumer_Info_API SCP_UserAgent_ConsumerInfo_API_P0
Scp_User_Agent_Info_API SCP_UserAgent_Info_API_P0
Worker_Pod_Overload_Action_Policy_Config_API SCP_WorkerPodOverLoadControl_ActionPolicy_API_P0
CPUOverloadCtrlByNoAction SCP_WorkerPodOverLoadControl_CPUbasedNoAction_P0
Worker_Pod_Overload_Ctrl_Policy_Config_API SCP_WorkerPodOverLoadControl_CtrlPolicy_API_P0
Worker_Pod_Overload_Discard_Policy_Config_API SCP_WorkerPodOverLoadControl_DiscardPolicy_API_P0
Worker_Traffic_Pod_Overload_P0 SCP_WorkerPodOverLoadControl_PendingTransaction_P0
Worker_Traffic_Pod_Overload_P1 SCP_WorkerPodOverLoadControl_PendingTransaction_P1
API_Worker_Pod_Pending_Transaction_Overload_Config_P0.feature SCP_WorkerPodOverLoadControl_PendingTransactionConfig_API_P0
SCP_1_12_0_Bug_Fixes SCP_1_12_0_BugFixes_P0
SCP_1.9.0_Bug_Fixes_SMF SCP_1.9.0_BugFixes_SMF_P0
SCP_1.9.0_Bug_Fixes_UDR SCP_1.9.0_BugFixes_UDR_P0
SCP_22.2.0_Bug_Fixes_PCF_Cases SCP_22.2.0_BugFixes_PCF_P0
SCP_22.2.0_Bug_Fixes_UDM_Cases SCP_22.2.0_BugFixes_UDM_P0
SCP_22.3.0_Bug_Fixes SCP_22.3.0_BugFixes_P0
SCP_22.3.1_Bug_Fixes SCP_22.3.1_BugFixes_P0
22.4.0_Bug_Fixes SCP_22.4.0_BugFixes_P0
22.4.0_Bug_Fixes_Mediation SCP_22.4.0_Bug_Fixes_Mediation
22.4.4_Bug_Fixes SCP_22.4.4_BugFixes_PCF_P0
23.1.0_Bug_Fixes SCP_23.1.0_BugFixes_P0
23.2.0_Bug_Fixes_HTTPS SCP_23.2.0_BugFixes_HTTPS_P0
23.2.0_Bug_Fixes SCP_23.2.0_BugFixes_P0
The following table displays the ATS Regression feature tests that have been split into SingleIpEndpoint and MultipleIpEndpoint categories, and renamed accordingly:
Table 4-4 ATS Regression Feature Tests
Feature Test Name before Spliting Feature Test Name after Spliting
  • SCP_SupportForNEFservices_SingleIpEndpoint_EnhancedSuspendedStateRouting_P0
  • SCP_SupportForNEFservices_MultipleIpEndpoint_EnhancedSuspendedStateRouting_P0
SCP_RoutingOptionEnhancments_CBAndCongestionControl_SMF_P0
  • SCP_RoutingOptionEnhancments_CBAndCongestionControl_SMF_P0
  • SCP_RoutingOptionEnhancments_SingleIpEndpoint_CBAndCongestionControl_SMF_P0
  • SCP_RoutingOptionEnhancments_MultipleIpEndpoint_CBAndCongestionControl_SMF_P0
SCP_OutlierDetection_AUSF_P0
  • SCP_OutlierDetection_MultipleIpEndpoint_AUSF_P0
  • SCP_OutlierDetection_SingleIpEndpoint_AUSF_P0
  • SCP_Oauth2Support_GranularityConfigModelD_SMFandNRF_P0
  • SCP_Oauth2Support_SingleIpEndpoint_GranularityConfigModelD_SMFandNRF_P0
  • SCP_Oauth2Support_MultipleIpEndpoint_GranularityConfigModelD_SMFandNRF_P0
  • SCP_ModelC_NFInstance_NEF_P0
  • SCP_ModelC_SingleIpEndpoint_NFInstance_NEF_P0
  • SCP_ModelC_MultipleIpEndpoint_NFInstance_NEF_P0
  • SCP_LCIsupport_Miscellaneous_P0
  • SCP_LCIsupport_SingleIpEndpoint_Miscellaneous_P0
  • SCP_LCIsupport_MultipleIpEndpoint_Miscellaneous_P0
  • SCP_EgressHostPreference_SingleIpEndpointInterSCPRoutingNonASM_CHF_P0
  • SCP_EgressHostPreference_MultipleIpEndpointInterSCPRoutingNonASM_CHF_P0
  • SCP_DNSSRV_ModelC_SingleIpEndpoint_PCF_P0
  • SCP_DNSSRV_ModelC_MultipleIpEndpoint_PCF_P0
  • SCP_AlternateRoutingUsingStaticConfig_SMF_P0
  • SCP_AlternateRoutingUsingStaticConfig_SingleIpEndpoint_SMF_P0
  • SCP_AlternateRoutingUsingStaticConfig_MultipleIpEndpoint_SMF_P0
  • SCP_22.3.0_BugFixes_SingleIpEndpoint_P0
  • SCP_22.3.0_BugFixes_MultipleIpEndpoint_P0
4.6 Running SEPP Test Cases using ATS
This section describes how to run SEPP test cases using ATS.
4.6.1 Prerequisites
To run SEPP Test Cases using SEPP ATS 25.1.201, you need to ensure that following prerequisites are fulfilled:
  • Debug container should be DISABLED for all microservices during ATS runs.
  • To run the ATS testcases, the user should not configure any value for apiPrefix key in ocsepp-custom-values.yaml file. It should be empty.
  • The number of replicas of all SEPP microservices pods must be set to 1 as ATS is enabled to perform the metric validations for metrics obtained from a single pod.
  • Create Kubernetes secret with certificates/keys (public and private) for both PLMN and N32 gateways before deploying SEPP.
  • Deploy SEPP 25.1.201 with default helm configurations using helm charts.
  • For ATS execution, deploy SEPP microservices with single replica.
  • Ensure all microservices of SEPP are up and running.
  • Create Kubernetes secret with certificates/keys (public and private) for ATS client and stub server microservices before deploying SEPP ATS.
  • Update ocats_ocsepp_values_25.1.201.yaml file with the latest secrets and certificates.
  • Deploy ATS using helm charts.
  • The user must not initiate a job in two different pipelines at the same time.
  • User must not abort a running job, this may lead to data corruption in the database.
  • The user needs to edit cn32f-svc and pn32f-svc deployment yaml. Set CACHE_REFRESH_TIMEOUT to 1000.
  • User need to set n32cHandshakePlmnIdListValidationEnabled to true in localProfile section of ocsepp-custom-values.yaml file. Or n32cHandshakePlmnIdListValidationEnabled Parameter can also be changed after SEPP deployment by editing cn32c-svc and pn32c-svc deployment yaml.
  • User needs to update the plmnIdList provided in the ATS installation guide to run the ATS testcases.
  • The user needs to edit cn32f-svc and pn32f-svc deployment yaml. Set "TOPOLOGY_HIDING_CACHE_REFRESH_TIMEOUT" to 1000.
  • The user needs to edit cn32f-svc and pn32f-svc deployment yaml. Set "SECURITY_CACHE_REFRESH_TIMEOUT" to 1000.
  • All the features are set to disable by default. Ensure that the features must be disabled while configuring SEPP ATS.
  • The user needs to edit cn32f-svc, pn32f-svc, plmn-egress-gateway, and n32-egress-gateway deployment yaml. Set "REQUEST_TIMEOUT" to 2000.
  • The user needs to edit n32-ingress-gateway deployment yaml. Set "REQUEST_TIMEOUT" to 5000.
  • The user needs to edit configmap of n32-ingress-gateway. Set "requestTimeout" to 5000.
  • The user needs to edit n32-ingress-gateway deployment yaml. SET "IDLE_TIMEOUT" to 5000.
  • The user needs to edit pn32f-svc deployment yaml. SET "EVICT_SAN_HEADER_CACHE_DELAY" to 100.
  • To run the Cat-3 testcases, user must have pre-installed coherence-svc while SEPP installation.
  • For DNS SRV and SOR, plmn-egress-gateway should be deployed in REST mode.
  • To run the DNS SRV testcases, user must have pre-installed alternate-route service while SEPP installation.
  • To run the Load Sharing among Multiple Remote SEPP Nodes testcases, user must have pre-installed alternate-route service while SEPP installation.
  • To run the Egress Rate Limiter testcases user must have enabled the Egress Rate Limiter feature while SEPP deployment. Also set "EgressRateLimiterFlag" to true in ocats_ocsepp_values_25.1.201.yaml.
  • To run the Ingress Rate Limiter testcases user must have enabled the Ingress Rate Limiter feature while SEPP deployment. Also set "IngressRateLimiterFlag" to true in ocats_ocsepp_values_25.1.201.yaml.
  • To run the ATS testcases, user should not configure any value for apiPrefix key in ocsepp-custom-values.yaml file. It should be empty.
  • In ASM mode, set expose_tls_service parameter to false in stubserver section of ocats_ocsepp_values_25.1.201.yaml file.
Custom Folder Implementation
ATS provides custom test case folders (cust_newfeatures, cust_regression and cust_performance) using which you can add new test cases, remove unwanted test cases and modify existing test cases. It does not impact the original product packaged test cases available in the newfeatures, regression and performance folders. For more details, refer to Custom Folder Implementation.
4.6.2 Logging into ATS
Before logging into ATS, you need to ensure that ATS is deployed successfully using Helm charts as shown below:
To modify default log in password, refer to Modifying Login Password.
Figure 4-61 Pods
img/sepp-ats-24.3.0_logging.png
For more information on verifying ATS deployment, see Verifying ATS Deployment.
There are following ways to login to ATS GUI.
  • When an external load balancer (metalLB in case of OCCNE) is available and an external IP Address is provided to the ATS service, login to ATS GUI using <External-IP>:8080.
  • When an external IP Address is not provided to the ATS service, open the browser and provide the external IP Address of the worker node and nodeport of the ATS service to login to ATS GUI.
    In the Verifying ATS Deployment screen, ATS nodeport is highlighted in red as 30076. For more details on ATS deployment, refer to SEPP ATS Installation Procedure.
  • When ATS is installed with TLS enabled:
    • If the external load balancer IP is used in the ssl.conf file to open the ATS GUI then the URL will be "https://<IP>:<https_nodeport>".
    • If the external load balancer IP or worker node IP is not present on the setup, then with the common name provided in the ssl.conf file, the user can open the ATS GUI. The user needs to do the ssh port forwarding and then need to update the common name (CN) in the etc/hosts/ file of the local machine against the localhost IP (127.0.0.1).
    • ATS GUI URL format:
      • https://127.0.0.1:<port-forwarding-port>
      • https://<common name>:<port-forwarding-port>
Open a browser and provide IP Address and port details as <Worker-Node-IP>:<NodePort-of-ATS> (As per the above example: 10.98.101.171:32013). The ATS login screen appears.
Figure 4-62 ATS Login
img/sepp_ats_23.4.0_image2.png
To run ATS:
  • Enter the username as 'seppuser' and password as 'sepppasswd'. Click Sign in. The following screen appears showing pre-configured pipelines for SEPP individually (3 Pipelines).
Figure 4-63 Pre-Configured Pipelines
  • SEPP-NewFeatures: This pipeline has all the test cases that are delivered as part of SEPP ATS.
  • SEPP-Regression: This pipeline has all the test cases of previous releases.
  • SEPP-HealthCheck: This pipeline has the utility to run the helm test functionality.
Currently, SEPP does not have any performance pipeline.
4.6.3 SEPP NewFeatures Pipeline
After identifying the SEPP pipelines, the user needs to do one-time configuration in ATS as per their SUT deployment. In this pipeline, all the new test cases related to SEPP are run. To configure its parameters:
  1. Click SEPP-NewFeatures in the Name column. The following screen appears:
    Figure 4-64 SEPP-NewFeatures Pipeline
    img/screenshot2_25.1.200.png
    In the above screen:
    • Click Configure to configure SEPP-New Features.
    • Click Documentation to view the documented test cases which are part of this SEPP release.
    • Click blue dots inside Build History box to view the success console logs of the "All" and "Sanity" respectively.
    • The Stage View shows pipeline that is already run for the customer reference.
    • Click Open Blue Ocean to view the respective group, re-run logs and the consolidated report summary.
    • Click Abort_Build button to gracefully stop the currently running ATS build.
  2. Click Configure. Users must wait for the page to load completely. Once the page loads completely, click the Pipeline tab to reach the Pipeline configuration as shown below:
    The Pipeline section of the configuration page appears as follows:
Figure 4-65 Pipeline script
Pipeline script
In the above screen, you can change the values of the 'Pipeline script'.
  • The user must not change any other value apart from line number 12 to line 20 and line number 26.
  • User can change only those parameters that are marked as "a" to "h" as per your requirement.
  • A new parameter "p" has been introduced to customize the global wait time for the scale up and scale down of pods test cases. Pods scaling time is different on different setups. Sometimes pods take longer than usual for scaling up or scaling down operations. To handle this situation you can increase the global wait time parameter as required. Recommended value is 60.
  • Recommended value for rerun count is "3".
a: Name of the NF to be tested in capital (SEPP).
b: Config manager service name and namespace
c: Plmn ingress service name and namespace
d: N32 ingress service name and namespace
e: Stub server service name and namespace
f: SEPP Instance ID configured
g: Prometheus hostname and namespace
h: Prometheus port
i: Prometheus API endpoint
j: Re run count
k: ELK wait time before logs are fetched
l: ELK hostname and namespace
m: ELK port
n: Stub log collection enable
o: Type of log collection method ( kubernetes/Elasticsearch)
p: GLOBAL WAIT TIME
Do not change any value if OCCNE cluster is used and SEPP, ATS and STUB are deployed in ocsepp namespace.
  1. Click Save after making necessary changes. The Pipeline SEPP-NewFeatures screen appears.
To run SEPP test cases:
  1. Click the Schedule a Build with parameters icon present on the SEPP-NewFeatures screen in the extreme right column corresponding to SEPP-NewFeatures row. The following screen appears:
    Figure 4-66 SEPP-NewFeatures
    img/screenshot5_25.1.200.png
  2. In the above screen, there is an option Execute_Suite to select SEPP or Roaming_Hub. If you have deployed SUT as SEPP, select SEPP option and if you have deployed SUT as Roaming_Hub, select Roaming_Hub option.
  3. In the above screen, there is an option Configuration_Type to select product/custom configuration.
  4. In the above screen, there are three Select_Option(s), which are:
    • All: This is the default option. It runs all the SEPP test cases. Scroll-down and click Build to run all the test cases.
    • Sanity: It is recommended to run Sanity before running any test case. It ensures all the deployments are done properly.
    • Single/Multiple Feature: This option allows you to select any number of test cases you want to run from total number of test cases available for execution. After selecting the test cases, scroll-down and click Build to run the selected SEPP test cases.
  5. In the above screen, When FilterWithTags option is selected as Yes, GUI offers the following four options, select the required tags from the different tags list and click Submit.
    1. Feature_Include_Tags: The features that contain either of the tags available in the Feature_Include_Tags field are considered for tagging.
