5 Background Processes on the SMS
Overview
This chapter provides a description of the programs or executables used by the System as background processes on an SMS.
Executables are located in the /IN/service_packages/SMS/bin
directory.
Some executables have accompanying scripts that run the executables after performing certain cleanup functions. All scripts should be located in the same directory as the executable.
It is a pre-requisite for managing these core service functions that the operator is familiar with the basics of Unix process scheduling and management. Specifically, the following Unix commands:- init (and inittab)
- cron (and crontab)
- ps
- kill
cmnConfigRead
Purpose
cmnConfigRead is used by the installation process to read the configuration files.
cmnConfigRead reads the Convergent Charging Controller configuration file (eserv.config), specified by the
Oracle_CONFIG_FILE environment variable and returns the value of path.
This can be used in commands to return the eserv.config specified path value.
Example:
FILENAME=`cmnConfigRead CCS.MyReport.filename
/IN/service_packages/CCS/tmp/MyReport.log`
This sets $FILENAME to the value of CCS.MyReport.filename.
If CCS.MyReport.filename is not present or there is an error,
$FILENAME defaults to /IN/service_packages/CCS/tmp/MyReport.log.
cmnReceiveFiles
Purpose
WARNING:
You must install the xinetd daemon as a prerequisite to running cmnReceiveFiles. You install this daemon by entering the following command:yum install xinetd
Startup
cmnReceiveFiles is started by the following entry in /etc/inetd.conf:
smsoperFile stream tcp nowait smf oper /IN/service_packages/SMS/bin/cmnReceiveFilesStartup.sh cmnReceiveFilesStartup.shParameters
cmnReceiveFiles does not have any direct parameters or configuration. Most details are provided by cmnPushFiles with the EDR.
The port cmnReceiveFiles listens on is set in /etc/services in the following line:
smsoperFile 2028/tcp # cmnAddInetServicesEntry
The port number must match the port specified by cmnPushFiles.Failure
If cmnReceiveFiles fails, the EDRs stay on the SLC and are moved to the retry directory. For more information about this process, see cmnPushFiles.
smsAlarmDaemon
Purpose
The smsAlarmDaemon executable runs on all alarm-managed nodes in the SMS system, including the SMS node itself. The role of smsAlarmDaemon is to gather alarms from the following sources:
- Error messages log (/var/adm/messages)
- Oracle error log ($ORACLE_BASE/admin/SID/bdump/alert_SID.log)
- Sigtran stack logs (/IN/service_packages/SLEE/stats) [If installed]
On the SMS machine itself, the error messages are written directly into the SMF_ALARM_MESSAGE database table. When run on other nodes, replication is used to update the SMF_ALARM_MESSAGE table.
Alarm replication and buffering
smsAlarmDaemon allows only a limited number of alarms to be sent within a configured time period. Both the number of messages that can be sent within a time period and the length of each period can be configured from the command line.
If more messages arrive than are allowed through the filter, the remaining messages are buffered and sent later. The buffer size is limited but can hold a large number of messages. If it needs to make more space, it discards messages of the lowest severity (informational). The buffer also has an upper limit, ensuring that the daemons do not grow unchecked. This upper limit defaults to a maximum of 1000 messages and can be configured.
If more than one of the same alarm appears within the configured time, only one update request is sent.
Startup
In an unclustered install, this task is started by entry sms5 in the inittab, through the /IN/service_packages/SMS/bin/smsAlarmDaemonSmsStartup.sh shell script.
In a clustered install, this task is started by the clustering software, through the /IN/service_packages/SMS/bin/smsAlarmDaemonCluster.sh shell script.
Configuration
smsAlarmDaemon accepts the following command-line arguments.
Usage:
smsAlarmDaemon [-l seconds] [-h seconds] [-n number] [-m number] [-p] [-d] [-a
path] [-r node] [-u user/pass] [-f] [-i] [-g] [-c number] [-t seconds]
The available parameters are:
| Parameter | Default | Description |
-a path |
Null |
Propagate alarms from the specified Oracle alert log to the database. By default, smsAlarmDaemon does not propagate alarms from the Oracle alert log. |
-c number |
1 | Commit Rate. The number of inserts before committing to the database. |
-d |
Sort messages |
Disable sorting of messages in the buffer by severity. Specifically, messages are kept in the buffer and subsequently written into the SMF database, in the same sequence in which they are received. |
-f
No filtering | Filtering. Delete duplicate alarms and increase the alarm count. |
-g |
Uses local time | GMT timezone. Use GMT instead of local time. |
-h seconds |
60 | Heartbeat message. Will be forced to be greater or equal to time period (seconds). |
-i |
Use fuzzy matching |
Filtering type. Use exact matching (rather than fuzzy matching). Indicates that duplicate matches should be performed on text only (that is, excluding digits). Note: Only valid when used in conjunction with -f. |
-l seconds |
2 | Filter Period. Duration between linked-list checks (in seconds). |
-n number |
5 |
Filter Number. The number of alarm messages allowed within the time period. Allowed values: Integers |
-m number |
1000 |
Maximum number of alarm messages to buffer. Allowed values: Integers 1-1000000 |
-p |
Do not drop messages | Drop low-priority messages when the buffer is full. Specifically, when -m number messages have been received but it is not yet time to write the buffer contents to the SMS database, low priority messages in the buffer are dropped in favor of higher-priority messages that may be received on its input stream. |
-r node |
Direct to the Oracle DB | Replication node. Specify the replication requester node. |
-t seconds
1 | Commit interval. The maximum interval between database commits (in seconds). |
-u user/pass
/ | Use the supplied Oracle user/password pair. |
Usage example
Here is an example of using smsAlarmDaemon:
smsAlarmDaemon -l 5 -h 30 -n 10 -m 2000 -p -d -a /volB/home/saich -r 750 -u
smf/smf -f -i -g -c 2 -t 2
- Filter Period (-I) = 5 seconds
- Commit Interval (-t) = every 2 seconds if 2 records not reached
- Commit Rate (-c) = every 2 number of inserts
- GMT timezone (-g) = Yes
- Filtering type (-i) = Exact match
- Filtering (-f) = Multiple alarms combined
- Oracle User (-u) = smf/smf
- Rep node (-r) = 750
- Oracle Alert Log location (-a) = /volB/home/saich
- Sort messages by severity (-d) = false
- Drop low priority messages (-p) = true
- Max number(-m) = 2000 records
- Filter Number (-n) = 10 each period
- Heart beat (-h) = Yes every 30 seconds
Failure
The smsAlarmDaemon on each alarm-managed node in the installation will by default generate a health-check alarm once per minute. These health check alarms will be relayed in the same fashion as all other alarms.
If these health check alarms are not received at the target destination, then the smsAlarmDaemon may have failed, and should be investigated.
smsAlarmManager
Purpose
The smsAlarmManager runs on the SMS. The role of the smsAlarmManager is to:
- Match alarm instances to the correct alarm types
- Automatically time out alarms that have not been cleared
- record alarm instances that have no alarm type match
Startup
This task is started by entry efm1 in the inittab, through the /IN/service_packages/EFM/bin/smsAlarmManagerStartup.sh shell script.
The inittab entry will be similar to that shown below:
efm1:34:respawn:su - smf_oper -c "exec /IN/service_packages/EFM/bin/smsAlarmManagerStartup.sh >> /IN
/service_packages/EFM/tmp/smsAlarmManager.log 2>&1" > /dev/null 2>&1 0<&1
Configuration
The smsAlarmManager accepts the following command line arguments.
Usage:
smsAlarmManager -a alarm_batch_size -c correlate_batch_size -o
timeout_commit_rate -p pending_timeout_length -r reload_defn_interval -s number -t
timeout_check_interval -u user/password
-a alarm_batch_size
20 | The number of alarms to attempt to find an ID for before carrying on to other tasks. |
-c correlate_batch_size |
20 | The number of non-correlated CLEAR alarms to attempt to correlate against open alarms before carrying on to other tasks. |
-o timeout_commit_rate |
1000 | The number of rows to update with automatic timeout before committing. |
280 | The amount of time given to another node in the cluster before assuming that it has failed to generate an ALARM_TYPE_ID |
-r reload_defn_interval |
86400 |
interval (s) for reloading the alarm definitions for the DB. Interval between reloading the regular expressions from SMF_ALARM_DEFN and SMF_ALARM_IGNORE. This should only be needed after an install of new packages/patches, and also acts to keep the preferred cache current |
-s
50000 | interval (microseconds) to sleep for when no work to do |
-t timeout_check_interval |
300 | Interval between checks for alarms that need to be closed with a timeout. |
-u "user/password" |
u ”/” The username/password combination used to log into the database. The default value is sufficient if smsAlarmManager is run from the smf_oper user account. |
smsAlarmManager will respond to SIGHUP, to reread the regular expressions from the database.