    2. Feature_Exclude_Tags: The features that contain neither of the tags available in the Feature_Exclude_Tags field are considered for tagging.
    3. Scenario_Include_Tags: The scenarios that contain either of the tags available in the Scenario_Include_Tags field are considered.
    4. Scenario_Exclude_Tags: The features that contain neither of the tags available in the Scenario_Exclude_Tags field are considered.
  6. Click Abort_Build button to gracefully stop the currently running ATS build.
  7. Click Build to execute the ATS run.
In the above screen, the feature files are now shown in the respective stage and group.
4.6.3.1 Single Click Job Creation for SEPP New Features
Perform the following steps to create the custom pipeline for the new features:
  1. Log in to ATS using network function specific log-in credentials.
  2. Click New Item in the left navigation pane of the ATS application. The following page appears:
    Figure 4-67 New Item Window
    New Item Window
  3. In the Enter an item name text box, enter the job name. Example: <NF-Specific-name>-NewFeatures.
  4. In the Copy from text box, enter the actual job name for which you need single-click execution functionality. Example: <NF-Specific-name>-NewFeatures.
  5. Click OK. You are automatically redirected to edit the newly created job's configuration.
  6. Under the General group, deselect the This Project is Parameterised option.
  7. Under the Pipeline group, make the corresponding changes to remove the 'Active Choice Parameters' dependency.
  8. Provide the default values for the TestSuite, SUT, Select_Option, Configuration_Type, and other parameters, as required, on the BuildWithParameters page.
    Example: Pipeline without Active Choice Parameter Dependency
    node ('built-in'){
    //a = SELECTED_NF b = SEPPCONFIGSVCNAME c = CSEPPIGWNAME d = PSEPPIGWNAME
    //e = SEPPSTUBNAME f = NFINSTANCEID g = PROMSVCIP h = PROMSVCPORT  i= PROMSVCURI j = RERUN_COUNT
    //k = ELK_WAIT_TIME l = ELK_HOSTNAME m = ELK_PORT n = STUB_LOGS  o = LOG_TYPE p = GLOBAL_WAIT_TIME
    withEnv([
     'TestSuite=NewFeatures',
     'Execute_Suite=SEPP',
     'FilterWithTags=true,false',
     'Fetch_Log_Upon_Failure=NO',
     'Select_Features_Option=All',
     'Configuration_Type=Product_Config'
    sh '''
    sh /var/lib/jenkins/ocsepp_tests/preTestConfig.sh \
    -a SEPP \
    -b ocsepp-release-config-mgr-svc.csepp \
    -c ocsepp-release-plmn-ingress-gateway.csepp \
    -d ocsepp-release-n32-ingress-gateway.csepp \
    -e sepp-ats-rel-stubserver.csepp \
    -f 9faf1bbc-6e4a-4454-a507-aef01a101a06 \
    -g prometheus.cne-infra \
    -h 9090 \
    -i /api/ \
    -j 1 \
    -k 10 \
    -l occne-elastic-elasticsearch-master.occne-infra \
    -m 9200 \
    -n yes \
    -o kubernetes \
    -p 5
    if(env.Include_Regression && "${Include_Regression}" == "YES"){
        load "/var/lib/jenkins/ocsepp_tests/jenkinsData/Jenkinsfile-Merged"
    else{
        load "/var/lib/jenkins/ocsepp_tests/jenkinsData/Jenkinsfile-NewFeatures"
  9. Click Save. The ATS application is ready to run TestSuite with 'SingleClick' using the newly created job.
  10. Run the custom pipeline job.
  11. Click the Build Now in the main page for the Custom pipeline job.
Value of j (RERUN_COUNT) = 3 is recommended. But it can be changed as per operator environment.
4.6.4 NewFeatures - Documentation
To view SEPP functionalities, go to SEPP-NewFeatures pipeline and click the Documentation link in the left navigation pane. The following screen appears:
Figure 4-68 Documentation
img/screenshot6_25.1.200.png
Click any functionality to view its test cases and scenarios of each test case. A sample screen is given below:
Sample Feature: CONFIG_SERVICE_API_QUERY_PARAM_VALIDATION
Figure 4-69 Test cases and Scenarios
img/screenshot7_25.1.200.png
Based on the functionalities covered under the documentation, the build Requires parameter screen displays test cases. To navigate back to the Pipeline SEPP-NewFeatures screen, click the Back to SEPP-NewFeatures link available on top left corner of the screen.
4.6.5 SEPP Regression Pipeline
This section describes how to run test cases for SEPP Regression pipeline.
The SEPP_Regression pipeline is a pre-configured pipeline where all the test cases of previous releases are available. For example, for SEPP 25.1.2xx, this pipeline has all the test cases released till SEPP 25.1.1xx.
To view SEPP_Regression pipeline details, perform the following steps:
  1. Click SEPP_Regression in the Name column. The following screen appears:
    Figure 4-70 SEPP Regression
    img/seppats23.1.0_7.png
  2. Click Build with Parameters in the left navigation pane.
  3. Click Documentation to view the documented test cases which are part of this SEPP release.
  4. Click blue dots in the Build History box to view the success console logs of the "All" and "Sanity" respectively.
  5. The Stage View shows pipeline that is already run for the customer reference.
  6. Click Configure to configure SEPP Regression. Users must wait for the page to load completely. Once the page loads completely.
  7. click the Pipeline tab to see the Pipeline configuration.
Copy the required test cases that are available in the SEPP folder and place them appropriately within the custom folder for SEPP_Regression. Reload the page to view the test cases available in the custom Regression folder.
The configuration method and parameters are same as the NewFeatures pipeline.
4.6.5.1 Single Click Job Creation for SEPP Regression Features
  1. Log in to ATS using network function specific log-in credentials..
    Figure 4-71 New Item Window
    New Item Window
    node ('built-in'){
    withEnv([
     'TestSuite=Regression',
     'Configuration_Type=Custom_Config'
    sh '''
    -a SEPP \
    -h 9090 \
    -i /api/ \
    -j 1 \
    -k 10 \
    -m 9200 \
    -n yes \
    -o kubernetes \
    -p 5
    else{
        load "/var/lib/jenkins/ocsepp_tests/jenkinsData/Jenkinsfile-Regression"
4.6.6 SEPP Regression Documentation
This section describes the documentation for SEPP-Regression pipeline.
To view the documentation for any of the SEPP features, on the ATS home page, click SEPP-Regression. Then, click Documentation in the left navigation pane.
The following screen shows all the documentation features:
Figure 4-72 SEPP-Regression documentation
img/seppregression_documentation1.png
The following screen appears if the CN32C_SUCCESS_SECURITY_CAPABILITY_TLS is selected.
Figure 4-73 CN32C_SUCCESS_SECURITY_CAPABILITY_TLS
img/seppregression_documentation2.png
4.6.7 Running SEPP Health Check Pipeline
To run health check on SEPP:
  1. Navigate to SEPP-HealthCheck pipeline and click Configure.
  2. The General tab appears. The user must wait for the page to load completely.
  3. Click the Advanced Project Options tab. Scroll-down to reach the Pipeline configuration section as follows:
    Important:
    Ensure that the page loads completely before you perform any action on it. Do not modify any configuration except the one discussed below.
    Figure 4-74 SEPP-HealthCheck
    img/healthcheck.png
    Do not change any value other than line numbers 17, 18, and 19. You can change the parameters marked as "a","b",and "c" as per user requirement. The parameters details are provided as comments in line number 7, 8, and 9. The parameters description is as follows:
    • a - helm releases [Provide Release Name with Comma Separated if more than 1 ]
    • b - namespace of SUT.
    • c - helm version supported
  4. Click Save. The Pipeline SEPP-HealthCheck page appears.
  5. Click Build Now. This triggers health check for SUT.
Example output:
Started by user seppuser
[Pipeline] Start of Pipeline
[Pipeline] node
Running on Jenkins in /var/lib/jenkins/.jenkins/workspace/SEPP-HealthCheck
[Pipeline] {
[Pipeline] stage
[Pipeline] { (Helm-Test-Init)
[Pipeline] catchError
[Pipeline] {
[Pipeline] sh
+ set +x
export HelmTestRelease=ocsepp-release-naman
export HelmTestNamespace=sepp2
export HelmCmd=helm
[Pipeline] sh
+ export NF=SEPP
+ NF=SEPP
+ /env/bin/python3 /env/lib/python3.9/site-packages/ocnftest_lib/helmtest_with_secret.py
[Pipeline] }
[Pipeline] // catchError
[Pipeline] }
[Pipeline] // stage
[Pipeline] stage
[Pipeline] { (Validate-Helm-Test)
[Pipeline] {
[Pipeline] echo
2022-08-29 05:14:23,045[32m     INFO LOG.HELM-TEST:108 [0m| [32mhelm test ocsepp-release-naman -n sepp2[0m
2022-08-29 05:14:53,006[32m     INFO LOG.HELM-TEST:120 [0m| [32m
LAST DEPLOYED: Wed Aug 24 10:08:10 2022
NAMESPACE: sepp2
STATUS: deployed
REVISION: 1
TEST SUITE:     ocsepp-release-naman-test
Last Started:   Mon Aug 29 05:14:36 2022
Last Completed: Mon Aug 29 05:15:00 2022
Phase:          Succeeded[0m
[Pipeline] }
[Pipeline] }
[Pipeline] // stage
[Pipeline] }
[Pipeline] // node
[Pipeline] End of Pipeline
Finished: SUCCESS
4.7 Running UDR Test Cases using ATS
This section describes how to run UDR test cases using ATS.
4.7.1 Prerequisites
4.7.1.1 Prerequisites for SLF Pipelines
The prerequisites to run SLF pipelines are:
  • Select any one of the following System Under Test (SUT) deployment models, depending on your requirements.
    • Model 1: To run all the scenarios (SUTSuite: 'All') in the SLF-Regression and SLF-NewFeatures pipeline, deploy UDR with the following configurations:
      • Four UDRs like UDR1, UDR2, UDR3, and UDR4 where UDR1 and UDR2 are in segment1 and UDR3 and UDR4 in segment2.
      • Deploy one Provisioning Gateway along with Provisioning Gateway Auditor service.
      • Deploy two NRF-Stubs
      • Deploy one ATS in same namespace as UDRs, ProvGW, NRF-Stubs
      To deploy four UDRs in same namespace as ProvGw, ATS, and NRF stubs, create four secrets, such as each UDR has unique configuration database (configdb), but UDRs in same segment shares the subscriber database.
      Configure the Provisioning Gateway segment so that the UDR1 and UDR3 are preferred SLFs in their segment 1 and segment 2 respectively. You must also deploy bulk import tool, export tool, and OSO.
    • Model 2: To run the SLF-Performance pipeline, deploy UDR with the resources defined in the Resource Requirements section.
      The UDR must be deployed with the following replica counts:
      Table 4-5 Replica Count
      Service name Setup type CPU/Pod Memory/Pod Number of pods
      ingressgateway-sig UDR 6 4 2
      ingressgateway-prov UDR 6 4 2
      nudr-drservice UDR 5 4 2
      nudr-provservice UDR 5 4 2
      The ATS pod must be installed with the following configuration for 1K TPS:
      Table 4-6 ATS Pod Installation for 1K TPS
      ocats-udr ATS 4 6 1
      The ATS pod must be installed with the following configuration for 2K TPS:
      Table 4-7 ATS Pod Installation for 2K TPS
      ocats-udr ATS 8 16 1
      OSO must also be deployed on the same namespace.
      The above configuration is tested for both, constant 1K TPS and varying TPS between 1K and 2K, for a duration of 15 minutes.
    • Model 3: To run the Multi_Site option of the SUTSuite field in the SLF Regression pipeline, deploy two UDRs in two different namespaces having two different cnDBTier with database site replication feature enabled between the two. Provisioning Gateway also needs to be deployed on each namespace. Bulk Import tool and export tool needs to be deployed on first namespace. You must also deploy OSO on each namespace.
4.7.1.1.1 UDR Custom Values File Configuration for SLF Pipelines
This section highlights only the necessary changes to be done in the UDR custom-values.yaml file to run ATS.
  • Deploy UDR in the SLF mode. For more information about UDR installation, see Oracle Communications Cloud Native Core, Unified Data Repository Installation, Upgrade, and Fault Recovery Guide.
  • To configure ASM with UDR (including setting istio-proxy, CPU, and memory), see the ASM Specific Configuration and UDR Configuration Parameters sections in the Oracle Communications Cloud Native Core, Unified Data Repository Installation, Upgrade, and Fault Recovery Guide. The UDR custom-values.yaml file is available with documentation package on MOS.
  • Configure the global section of the OCUDR custom values file as follows:
    global:
      dockerRegistry: <docker-registry>:<docker port>/ocudr
      mysql:
        dbServiceName: <db service to which UDR should be connected>
        port: &dbPortNumber "3306"
        configdbname: &configdbname <config db name>
        dbname: &dbname <subscriber db name>
      createNetworkPolicy: true #only if network policy is supported in the environment. SLF pipeline to validate network policy supports only default policy
      dbCredSecretName: <udr secret name>
      alternateRouteServiceEnable: true
      alternateRouteServiceHost: <udr-helm-release-name>-alternate-route
      performanceServiceEnable: true
      udrServices: "nudr-group-id-map"
      diamGatewayEnable: false
      deploymentMode: &deploymentMode IPv6_IPv4 #If it is intended to run Dual Stack scenarios, else do not modify the default value
      appInfoBaseUrl: "<udr-helm-release-name>-nudr-app-info:5906"
      nrfClientNfManagementEnable: true # value is true for UDR1 deployment; UDR2, UDR3 and UDR4 should be deployed with false
      deploymentNrfClientService:
        envNfNamespace: <namespace where UDR is to be deployed>
      enableControlledShutdown: &enableControlledShutDown true
      serviceMeshCheck: &serviceMeshFlag true #if UDR is intended to be deployed with ASM.
    • If UDR is installed with ASM, then use the annotations defined in the Oracle Communications Cloud Native Core, Unified Data Repository Installation, Upgrade, and Fault Recovery Guide.
    • Database names provided in the SLF custom.values files must match with the names created in the corresponding database secrets.
    • The nfInstanceId for each of SLF must be unique for all model.
  • Update the config-server section as follows:
    config-server:
      fullnameOverride: <udr-helm-release-name>-config-server
  • Update the ingressgateway-sig section as follows:
    ingressgateway-sig:
      global:
        istioIngressTlsSupport:
          ingressGateway: true #only if UDR is being deployed with ASM.
        lciHeaderConfig:
          enabled: true
          loadThreshold: 30
          localLciHeaderValidity: 10000
        svcToSvcInstanceIdMapping:
        - svcName: "<udr-helm-release-name>-nudr-drservice"
          serviceInstanceId: <serviceInstanceId-defined-in-appProfiles-for-nudr-group-id-map>
        xfccHeaderValidation:
          validation:
            enabled: &xfccValidationEnabled true #should be disabled for Model 2 and Model 3.
      serverHeaderDetails:
        enabled: true
      oauthValidatorEnabled: true #should be disabled for model 2 and model 3.
      nrfPublicKeyKubeSecret: <oauth secret name for sig>
      nrfPublicKeyKubeNamespace: <UDR namespace>
      validationType: relaxed
      enableControlledShutdown: true
      controlledShutdownConfigMode: REST
      userAgentHeaderValidationConfigMode: REST
  • Update the ingressgateway-prov section as follows:
    ingressgateway-prov:
      global:
         validation:
           enabled: &xfccValidationEnabled false
        enabled: false
      nrfPublicKeyKubeSecret: <oauth secret name for prov>
      checkContentLength: true
      copyContentLengthFromBody: true
  • Configure targets and ports in the alternate-route.staticVirtualFqdns section with the NRF stubs FQDNs and ports.
    This is applicable only for Model 1.
    alternate-route:
      staticVirtualFqdns:
        - name: http://abc.test.com
          alternateFqdns:
           - target: <stub1 fqdn>
             port: <stub1 port>
             priority: 10
           - target: <stub2 fqdn>
             port: <stub2 port>
             priority: 20
  • Update the appinfo section as follows:
    appinfo:
      dbStatusUri: http://<DB monitoring SVC>:<DB monitoring svc port>/db-tier/status/local
      realtimeDbStatusUri: http://<DB monitoring SVC>:<DB monitoring svc port>/db-tier/status/cluster/local/realtime
      replicationUri: http://<DB monitoring SVC>:<DB monitoring svc port>/db-tier/status/replication
      prometheusUrl: "http://<Prometheus fqdn or IP>:<prometheus port>/<domain-name>/prometheus"
      alertmanagerUrl: "http://<alertmanager fqdn or IP>:<prometheus port>/<domain-name>/alertmanager"
      tagNamespace: kubernetes_namespace # change this field only if it is being deployed with OSO. Please refer to UDR User Guide for more information.
      core_services:
        udr: *slf
      fullnameOverride: <udr-helm-release-name>-app-info
    Run the below curl command from ATS pod to find domain name of OSO:
    curl -i http://<OSO FQDN or IP>:<OSO PORT>/
    Example:
    (env) [jenkins@ocats-udr-5c55f59d66-jkzml ~]$ curl -i http://oso-svr:80/
    HTTP/1.1 302 Found
    Content-Type: text/html; charset=utf-8
    Date: Thu, 20 Apr 2023 06:28:48 GMT
    Content-Length: 48
    <a href="/cne-23-1/prometheus">Found</a>.
    Prometheus URL is http://oso-svr:80/cne-23-1/prometheus.
  • Update the nrf-client section as follows:
    nrf-client:
      profile: |
        #uncomment appProfiles that is dedicated to used for SLF mode (nudr-group-id-map) and comment the rest of the appProfiles.
        enableVirtualNrfResolution=true
        #virtualNrfFqdn value must be same as that of alternate-route.staticVirtualFqdns.name[0] without the url scheme as shown below
        virtualNrfFqdn=abc.test.com
      nrf-client-nfmanagement:
        replicas: 1
        enablePDBSupport: false
  • Update the perf-info section as follows:
    perf-info:
      envMysqlDatabase: <configdb name used for UDR>
      configmapPerformance:
        prometheus: "http://<Prometheus fqdn or IP>:<prometheus port>/<domain-name>/prometheus"
      log:
        level:
          perfinfo: "WARN"
    The values for namespace, container name, and servicename depend on CNE or OSO versions. For information, see Oracle Communications Cloud Native Core, Unified Data Repository User Guide.
  • Update the egressgateway section as follows:
    egressgateway:
      userAgentHeaderConfigMode: REST
  • Configure the following parameters in the bulk-import tool yaml file:
    To test the bulk import tool, it is important to install the bulk import tool as a separate helm deployment in the same namespace as that of UDR. For information about the bulk import tool installation and sample bulk import yaml file, see Oracle Communications Cloud Native Core, Unified Data Repository User Guide. This is applicable for Model 1 only.
    • Ensure the secret is used to install subscriber bulk import tool is same as UDR1. The Bulk Import tool should communicate with UDR1.
      bulk import deployment
      global:
        mysql:
          dbServiceName: "<DB Endpoint provided for UDR deployment>"
          port: "<PORT Used provided UDR deployment>"
        dbCredSecretName: '<UDR1 Secret>'
      xmlToCsv:
        enabled: false
      customExtension:
          allResources:
            labels: {}
            annotations:
              oracle.com/cnc: "true"
      serviceMeshCheck: true #if exprt tool is intended to be deployed with ASM ...
      ocudrReleaseName: '<UDR1 Helm name>'
      • To run the bulk import scenarios, disable xmlToCsv.
      • Subscriber bulk import tool must always be clean installed.
Subscriber Export tool Configuration
Configure the following parameters in the nudr-export-tool yaml file:
To test the subscriber export tool, it is important to install the subscriber export tool as a separate helm deployment in the same namespace as that of UDR. For information about the subscriber export tool, see Subscriber Export Tool section in Oracle Communications Cloud Native Core, Unified Data Repository User Guide.
  • Ensure the secret is used to install the subscriber export tool is same as UDR1. The subscriber export tool should communicate with UDR1.
    Update the nudr-export-tool deployment section as follows
    global:
      mysql:
    sftpDetails:
      sftpExportEnabled: false
    serviceMeshCheck: true #if export tool is intended to be deployed with ASM
    batch:
      corePoolSize: 1
      maxPoolSize: 1
    exportMode: SLF_EXPORT
Subscriber export tool must always be clean installed.
Other configuration details
  • Configure Prometheus with UDR and Provisioning Gateway default alerts. For more information about UDR alerts, see Oracle Communications Cloud Native Core, Unified Data Repository User Guide and for Provisioning Gateway alerts, see Oracle Communications Cloud Native Core, Provisioning Gateway Installation Guide.
  • Certificates used for Provisioning Gateway TLS should be provided in /var/lib/jenkins/ocslf_tests/certs in pod.
  • Create Envoy Filter for both, UDR1 setup and ATS as described in Enabling Service Mesh for XFCC header validation scenarios and server header scenarios if installed with ASM.
  • Create Peer Authentication as described in Enabling Service Mesh and Oracle Communications Cloud Native Core, Unified Data Repository Installation, Upgrade, and Fault Recovery Guide, if installed with ASM.
4.7.1.1.2 Provisioning Gateway Custom Values File Configuration for SLF Pipelines
For more information about Provisioning Gateway installation, see Oracle Communications Cloud Native Core Provisioning Gateway Installation Guide. The ProvGW custom-values.yaml file is available with documentation package on MOS.
  • Update the global section of the ProvGW custom-values.yaml file as follows:
    global:
      dockerRegistry: <docker-registry>:<docker port>/provgw
      mysql:
        configdbname: &configdbname <ProvGw DB name>
        dbname: &dbname <ProvGw DB name>
      usageMode: "SLF"
      udr:
        httpsEnabled: false
        segDetails:
          - name: SEG-1
            fqdnValues: <UDR1 fqdn>,<UDR2 fqdn>
            preferred: <UDR1 fqdn>
          - name: SEG-2
            fqdnValues: <UDR3 fqdn>,<UDR4 fqdn>
            preferred: <UDR3 fqdn>
    Database names provided in the Provisioning Gateway custom values files must match with the names created in the corresponding database secret.
  • Database monitoring fqdn and port must provided under provgw-service:
    provgw-service
    provgw-service:
      probes:
        dbStatusCheckUrl: "http://<DB Monitoring svc>:<DB monitoring port>/db-tier/status/cluster/local/realtime"
  • Enable the auditor-service parameter as follows:
    auditor-service:
      enabled: true
      sftpDetails:
        secrets:
          privatekey:
            name: <private key secret created for SFTP from export tool>
          publickey:
            name: <public key secret created for SFTP from export tool>
      usePersistentVolume: true
      probes:
  • Configure provgw-config as below:
    provgw-config:
      probes:
  • Under the prov-ingressgateway annotations section, set the traffic.sidecar.istio.io/excludeInboundPorts as '8443'.
    Ensure the ssl section has secret names and namespace that are created as part of Transport Layer Security (TLS) support. Set the initssl and enableIncomingHttps parameters as 'true'.
    prov-ingressgateway:
     deployment:
        customExtension:
          labels: {}
          annotations:
            traffic.sidecar.istio.io/excludeInboundPorts: "8443"
        ssl:
          tlsVersion: TLSv1.2,TLSv1.3
          privateKey:
            k8SecretName: <TLS support secret name>
            k8NameSpace: <ProvGw Namespace>
            rsa:
              fileName: <RSA private key pem file>
            ecdsa:
              fileName: <ECDSA private key pem file>
          certificate:
            rsa:
              fileName: <RSA certificate>
            ecdsa:
              fileName: <ECDSA certificate>
          caBundle:
            k8NameSpace: <ProvGw namespace>
            fileName: <caBundle file name>
          keyStorePassword:
            fileName: <key txt file>
          trustStorePassword:
            fileName: <trust txt file>
      initssl: true
      enableIncomingHttps: true
For information about Provisioning Gateway installation and ASM configuration for Provisioning Gateway, see Oracle Communications Cloud Native Core Provisioning Gateway Installation Guide. This section highlights the necessary changes that you are required to do in the Provisioning Gateway custom-values.yaml file to run ATS.
4.7.1.2 Prerequisites for UDR Pipelines
The prerequisites to run UDR pipelines are:
  • Select any one of the following SUT deployment models depending on your requirements.
    • Model 1: Single Site Deployment
      To run UDR-NewFeatures, select SUTSuite: as 'All' and for UDR-Regresssion, select SUTSuite: 'ALL', Features: All (Except UDR_Multisite). For this, you must deploy one UDR, one Provisioning Gateway in UDR mode, two diameter stubs, one Fourg stub, one NOTIFY Stub, two NRF-stubs, one SCP stub, and one ATS in same namespace.
    • Model 2: Multiple Site Deployment: To run UDR-Regression pipeline where SUTSuite: is 'MULTISITE', you must deploy:
      • Two UDRs in two different namespaces that has two different cnDBTier with database site replication enabled between the two.
      • ATS in any one namespace.
      • Namespace-1 with one UDR, two diameter stubs, one Fourg stub, one NOTIFY stub, two NRF-Stubs, one SCP stub, and one ATS.
      • Namespace-2 with one UDR.
4.7.1.2.1 UDR Custom Values File Configuration for UDR Pipelines
This section highlights only the necessary changes that you are required to do in the UDR custom-values.yaml file to run ATS.
For information about UDR installation and ASM configuration for UDR, see the Oracle Communications Cloud Native Core, Unified Data Repository Installation, Upgrade, and Fault Recovery Guide available on My Oracle Support.
  • Update the global section as follows:
    global:
      mysql:
     autoCreateSubscriber: false
      FourGPolicyConfiguration:
        ondemandMigration:
          enabled:  &onDemandMigrationEnabled true
      s13InterfaceEnable: false
        envNfNamespace: <UDR namespace>
      egressHttpsEnabled: &egressHttpsFlag true
    Database names provided in the UDR custom values files must match with the names created in the corresponding database secret.
    ingressgateway-sig:
      global:
        lciHeaderConfig:
          enabled: true
          loadThreshold: 30
         validation:
      service:
        ssl:
          privateKey:
            k8NameSpace: <UDR Namespace>
            rsa:
            ecdsa:
          certificate:
            rsa:
            ecdsa:
          caBundle:
            k8NameSpace: <UDR namespace>
          keyStorePassword:
          trustStorePassword:
        enabled: true
      initssl: true
      oauthValidatorEnabled: &oauthEnabled true
      nrfPublicKeyKubeSecret: <oauth secret name>
      global:
         validation:
      service:
        ssl:
          privateKey:
            rsa:
            ecdsa:
          certificate:
            rsa:
            ecdsa:
          caBundle:
          keyStorePassword:
          trustStorePassword:
        enabled: false
      initssl: true
  • Update the alternate-route section as follows:
    alternate-route:
      staticVirtualFqdns:
          alternateFqdns:
           - target: <nrf stub1 fqdn>
             port: <nrf stub1 port>
             priority: 10
           - target: <nrf stub2 fqdn>
             port: <nrf stub2 port>
             priority: 20
    nrf-client:
      configmapApplicationConfig:
        profile:
          nrfRetryConfig=[{"serviceRequestType":"ALL_REQUESTS","primaryNRFRetryCount":1,"nonPrimaryNRFRetryCount":1,"alternateNRFRetryCount":1,"errorReasonsForFailure":["503","504","500","SocketTimeoutException","JsonProcessingException","UnknownHostException","NoRouteToHostException","IOException"],"gatewayErrorCodes":["503"],"requestTimeout":10},{"serviceRequestType":"AUTONOMOUS_NFREGISTER","primaryNRFRetryCount":1,"nonPrimaryNRFRetryCount":1,"alternateNRFRetryCount":-1,"errorReasonsForFailure":["503","504","500","SocketTimeoutException","JsonProcessingException","UnknownHostException","NoRouteToHostException","IOException"],"gatewayErrorCodes":["503"],"requestTimeout":10}]
  • Update the egressgateway section to run SCP routing and TLS notification scenarios as follows:
    egressgateway:
      global:
        lciHeaderConfig:
          enabled: true
      sbiRouting:
        peerConfiguration:
        - id: peer1
          host: '<scp stub svc and this should match with scp stub expectedAuthorityHeader in scp stub custom values>'
          port: '<scp stub port>'
          apiPrefix: "/"
        peerSetConfiguration:
        - id: set0
          httpConfiguration:
          - priority: 1
            peerIdentifier: peer1
      routesConfig:
      - id: scp_route
        path: /scp/**
        order: 2
        metadata:
           sbiRoutingEnabled: true
      initssl: true
      enableOutgoingHttps: *egressHttpsFlag
      service:
       ssl:
           privateKey:
             rsa:
             ecdsa:
           certificate:
             rsa:
             ecdsa:
           caBundle:
           keyStorePassword:
           trustStorePassword:
    perf-info:
      log:
        level:
          perfinfo: "WARN"
    Formation of Prometheus URL is as below:
    HTTP/1.1 302 Found
    Content-Length: 48
    Prometheus url would be: http://oso-svr:80/cne-23-1/prometheus
    The values for namespace, container name and service name depend on CNE versions. For more information, see Oracle Communications Cloud Native Core, Unified Data Repository User Guide.
  • Update the app-info section as follows:
    appinfo:
    To test the bulk import tool, it is important to install the bulk import tool as part of UDR. For information about Bulk Import tool installation and sample bulk import yaml file, see Oracle Communications Cloud Native Core, Unified Data Repository User Guide.
    • Ensure the secret used to install bulk import tool is same as UDR. Configure the bulk import deployment values.yaml file as follows:
      global:
        mysql:
        dbCredSecretName: '<UDR Secret>'
      batchConfig:
        asynchronous: false
      xmlToCsv:
        enabled: true
      ocudrReleaseName: '<UDR Helm name>'
    • Do not change the containers name. It should be 'nudr-bulk-import' and 'nudr-xmltocsv'.
  • Configure the following parameters in the ocudr_nudr_migration_tool_custom_values.yaml file:
    Migration tool must be installed as a separate helm deployment. For information about Migration tool installation, see "Migration Tool" section in Oracle Communications Cloud Native Core, Unified Data Repository User Guide.