Failure
On startup the smsAlarmManager logs the following information:
smsAlarmManager startup.
Alarm Batch Size = 20
Correlate Batch Size = 20
Pending Timeout Length = 280
Timeout Check Interval = 300
Reload Defn Interval = 86400
Timeout Commit Rate = 1000
Sleep Time (microseconds) for no Work = 50000
Username/Password = /
Aug 30 15:31:07 smsAlarmManager(18347) NOTICE: smsAlarmManager started.
Cache successfully reloaded Output
Cache successfully reloadedsmsAlarmRelay
Purpose
The smsAlarmRelay is responsible for implementing the SNMP Agent. It runs continuously, polling the database to check for new entries written into the SMF_ALARM_MESSAGE table by the smsAlarmDaemon processes running on the various managed nodes which form the SMS-managed installation.
The information in the SMF_ALARM_MESSAGE is relayed to the destinations, as configured in the SMF_ALARM_HANDLER table using the Alarm Notification screens. For more information about how to configure alarm relay destinations, see the Service Management System User's Guide.
You can configure smsAlarmRelay to do the following:
- Send X.733 information with all forwarded alarms
- Check for SNMP requests (to resend alarms)
- Send version 3 (instead of version 1) SNMP traps
Startup
In an unclustered installation, this task is started by entry sms1 in the inittab, through the /IN/service_packages/SMS/bin/smsAlarmRelayStartup.sh shell script.
In a clustered installation, this task is started by the cluster software, through the /IN/service_packages/SMS/bin/smsAlarmRelayCluster.sh shell script.
Parameters
The smsAlarmRelay accepts the following command line
arguments.
Usage:
smsAlarmRelay [-u <usr/pwd>] [-s <secs>] [-p] [-x] [-t] [-e]
SNMP processing is not currently enabled by default.The available parameters are:
-u
| Syntax: | -u user/pwd
| Description: | The Oracle user and password pair. |
| Type: | String |
| Optionality: | Optional (default used if not set). |
| Allowed: | |
| Default: | / |
| Notes: | |
| Example: |
-s
| Syntax: | -s seconds
| Description: | The number of seconds to sleep between database checks. |
| Type: | Integer |
| Allowed: | |
| Default: | 1 |
| Notes: | |
| Example: |
-p
| Syntax: | -p
| Description: | Whether to do SNMP processing or not. |
| Type: | Boolean |
| Allowed: |
set: Use SNMP not set: Do not use SNMP |
| Default: | not set |
| Notes: | |
| Example: |
-x
| Syntax: | -x
| Description: | Whether to send SNMP traps in X.733 format or not. |
| Type: | Boolean |
| Allowed: |
| Notes: | |
| Example: |
-t
| Syntax: | -t |
| Description: | Whether to format the enterprise id with the severity. |
| Type: | Boolean |
| Allowed: |
| Notes: | |
| Example: |
-e
| Syntax: | -e
| Description: | Loads the EFM rules from the smf_alarm_relay_filter database table to provide alarm filtering. |
| Type: | Boolean |
| Optionality: | Optional. |
| Allowed: | Set or not set. |
| Default: | Not set |
Resend Alarms
The smsAlarmRelay can be configured to listen for a request to resent all alarms above a certain alarm number. This is designed for use by an SNMP Manager that has been off line for a while and may have missed some alarm notifications.
To request a resend of alarms the relay application needs send an SNMP set-request using the format described in the variables.mib file.
The smsAlarmRelay will listen using the port number specified as the listenPort parameter in snmp.cfg. The alarmRelay keeps an internal count of the highest alarm number sent. When a valid SNMP set-request is received, the alarmRelay will take note of the number in the message and send all alarms with an alarm ID greater than this number.
Failure
If these health check alarms are not received at the target destination, then the smsAlarmRelay may have failed, and should be investigated.
Output
The smsAlarmRelay.sh writes error messages to the system messages file, and also writes additional output to /IN/service_packages/SMS/tmp/smsAlarmRelay.log.
The following table summarizes the information in the Service Management System User's Guide.
| Destination | Field Content |
| SNMP | Host name of the target SNMP TRAPS recipient |
| FILE | Name of a file to which the daemon has write access |
| NFM | Host name of the NFM target. |
| Q3 | Host name of the Q3 target. |
| SNMP | Host name of the SNMP target. |
| NORELAY | The field is empty, as the alarm is not forwarded to a target |
Setting the target to NORELAY will stop any other notification rules being actioned. Consequently, the NORELAY rules must be very specific. Otherwise an important alarm may accidentally be missed.smsConfigDaemon
Purpose
smsConfigDaemon exists on both the source node (example, SMS) as well as the target node
(example, SLC). It takes an optional parameter (-m) which decides its
action.
When run with the -m, it monitors for changes to the master XML file
(example, esgConfigMaster.xml). If it finds changes made to the master config
file, smsConfigDaemon will call smsSendConfig.sh.
If the the -m parameter is missing, smsConfigDaemon monitors for changes
to the derived eserv.config file (example, eserv.config.derived) on the
target node, and calls smsApplyConfig.sh if it finds changes to the file.
About Database Connections
smsConfigDaemon connects to the database on a local or a remote SMS node by using the user credentials set in the following environment variables in smsConfigVariables.sh:
- SMP_DB_USER_NAME
- SMP_DB_CONNECT_STRING
- SMP_DB_PASSWORD
For connections to a:
- Local database, specify the username and password by setting the SMP_DB_USER_NAME and SMP_DB_PASSWORD variables. You can set only the user name in the SMP_DB_USER_NAME variable, if required.
- Remote database, specify the username and password by setting the SMP_DB_USER_NAME and SMP_DB_PASSWORD variables, and specify the SID of the remote database in the SMP_DB_CONNECT_STRING variable. You can set the SMP_DB_USER_NAME and the SMP_DB_CONNECT_STRING variables only, if required.
- Local or a remote database by using the Oracle wallet secure external password store, specify only the TNS connection string in the SMP_DB_CONNECT_STRING variable, where the connection string is the alias defined for the username and password credentials in the external password store. This alias can be either a TNS name or a service name from tnsnames.ora. The SMP_DB_CONNECT_STRING variable has the following format: "\@connect_string".
If you set none of these variables, smsConfigDaemon connects to the database by using the default value of "/".Startup
smsConfigDaemon is started by the script smsConfigDaemonScript. This process is driven by the system and is not intended to be changed by the user.
Configuration
For more information on the parameters used by smsConfigDaemon, see smsConfigDaemonScript.
Purpose
smsConfigDaemonScript is responsible for starting the smsConfigDaemon process. It also runs the smsConfigVariables.sh script which includes a set of configurable environment variables that are used by smsConfigDaemon and its helper scripts; for example, to set the username and password credentials for connecting to the Oracle database.
For more information about smsConfigDaemon, see smsConfigDaemon.
Environment Variables Set in smsConfigVariables.sh
The smsConfigVariables.sh file is located in the following directory:
Table 5-1 lists descriptions for the environment variables that you can configure in the smsConfigVariables.sh file and provides their default values.