    • Ensure the secret used to install the migration tool is same as UDR. Configure the ocudr_nudr_migration_tool_custom_values.yaml file as follows:
      global:
        mysql:
        preInstall:
          config:
            additionalErrorLogging: ENABLED
            logSubscriberInfo: ENABLED
      fourG:
        realm: "oracle.com"
        identity: "tekelec.oracle.com"
        nodePort: 3000
        nodeHost: "fourgstub-stub-service"
        maxConnectionRetry: 100
      hikari:
        queryTimeout: "-1"
      sourceEndPointURL: 'http://10.75.229.43:3868'
      udrServiceBaseURL: '<UDR Helm name>-ingressgateway-prov:80'
      gracefulShutdown:
        gracePeriod: 30s
  • Configure the following parameters in the ocudr_nudr_export_tool_custom_values.yaml file:
    The subscriber export tool must be installed as a separate helm deployment. For information about Migration tool installation, see "Subscriber Export Tool " section in Oracle Communications Cloud Native Core, Unified Data Repository User Guide.
    • Ensure the secret used to install the subscriber export tool is same as UDR. Configure the ocudr_nudr_export_tool_custom_values.yaml file as follows:
      global:
        mysql:
      createExportToolPVC:
        fileExtension: ".exml"
      sftpDetails:
      batch:
        corePoolSize: 1
        maxPoolSize: 1
      exportMode: EXML_EXPORT
  • Other configuration details:
    • Configure Prometheus with UDR default alerts. For more information about UDR alerts, see Oracle Communications Cloud Native Core, Unified Data Repository User Guide.
    • Certificates used for UDR-TLS should be provided in /var/lib/jenkins/ocudr_tests/certs in ATS pod as defined for severheaderFlag in values.yaml file (must be true during UDR installation). For more information, see Installing ATS for UDR.
4.7.1.2.2 Provisioning Gateway Custom Values File Configuration for UDR Pipelines
For more information about Provisioning Gateway installation and ASM installation for Provisioning Gateway, see Oracle Communications Cloud Native Core Provisioning Gateway Installation Guide. The ProvGW custom-values.yaml file is available with documentation package on MOS. This section highlights only the necessary changes that are required in the ProvGW custom-values.yaml file to run ATS.
    global:
      mysql:
      usageMode: "UDR"
  • Enable the provgw-service parameter as follows:
    provgw-service:
      soapService:
        udrIp: <UDR-Prov fqdn>
        udrSignallingIp: <UDR-Sig Fqdn>
        convertToSec: false
        secEntity: |
          - name: QuotaEntity
          elementString: usage
          innerElemenString: quota
          outerFields:
            - version
            - quota
            - SequenceNumber
          innerFields:
            - name
            - cid
            - time
            - totalVolume
            - inputVolume
            - outputVolume
            - serviceSpecific
            - nextResetTime
            - Type
            - grantedTotalVolume
            - grantedInputVolume
            - grantedOutputVolume
            - grantedTime
            - grantedServiceSpecific
            - QuotaState
            - RefInstanceId
            - custom1
          - name: DynamicQuotaEntity
          elementString: definition
          innerElemenString: DynamicQuota
          outerFields:
            - version
            - DynamicQuota
            - SequenceNumber
          innerFields:
            - Type
            - name
            - InstanceId
            - Priority
            - InitialTime
            - InitialTotalVolume
            - InitialInputVolume
            - InitialOutputVolume
            - InitialServiceSpecific
            - activationdatetime
            - expirationdatetime
            - purchaseddatetime
            - Duration
            - InterimReportingInterval
            - custom1
          - name: Subscriber
          elementString: subscriber
          outerFields:
            - IMSI
            - MSISDN
            - NAI
            - EXTID
            - ACCOUNTID
            - BillingDay
            - Entitlement
            - Tier
            - SequenceNumber
            - custom1
            - custom2
            - custom3
            - custom4
            - custom5
            - custom6
            - custom7
            - custom8
            - custom9
            - custom10
            - custom11
            - custom12
            - custom13
            - custom14
            - custom15
          - name: StateEntity
          elementString: state
          innerElemenString: property
          outerFields:
            - version
            - property
            - SequenceNumber
          innerFields:
            - name
            - value
          - name: CustomEntity
          elementString: customusage
          innerElemenString: customent
          outerFields:
            - version
            - customent
            - SequenceNumber
          innerFields:
            - name
            - custcid
            - custtotal
      probes:
  • Disable auditor-service and configure auditor-service section as follows:
    auditor-service:
      enabled: false
  • Enable the provgw-config section as below:
    provgw-config:
      probes:
  • Under the prov-ingressgateway annotations section, set the routesConfig for provgw-service port as '62001'. Ensure the ssl section has secret names and namespace that are created as part of Transport Layer Security (TLS) support. Set the initssl and enableIncomingHttps parameters as 'true'.
     deployment:
        ssl:
          privateKey:
            rsa:
            ecdsa:
          certificate:
            rsa:
            ecdsa:
          caBundle:
          keyStorePassword:
          trustStorePassword:
      initssl: true
      routesConfig:
      - id: traffic_mapping_rest_group_prov
        uri: http://{{ .Release.Name }}-provgw-service:62001
4.7.1.3 Prerequisites for EIR Pipelines
To run EIR Pipelines, you must deploy one EIR, two NRF-stubs, one ATS, one diam-stub deployed in n5g-eir-eic mode, subscriber bulk import tool, and subscriber export tool in same namespace.
4.7.1.3.1 UDR Custom Values File Configuration for EIR Pipelines
Deploy UDR in the EIR mode. For more information about UDR installation, see Oracle Communications Cloud Native Core, Unified Data Repository Installation, Upgrade, and Fault Recovery Guide. This section highlights only the necessary changes that you are required to do in the UDR custom-values.yaml file to run ATS.
    global:
      mysql:
      udrServices: "n5g-eir-eic"
      diamGatewayEnable: true
  • Update the config-server as follows:
    config-server:
  • Update the ingressgateway-sig as follows:
    ingressgateway-sig:
      global:
        lciHeaderConfig:
          enabled: true
          loadThreshold: 30
         validation:
      service:
        ssl:
          privateKey:
            rsa:
            ecdsa:
          certificate:
            rsa:
            ecdsa:
          caBundle:
          keyStorePassword:
          trustStorePassword:
        enabled: true
      initssl: true
      nfType: 5G_EIR
      producerScope: n5g-eir-eic
  • Update the ingressgateway-prov as follows:
      global:
         validation:
        enabled: false
      initssl: true
      nfType: 5G_EIR
      producerScope: n5g-eir-prov
    alternate-route:
      staticVirtualFqdns:
          alternateFqdns:
             priority: 10
             priority: 20
    appinfo:
      core_services:
        5g_eir: *eir
    nrf-client:
      profile: |
        #uncomment appProfiles that is dedicated to used for EIR mode (n5g-eir-eic) and comment the rest of the appProfiles.
        replicas: 1
    pperf-info:
      log:
        level:
          perfinfo: "WARN"
    The values for namespace, container name, and servicename depend on CNE or OSO versions. For information, see Oracle Communications Cloud Native Core, Unified Data Repository User Guide..
    egressgateway:
  • Update the nudr-diameterproxy to verify diameter S13 scenarios as follow:
    nudr-diameterproxy:
      enabled: true
    To test the subscriber bulk import tool, it is important to install the bulk import tool as a separate helm deployment in the same namespace as that of EIR. For information about the bulk import tool installation and sample bulk import yaml file, see Oracle Communications Cloud Native Core, Unified Data Repository User Guide..
    • Ensure the secret is used to install subscriber bulk import tool is same as EIR. Configure the Bulk Import deployment values.yaml file as follows:
      global:
        mysql:
        dbCredSecretName: '<EIR Secret>'
      batchConfig:
        asynchronous: false
      xmlToCsv:
        enabled: false
      pdbiToCsv:
        enabled: true
      ocudrReleaseName: '<EIRHelm name>'
  • Configure the following parameters in the nudr-export-tool deployment yaml file:
    To test the subscriber export tool, it is important to install the subscriber export tool as a separate helm deployment in the same namespace as that of UDR. For information about the subscriber export tool installation, see Oracle Communications Cloud Native Core, Unified Data Repository User Guide..
    • Ensure the secret is used to install subscriber export tool is same as EIR. Configure the subscriber export tool deployment values.yaml file as follows:
      global:
        mysql:
          dbServiceName: "<DB Endpoint provided for EIR deployment>"
      sftpDetails:
      ocudrReleaseName: '<EIR Helm name>'
      exportMode: EIR_EXPORT
    • Configure Prometheus with EIR default alerts. For more information about EIR alerts, see Oracle Communications Cloud Native Core, Unified Data Repository User Guide.
4.7.2 UDR Golden Configuration Support
The ATS golden configuration feature will facilitate the provisioning of customer specific configuration to run test cases. UDR ATS has been integrated with the ATS golden configuration feature. This feature enables the customer to provide their own configuration and save the configuration once the ATS runs are completed.
When running a test, ATS detects the existence of a <feature_name>.yaml configuration file within the <conf_type>_config directory. ATS will populate the parameterized steps and data files with the values present in the global and feature-specific configuration files. The two configuration types are:
  • Product configuration
  • Custom configuration
You must use the custom_config directory files for provisioning the golden configuration data.
To Configure ATS Golden Configuration
  • Modify the parameter values in the /ocslf_tests/custom_config/global.yaml and/or feature config file (/ocslf_tests/custom_config/<feature>.yaml).
  • Select the custom_config in the jenkins pipeline GUI to run the test cases with data provided in the custom_config directory.
ATS Golden Configuration Directory
ATS golden configuration uses the below directories located within the /var/lib/jenkins/ocslf_tests directory:
  • Parameterized features
    • features/
      • cust_newfeatures/
      • cust_regression/Singlesite/
  • Configuration files
    • custom_config/
      • yaml
      • <feature_name>.yaml
  • Test data
    • cust_data/
New and regression feature configuration files use the same custom_config directory.
ATS Golden Configuration Feature Configuration files
This section describes the ATS golden configuration files:
  • The global.yaml configuration file contains Key-Value pair parameters. The Key-Value pair parameters applies to more than one parameterized feature file.
  • The Key-Value pair parameters in the <feature>.yaml configuration file includes the following fields:
    • subscriber profile data information
    • cust_data payload file values
    • data folder name
    • other feature specific fields
  • The <feature>.yaml file is divided into scenario specific sections, containing Key-Value pair parameters. Each parameter in the parameterized feature file takes values only from its own scenario File_Parameters dictionary. You can use the same parameter name in more than one scenario with different scenario specific values.
  • When goldenConfig.py is running, each feature config yaml contains the global section at the top between #START_GLOBAL and #END_GLOBAL strings.
  • Each SLF <feature>.yaml file allows to make the following changes, if applicable:
    • Use global.yaml anchors to copy the values to scenario specific sections that uses the yalm alias. The data folder name is taken from the global section and is used when a behave step is needed to open a json payload file.
    • Provisioning the subscriber profile data.
    • Overwrite data_folder payload file values. The payload file values will be overwritten in the specified path. The golden configuration feature will overwrite data string with cust_data even if each path is written with the data directory.
    • Provisioning custom values to feature specific fields.
Test data
The test data files includes the json payload files used by each feature. A new cust_data directory, which is a copy of the original data directory, is created to maintain the data directory with product configuration unchanged because the golden configuration feature allows to overwrite data in these json files.
ATS Golden Configuration backup for SLF and Provisioning Gateway
The SLF and Provisioning Gateway backup process is implemented in the before_all and after_all behave hooks to allow ATS pipeline runs to implement feature specific configuration and revert them to the customer specific golden configuration at the end.
ATS Golden Configuration backup Considerations for SLF:
  • Backup will be automatically executed for SLF and Provisioning Gateway deployments.
  • If failure to export SLF or Provisioning Gateway golden configuration, pipeline execution will be aborted and feature test will not be performed.
  • If you fail to import SLF or Provisioning Gateway golden configuration then you are required to manually backup by using 'slfgoldenconfig.zip' and 'provgwgoldenconfig.zip' that is located in ATS pod in the /var/lib/jenkins/ocslf_tests/ directory.
Selective Run of Features and Scenarios
For SLF ATS golden configuration support, test execution of certain features is depended on the values set for fields in the ocslf_tests/custom_config/global.yaml file.
The values provided in the global.yaml must match with the SUT configurations (SLF values.yaml).
#START_GLOBAL
global:
  data_folder: &data_folder cust_data
  # To select an appropriate retries value take from SLF values.yaml the localLciHeaderValidity value (value in
  #   milliseconds) and perform the following formula: (localLciHeaderValidity/5000)+1.
  #   It is recommended to use 6 as the minimum retries value for igw-sig-lciHeaderRequestRetries.
  igw-sig-lciHeaderRequestRetries: &igw-sig-lciHeaderRequestRetries '6'