Table 5-1 Descriptions for the Environment Variables
| Variable | Default Value | Description |
| SMP_DB_USER_NAME | None | The Oracle user that smsConfigDaemon uses to log in to the Oracle database. |
| SMP_DB_PASSWORD | None | The password for the Oracle user that smsConfigDaemon uses to log in to the Oracle database. |
| SCP_DB_USER_NAME | None | The Oracle user that the smsSignalConfigChange script uses to access sqlplus. |
| SCP_DB_PASSWORD | None | The password for the Oracle user that the smsSignalConfigChange script uses to access sqlplus. |
| SMP_DB_CONNECT_STRING | None | Any extra connect parameters that smsConfigDaemon requires to log in to the Oracle database. |
| DETECTION_PERIOD | 10 | The number of seconds between smsConfigDaemon change detection attempts. |
| RETRY_PERIOD | 60 | The number of seconds between smsConfigDaemon sendConfig retry attempts. |
| SLEEP_TIME | 100 | The number of milliseconds to sleep inside the smsConfigDaemon main loop. |
Configuration
smsConfigDaemonScript sets the configurable parameters for smsConfigDaemon and its helper scripts.
smp_db_user user/password |
Oracle user/password for the SMF. Example: |
scp_db_user user/password |
Oracle user/password for the smsSignalConfigChange script should use for sqlplus. Example: |
connect_string |
Any extra connect parameters to be used by smsConfigDaemon | |
detection_period |
10 | Period (in seconds) after which smsConfigDaemon attempts to detect changes. |
retry_period |
60 | Period (in seconds) after which smsConfigDaemon attempts to retry initiating sendConfig. |
sleep_time |
100 | Period (in milliseconds) to wait inside smsConfigDaemon's main loop. |
source_root |
/IN/html/Configuration |
Location where all the XML-driven config files and directories are stored. Not to be changed by the user. |
master_xml_dir |
Location of the master config.xml file. Not to be changed by the user. |
master_config_file |
esgConfigMaster | Name of the master configuration xml file. |
master_config_file_full_path |
Full path of the master configuration file monitored by the SMP config daemon (derived from the master config xml file). | |
archive_xml_dir |
Location where the master config.xml files are archived to prior to modification. | |
derived_eserv_dir |
Location of the derived eserv file. | |
pending_dir |
Location where the config files from failed updates are held, pending a retry. | |
xml_convert_script |
Location of the XML to eserv.config converter script. | |
target_root |
/IN/service_packages/Configuration | Location of the USP nodes where the eserv.config file is sent. |
target_eserv_config_dir |
Location on the USP nodes where the eserv.config file is pushed out to. | |
derived_eserv |
eserv.config.derived | Name of the eserv.config file sent to the target nodes. |
derived_config_file_full_path |
Full path of the derived config file monitored by the SCP config daemon (derived from the eserv.config file sent to the target nodes) | |
management_interface_host |
localhost | Location of the management interface. |
management_interface_port |
Port is the management interface listening on. |
It is not recommended to change the values of these parameters. All necessary configuration is done at installation time by the configuration script; this section exists for information only. Please contact Oracle support prior to attempting any modification to configuration data.Startup
smsConfigDaemonScript is started by the system and is not intended to be changed by the user
Failure
If smsConfigDaemonScript encounters problems, the smsConfigDaemon will fail to start and the updated eserv.config data will not be copied to the relevant platforms. Appropriate alarm messages are generated.
Output
The smsConfigDaemonScript writes error messages to the system messages file, and also
writes additional output, when smsConfigDaemon has been started using the -m
option, to the /IN/service_packages/SMS/tmp/smsConfigDaemonMaster.log.
If the -m option is not used, output will be written to
/IN/service_packages/SMS/tmp/smsConfigDaemonClient.log.
smsCdrArchiver
Purpose
smsCdrArchiver performs a daily search of a specified input directory for CDR or EDR files to archive, and archives them to a file in a specified output directory. It also compresses and deletes old archive files according to the rules specified in the smsCdrArchiver configuration.
About Archive File Names
The name of the archive file output daily by smsCdrArchiver has the following format:
[machineName]+[outputFileTag]+[_serviceType]+_Date[-HH]+[outputFileSuffix]
Where
- machineName is the name of the machine that generated the data record.
smsCdrArchiver prefixes the output file name with the machine name when you set the
useMachineNameparameter to true. - outputFileTag is an identifying tag for the output file that you
specify in the optional
outputFileTagparameter. - serviceType is the service type that generated the data record.
smsCdrArchiver includes the service type in the output file name when you set the
useServiceTypeparameter to true. - Date is the date timestamp for the data record formatted as: YYYYMMDD.
- HH is the record hour that is appended to the Date value by using the
following format: YYYYMMDD-HH, when you set the
UseRecordHourparameter to true. - outputFileSuffix is the suffix specified in the optional
outputFileSuffixparameter that is appended to the output file name.
File name example
smsCdrArchiver has the following output file parameters configured in the eserv.config file:
smsCdrArchiver = {
outputFileTag = "ACS"
outputFileSuffix = ".cdr"
useRecordHour = true
useMachineName = true
useServiceType = true
} For machine name "telco-p-uas", service type "ACS", and timestamp "2014061512", the following output file would be created:
telco-p-uasACS_ACS_20140615-12.cdr
Startup
The smsCdrArchiver process is started by the smsCdrArchiver.sh script, that is located in the /IN/service_packages/SMS/bin/ directory. The smsCdrArchiver.sh script runs in the crontab for the smf_oper user.
If smsCdrArchiver.sh script or smsCdrArchiver binary is not found under /IN/service_packages/SMS/bin directory, copy them from /IN/service_packages/SUPPORT/bin directory.Rename smsCdrArchiverStartup.sh to smsCdrArchiver.shbefore moving the file to /IN/service_packages/SMS/bin directory.
Configuration
SMS = {
smsCdrArchiver = {
recordType = "CDR"
inDir = "/cdr/processed"
outDir = "/cdr/CDR-archive"
writeIndexFile = false
useDateOutDirs = true
prefixFileName2Data = false
fileMatch = "telco-p-uas\*_ACS_"
fileOwner = "smf_oper"
compressionCommand = "GZIP"
compressModTime = 2
compressImmediately = false
compressMinRunTime = 0
deleteModTime = 31
runCleanupHour = 03
BFT = {
exportBFTDataRecords = true
exportBFTOutDir = "/cdr/export/BFT"
exportBFTOutputFileSuffix = ""
changeBFTOutputFileGroup = ""
compressBFTDataRecords = true
exportBFTKeepDays = 4
ext5BFTHex2Dec = false
zeroPadExt5Hex2Dec = 0
} smsCdrArchiver Parameters
The smsCdrArchiver section accepts the following parameters.
recordType
| Syntax: | recordType = "str" |
| Description: |
Defines the type of data records to archive. When
| Type: | String |
| Optionality: | Required |
| Allowed: | CDR, EDR |
| Default: | |
| Notes: | |
| Example: | recordType = "CDR"
inDir
| Syntax: | inDir = "dir" |
| Description: | The directory that contains CDR or EDR input files. |
| Type: | String |
| Allowed: | A vaild directory path and name. |
| Default: | |
| Notes: | ccsCdrArchiver will not search sub-directories of the specified directory for input files. |
| Example: | inDir = "/cdr/processed" |
outDir
| Syntax: | outDir = value
| Description: | The output directory for the archived CDR or EDR file. |
| Type: | String |
| Allowed: | A valid directory path and name |
| Default: | |
| Notes: | |
| Example: | outDir = "/cdr/CDR-archive"
outputFileTag
| Syntax: | outputFileTag = "str"
| Description: | An identifying tag for the output file, such as the name
of the application that generated the data records. For example, for ACS
CDRs set outputFileTag to "ACS".
| Type: | String |
| Optionality: | Optional |
| Allowed: | |
| Default: | Not used |
| Notes: | |
| Example: | outputFileTag = "ACS" |
outputFileSuffix
| Syntax: | outputFileSuffix = "suffix"
| Description: | The suffix to append to the name of the output file; for example, ".cdr" or ".edr" . |
| Type: | String |
| Allowed: | |
| Notes: | |
| Example: | outputFileSuffix = ".cdr" |
useRecordHour
| Syntax: | useRecordHour = true|false
| Description: |
When set to true, the record hour is appended to the record date in the archive output file name by using the following format: YYYYMMDD-HH Where YYYYMMDD is the record date, and HH is the record hour. |
| Type: | Boolean |
| Allowed: | true, false |
| Notes: | |
| Example: | useRecordHour = true
useMachineName
| Syntax: | useMachineName = true|false
| Description: | When set to true, codephfix the archive output file name with the name of the machine that generated the data record. |
| Type: | Boolean |
| Optionality: | Optional (default used if not set) |
| Default: | false |
| Notes: | The machine name can only be used in the output file name if the input file name has been codephfixed with the machine name. This is the standard used by the cmnPushFiles process. |
| Example: | useMachineName = true |
useServiceType
| Syntax: | useServiceType = true|false
| Description: |
Include the data record service type tag in the output file name. The service type:
| Type: | Boolean |
| Default: | false |
| Notes: | |
| Example: | useServicetype = true
writeIndexFile
| Syntax: | writeIndexFile = true|false
| Description: |
When set, smsCdrArchciver writes an index file that links data record entries to the output file name. The name of the index file is outputFilename.idx, where outputFilename is the archive output file name. Index file entries have the following formats:
Where:
You use the index file to search, based on the fields listed above, for the identity of the archived output file containing the complete record. |
| Type: | Boolean |
| Default: | false |
| Notes: | Using this option requires extra processing that can cause the smsCdrArchiver to run more slowly. |
| Example: | writeIndexFile = true
useDateOutDirs
| Syntax: | useDateOutDirs = true|false
| Description: | When set to true, smsCdrArchiver separates output files
into date (YYYYMMDD) directories based on the TCS or RECORD_DATE values.