  # Values provided in this global.yaml should match with the SUT configurations (SLF values.yaml).
  alternateRouteServiceEnable: true #true/false
  performanceServiceEnable: true #true/false
  igw-sig-lciheader-enabled: true #true/false
  igw-sig-oauth-enabled: true #true/false
  igw-sig-userAgentHeaderValidationConfigMode: REST #HELM/REST
  igw-sig-userAgentHeaderValidation-enabled: true #true/false
  igw-sig-userAgentHeader-validationType: &igw-sig-userAgentHeader-validationType relaxed #relaxed/strict
  igw-prov-oauth-enabled: true #true/false
  nrf-client-enableVirtualNrfResolution: true #true/false
  egw-userAgentHeaderConfigMode: REST #HELM/REST
  egw-userAgentHeader-enabled: true #true/false
  egw-addFqdnToHeader: true #true/false
  egressgateway_nfFqdn: &egressgateway_nfFqdn udr.oracle.com
  error_logging_enabled: true
#END_GLOBAL
List of Parameterized Features
The below tables provide the list of parameterized features for EIR, SLF, and UDR:
Table 4-8 Parameterized Features for EIR
EIR Feature
Prometheus_Scenarios.feature
EIR_XFCC.feature
EIR_User_Agent_Header.feature
EIR_User_AgentHeader_Nrf.feature
EIR_TLS_Signalling.feature
EIR_TLS_Provisioning.feature
EIR_Subscriber_Prov.feature
EIR_Signalling.feature
EIR_Server_Header.feature
EIR_Provisioning_Err.feature
EIR_PDBI_Import.feature
EIR_OAuth2_Signalling.feature
EIR_OAuth2_Provisioning.feature
EIR_MGM_API.feature
EIR_Default_Response.feature
EIR_CSV_Import.feature
EIR_AccessLog.feature
EIR_IMEISV.feature
EIR_IMEISV_Default_Response.feature
EIR_IMEISV_AccessLog.feature
EIR_PDBI_IMEISV_Import.feature
EIR_Subscriber_Export_Tool.feature
EIR_22_4_x_Patch_PDBI_Import.feature
EIR_Validation_Additional_Scenarios.feature
EIR_PDBI_Synchronous_Scenarios.feature
EIR_Subscriber_Export_Tool_New.feature
Table 4-9 Parameterized Features for SLF
SLF Feature
SLF_BulkImport.feature
ProvGw_Config_ImportExport.feature
SLF_CHFGroupId.feature
SLF_DefaultGroupId.feature
SLF_User_Agent_Header.feature
SLF_LCI_Header.feature
SLF_Prov_OAuth2_Validation.feature
SLF_User_AgentHeader_Nrf.feature
SLF_LCI_Via_Header.feature
SLF_Subscriber_Activity_Logging.feature
SLF_Subscriber_Export_Tool.feature
SLF_Singlesite_NFCS_BulkImport.feature
SLF_Singlesite_NFCS_Nrf_Client_Scenarios.feature
SLF_Singlesite_NFCS_Prometheus_Scenarios.feature
SLF_Singlesite_NFCS_Scenarios.feature
SLF_Singlesite_NFCS_Subscriber_Export_Tool.feature
ProvGw_Auditor_Status_API.feature
SLF_NF_Scoring_Multisite.feature
SLF_Network_Policy_Validation.feature
SLF_Subscriber_Export_File_Cleanup.feature
Table 4-10 Parameterized Features for UDR
UDR Feature
UDR_LCI_Header_Via.feature
UDR_Subscriber_Activity_Logging.feature
UDR_VSA_PCF_Validation.feature
UDR_PCF_ETag_Validation.feature
UDR_PCF_ETag_Notify_Validation.feature
UDR_AUTO_Enroll_policy_Data.feature
UDR_22.4.x_PCF_VSA_GET_DELETE.feature
ProvGw_SOAP_Additional_scenarios.feature
23_1_1_ProvGw_fixes.feature
UDR_Mgm_Attribute_Mapping.feature
UDR_PCF_Auto_Enrollment_New.feature
UDR_ProvGw_Prov_Headers.feature
UDR_Quota_Migration_Policy_Sh_Soap.feature
UDR_Network_Policy_Validation.feature
UDR_VSA_Delete_All_Validation.feature
UDR_Quota_Migration_Sh_interface.feature
UDR_Quota_Migration_OnDemand_VSA.feature
UDR_Quota_Migration_OnDemand_Sh.feature
UDR_Quota_Migration_OnDemand_SOAP_ProvPolicy.feature
UDR_Quota_Migration_OnDemand_NudrPolicy.feature
UDR_Quota_Migration_OnDemand_Misc.feature
UDR_Bug_Fix_25_1_0.feature
UDR_Default_Headers.feature
4.7.3 UDR Application Log Collection
Application log collection enables ATS to collect logs from System Under Test (SUT) when there are scenario failures. User can set log level to one of values mentioned below:
  • WARN
  • INFO
  • DEBUG
  • ERROR
  • TRACE
Application log collection is enabled or disabled from the Jenkins Graphical User Interface (GUI). By default application log collection is disabled. When the application log collection is enabled you must follow the ATS Persistent Volume Claim (PVC) guidelines to deploy the ATS with appropriate PVC size. Depending on the log type, the PVC size for the ATS will vary. For storing PCAP logs ATS requires more PVC size than the application logs. Logs can be collected for application logs or PCAP logs or both based on the selection provided through the Jenkins GUI. For more information, see Application Log Collection and PCAP Log Collection.
  • If the application log collection feature is enabled, it will increase the execution time of the pipeline because some of the steps are executed before and after each scenario. It is recommended to enable the application log collection only if there are consistent failures and pod logs are required to further debug the issues.
  • Do not provide any values for Values.k8sResource.container.prefix and Values.k8sResource.container.suffix in the UDR custom values file and do not modify debug tools container name when PCAP logs are collected.
Configuration
To configure application log collection before installing ATS follow the steps below:
  1. ATS must be deployed with PVC enabled. For more information on PVC configurations. For more information, see Enabling Persistent Volume.
  2. For PVC size refer to ATS PVC Size Calculation.
  3. SUT must be deployed with debug tools to capture PCAP logs on SLF, UDR, and EIR. For more information, see Pod Security Policy, Role, and Role Binding Creation section in Oracle Communications Cloud Native Core, Unified Data Repository Installation, Upgrade, and Fault Recovery Guide.
  4. To enable a debug tool containers for UDR and Provision Gateway edit the global section of the custom-values.yaml file of UDR and Provision Gateway. For more information, see Using Debug Tools in Oracle Communications Cloud Native Core, Unified Data Repository Troubleshooting Guide and Oracle Communications Cloud Native Core, Provisioning Gateway Guide.
To configure application log collection after installing ATS follow the steps below:
  1. When the ATS and SUT are installed enable the log collection from the ATS Jenkins GUI. This is available on each pipelines on the BuildWithParameters screen of the UDR ATS. This is currently provided only for NewFeatures and Regression Pipelines.
    Figure 4-75 SLF-NewFeatures BuildWithParameters
  2. To enable the application log collection follow the below steps
    1. From the Fetch_Log_Upon_Failure select YES from the dropdown list.
    2. From the Log_Type select the required options, AppLog or PcapLog or both. Follow the below steps depending on the selection and requirement:
      1. ATS must be deployed with the corresponding PVC size if AppLog is selected from the Log_Type.
      2. SUT must be deployed with debug tools container and ATS must be deployed with corresponding PVC size if PcapLog is selected from the Log_Type or if both AppLog and PcapLog are selected.
  3. Application log collection provides Log_Level values from the dropdown. The log level can be set for all the microservices to capture the SUT log for failure. The possible values for Log_Level are as follows:
    • WARN
    • INFO
    • DEBUG
    • ERROR
    • TRACE
The captured logs for AppLogs, PcapLogs, or both are stored on the PVC and can be accessed from the ATS builds path as follows:
  • Run the following command to log in to the ATS pod:
    $kubectl exec -it <ATS_POD> -n <NAMESPACE> bash
  • Select the builds path to capture AppLogs and PcapLogs :
    (env) [jenkins@slfats-ocats-udr-56f76cd668-jzj4d ~]$cd /var/lib/jenkins/.jenkins/jobs/<JOB-NAME>/builds/<BUILD-NUM>/
    (env) [jenkins@slfats-ocats-udr-56f76cd668-jzj4d ~]$ls -lrt
ATS PVC Guidelines
ATS must be deployed with required PVC storage to store the application logs collected during the ATS pipeline runs for the failed scenarios. The PVC size can vary depending on the following selections:
  • ATS_Type, Pipeline_Type
  • Log_Type
  • Log_Level
  • Number_of_pipeline_runs
The PVC requirement size per scenario for ATS_Type (SLF-ATS, UDR-ATS, and EIR-ATS) and Log_Type (AppLogs,PcapLogs, or both), and the minimum memory requirements to store the logs on the PVC are given below:
  1. SLF-ATS:
    • AppLogs only: Per failure scenario: 72MB
    • PcapLogs only: Per failure scenario: 554MB
    • AppLogs and PcapLogs: Per failure scenario: 626MB
  2. UDR-ATS:
    • AppLogs only: Per failure scenario: 1MB
    • PcapLogs only: Per failure scenario: 12GB
    • AppLogs and PcapLogs: Per failure scenario: 13GB
  3. EIR-ATS:
    • AppLogs only: Per failure scenario: 500KB
    • PcapLogs only: Per failure scenario: 10GB
    • AppLogs and PcapLogs: Per failure scenario: 11GB
The maximum PVC size for a given ATS_Type, Pipeline_Type, and Log_Type are calculated using the below formula:
The maximum PVC size must be able to store the logs even if all the scenarios fail in all the runs.
PVC_size = Number of scenarios in Pipeline Type * PVC requirement per scenario for given type [ATS_Type or Log_Type] * Total runs to be executed.
Example 1: To capture the application logs for SLF-ATS-NewFeatures and the Log_Type is set as AppLogs only for 10 pipeline runs, the PVC for ATS is calculated as:
The given SLF-ATS-NewFeatures has 19 scenarios. The memory requirement per scenario is 72MB.
PVC_size = 19*72MB*10 = 13GB. The maximum PVC size required for ATS is 13 GB.
Example 2: To capture the application logs for EIR-ATS-Regression and the Log_Type is set as PcapLogs only for 1 pipeline run, the PVC for ATS is calculated as:
The given EIR-ATS-Regression has 242 scenarios. The memory requirement per scenario is 10GB.
PVC_size = 242*10GB*1 = 2420GB. The maximum PVC size required for ATS is 2420 GB.
4.7.4 Parallel Test Execution
Parallel test execution allows you to perform multiple logically grouped tests simultaneously on the same System Under Test (SUT) to reduce the overall execution time of ATS.
ATS currently runs all its tests in a sequential manner, which is time-consuming. With parallel test execution, tests can be run concurrently rather than sequentially or one at a time. Test cases or feature files are now separated into different folders, such as stages and groups, for concurrent test execution. Different stages, such as stage 1, stage 2, and stage 3, run the test cases in a sequential order, and each stage has its own set of groups. For more information about Parallel Test Execution, see Parallel Test Execution.
SLF ATS Stages and Groups
Following table provides different stages and groups for SLF ATS:
Table 4-11 SLF ATS Stages and Groups
Single Site Stages and Groups Multiple Site Stages and Groups
Singlesite/
├── Stage_1
│   ├── bulk_import_basics
│   │   ├── behave.ini
│   │   └── SLF_BulkImport.feature
│   ├── export_tool_basics
│   │   ├── behave.ini
│   │   └── SLF_Subscriber_Export_Tool.feature
│   ├── independent_features
│   │   ├── behave.ini
│   │   ├── SLF_Network_Policy_Validation.feature
│   │   └── SLF_Sbi_Correlation_Header.feature
│   ├── ingressgatway_features
│   │   ├── behave.ini
│   │   ├── SLF_Ingress_XFCC_Header.feature
│   │   ├── SLF_LCI_Via_Header.feature
│   │   ├── SLF_OAuth2_Validation.feature
│   │   ├── SLF_Prov_OAuth2_Validation.feature
│   │   └── SLF_Server_Header.feature
│   ├── nrf-client
│   │   ├── behave.ini
│   │   ├── Prometheus_Scenarios_NrfClient.feature
│   │   ├── SLF_Dns_Srv.feature
│   │   ├── SLF_Nrf_Client_Scenarios.feature
│   │   └── SLF_User_AgentHeader_Nrf.feature
│   ├── provgw
│   │   ├── behave.ini
│   │   ├── Prometheus_Scenarios_ProvGw.feature
│   │   ├── ProvGw_Basic_Func_Error.feature
│   │   ├── ProvGw_Basic_Func_Success.feature
│   │   ├── ProvGw_CHFGroupId.feature
│   │   ├── ProvGw_Data_Mismatch.feature
│   │   └── ProvGw_SSL_Enabled.feature
│   └── slf_basics
│       ├── behave.ini
│       ├── SLF_CHFGroupId.feature
│       └── SLF_Prov_and_Lookup_NonMetric.feature
├── Stage_2
│   ├── provgw_config
│   │   ├── behave.ini
│   │   └── Provgw_Config.feature
│   └── slf_config
│       ├── behave.ini
│       ├── SLF_DefaultGroupId.feature
│       ├── SLF_Mgm_Apis.feature
│       └── SLF_Subscriber_Activity_Logging.feature
└── Stage_3
    └── sequential_execution
        ├── behave.ini
        ├── Prometheus_Scenarios.feature
        ├── ProvGw_Auditor.feature
        ├── ProvGw_Auditor_Status_API.feature
        ├── ProvGw_Config_ImportExport.feature
        ├── ProvGw_Loglevel.feature
        ├── ProvGw_Segdown.feature
        ├── SLF_Config_Import_Export.feature
        ├── SLF_LCI_Header.feature
        ├── SLF_LogLevels.feature
        ├── SLF_NF_Scoring.feature
        ├── SLF_Prov_and_Lookup_Metric.feature
        ├── SLF_Singlesite_NFCS_BulkImport.feature
        ├── SLF_Singlesite_NFCS_Nrf_Client_Scenarios.feature
        ├── SLF_Singlesite_NFCS_Prometheus_Scenarios.feature
        ├── SLF_Singlesite_NFCS_Scenarios.feature
        ├── SLF_Singlesite_NFCS_Subscriber_Export_Tool.feature
        ├── SLF_Subs_Activity_Logging_Loglevels.feature
        └── SLF_User_Agent_Header.feature
Multisite/
└── Multi_Site
    └── two_site
        ├── behave.ini
        ├── SLF_Multisite.feature
        ├── SLF_Multisite_NFCS_Scenarios.feature
        └── SLF_NF_Scoring_Multisite.feature
UDR ATS Stages and Groups
Following table provides different stages and groups for UDR ATS:
Table 4-12 UDR ATS Stages and Groups
UDR New Feature UDR Regression (Single Site) UDR Regression (Multiple Site)
Singlesite/
├── All
│   └── Stage_1
│       └── sequential_execution
│           ├── behave.ini
│           ├── UDR_Bulk_Import_PNR_Validation.feature
│           ├── UDR_PUR_Scenarios.feature
│           ├── UDR_Quota_Dq_Additional_Scenarios.feature
│           ├── UDR_Sm_Data_Dnn_Schema_Validation.feature
│           └── UDR_Subscriber_Export_Tool.feature
└── MISCELLANEOUS
    └── Stage_1
            ├── behave.ini
Singlesite/
├── All
│   ├── Stage_1
│   │   ├── bulk_import_metrics_autocreate_true