The output files are written to the following location:
outDir/YYYYMMDD/outFile.
| Type: | Boolean |
| Default: | false |
| Example: | useDateOutDirs = true
codephfixFileName2Data
| Syntax: | codephfixFileName2Data = true|false
| Description: |
When set to true, smsCdrlArchiver codephfixes the archived
data record with the filename of the CDR or EDR record, by using the
following format: Where:
You can use this option to identify the original filename in case of loading errors; for example, for CCS EDRs that are post-processed by the ccsCdrLoader. |
| Type: | Boolean |
| Default: | false |
| Notes: | You should use this option for EDRs only. |
| Example: | codephfixFileName2Data = true |
fileMatch
| Syntax: | fileMatch = "str"
| Description: |
Use to search for file names that match the codephfix defined by the specified regular excodephssion. You can define more than one codephfix to match. The codephfixes should be enclosed in double quotes "", and separated by white space. You can include the following wild cards in codephfix strings:
| Type: | String |
| Allowed: | |
| Notes: | |
| Example: | filematch = "telco-p-uas\*_ACS_" |
fileOwner
| Syntax: | fileOwner = "str" |
| Description: | When set, smsCdrArchiver locates only those files that are owned by the specified user. |
| Type: | String |
| Allowed: | |
| Notes: | |
| Example: | fileOwner = "smf_oper" |
comcodephssionCommand
| Syntax: | comcodephssionCommand = "str"
| Description: | Specifies the comcodephssion utility to use for comcodephssing old archive files. |
| Type: | String |
| Allowed: | GZIP, BZIP2, PBZIP2 |
| Default: | GZIP |
| Notes: | |
| Example: | comcodephssionCommand = GZIP |
Billing Failure Treatment CDR parameters
The Billing Failure Treatment (BFT) parameters define rules for exporting BFT data records to a special directory for BFT post processing by the billing server.
The BFT parameters apply only to ACS CDRs, where therecordType field is set to "CDR".
smsCdrArchiver = {
BFT = {
} exportBFTDataRecords
| Syntax: | exportBFTDataRecords = true|false |
| Description: | Enables BFT CDRs to be exported to the directory specified by the exportBFTOutDir parameter. |
| Type: | Boolean |
| Default: | false |
| Notes: | |
| Example: | exportBFTDataRecords = true |
exportBFTOutDir
| Syntax: | exportBFTOutDir = "str"
| Description: | The directory path for the directory to which to export BFT CDRs. |
| Type: | String |
| Allowed: | |
| Default: | |
| Notes: | |
| Example: | exportBFTOutDir = "/cdr/export/BFT" |
| Syntax: | exportBFTOutputFileSuffix = "str"
| Description: | Specifies the suffix for the BFT output file. If this is unset, then the original input file name is used. |
| Type: | String |
| Allowed: | |
| Default: | |
| Notes: | White spaces are replaced by the _ (underscore) character. |
| Example: | exportBFTOutputFileSuffix = "" |
| Syntax: | changeBFTOutputFileGroup = "str" |
| Description: | Sets the group file permissions for the output file; for example, to change group read/write access to allow third parties to collect BFT CDRs for post processing. |
| Type: | String |
| Allowed: | The group file permissions must be valid for the user running the smsCdrArchiver script. |
| Default: | |
| Notes: | If the group is invalid, or left undefined, then the group file permissions are not changed. |
| Example: | changeBFTOutputFileGroup = ""
| Syntax: | compressBFTDataRecords = true|false
| Description: | Set to true to compress the BFT oputput files as they are written. If set to false, then the compressModTime parameter does not take the BFT CDR files into account and no further compression will be done. |
| Type: | Boolean |
| Default: | true |
| Notes: | The compression utility used is defined by the compressionCommand parameter. |
| Example: | compressBFTDataRecords = true
exportBFTKeepDays
| Syntax: | exportBFTKeepDays = int
| Description: | The number of days to keep the exported BFT CDRs before they are deleted. |
| Type: | Integer |
| Allowed: | |
| Default: | 1 - The default value of one will be used if you specify a value that is less than one. |
| Notes: | |
| Example: | exportBFTKeepDays = 4 |
ext5BFTHex2Dec
| Syntax: | ext5BFTHex2Dec = true|false |
| Description: | Whether the ACS CDR EXT5 field is written as a hexidecimal value, such as EXT5=0000000A, or whether it is converted to a decimal value, such as EXT5=10, for the BFT post-processing tools. |
| Type: | Boolean |
| Allowed: |
| Default: | false |
| Notes: | |
| Example: | ext5BFTHex2Dec = false |
zeroPadExt5Hext2Dec
| Syntax: | zeroPadExt5Hext2Dec = int
| Description: | The number of leading zeros to use when padding the converted EXT5 decimal number (if ext5BFTHex2Dec is set to true). Set to 0 (zero) or 1 (one) for no leading zero padding. |
| Type: | Integer |
| Allowed: | |
| Default: | 0 |
| Notes: | If zeroPadExt5Hext2Dec is set to a negative number then the decimal number will be padded so that it is the same length as the original hex number. For example, the hex number: 0000000A is converted to the decimal number: 00000010. |
| Example: | zeroPadExt5Hext2Dec = 0
smsCdrProcess.sh
Purpose
smsCdrProcess.sh performs basic EDR processing and archiving. smsCdrProcess.sh runs the smsProcessCdr binary with specified command line parameters. One output EDR file is created for each input EDR file.
smsCdrProcess.sh can also be configured to prevent processing the EDR.
For more information about how smsProcessCdr processes EDRs, see smsCdrProcess.sh.
EDR Format
The format of the records in the EDR file are specific to the application which generates them. The most commonly used EDR format processed by this mechanism is the ACS "Pipe Tag LF" format, which uses TAG=VALUE pairs separated by the "|" character. Records are line field delimited.
For more information about this format, see the ACS Technical Guide.
Startup
This task is run in the crontab for smf_oper, by default at 1:00 am system clock time. It is scheduled as the /IN/service_packages/SMS/bin/smsCdrProcess.sh script.
The script runs the smsProcessCdr process with set parameters.
Configuration
The following command in the smsProcessCdr.sh prevents the EDR from being processed and copies it directly to the output directory.
Example Command:
$BINDIR/smsProcessCdr -d $CDRDIR -D $OUTDIR -s $INSFX -S $OUTSFX
To process EDRs, use the following command instead:
Example Command: $BINDIR/smsProcessCdr -t $OUTFMT -d $CDRDIR
smsDbCleanup.sh
Purpose
This task executes SQL statements to delete old data from the following table.
| SQL Statement | Data deleted |
| SMF_AUDIT | Audit trail of database changes. |
| SMF_STATISTICS | Application bulk usage counters. |
| SMF_ALARM_MESSAGE | System messages. |
| SMF_ALARM_UNKNOWN | System messages which do not match any known alarm definitions. |
Startup
This task is run in the crontab for smf_oper, by default at 1:00 am system clock time. It is a shell script, specifically /IN/service_packages/SMS/bin/smsDbCleanup.sh.
Parameters
The decision on when to delete data is determined according to various parameters configured in eserv.config. These values can be changed by the usual eserv.config editing method, subject to database sizing limitations and availability of space for additional historical data.
The default parameters are:
alarmAge |
7 | Delete records older than this number of days. Refers to the actual age of the alarm, and controls the deletion of all alarms of a certain age, regardless of whether they are noted (closed). |
alarmMax
100000 | Maximum number of records to keep. After this value is reached, smsDbCleanup.sh delete records. |
alarmNotedAge
3 | Controls the deletion of noted (closed) alarms. |
auditAge
7 | Delete records older than this number of days. |
commit
100 | Number of statistic records to delete before committing the deletions. |
statsAge
30 | Delete records older than this number of days. |
unknownMax
5000 | Maximum number of alarms to keep in table smf_alarm_unknown. After this value is reached, new additions cause oldest to be deleted from the table. |
smsLogCleaner
Purpose
smsLogCleaner archives the following types of log files:
- Convergent Charging Controller process log files (/IN/service_packages/Product/tmp/Process.log)
- System log files (syslog)
For more information, see System Administrator's Guide.
Startup
This task is run in the crontab for smf_oper. By default, it runs at 30 minutes past each hour. It is run via the shell script:
/IN/service_packages/SMS/bin/smsLogCleanerStartup.shParameters
smsLogCleaner supports the following command-line options:
Usage
smsLogCleaner -c configuration_file -d days -s storage_file [-h]
-c configuration_file |
logjob.conf |
The name of the configuration file. |
-d days |
7 |
How often to clean the archive (in days). |
-s storage_file |
storage.txt |
The name of the storage file. |
-h |
Not applicable. |
Provides help information. |
At installation, the cronjob is configured to execute by default with the following command-line parameters:
-c/IN/service_packages/SMS/etc/logjob.conf
-s/IN/service_packages/SMS/tmp/sms_storage.txt
-d 7
An operator can change these values, subject to disk storage availability and site-specific archiving policies.
Failure
If the process is not running, log files in the following directory will accumulate in size and age beyond the expected values.
Output
The smsLogCleaner run by smf_oper writes error messages to the system messages file, and also writes additional output to /IN/service_packages/SMS/tmp/smsLogCleaner.log.
logjob.conf
The logjob.conf configuration file has the following format:
log file age hrs size size arcdir dir logonce zip size
| Parameter | Description |
| log file |
The full directory path and name of the file to be cleaned. You can include the '*' wildcard in the file name if required. Example:
Tip: Most processes and tools document where their output is written to in their Output topic. |
| age hrs |
Sets the minimum age, in hours, for the log file before it is cleaned. You must set either this parameter or the size parameter. If both parameters are set, the log file is cleaned when either condition is met. Example: age 100 |
| size size |
Sets the minimum size for the log file before it is cleaned. You must set either this parameter or the age parameter. If both parameters are set, the log file is cleaned when either condition is met. Examples: size 60K, or size 60M |
| arcdir dir |
The directory for storing the old log file. If this parameter is not specified, the log file is deleted. Example:
| logonce | Include this parameter if you want to keep only one archived version of the log file. |
| zip size |
Automatically compress log files that exceed the specified size. Example: zip 100M |
smsMergeDaemon
Purpose
The smsMergeDaemon monitors the connections between the SMS and SLCs via a heartbeat. The smsMergeDaemon will initiate a startMerge to resyncronise the SMS and SLCs where:
- the infMaster on the disconnected SLC reports that it has received updates that would have normally gone to the SMS or it has an updateLoader or updateRequester pointing to it, and
- the heartbeat to the SMS and SLC have been stable for a period.
For more information about the startMerge process, see startMerge.
Startup
This task is started by entry sms9 in the inittab, via the shell script:
/IN/service_packages/SMS/bin/smsMergeDaemonStartup.sh
smsMergeDaemon is not used in a clustered install.Parameters
The smsMergeDaemon accepts the following command line arguments.
Usage:
smsMergeDaemon -nodeid
| -nodeid | 1000 | The node number of the smsMergeDaemon. |
The rest of the configuration details are taken from replication.def File. Relevant parameters include:
- HB PERIOD
- TICK_TIME 1000
- SMS_PORT 7
- REP_PATH "/IN/service_packages/SMS/etc/replication.config"
- MERGE_INTERVAL 600
- MAX_CONNECTION_TIME 100000000
- MAX_ROUNDTRIP 3
- LONG TIMEOUT
smsMaster
Purpose
The smsMaster is the central correlation point for the replication system.
smsMaster:
- Sends notifications of updates to remote updateLoaders to be loaded into secondary databases.
- Accepts update requests from remote systems that wish to change the master database (including the smsStatsDaemon, RequesterIF and smsAlarmDaemon).
- Correlates full resynchronization with remote databases, and communicates with inferior masters which can assume some smsMaster functions in the case of a platform or network failure.
Startup
This task is started by entry sms7 in the inittab, through the shell script:
/IN/service_packages/SMS/bin/smsMasterStartup.sh
Configuration
The smsMaster supports the following command-line options:
Usage:
smsMaster -maxpending int
-maxpending
| Syntax: | -maxpending int
| Description: | The size of pending request queue. |
| Type: | Integer |
| Allowed: | |
| Default: | 10000 |
| Notes: | |
| Example: |
smsNamingServer
Introduction
The smsNamingServer listens for IORs being exported from CORBA processes, and stores them in the database in the IORS table owned by Oracle user SMF. It also serves requests to read IOR strings from the database.
This functionality is required to support processes that wish to store/retrieve IOR strings, but which do not have Oracle access to the SMF database instance, for security or licensing reasons.
Startup
In an unclustered installation, this task is started by entry sms2 in the inittab, through the shell script:
/IN/service_packages/SMS/bin/smsNamingServerStartup.sh
In a clustered installation this task is started by the cluster software, through the shell script:
/IN/service_packages/SMS/bin/smsNamingServerCluster.sh
Parameters
The smsNamingServer supports the following command-line options:
Usage:
smsNamingServer [-u usr/pwd] [-p port]
-u
| Syntax: | -u usr/pwd
| Type: | String |
| Allowed: | |
| Default: | / |
| Notes: | |
| Example: | -u / |
-p
| Syntax: | -p port
| Description: | The port number on which to listen for requests. |
| Type: | Integer |
| Allowed: | |
| Default: | 7362 |
| Notes: | |
| Example: | -p 7362
smsReportsDaemon
Purpose
smsReportsDaemon is a CORBA server process that generates reports on demand.
When the SMS user interface (UI) Reports function requests a report, smsReportsDaemon:
- Returns the report output filename
- Writes the report output to a specified directory on the SMS
The SMS UI Reports function then displays the report. For more information about the SMS Reports function, see Service Management System User's Guide.
Startup
In an unclustered installation, smsReportsDaemon is started by entry sms3 in the inittab, via the shell script:
/IN/service_packages/SMS/bin/smsReportsDaemonStartup.sh
In a clustered installation, smsReportsDaemon is started by the cluster software, via the shell script:
/IN/service_packages/SMS/bin/smsReportsDaemonCluster.sh
Parameters
smsReportsDaemon supports the following command-line options.
Usage:
smsReportsDaemon [-h host] [-p port] [-i dir] [-o dir] [-f dir] [u user/password]
[t host] [s port] [z timezone] [m num]
| -h host | Value returned by gethostname |
smsNamingServer hostname. Allowed value type: ASCII String |
| -p port | 7362 |
smsNamingServer port number. Allowed value type: Number |
| -i dir | /IN/service_packages/SMS/input |
Report scripts/binaries input directory. Allowed value type: ASCII String |
| -o dir | /IN/service_packages/SMS/output |
Generated report output directory. Allowed value type: ASCII String |
| -f dir | /IN/service_packages/SMS/input | The setTZ.sql file directory. By default, the file is located in /IN/service_packages/SMS/input. |
| -u user/password |
Oracle SMF database username and password. Allowed value type: ASCII String |
| -t host | Default determined by CORBA | CORBA transport layer hostname. |
| -s port | Default determined by CORBA | CORBA transport layer port number. This parameter is ignored if the CorbaServices section is present in the eserv.config configuration file. For more information, see Configuring Connections for CORBA Services. |
| -z timezone | Timezone in which the smsReportsDaemon SQL queries are run generating the report output. | |
| -m num | 2 | Maximum number of concurrent reports per node. |
Output
smsReportsDaemon writes error messages to the system messages file, and writes additional output to /IN/service_packages/SMS/tmp/smsReportsDaemon.log.
smsReportsDaemon writes report output to subdirectories of the specified output directory (by default, /IN/service_packages/SMS/output). The subdirectory depends on the application and category defined for the report:
/IN/service_packages/SMS/output/Application/Category
The report output filename is in the format:
YYMMDDHHmmss.9_random_characters.txt
Interactive Reports
smsReportsDaemon generates on-demand reports.