│   │   │   ├── behave.ini
│   │   │   ├── UDR_Bulk_Import.feature
│   │   │   ├── UDR_Bulk_Import_ixml_part1.feature
│   │   │   ├── UDR_Bulk_Import_PolicyAndVsa.feature
│   │   │   └── UDR_ProvGw_Prov_Headers.feature
│   │   ├── diameter_only_metrics
│   │   │   ├── Diameter_All_Entities.feature
│   │   │   ├── Diameter_Config.feature
│   │   │   ├── Diameter_Misc.feature
│   │   │   ├── Diameter_User_Data.feature
│   │   │   ├── UDR_22_4_1_Diameter.feature
│   │   │   ├── UDR_23_1_0_Diameter.feature
│   │   │   ├── UDR_23_2_0_Diameter.feature
│   │   │   ├── UDR_All_Migration_State_Entity_part1.feature
│   │   │   ├── UDR_Migration_tool_Additional_scenarios.feature
│   │   │   └── UDR_Migration_tool_part1.feature
│   │   ├── nrf_only_metrics
│   │   │   ├── UDR_NRFclient_DNS_Srv.feature
│   │   │   ├── UDR_NRFclient_Scenarios.feature
│   │   │   └── UDR_User_AgentHeader_Nrf.feature
│   │   ├── oauth2_only_metrics
│   │   │   ├── UDR_OAuth2_Validation.feature
│   │   │   ├── UDR_PCF_Prov_OAuth2_Validation.feature
│   │   │   └── UDR_UDM_Prov_OAuth2_Validation.feature
│   │   ├── pcf_subscription_no_metrics
│   │   │   ├── UDR_PCF_DELETE.feature
│   │   │   ├── UDR_PCF_SMData_Patch.feature
│   │   │   ├── UDR_Subscriber_Policy_Data.feature
│   │   │   ├── UDR_UDM_API_SDM_Subscription.feature
│   │   │   └── UDR_UDM_Subscription_Data_Subscription.feature
│   │   └── vsa_no_metrics
│   │       ├── behave.ini
│   │       ├── UDR_22.4.x_PCF_VSA_GET_DELETE.feature
│   │       ├── UDR_VSA_PATCH_Fix.feature
│   │       └── UDR_VSA_PCF_Validation.feature
│   ├── Stage_2
│   │   ├── bulk_import_autocreate_false
│   │   │   └── UDR_Bulk_Import_ixml_part2.feature
│   │   └── no_igw_dr_metrics
│   │       ├── behave.ini
│   │       ├── UDR_PCF_ETag_Notify_Validation.feature
│   │       ├── UDR_PCF_Notification_New_API.feature
│   │       ├── UDR_PCF_User_Agent_Header.feature
│   │       ├── UDR_Suppressed_Notifications.feature
│   │       ├── UDR_UDM_Notification.feature
│   │       ├── UDR_UDM_UserAgent_Header.feature
│   │       └── UDR_User_AgentHeader_Notification.feature
│   ├── Stage_3
│   │   ├── provgw_no_igw_dr_metrics
│   │   │   ├── 23_1_1_ProvGw_fixes.feature
│   │   │   ├── ProvGw_SOAP_Additional_scenarios.feature
│   │   │   ├── ProvGw_SOAP_CNCESUDR82_misc.feature
│   │   │   ├── ProvGw_SOAP_ConvertToSec_strict.feature
│   │   │   ├── ProvGw_SOAP_Custom_Entities.feature
│   │   │   ├── ProvGw_SOAP_Custom_Fields.feature
│   │   │   ├── ProvGw_SOAP_Format_Tags.feature
│   │   │   ├── ProvGw_SOAP_GetSubscription.feature
│   │   │   ├── ProvGw_SOAP_Misc.feature
│   │   │   ├── ProvGw_SOAP_Reset_Quota.feature
│   │   │   ├── ProvGw_SOAP_SSL.feature
│   │   │   ├── ProvGw_SOAP_Subscriber_Entities.feature
│   │   │   ├── ProvGw_SOAP_Subscriber_Entity_Fields.feature
│   │   │   ├── ProvGw_SOAP_Subscriber_Fields.feature
│   │   │   ├── ProvGw_SOAP_Subscriber_Profile.feature
│   │   │   └── UDM_SUBS_Enhancements_Non_Metrics.feature
│   │   └── udr_no_igw_dr_metrics
│   │       ├── behave.ini
│   │       ├── UDR_EGW_LCI_Header.feature
│   │       ├── UDR_LCI_Header_Via.feature
│   │       ├── UDR_SCP_Routing.feature
│   │       ├── UDR_SM_Data_Custom_Data_Enhancements.feature
│   │       └── UDR_VSA_Notifications.feature
│   └── Stage_4
│           ├── behave.ini
│           ├── ProvGw_SOAP_AndUDR_VSA_New.feature
│           ├── ProvGw_SOAP_Bug_Fixes.feature
│           ├── UDM_SUBS_Enhancements_Metrics.feature
│           ├── UDR_23_2_0_Bug_fixes.feature
│           ├── UDR_All_Migration_State_Entity_rest_metric.feature
│           ├── UDR_AUTO_Enroll_policy_Data.feature
│           ├── UDR_Bulk_Import_All_metrics.feature
│           ├── UDR_Bulk_Import_Configuration_validation.feature
│           ├── UDR_Bulk_Import_ixml_bug_fixes.feature
│           ├── UDR_Bulk_Import_VSA.feature
│           ├── UDR_Config_Import_Export.feature
│           ├── UDR_Config_Service.feature
│           ├── UDR_Custom_Fields_Profile.feature
│           ├── UDR_Diameter_CER_Changes.feature
│           ├── UDR_Diameter_Ondemand_Mig.feature
│           ├── UDR_Egw_TLS.feature
│           ├── UDR_IGW_LCI_Header.feature
│           ├── UDR_Log_Level.feature
│           ├── UDR_Mgm_Attribute_Mapping.feature
│           ├── UDR_Migration_tool_part2.feature
│           ├── UDR_Misc_Metrics_Alerts.feature
│           ├── UDR_NEF_AM_Data.feature
│           ├── UDR_NEF_MGM_APIs.feature
│           ├── UDR_NEF_Misc.feature
│           ├── UDR_NEF_Notification.feature
│           ├── UDR_NEF_Prov.feature
│           ├── UDR_NEF_Prov_OAuth2_Validation.feature
│           ├── UDR_NEF_SM_Data.feature
│           ├── UDR_NEF_Subscritption.feature
│           ├── UDR_Network_Policy_Validation.feature
│           ├── UDR_New_Log_Level.feature
│           ├── UDR_PCF_Auto_Enrollment_New.feature
│           ├── UDR_PCF_ETag_Validation.feature
│           ├── UDR_PCF_MGM_APIs.feature
│           ├── UDR_PCF_New_API_AllData.feature
│           ├── UDR_PCF_New_API_AM.feature
│           ├── UDR_PCF_New_API_SM.feature
│           ├── UDR_PCF_New_API_Subscription.feature
│           ├── UDR_PCF_New_API_UeData.feature
│           ├── UDR_PCF_New_API_UMD.feature
│           ├── UDR_PCF_New_Server_Header.feature
│           ├── UDR_PCF_Ondemand.feature
│           ├── UDR_PCF_Sbi_Correlation_Header.feature
│           ├── UDR_PCF_User_Agent_Header_New.feature
│           ├── UDR_PCF_VSA_Diameter.feature
│           ├── UDR_PCF_VSA_ETag_New.feature
│           ├── UDR_Profile_Data_New.feature
│           ├── UDR_Prov_Policy_Ondemand.feature
│           ├── UDR_Quota_Migration_OnDemand_Misc.feature
│           ├── UDR_Quota_Migration_OnDemand_NudrPolicy.feature
│           ├── UDR_Quota_Migration_OnDemand_Sh.feature
│           ├── UDR_Quota_Migration_OnDemand_SOAP_ProvPolicy.feature
│           ├── UDR_Quota_Migration_OnDemand_VSA.feature
│           ├── UDR_Quota_Migration_Policy_Sh_Soap.feature
│           ├── UDR_Quota_Migration_Sh_interface.feature
│           ├── UDR_SMData_Custom_Fields.feature
│           ├── UDR_Subscriber_Activity_Logging.feature
│           ├── UDR_TLS_Enable.feature
│           ├── UDR_UDM_API_Additional_Err.feature
│           ├── UDR_UDM_API_Authentication_Data.feature
│           ├── UDR_UDM_API_Context_Data.feature
│           ├── UDR_UDM_API_EE_Profile_Data.feature
│           ├── UDR_UDM_API_Identity_Data.feature
│           ├── UDR_UDM_API_Operator_Determined_Barring_Data.feature
│           ├── UDR_UDM_API_Operator_Specific_Data.feature
│           ├── UDR_UDM_API_Provisioned_Data.feature
│           ├── UDR_UDM_API_Provisioned_paramenter_Data.feature
│           ├── UDR_UDM_API_UE_Update_Confirmation_Data.feature
│           ├── UDR_UDM_Mgm_Apis.feature
│           ├── UDR_UDM_Prov_Authentication_Data.feature
│           ├── UDR_UDM_Prov_Context_Data.feature
│           ├── UDR_UDM_Prov_EE_Profile_Data.feature
│           ├── UDR_UDM_Prov_Identity_Data.feature
│           ├── UDR_UDM_Prov_Operator_Determined_Barring_Data.feature
│           ├── UDR_UDM_Prov_Operator_Specific_Data.feature
│           ├── UDR_UDM_Prov_Provisioned_Data.feature
│           ├── UDR_UDM_Prov_Provisioned_Paramenter_Data.feature
│           ├── UDR_UDM_Prov_UE_Update_Confirmation_Data.feature
│           ├── UDR_UDM_Sbi_Correlation_Header.feature
│           ├── UDR_VSA_Delete_All_Validation.feature
│           ├── UDR_Vsa_Ondemand.feature
│           ├── UDR_XFCC.feature
│           └── VSA_SMPOLICY.feature
├── BULK-IMPORT
│   ├── Stage_1
│   │   └── bulk_import_metrics_autocreate_true
│   │       ├── behave.ini
│   │       └── UDR_Bulk_Import_PolicyAndVsa.feature
│   ├── Stage_2
│   │   └── bulk_import_autocreate_false
│   │       ├── behave.ini
│   └── Stage_4
│           ├── behave.ini
│           └── UDR_Bulk_Import_VSA.feature
├── CONFIG
│   └── Stage_4
│           ├── behave.ini
│           └── UDR_New_Log_Level.feature
├── DIAMETER
│   └── Stage_1
│       └── diameter_only_metrics
│           ├── behave.ini
│           └── UDR_23_2_0_Diameter.feature
├── MISCELLANEOUS
│   ├── Stage_1
│   │   └── oauth2_only_metrics
│   │       ├── behave.ini
│   │       └── UDR_OAuth2_Validation.feature
│   ├── Stage_2
│   │       ├── behave.ini
│   ├── Stage_3
│   │   │   └── ProvGw_SOAP_Subscriber_Profile.feature
│   │       ├── behave.ini
│   │       └── UDR_SCP_Routing.feature
│   └── Stage_4
│           ├── behave.ini
│           └── UDR_XFCC.feature
├── NEF
│   └── Stage_4
│           ├── behave.ini
│           └── UDR_NEF_Subscritption.feature
├── NRF-CLIENT
│   └── Stage_1
│       └── nrf_only_metrics
│           ├── behave.ini
│           └── UDR_NRFclient_Scenarios.feature
├── ONDEMAND
│   └── Stage_4
│           ├── behave.ini
│           └── UDR_Vsa_Ondemand.feature
├── PCF
│   ├── Stage_1
│   │   │   └── UDR_PCF_Prov_OAuth2_Validation.feature
│   │   └── pcf_subscription_no_metrics
│   │       ├── behave.ini
│   │       └── UDR_Subscriber_Policy_Data.feature
│   ├── Stage_2
│   │       ├── behave.ini
│   │       └── UDR_PCF_User_Agent_Header.feature
│   ├── Stage_3
│   │       ├── behave.ini
│   │       └── UDR_SM_Data_Custom_Data_Enhancements.feature
│   └── Stage_4
│           ├── behave.ini
│           └── UDR_TLS_Enable.feature
├── UDM
│   ├── Stage_1
│   │       ├── behave.ini
│   ├── Stage_2
│   │       ├── behave.ini
│   │       └── UDR_UDM_UserAgent_Header.feature
│   ├── Stage_3
│   │   └── provgw_no_igw_dr_metrics
│   │       ├── behave.ini
│   └── Stage_4
│           ├── behave.ini
│           └── UDR_UDM_Sbi_Correlation_Header.feature
└── VSA
    ├── Stage_1
    │       ├── behave.ini
    ├── Stage_3
    │       ├── behave.ini
    └── Stage_4
            ├── behave.ini
Multisite/
└── Multi_Site
    └── two_site
        ├── behave.ini
        └── UDR_Multisite.feature
EIR ATS Stages and Groups
Following table provides different stages and groups for EIR ATS:
Table 4-13 EIR ATS Stages and Groups
EIR NewFeatures EIR Regression
cust_newfeatures/
└── Stage_1
    └── eir_basics
        ├── behave.ini
        └── EIR_ErrorResponseDetail.feature
cust_regression/
├── Stage_1
│   │   ├── behave.ini
│   │   ├── EIR_22_4_x_Patch_PDBI_Import.feature
│   │   ├── EIR_CSV_Import.feature
│   │   ├── EIR_PDBI_IMEISV_Import.feature
│   │   ├── EIR_PDBI_Import.feature
│   │   └── Prometheus_bulk_import.feature
│   ├── eir_basics
│   │   ├── behave.ini
│   │   ├── EIR_Provisioning_Err.feature
│   │   ├── EIR_TLS_Provisioning.feature
│   │   ├── EIR_TLS_Signalling.feature
│   │   └── EIR_Validation_Additional_Scenarios.feature
│   │   ├── behave.ini
│   │   ├── EIR_Subscriber_Export_Tool.feature
│   │   └── EIR_Subscriber_Export_Tool_New.feature
│   │   ├── behave.ini
│   │   ├── EIR_OAuth2_Provisioning.feature
│   │   ├── EIR_OAuth2_Signalling.feature
│   │   ├── EIR_Server_Header.feature
│   │   └── EIR_XFCC.feature
│   └── nrf-client
│       ├── behave.ini
│       ├── EIR_Dns_Srv.feature
│       ├── EIR_Nrf_Client_Scenarios.feature
│       ├── EIR_User_AgentHeader_Nrf.feature
│       └── Prometheus_nrfclient.feature
└── Stage_2
        ├── behave.ini
        ├── EIR_22_4_x_Patch_PDBI_Import_part2.feature
        ├── EIR_AccessLog.feature
        ├── EIR_Config_Import_Export.feature
        ├── EIR_CSV_Import_part2.feature
        ├── EIR_DefaultIMEINotFound_Response.feature
        ├── EIR_Default_Response.feature
        ├── EIR_Export_Configuration_validation.feature
        ├── EIR_IMEISV_AccessLog.feature
        ├── EIR_IMEISV_Default_Response.feature
        ├── EIR_IMEISV.feature
        ├── EIR_LogLevels.feature
        ├── EIR_MGM_API.feature
        ├── EIR_PDBI_IMEISV_Import_part2.feature
        ├── EIR_PDBI_Import_part2.feature
        ├── EIR_PDBI_Synchronous_Scenarios.feature
        ├── EIR_Provisioning_Err_part2.feature
        ├── EIR_Signalling.feature
        ├── EIR_Subscriber_Prov.feature
        ├── EIR_User_Agent_Header.feature
        ├── EIR_Validation_Additional_Scenarios_part2.feature
        └── Prometheus_Scenarios.feature
Viewing Console Logs for Specific Group
When parallel test execution feature is enabled and ATS runs are triggered, you can view the progress of each stage and group on the corresponding pipeline dashboard.
Figure 4-76 Sample SLF Regression
SLF Regression
Figure 4-77 Sample Stage Logs
Stage Logs
4.7.5 Logging into ATS
Before logging into ATS, it is important to know the nodeport of the "-ocats-UDR" service. To get the nodeport detail, run the following command:
kubectl get svc -n <slf_namespace>
Example: kubectl get svc -n ocudr ocats-udr-ga
Figure 4-78 UDR Nodeport
UDR Nodeport
In the previous image, 31175 is the nodeport.
Run the following command to get the worker node IP address:
kubectl get nodes -o wide
To log in to ATS:
  1. In the web browser, type http://<Worker IP>:nodeport and press Enter.
    Example: http://10.75.229.87:30156
    The log in page appears.
  2. Enter the username and password. Click Sign in. A page with pre-configured pipelines appears.
    Figure 4-79 SLF, EIR, and UDR Pre-configured Pipelines
    Figure 4-80 EIR ATS Pipeline
    EIR ATS Pipeline
    To modify the default log in password, see Modifying Login Password.
    • SLF-HealthCheck: This pipeline does a test probe with SUT - trigger Helm test and provide the results in Console Logs.
    • SLF-NewFeatures: This pipeline has all the test cases delivered as part of SLF ATS - 25.1.200 release.
    • SLF-Performance: This pipeline provides a means to run 1K TPS of lightweight traffic.
    • SLF-Regression: This pipeline has all the test cases of previous releases.
    • UDR-HealthCheck: This pipeline does a test probe with SUT - trigger helm test and provide the results in Console Logs.
    • UDR-NewFeatures: This pipeline has all the test cases delivered as part of UDR ATS - 25.1.200 release.