Reports are defined through SQL commands, shell scripts, or compiled executable programs. Additional reports can be created and made available for on-demand and scheduled generation as a post-installation manual function. For more information, see Reports.
At startup, smsReportsDaemon publishes its IOR string via the smsNamingServer. If not
specified, the IP port number on which the CORBA service is provided will be determined
by the CORBA framework. In most installations, a firewall is used to protect the SMS
host, and hence the CORBA service port must be fixed. Use the -s
parameter for this purpose.
smsReportScheduler
Purpose
The smsReportScheduler monitors the database table SMF_REPORT_SCHEDULE for entries inserted via the SMS Java screens.
smsReportScheduler sleeps until the next report is due to be run. The output of the report is optionally copied to a specified directory, spooled to a specified printer, or sent to a specified email address. For more information about how to schedule reports which will be performed periodically and how to configure the report destination, see the Service Management System User's Guide.
Startup
In an unclustered installation, this task is started by entry sms4 in the inittab, via the shell script:
/IN/service_packages/SMS/bin/smsReportSchedulerStartup.sh
In a clustered installation this task is started by the cluster software, via the shell script:
/IN/service_packages/SMS/bin/smsReportSchedulerCluster.sh
Parameters
The smsReportScheduler supports the following command-line options:
Usage:
smsReportScheduler [-i dir] [-o dir] [-u usr/pwd] [-v] [-z timezone]
-i dir
| Syntax: | -i dir
| Description: | The input directory for report generation scripts/binaries dir. |
| Type: | String |
| Allowed: | |
| Default: | /IN/service_packages/SMS/input |
| Notes: | |
| Example: |
-o dir
| Syntax: | -o dir
| Description: | The output directory for report generation. |
| Type: | String |
| Allowed: | |
| Default: | /IN/service_packages/SMS/output |
| Notes: | Report may provide a default output directory which overrides smsReportDaemon's default. |
| Example: |
-u usr/pwd
| Description: | The userid and password for oracle login string. |
| Type: | String |
| Allowed: | |
| Default: | / |
| Notes: | |
| Example: |
-v
| Syntax: | -v |
| Description: | What level of information to output. |
| Type: | Boolean |
| Allowed: |
set: Print additional information. not set: Only print the standard level of information.
| Notes: | |
| Example: |
-z timezone
| Syntax: | -z timezone
| Description: | The timezone in which to schedule the report. |
| Type: | String |
| Allowed: | Java supported timezone |
| Default: | GMT |
| Notes: |
For a full list of Java supported timezones see ACS Technical Guide - Appendix TimeZones. |
| Example: | -z "EST" |
Failure
In the case of failure, the scheduled report will not appear at the specified destination, or may contain incorrect or missing output.
Output
The smsReportScheduler writes error messages to the system messages file, and also writes additional output to /IN/service_packages/SMS/tmp/smsReportScheduler.log.
Unix Utilities
The table below lists the Unix utilities required for scheduling.
| Unix Binary Required | Description | Location Expected |
| mailto | E-mail agent used by report generation component to send emails. | /usr/bin/mailto |
| sendmail (or equivalent delivery agent) | E-mail delivery agent. | daemon started at boot time. |
| lpr | Printing utility. | /usr/ucb/lpr |
E-mail sending/receiving/delivery agent requires all local e-mail user names to be under 13 characters. For local e-mail user names longer than 13 characters, mailto and sendmail will not function properly.smsReportCleanupStartup.sh
Purpose
The Reports cleaner looks for output from ad-hoc and scheduled reports generated by the smsReportsDaemon and the smsReportScheduler.
It deletes files that are older than a specified age.
Startup
This task is run in the crontab for smf_oper. By default it runs at 2:00 am system time. It is scheduled as the following script:
/IN/service_packages/SMS/bin/smsReportsCleanerStartup.sh
Parameters
The command inside the script contains a command line parameter specifying the cleanup age of report output files. By default this is seven days. Report output files older than this age are deleted.
An operator may change this value, subject to disk storage availability and site-specific archiving policies.
smsStatsDaemon
Description
smsStatsDaemon can be run as a background process on an SMS, SLC, and also on other IPs such as Voucher and Wallet Servers.
For more information about smsStatsDaemon, see the discussion about the smsStatsDaemon in Background Processes on the SLC.
smsStatisticsWriter
Purpose
The smsStatisticsWriter is responsible for collecting statistical data provided by the smsStatDaemons and writing it to files, either for standalone statistics, or for groups of statistics associated with an event.
smsStatisticsWriter structure
Here is an example structure of the smsStatisticsWriter.config file.
smsStatisticsWriter = {
tempDir = "/IN/service_packages/SMS/tmp/smsStatisticsWriter"
outDir = "/IN/service_packages/SMS/logs/smsStatisticsWriter"
outDirType = 'FLAT'
outDirExpectedFiles = 65536
outDirBucketSize = 10
outFileName = "smsStatisticsWriter"
maxFileSize = 100
maxFileOpenTime = 3600
statsDaemonRestartDelay = 10
statsDaemonStartupTime = 5
scanInterval = 100000
replicationAllowance = 60
endOfEventTolerance = 5
resetInterval = {
days = 1
hours = 0
minutes = 0
seconds = 0
Events = [
eventName = "EventGood"
resetAllEventStatisticsOnStartup = true
eventResetBaseTime = "20110511130000"
resetInterval = {
days = 0
hours = 0
minutes = 4
seconds = 0
eventStartDateTime = "20100728000000"
eventEndDateTime = "20101231000000"
eventWritePeriod = 30
Statistics = [
applicationName = "TELEVOTING"
statisticName = "Stat1"
applicationName ="TELEVOTING"
statisticName = Statn
etc
eventName = "Event2"
parameters for event...
eventName = "Eventn"
Statistics = [
StatisticName = "Stat2"
resetStatisticOnStartup = false
statWritePeriod = 0
statResetBaseTime = "20110511130000"
resetInterval = {
days = 0
hours = 0
minutes = 5
seconds = 0
statisticName = "StatN"
parameter for statistic...
Etc
] smsStatisticsWriter parameters
The smsStatisticsWriter section accepts the following parameters.
tempDir
| Syntax: | tempDir = "dir"
| Description: | The temporary directory for writing intermediate statistics files to. |
| Type: | String |
| Allowed: | |
| Default: | "/IN/service_packages/SMS/tmp/smsStatisticsWriter" |
| Notes: | |
| Example: | tempDir = "/IN/service_packages/SMS/tmp/smsStatisticsWriter"
outDir
| Syntax: | outDir = "dir"
| Description: | The base directory for storing completed statistics files. |
| Type: | String |
| Allowed: | |
| Default: | "/IN/service_packages/SMS/logs/smsStatisticsWriter" |
| Notes: | |
| Example: | outDir =
outDirType
| Syntax: | outDirType: = "type" |
| Description: | File store type. |
| Type: | String |
| Allowed: | HASH or FLAT |
| Default: | "FLAT" |
| Notes: | |
| Example: | outDirType: = "FLAT"
outDirExpectedFiles
| Syntax: | outDirExpectedFiles = num
| Description: | The maximum number of files in outDir when outDirType is HASH. |
| Type: | Integer |
| Allowed: | |
| Default: | 65536 |
| Notes: | |
| Example: | outDirExpectedFiles = 65536 |
outDirBucketSize
| Syntax: | outDirBucketSize = size
| Description: | The maximun number of files in any leaf directory when outDirType is HASH. |
| Type: | Integer |
| Allowed: | |
| Default: | 10 |
| Notes: | |
| Example: | outDirBucketSize = 10 |
outFileName
| Syntax: | outFileName = "name" |
| Description: | The base of the statistics file name. |
| Type: | String |
| Allowed: | |
| Default: | "smsStatisticsWriter" |
| Notes: | |
| Example: | outFileName = "smsStatisticsWriter" |
maxFileSize
| Syntax: | maxFileSize = size
| Description: | The maximum size of a statistics file (kilobytes). |
| Type: | Integer |
| Allowed: | |
| Default: | 100 |
| Notes: | |
| Example: | maxFileSize = 100 |
maxFileOpenTime
| Syntax: | maxFileOpenTime = sec
| Description: | The maximum time a statistics file can be kept open (seconds). |
| Type: | Integer |
| Allowed: | |
| Default: | 3600 |
| Notes: | |
| Example: | maxFileOpenTime = 3600 |
| Syntax: | statsDaemonRestartDelay = sec
| Description: | The length of time to allow updated statistics to be replicated to the SLC nodes before restarting the smsStatsDaemon processes on those nodes. (seconds). |
| Type: | Integer |
| Allowed: | |
| Default: | 10 |
| Notes: | |
| Example: | statsDaemonRestartDelay = 10
| Syntax: | statsDaemonStartupTime = <seconds>
| Description: | The length of time (in seconds) to allow for smsStatsDaemon to restart and initialize after startUp request issued. |
| Type: | Integer |
| Allowed: | |
| Default: | 5 |
| Notes: | |
| Example: | statsDaemonStartupTime = 8
scanInterval
| Syntax: | scanInterval = msec
| Description: | Length of time between scans of the statistics (microseconds). |
| Type: | Integer |
| Allowed: | |
| Default: | 100000 |
| Notes: | |
| Example: | scanInterval = 100000
| Syntax: | replicationAllowance = <seconds>
| Description: | The time (in seconds) to allow for stats to be replicated to SMS from SLC. |
| Type: | Integer |
| Allowed: | |
| Default: | 60 |
| Notes: | For best results this value should be less than any of the reporting periods of statistics included in event configuration. |
| Example: | replicationAllowance = 40 |
Events
Event configuration parameters may or may not have default values, where defaults are defined that parameter may be omitted, for all others the parameter is required. There may be multiple events configured.