    • UDR-Regression: This pipeline has all the UDR test cases of previous releases.
    • EIR-HealthCheck: This pipeline does a test probe with SUT - trigger Helm test and provide the results in Console Logs.
    • EIR-NewFeatures: This pipeline has all the test cases delivered as part of EIR ATS - 25.1.200 release.
    • EIR-Regression: This pipeline has all the EIR test cases of previous releases.
4.7.6 Running SLF Pipelines
4.7.6.1 Running SLF-NewFeatures Pipeline
To run the test cases:
  1. Click SLF-NewFeatures. The following page appears:
    Figure 4-81 SLF-NewFeatures Configure
  2. Click Configure in the left navigation pane. The General tab appears. You must wait for the page to load completely.
  3. Select the Discard old builds. This option allows you to configure the number of builds you want to retain in the persistent volume.
    It is recommended to configure this option. If there is large number of builds, the Persistent Volume may be utilized completely.
    Figure 4-82 Discard Old Builds
    Discard Old Builds
  4. Click the Advanced Project Options tab. Scroll down to reach the Pipeline configuration section as follows:
    Important:
    Make sure the page loads completely before you perform any action on it. Do not modify any configuration except the one discussed below.
    Figure 4-83 SLF Configuration page
    In the pipeline script, do not change any value other than from line number 68 to line 112. You can change the parameters marked as "b" - to - "T" as per user requirement. The parameters details are provided as comments in line number 15 to 60. The parameters description is as follows:
    • a - Selected NF
    • b - NameSpace in which UDR is Deployed (Mandatory)
    • c - NameSpace in which ProvGw is Deployed (Mandatory)
    • d - Preferred UDR1 FQDN and PORT of segment 1 in the format FQDN:PORT
    • e - UDR2 FQDN and PORT of segment 1 in the format FQDN:PORT
    • f - Preferred UDR3 FQDN and PORT of segment 2 in the format FQDN:PORT
    • g - UDR4 FQDN and PORT of segment 2 in the format FQDN:PORT
    • h - ProvGw FQDN and PORT in the format FQDN:PORT
    • i - prometheus_ip and port of prometheus server in the format FQDN:PORT
    • j - re-run count
    • k - Name and Port of Kubernetes Host server in the format FQDN:PORT
    • l - Mode of Communication (Can be either IP or fqdn)
    • m - Helm Name for UDR1
    • n - Helm Name for UDR2
    • o - Helm Name for UDR3
    • p - Helm Name for UDR4
    • q - Helm Name for ProvGw
    • r - FQDN:PORT format for primary nrf-stub
    • s - primary nrf-stub metrics port
    • t - nudr-config FQDN:PORT format
    • u - prometheus uri apiName and apiVersion
    • v - FQDN:PORT format for secondary nrf-stub
    • w - secondary nrf-stub metrics port
    • x - primary nrf-stub deployment name
    • y - secondary nrf-stub deployment name
    • z - ProvGw HTTPS port
    • A - root certificate authority
    • B - Server certificate signed with root CA private key
    • C - private key in .pem format
    • D - Number of retries to check if pod down is successful
    • E - Number of retries to check if pod up is successful
    • F - Number of retries when ATS detects tcp connection failures
    • G - Time interval in seconds between tcp connection retries
    • H - UDR2 FQDN:PORT for multi-site scenarios
    • I - UDR2 nudr-config FQDN:PORT for multi-site scenarios
    • J - ProvGateway Config service host and port in the format FQDN:PORT
    • K - Bulk import helm name
    • L - true if CNE VERSION is 1.9 or above or OSO version is 1.10.x or above, else false.
    • M - Preferred UDR1 PROV FQDN and PORT of segment 1 in the format FQDN:PORT
    • N - UDR2 PROV FQDN and PORT of segment 1 in the format FQDN:PORT
    • O - Preferred UDR3 PROV FQDN and PORT of segment 2 in the format FQDN:PORT
    • P - UDR4 PROV FQDN and PORT of segment 2 in the format FQDN:PORT
    • Q - MultiSite UDR2 PROV FQDN and PORT in the format FQDN:PORT
    • R - Helm Release name of SLF export tool (slfexport)
    • S - Enable Error Response Logging Validation (true)
    • T - true if underlying platform supports dual stack, else false. All dual stack scenarios will be marked as skipped if false (Default is false)
    Setting rerun count, number of retries to check pod status and segment details:
    • Rerun count can be set to any desired value by changing option 'j' in the pipeline script.
    • Number of retries to check if pod is down can be set by providing option 'D' in the pipeline script.
    • Number of retries to check if pod is up can be set by providing option 'E' in the pipeline script.
    • If ProvGw is deployed with segment details having UDR fqdn/IP:port, provide option 'l' as "IP". If ProvGw is deployed with segment details having only UDR fqdn/IP, provide option 'l' as "fqdn". If any value other than "IP" and "fqdn" is provided, ATS assumes that the segment details in ProvGw is in "IP" mode.
    • Option 'u' shall take value '/<domain name>/prometheus/api/v1 for CNE version 1.9 or above or OSO version is 1.10.x or above. If domain name is not known, then domain name can be found after executing the command from ATS pod:
      curl http://<prometheus fqdn>:<port>/
      Example:
      curl http://occne-kube-prom-stack-kube-prometheus.occne-infra/
      <a href="/udr-cne/prometheus">Found</a>
  5. Click Save. The SLF-NewFeatures page appears.
  6. Click Build with Parameters. The following page displays all the newly added features and total count of the features, counts of scenarios in each feature, name of each feature and scenarios in each feature:
    Figure 4-84 SLF Build with Parameters
    • Select the Configuration_Type. For information about this feature, see Parameterization.
    • There are two Select_Option(s), which are:
      • All: By default, it selects all the SLF test cases to run. Scroll-down and click Build to run all the test cases.
      • Single/MultipleFeatures: This option allows you to select the test cases you want to run. After selecting the test cases, scroll-down and click Build.
      If the Select_Option is selected as 'All', the TestCases details are mapped to each feature and if the Select_Option is selected as 'Single/MultipleFeatures', only the TestCases details corresponding to those test cases appear. For more information, see Support for Test Case Mapping and Count.
To view consolidated and detailed stack trace results in case of any failures, click Test Results Analyzer in the left navigation pane. The test results analyzer report appears. For more information, see Test Results Analyzer.
A sample consolidated test report, when rerun is set to 0, is as follows:
Figure 4-85 Consolidated Test Report - Rerun is 0
For more details on consolidated test report, see Final Summary Report, Build Color and Application Logs.
4.7.6.2 Running SLF Regression Pipeline - Single Site Deployment
This pre-configured pipeline consists of all the test cases delivered till SLF ATS 25.1.200. However, some test cases are updated as per new implementation of SLF. To run the single site scenarios:
Model 1 deployment is required for this pipeline. For more information, see Prerequisites for SLF Pipelines.
  1. Click SLF-Regression and then, click Configure.
    Figure 4-86 SLF-Regression Pipeline
  2. The General tab appears. The user must wait for the page to load completely.
  3. Select the Discard old Builds. This option allows you to configure the number of builds you want to retain in the persistent volume.
    It is recommended to configure this option. If there is a large number of builds, the Persistent Volume may be utilized completely.
  4. Click the Advanced Project Options tab. Scroll-down to reach the Pipeline configuration section as follows:
    Important:
    Figure 4-87 SLF Configuration page
    Do not change any value other than from line number 68 to 112. You can change the parameters marked as "b" - to - "T" as per user requirement. The parameters details are provided as comments in line number 15 to 60. The parameters description is as follows:
    • a - Selected NF
    • j - re-run count
    • T - true if underlying platform supports duals tack, else false. All dual stack scenarios will be marked as skipped if false (Default is false)
      Example:
      <a href="/udr-cne-190/prometheus">Found</a>
  5. Click Save. The Pipeline SLF-Regression page appears.
    Figure 4-88 Build with Parameters
  7. Select the Configuration_Type. For more information about this feature, see Parameterization.
  8. Select SUTSuite as 'All'. This lists all regression features and displays the total count of the features, counts of scenarios in each feature, name of each feature, and scenarios in each feature.
  9. Click Build.
Figure 4-89 Consolidated Test Report Rerun
4.7.6.3 Running SLF Regression Pipeline - Multiple Site Deployment
This pre-configured pipeline consists of all the test cases delivered till SLF ATS 25.1.200. However, some test cases are updated as per new implementation of SLF. To run the multiple site scenarios:
Model 3 deployment is required for this pipeline. For more information, see Prerequisites for SLF Pipelines.
    It is recommended to configure this option. If there are large number of builds, the Persistent Volume may be utilized completely.
    Important:
    Do not change any value other than from line number 68 to line 112. You can change the parameters marked as "b" - to - "T" as per user requirement. The parameters details are provided as comments in line number 15 to 60. The parameters description is as follows:
    • a - Selected NF
    • j - re-run count
    Setting rerun count, number of retries to check pod status, and segment details:
  6. Click Build with Parameters. Select the Configuration_Type.
    For information about the Configuration_Type, see Parameterization.
  7. Select SUTSuite as 'Multi_Site'. This lists all the regression features and displays the total count of the features, counts of scenarios in each feature, name of each feature, and scenarios in each feature.
  8. Click Build.
    A sample consolidated test report, when rerun is set to 0 is as follows:
    Figure 4-90 SLF- Regression to run Multiple Site Scenarios - Consolidated Test Report - Rerun is 0
4.7.6.4 Running SLF HealthCheck Pipeline
To run health check on SLF or Provisioning Gateway:
  1. Navigate to SLF-HealthCheck pipeline and click Configure.
    Figure 4-91 UDR - SLF-HealthCheck Pipeline
  3. Click the Advanced Project Options tab. Scroll-down to reach the Pipeline configuration section as follows:
    Important:
    Do not change any value other than line numbers 16 and 17. You can change the parameters marked as "a" "b" and "c" as per user requirement. The parameters details are provided as comments in line number 7 and 9. The parameters description is as follows:
    • a - helm releases [Provide Release Name with Comma Separated if more than 1 ]
    • b - namespace of SUT.
    • c - helm command alias that is being used on the CNE (helm or helm2 or helm3)
    Figure 4-92 SLF-HealthCheck Pipeline configuration
  4. Click Save. The Pipeline SLF-HealthCheck page appears.
  5. Click Build Now. This triggers health check for SUT.
    Figure 4-93 SLF-HealthCheck Pipeline Build
    Figure 4-94 Sample Output - SLF Health Check
4.7.6.5 Running SLF-Performance Pipeline: Model 2: Single Site Deployment
To run light weight performance scenarios:
Model 2 deployment is required for this pipeline. For more information, see Prerequisites for SLF Pipelines.
  1. Navigate to the SLF-Performance pipeline and click Configure.
    Figure 4-95 SLF Single Site Performance Model 2
    Important:
    Do not change any value other than line number 22 and line number 31. You can change the parameters marked as "b" and "k" as per user requirement. The parameters details are provided as comments in line number 7 and 21. The parameters description is as follows:
    • a - Selected NF (should always be SLF)
    • b - UDR ingressgateway provisioning FQDN and port for performance testing (ocudr-ingressgateway-prov.ocudr:80)
    • c - UDR ingressgateway signalling FQDN and port for performance testing (ocudr-ingressgateway-sig.ocudr:80)
    • d - Prometheus Server FQDN and port (occne-prometheus-server.occne-infra:80)
    • e - Prometheus URI (/prometheus/api/v1)
    • f - Namespace in which UDR is deployed for performance testing (ocudr)
    • g - Helm Name of UDR (ocudr)
    • h - Kubernetes host FQDN (kubernetes.default)
    • i - Kubernetes host port number (443)
    • j - Duration for which performance needs to be tested (in seconds) (900)
    • k - Whether scenario with ramping up of TPS from 1K to 2K and back, needs to be run (false)
    Figure 4-96 SLF-Performance Pipeline Configuration
  4. Click Save. The Pipeline SLF-Performance page appears.
  5. Click Build Now. This triggers lightweight traffic on UDR-SLF.
    Figure 4-97 Sample Output - SLF Performance
4.7.6.6 SLF NewFeatures Documentation - Single Site Scenarios
To view the documentation of SLF-NewFeatures, click the Documentation link in the left navigation pane (present inside the build), as follows:
Figure 4-98 SLF-New Features Documentation
The page lists all the features. Click any feature to view description of that test case.
SLF-New Features My Project
The SLF new features list along with its description is as follows:
Table 4-14 SLF New Features
Feature Description
SLF_Subscriber_Export_File_Cleanup.feature This feature file has scenario to validate the clean up of the older SLF export dumps.
The Documentation option appears only if you have run the SLF-NewFeatures pipeline test cases atleast once.
Based on the functionalities covered under Documentation, the Build Requires Parameters page displays test cases. To navigate back to the Pipeline SLF-NewFeatures page, click Back to SLF-NewFeatures link available on top left corner of the page.
4.7.6.7 SLF Regression Documentation - Single Site Scenarios
Click Documentation in the left navigation pane of the SLF-Regression pipeline to view all the test cases.
Figure 4-99 SLF-Regression Documentation
Click any feature to see the description of that test case.
4.7.6.8 SLF Regression Documentation - Multiple Site Scenarios
Click Documentation in the left navigation pane of the SLF-Regression pipeline to view all the test cases provided.
Figure 4-100 SLF-Regression Documentation
Click any feature to view its details.
4.7.7 Running UDR Pipelines
4.7.7.1 Running UDR NewFeatures Pipeline
To run the UDR-NewFeatures (Model 1) pipeline test cases:
Running UDR-NewFeatures (Model 1) pipeline test cases
  1. Click UDR-NewFeatures. Click Configure in the left navigation pane. The General tab appears. The user must wait for the page to load completely.
    Figure 4-101 UDR NewFeatures Pipeline
  2. Once the page loads completely, select the Discard old Builds. This option allows you to configure the number of builds you want to retain in the persistent volume.
    It is recommended to configure this option. If there is large number of build, the Persistent Volume may be utilized completely.
  3. Click the Advanced Project Options tab. Scroll-down to reach the Pipeline configuration as follows:
    Important:
    You should not change any other value apart from line number 68 to 112. It means you can change the parameters marked as "b" - to - "T" as per user requirement. The parameters details are provided as comments in line number 15 to 60. The parameters description is as follows:
    • a - Name of the NF to be tested in capital (UDR).
    • b - Namespace in which the udr is deployed.
    • c - Name of signalling UDR1_ingressgateway_service.namespace and port (ocudr-ingressgateway-sig.ocudr:80).
    • d - Helm release name of UDR (ocudr)
    • e - FQDN and Port UDR's nudr-config in the format fqdn:port (ocudr-nudr-config.ocudr:5001)
    • f - Name_of_Prometheus_service.namespace and port(occne-prometheus-server.occne-infra:80).
    • g - If this option is not provided, Prometheus URI shall be /api/v1 (Default: /prometheus/api/v1) (if CNE 1.9+ /<cne-cluster-name>/prometheus/api/v1)
    • h - Number of times the re-run of failed case is allowed (default as 2).