Each event accepts the following parameters.
Events = [
resetInterval = {
days = 0
hours = 0
minutes = 4
seconds = 0
Statistics = [
} eventName
| Syntax: | eventName = "name"
| Description: | The name of the event. |
| Type: | String |
| Allowed: | |
| Default: | no default |
| Notes: | |
| Example: | eventName = "eventGood" |
| Syntax: | resetAllEventStatisticsOnStartup = true|false
| Description: | Reset all statistics defined for the event on start up. |
| Type: | Boolean |
| Optionality: | Optional (default used when omitted) |
| Allowed: |
| Default: | true |
| Notes: | If true, individual statistic resetStatisticOnStatup config is overidden. |
| Example: | resetAllEventStatisticsOnStartup = false |
eventResetBaseTime
| Syntax: | eventResetBaseTime = "<date and time>"
| Description: | Sets a specific date and time base to calculate resets for the statistics configured for this event. |
| Type: | String |
| Allowed: | |
| Default: | "20100101000000" - (00:00:00 on Jan 1 2010) |
| Notes: |
Date and time format is yyyymmddHHMMSS The event resetInterval parameter timing starts from this parameter's date and time. |
| Example: | eventResetBaseTime = "20110511130000" |
resetInterval
| Syntax: | resetInterval =
{<days>,<hours>,<minutes>,<seconds>}
| Description: | The interval between periodic resets of all statistics configured for the event. |
| Type: | Parameter list |
| Optionality: | Optional (default used if missing) |
| Allowed: | |
| Default: | Global resetInterval values are used. |
| Notes: | If non zero, the reset period configured for individual statistics will be overridden. |
| Example: |
resetInterval = { days = 0 hours = 0 minutes = 4 seconds = 0 } |
eventStartDateTime
| Syntax: | eventStartDateTime = "dateandtime"
| Description: | The event start time. |
| Type: | String |
| Allowed: | Expected format yyyymmddHHMMSS |
| Notes: | Statistics will only be collected for the event between the start and end times. |
| Example: | eventStartDateTime = "20100728000000" |
eventEndDateTime
| Syntax: | eventEndDateTime = "dateandtime"
| Description: | The event end time. |
| Type: | String |
| Example: | eventEndDateTime = "20101231000000" |
eventWritePeriod
| Syntax: | eventWritePeriod = <seconds>
| Description: | The period (in seconds) between successive writes of statistics data to the report file. |
| Type: | Integer |
| Allowed: | |
| Default: | 0 |
| Notes: | When set to 0 the write period is synchronized to the shortest sample period defined for the statistics included in the event. |
| Example: | eventWritePeriod = 30 |
Event Statistics
Each event can collect more than one statistic.
For example the event "EventGood" is a contest where you can vote for three contestants. The statistic for each contestant is collected separately to determine the winner.
Each event statistic accepts the following parameters:
applicationName
| Syntax: | applicationName = "name" |
| Description: | The name of application to which the statistic belongs. |
| Type: | String |
| Allowed: | |
| Notes: | |
| Example: | applicationName = "TELEVOTING" |
statisticName
| Syntax: | statisticName = "name"
| Description: | The name of the statistic. |
| Type: | String |
| Allowed: | |
| Notes: | |
| Example: | statisticName = "Stat1"
Statistics
Statistics generated by the SMS and SLCs are collected in the SMF_STATISTICS table of the SMF database. A set of tools provides management functions. Functions include:
- Filtering statistics
- Setting rules for statistics thresholds which raise alarms
- Running reports against the statistics held in SMF_STATISTICS
For more information about using these functions, see Service Management System User's Guide.
Event Name File Format
The smsStatisticsWriter process creates a file format as detailed below for an event configured in SMS.smsStatisticsWriter.Events.eventName:
"Event Name"
"Start Time"
"Stop Time"
[Automatic statistic reset Time Stamp]
Timestamp
"Statistic ID" Statistics Count
Timestamp
For example:
“Strictly Come Dancing”
“20:00:00”
“20:30:00”
Automatic statistic reset 21-04-2010 20:00:00
21-04-2010 20:00:00
“Contestant A” 0
“Contestant B” 0
“Contestant C” 0
21-04-2010 20:01:00
“Contestant A” 300
“Contestant B” 20
“Contestant C” 50
21-04-2010 20:20:00
“Contestant A” 1200
Automatic statistic reset 21-04-2010 20:20:00
“Contestant B” 0
“Contestant C” 95
21-04-2010 20:30:00
“Contestant A” 15345
“Contestant B” 12789
“Contestant C” 120
Statistics File Format
The smsStatisticsWriter process creates a file format as detailed below for a statistic configured in SMS.smsStatisticsWriter.Statistics:
"Application ID"
"Statistic ID"
[Automatic statistic reset Timestamp]
Timestamp Statistics Count
TimestampStatistics Count
For example:
“TPSA”
“Service A”
01-01-2010 00:00:000
01-01-2010 00:00:302
Automatic statistic reset 31-01-2010 12:00:00
31-01-2010 12:00:00 0
31-01-2010 12:00:30 3
31-01-2010 23:00:004000
smsStatsThreshold
Purpose
The smsStatsThreshold polls the database for updates to the SMF_STATISTICS table. It compares the values against threshold rules defined in the SMF_STATISTICS_RULE table, and raises an alarm if the threshold is exceeded. It inserts the alarm into the SMF_ALARM_MESSAGE table in the SMF database.
For more information about how to define new statistics threshold rules, see the Service Management System User's Guide. New threshold rules are automatically recognised by the program.
Startup
In an unclustered installation, this task is started by entry sms6 in the inittab, via the shell script:
/IN/service_packages/SMS/bin/smsStatsThresholdStartup.sh
In a clustered installation, this task is started by the cluster software, via the shell script:
/IN/service_packages/SMS/bin/smsStatsThresholdCluster.sh
Parameters
The smsStatsThreshold supports the following command-line options:
Usage:
smsStatsThreshold -u <usr/pwd> -s <secs>
-u <usr/pwd>
| Syntax: | -u <usr/pwd> |
| Type: | String |
| Allowed: | |
| Default: | / |
| Notes: | |
| Example: |
-s <secs>
| Syntax: | -s <secs> |
| Type: | Integer |
| Allowed: | |
| Default: | 60 |
| Notes: | |
| Example: |
smsSendConfig.sh
Purpose
smsSendConfig.shresides on the source node (for example, an SMS) and performs the following functions:
- Archives current master XML file
- Stores audit information
- Sets link to current archived file
- Converts XML format to derived eserv.config using the script cmnConfigXmlConvert.sh
- Sends derived eserv.config file to target node using scp.
smsSendConfig.sh connects to the database on a local or a remote SMS node by using the user credentials set in the following environment variables in smsConfigVariables.sh:
- SMP_DB_USER_NAME
- SMP_DB_PASSWORD
If you do not set any of these variables, smsSendConfig.sh connects to the database by using the default value of "/".Startup
smsSendConfig.sh is started by smsConfigDaemon (using the -m parameter).