    • i - Name of Kubernetes Host server and port (kubernetes.default:443)
    • j - diameter endpoint fqdn and port in the form fqdn:port (ocudr-nudr-diam-gateway.ocudr:3868)
    • k - fqdn or IP of http2-server in the format <ip/fqdn> (fqdn) (notify-stub-service.ocudr:80)
    • l - fqdn or IP for primary nrf stub and port in the format <ip/fqdn>:<port> (nrf-stub-server.ocudr:8080)
    • m - fqdn or IP for secondary nrf stub and port in the format <ip/fqdn>:<port> (nrf-stub-server2.ocudr:8080)
    • n - primary stub deployment name (nrfstub-ocstub-py)
    • o - secondary stub deployment name (nrfstub2-ocstub-py)
    • p - HTTPS port for UDR (443)
    • q - root certificate authority (CA) (caroot.cer)
    • r - Server certificate signed with root CA private key (apigatewayrsa.cer)
    • s - private key to .pem format (rsa_private_key_pkcs1.pem)
    • t - fqdn and port for 2nd diameter tool endpoint
    • u - MYSQL SERVICE ENDPOINT
    • v - NOTIFY STUB deployment name
    • w - Name of signaling in the format fqdn:port (ocudr-s2-ingressgateway-sig.ocudr-s2:80)
    • x - fqdn and port for UDR2 nudr-config (ocudr2-nudr-config.ocudr:5001)
    • y - fqdn and port for UDR2 DIAMETER_ENDPOINT (fqdn:port) (ocudr-s2-nudr-diam-gateway.ocudr-s2:3868)
    • z - FQDN and port for SCP stub (scp-stub-service:8080)
    • A - Deployment name for SCP stub (scpstub-notify-ocstub-py)
    • B - Bulk import helm name
    • C - ProvGw namespace (ocudr)
    • D - ProvGw endpoint in format fqdn:port (provgw-prov-ingressgateway.ocudr:80)
    • E - ProvGw endpoint https port(443)
    • F - ProvGw helm name
    • G - ProvGw config host in the format fqdn:port(provgw-provgw-config.ocudr:5001)
    • H - true if OCCNE is 1.9.x and above, else false (true)
    • I - fqdn and port for fourg stub in the form (fqdn:port)
    • J - fqdn and port for 1st diameter tool endpoint
    • K - fqdn and port for notify stub for TLS scenarios (tlsnotify-stub-service.ocudr:8443)
    • L - Service name of UDR1 provisioning ingressgateway in the format FQDN:PORT(ocudr-ingressgateway-prov.ocudr:80)
    • M - Service name of site2 UDR provisioning ingressgateway in the format FQDN:PORT(ocudr2-ingressgateway-prov.ocudr-s2:80)
    • N - Diameter Stub Tool1 Deploy Name (diamtoola-diam-stub)
    • O - Diameter Stub Tool2 Deploy Name (diamtoolb-diam-stub)
    • P - Migration tool Helm release name (migration-tool)
    • Q - Deployment name of the TLS notify stub (tlsnotifystub-ocstub-py)
    • R - Enable error response logging validation (true)
    • S - true (when underling CNE has support for CNLB Multus) to validate Traffic segregation feature else false
    • T - true if underlying platform supports dual stack, else false. All dual stack scenarios will be marked as skipped if false (Default: false)
    Figure 4-102 UDR NewFeatures Pipeline Configuration
  4. Click Save after making necessary changes. The Pipeline UDR-NewFeatures page appears.
  5. Click Build with Parameters. The page lists all the newly added features and displays the total number of features and the scenarios in each feature, name of each feature, and scenarios in each feature.
    Figure 4-103 UDR NewFeatures Pipeline Build with Parameter
    • Select the Configuration_Type. For more information, see Parameterization.
    • Choose the Select_Option(s), which are:
      • All: By default, it selects all the UDR test cases to run. Scroll-down and click Build to run all the test cases.
      • Single/MultipleFeatures: This option allows you to select any number of test cases you want to run from the list of total test cases available for execution.
  6. After selecting the test cases, scroll-down and click Build to run the selected UDR test cases.
Sample output with expected failures are as follows:
Stage:Stage_2 Group:no_igw_dr_metrics
  UDR_IGW_LCI_Header.feature:81  UDR_LCI_03_UserAgent_Err
  UDR_PCF_User_Agent_Header_New.feature:74  UDR_USER_AGENT_HEADER_02
  UDR_PCF_User_Agent_Header_New.feature:140  UDR_USER_AGENT_HEADER_03
Running UDR-NewFeatures (Model 2) pipeline test cases
    Figure 4-104 UDR NewFeatures Pipeline
    Important:
    You should not change any other value apart from line number 65 to 107. It means you can change the parameters marked as "b" - to - "R" as per user requirement. The parameters details are provided as comments in line number 14 to 57. The parameters description is as follows:
    Figure 4-105 UDR NewFeatures Pipeline Configuration
4.7.7.2 Running UDR Regression Pipeline
To run the UDR-Regression pipeline test cases:
Running UDR Regression Pipeline: Model 1: Single Site Deployment
  1. Click UDR-Regression and then, click Configure.
    Figure 4-106 UDR Regression Pipeline
    Important:
    Figure 4-107 UDR Regression Pipeline Configuration
    • h - Number of times the re-run of failed case is allowed (default as 1).
    • i - Name and port of Kubernetes Host server in the format FQDN:PORT(kubernetes.default:443).
    • j - fqdn and port for DIAMETER_ENDPOINT in the format FQDN:PORT (ocudr-nudr-diam-gateway:3868)
    • K - port for notify stub for TLS scenarios (8443)
    • P - Migration tool helm release name (migration-tool)
  5. Click Save. The Pipeline UDR-Regression page appears.
  6. Click Build with Parameters. A page listing all the regression features and displays the total count of the features and displays the total count of the features, count of scenarios in each feature, name of each feature, and scenarios in each feature.
    Figure 4-108 UDR Regression Pipeline Site Deployment
  7. Click Build to run the test cases.
    Figure 4-109 Consolidated Test Report
    • For information about Configuration_Type, see Parameterization.
    • The SUITSuite option selected as 'ALL' will run all suites except multiple site scenarios.
  UDR_Error_Response_log_validation.feature:299  UDR_Error_Response_log_Ondemand_05
  UDR_Suppressed_notification_to_the_initiator.feature:255  UDR_Suppressed_notification_to_the_initiator_05
Running UDR Regression Pipeline: Model 2: Multiple Site Deployment
    Figure 4-110 UDR Regression Pipeline
    Important:
    Figure 4-111 UDR Regression Pipeline Multiple Site Deployment
    • The SUITSuite option selected as 'MULTISITE' will run multiple site scenarios only.
    Figure 4-112 Consolidated Test Report
    Consolidated Test Report Consolidated Test Report
4.7.7.3 Running UDR HealthCheck Pipeline
To run health check on UDR:
  1. Navigate to UDR-HealthCheck pipeline and click Configure.
    Figure 4-113 UDR-HealthCheck Pipeline
    Figure 4-114 UDR-HealthCheck Configuration
    Important:
    Do not change any value other than line numbers 17 and 18. You can change the parameters marked as "a", "b" and "c"as per user requirement. The parameters details are provided as comments in line number 7 and 9. The parameters description is as follows:
    • c - -helm command alias (helm or helm2 or helm3)
  4. Click Save. The Pipeline UDR-HealthCheck page appears.
    Figure 4-115 UDR-HealthCheck Build Now
Figure 4-116 Sample Output
Sample Output
4.7.7.4 UDR NewFeatures Documentation
To view the documentation of UDR-NewFeatures, click Documentation in the left navigation pane of the UDR-NewFeatures pipeline to view all the UDR new features test cases.
Figure 4-117 UDR-NewFeatures Documentation
UDR new features list along with its description is as follows:
Table 4-15 UDR New Features List
Feature Description
UDR_Subscriber_Policy_Data_Export.feature This feature file validates the policy subscriber export feature in CSV format.
UDR_PNR_Multisite.feature This feature file validates the PNR scenarios on the Multisite.
UDR_Bug_Fix_25_1_100.feature This feature file validates the bugs raised for 25.1.100 release.
UDR_Default_Headers.feature This feature file validates multiple default headers received on the ingress gateway signaling and provisioning.
Click any feature to view its description.
4.7.7.5 UDR Regression Documentation
Click Documentation in the left navigation pane of the UDR-Regression pipeline to view all the UDR regression test cases.
Figure 4-118 UDR-Regression Documentation
4.7.8 Running EIR Pipelines
This section describes how to run EIR related pipelines. It includes:
4.7.8.1 Running EIR NewFeatures Pipeline
To run the EIR-NewFeatures pipeline test cases:
  1. Click EIR-NewFeatures. Click Configure in the left navigation pane. The General tab appears. The user must wait for the page to load completely.
    Figure 4-119 EIR NewFeatures Pipeline
    Important:
    You should not change any other value apart from line number 54 to 87. It means you can change the parameters marked as "b" - to - "I" as per user requirement. The parameters details are provided as comments in line number 12 to 46. The parameters description is as follows:
    • a - Selected NF.
    • b - NameSpace in which UDR is Deployed.
    • c - EIR signaling FQDN and PORT in the format FQDN:POR.
    • d - EIR provisioning FQDN and PORT in the format FQDN:PORT.
    • e - EIR config service FQDN and PORT in the format FQDN:PORT.
    • f - FQDN:PORT format for primary nrf-stub.
    • g - FQDN:PORT format for secondary nrf-stub.
    • h - FQDN and PORT of Kubernetes Host server in the format FQDN:PORT.
    • i - Helm name of EIR.
    • j - primary nrf-stub deployment name.
    • k - secondary nrf-stub deployment name.
    • l - primary nrf-stub metric port
    • m - secondary nrf-stub metric port
    • n - bulk import Helm name
    • o - Number of retries to check if pod down is successful.
    • p - Number of retries to check if pod up is successful.
    • q - Number of retries when ATS detects tcp connection failures.
    • r - Time interval in seconds between tcp connection retries.
    • s - re-run count.
    • t - FQDN and PORT of Prometheus server in the format FQDN:PORT.
    • u - prometheus uri apiName and apiVersion.
    • v - EIR HTTPS port.
    • w - root certificate authority for signalling ingressgateway.
    • x - Server certificate signed with root CA private key for signalling ingressgateway.
    • y - private key in .pem format for signalling ingressgateway.
    • z - root certificate authority for provisioning ingressgateway.
    • A - Server certificate signed with root CA private key for provisioning ingressgateway.
    • B - Private key in .pem format for provisioning ingressgateway.
    • C - True if HA prometheus else false (default: true).
    • D - Enable error response logging validation (true).
    • E - fqdn and port for diameter gateway in the format FQDN:PORT (oceir-nudr-diam-gateway:3868).
    • F - fqdn and port for diam-stub endpoint (diam-stub-service:3000).
    • G - Diameter Stub Tool1 Deploy Name (diamtoola-diam-stub).
    • H - true (when underling CNE has support for CNLB Multus) to validate traffic segregation feature else false (Default: false)
    • I - true if underlying platform supports dual stack, else false. All dual stack scenarios will be marked as skipped if false (Default: false)
    Figure 4-120 EIR NewFeatures Pipeline Configuration
    • Rerun count can be set to any desired value by changing option 's' in the pipeline script.
    • Number of retries to check if pod is down can be set by providing option 'o' in the pipeline script.
    • Number of retries to check if pod is up can be set by providing option 'p' in the pipeline script.
    • If ProvGw is deployed with segment details having UDR fqdn and port, provide option 'l' as port.
    • Option 'u' will take the value '/<domain name>/prometheus/api/v1 for CNE version 1.9 and above or OSO version 1.10.x and above. Run the below command, If domain name is not known. The domain name can be found after executing the command from ATS pod:
      Example:
  4. Click Save after making necessary changes. The Pipeline EIR-NewFeatures page appears.
    Figure 4-121 EIR Build with Parameters
  5. Click Build with Parameters. The page lists all the newly added features and displays the total count of features, counts of scenarios in each feature, name of each feature, and scenarios in each feature.
  6. To view consolidated and detailed stack trace results in case of any failures, click Test Results Analyzer in the left navigation pane. The test results analyzer report appears. For more information, see Test Results Analyzer.
    Figure 4-122 EIR-NewFeatures Pipeline Consolidated Automation Suite Test Report
4.7.8.2 Running EIR Regression Pipeline
Perform the below steps to run the EIR-Regression pipeline test cases:
  1. Click EIR-Regression and then, click Configure.
    Figure 4-123 EIR Regression Pipeline
    Figure 4-124 Discard Builds
    Discard and Build
    Important:
    Do not change any value other than from line number 48 to 76. You can change the parameters marked as "b" - to - "D" as per user requirement. The parameters details are provided as comments in line number 11 to 40. The parameters description is as follows:
    • a - Selected NF
    • c - EIR signaling FQDN and PORT in the format FQDN:PORT
    • i - helm name of EIR
    • s - re-run count
    • C - True if HA prometheus else false(default: true)
    • E - FQDN and port for diameter gateway in the format FQDN:PORT (oceir-nudr-diam-gateway:3868)
    • F - FQDN and port for diam-stub endpoint (diam-stub-service:3000)
    • G - Diameter Stub Tool1 deploy name (diamtoola-diam-stub)
  5. Click Save. The Pipeline EIR-Regression page appears.
    Figure 4-125 EIR Regression Configuration
    Setting rerun count and the number of retries to check the pod status and segment details is given below:
    • Option 'u' shall take value '/<domain name>/prometheus/api/v1 for CNE version 1.9 or above or OSO version is 1.10.x or above. Run the below command from ATS pod to find the domain name, if the domain name is not known:
      Example:
  6. Click Save. The Pipeline EIR-Regression page appears.
  7. Click Build with Parameters. A page listing all the regression features and displays the total count of the features and displays the total count of the features, count of scenarios in each feature, name of each feature, and scenarios in each feature.
    Figure 4-126 EIR Regression Build with Parameters
  8. A sample consolidated automation suite test report, when re-run is set to 0 is as follows
    Figure 4-127 EIR-Regression Consolidated Automation Suite Test Report
4.7.8.3 Running EIR HealthCheck Pipeline
To run health check on EIR:
  1. Navigate to EIR-HealthCheck pipeline and click Configure.
    Figure 4-128 EIR HealthCheck Pipeline
    Important:
    • c - helm command alias (helm, helm2, or helm3)
    Figure 4-129 EIR-HealthCheck Pipeline configuration
  4. Click Save. The Pipeline EIR-HealthCheck page appears.
    Figure 4-130 EIR-HealthCheck Build Now
4.7.8.4 EIR NewFeatures Documentation
To view the documentation of EIR-NewFeatures, click the Documentation link in the left navigation pane (present inside the build), as follows:
Figure 4-131 EIR-New Features Documentation
EIR new features list along with its description is as follows:
Table 4-16 EIR New Features List
Feature Description
NA NA
The Documentation option appears only if you have run the EIR-NewFeatures pipeline test cases atleast once.
Based on the functionalities covered under Documentation, the Build Requires Parameters page displays test cases. To navigate back to the Pipeline EIR-NewFeatures page, click Back to EIR-NewFeatures link available on top left corner of the page.
4.7.8.5 EIR Regression Documentation
Click Documentation in the left navigation pane of the EIR Regression pipeline to view all the test cases provided.
Figure 4-132 EIR Regression Documentation