It is driven by the system and is not intended to be changed by the user
Configuration
For more information on the parameters used by smsSendConfig.sh, see smsConfigDaemonScript.
smsTaskAgent
Purpose
smsTaskAgent is a CORBA server that performs various utility functions as requested by the SMS Java screens, including:
- Create replication.config file
- Change Oracle password for Convergent Charging Controller screens user
- Perform data consistency checks with remote nodes
- Change the customer care PIN for a subscriber
CORBA Service Port
At startup, smsTaskAgent publishes its IOR string via the smsNamingServer. If the IP port number is not specified, the port number on which the CORBA service is provided will be determined by the CORBA framework. The CORBA service port must be fixed because a firewall is used to protect the SMS host. Use the -s parameter to provide the port number on the CORBA transport.
Startup
In an unclustered installation, this task is started by entry sms8 in the inittab, via the shell script:
/IN/service_packages/SMS/bin/smsTaskAgentStartup.sh
/IN/service_packages/SMS/bin/smsTaskAgentCluster.sh
If there is no local SMF database and smsTaskAgent connects to the Oracle database only on a remote SMS, remove or comment out the following lines and all the lines in between:
"echo "`date` - Waiting for DB SMF""
"echo "`date` - DB SMF is ready""
smsTaskAgent configuration in eserv.config
SMS = {
smsTaskAgent = {
defaultOracleProfile = "password_profile"
} defaultOracleProfile
| Syntax: | defaultOracleProfile = "password_profile"
| Description: |
The name of the Oracle profile to allocate to new users created through the User Management screen in the SMS UI. The SMS uses the verification function for the allocated Oracle profile to check that the entered password is acceptable. The SMS also applies the verification function whenever the system administrator attempts to change a user's password through the SMS UI. If the entered password is rejected, the SMS displays an error message. You specify the error message text in the passwordPolicyMessage Java application property. See jnlp.sms.passwordPolicyMessage (on page 99) for more information. |
| Type: | String |
| Allowed: | The name of an existing Oracle profile (created by using the CREATE PROFILE command). |
| Default: | Use the standard Oracle profile called DEFAULT. |
| Notes: | For information about creating Oracle profiles and using the CREATE PROFILE command, see the Oracle Database online documentation. |
| Example: | defaultOracleProfile = "password_profile" |
Command Line Parameters
smsTaskAgent supports the following command line options:
Usage:
smsTaskAgent [-c] [-i ior_host] [-p ior_port] [-u usr/pwd] [-t trans_host] [-s
trans_port] [-w secs]
-c
| Syntax: | -c |
| Description: | Use secure shell and secure copy (ssh and scp). |
| Type: | Boolean |
| Allowed: | |
| Default: | Use standard connection and copy |
| Notes: | |
| Example: |
-i ior_host
| Syntax: | -i ior_host
| Description: | The IOR listener host to connection to. |
| Type: | String |
| Allowed: | |
| Default: | localhost |
| Notes: | |
| Example: | -i produsms |
-p port
| Syntax: | -p port
| Description: | The port on the IOR listener host to connect to. |
| Type: | Integer |
| Allowed: | |
| Default: | 5556 |
| Notes: | |
| Example: | -p 13579 |
-u usr/pwd
| Syntax: | -u usr/pwd|/@connect_string |
| Description: | The username and password, or the connection string, to use for connections to the Oracle database on a local or a remote SMS node. |
| Type: | String |
| Allowed: |
| Default: | / |
| Notes: | When smsTaskAgent invokes repConfigWrite in order to create the replication.config file, the specified user credentials are passed down to reConfigWrite as the -user argument. |
| Example: | -u SMF/SMF |
-t trans_host
| Syntax: | -t trans_host |
| Description: | The CORBA transport host to connect to. |
| Type: | String |
| Allowed: | |
| Default: | NULL |
| Notes: | |
| Example: |
-s trans_port
| Syntax: | -s trans_port |
| Description: | The port on the CORBA transport host to connect to. |
| Type: | Integer |
| Allowed: | |
| Default: | 0 |
| Notes: | |
| Example: |
-w secs
| Syntax: | -w secs
| Description: | The number of seconds smsTaskAgent waits for a consistency check update before timing out and abandoning a consistency check. |
| Type: | Integer |
| Allowed: | |
| Default: | 20 |
| Notes: | |
| Example: | -w 120 |
Failure -
If smsTaskAgent fails, any further smsTaskAgent based tasks that you perform are not processed and an error message is displayed. Oracle recommends that you call Oracle support when you see the following error messages:
| Error Message | Description |
| Failed to hash subscriber PIN in subscribers CORBA interface. | The encryption call used by smsTaskAgent failed. |
| Cannot retrieve IOR for the subscribers service from the IORS database table. | smsTaskAgent did not add an entry to the IORS table because the subscriber’s service is not registered. |
smsTrigDaemon
smsTrigDaemon manages control plan execution requests. It runs on the SMS platform.
smsTrigDaemon accepts control plan execution requests from either a remote PI client or the Java management screens. It forwards requests to ACS through the xmlTcapInterface on the SLC platform. An indication of whether or not the requests were successful passes back from the ACS to the initiating client.
Purpose
smsTrigDaemon manages control plan run requests. It runs on the SMS platform.
smsTrigDaemon accepts control plan run requests from either a remote PI client or the Java management screens. It forwards requests to ACS through the xmlTcapInterface on the SLC platform. An indication of whether or not the requests were successful passes back from the ACS to the initiating client.
Startup
In an unclustered installation, this task is started by entry sm11 in the inittab, via the shell script:
/IN/service_packages/SMS/bin/smsTrigDaemonStartup.sh
In a clustered environment this task is started by the binary startSmsTrigDaemon which is located in:
/opt/ESERVSmsTrigDaemon/util/startSmsTrigDaemon
startSmsTrigDaemon must be manually run as root in a clustered environment. smsTrigDaemon is then added as a cluster resource.Parameters
smsTrigDaemon is configured by the following parameters from the triggering section of eserv.config:
Usage:
triggering = {
oracleLogin = "userName/password"
useORB = true|false
listenPort = portNumber
slcBusyTimeout = seconds
useFIFO = true|false
extraFIFO = [
"1stPath"
"2ndPath"
"nthPath"
scps = [
"1stHostAddress:1stPortNumber"
"2ndHostAddress:2ndPortNumber"
"nthHostAddress:nthPortNumber"
} Available parameters are:
oracleLogin
| Syntax: | oracleLogin = "usr/pwd" |
| Description: | The Oracle user name and password that smsTrigDaemon uses when connecting to the database. |
| Type: | String |
| Allowed: | |
| Default: | / |
| Notes: | |
| Example: |
useORB
| Syntax: | useORB = <true|false> |
| Description: | Whether smsTrigDaemon accepts incoming CORBA requests. |
| Type: | Boolean |
| Allowed: |
true: smsTrigDaemon accepts incoming CORBA requests. false: smsTrigDaemon refuses incoming CORBA requests. |
| Default: | false |
| Notes: | |
| Example: |
listenPort
| Syntax: | listenPort = portNumber |
| Description: | The IP port on which smsTrigDaemon listens for CORBA requests. |
| Type: | Integer |
| Allowed: | 0 - 65535 |
| Default: | 0 |
| Notes: | If set to 0, any available port is used. |
| Example: |
slcBusyTimeout
| Syntax: | slcBusyTimeout = seconds |
| Description: | The number of seconds before connections to the SLC or VWS nodes will time out. |
| Type: | Integer |
| Allowed: | |
| Default: | 10 |
| Notes: | |
| Example: | slcBusyTimeout = 15
useFIFO
| Syntax: | useFIFO = true|false |
| Description: | Whether smsTrigDaemon accepts FIFO transport layer incoming requests. |
| Type: | Boolean |
| Allowed: |
true: smsTrigDaemon accepts FIFO transport layer incoming requests false: smsTrigDaemon refuses FIFO transport layer incoming requests |
| Default: | false |
| Notes: |
If set to false, the extraFIFO (on page 170) parameter array is ignored. If set to false and useORB (on page 168) is also set to false, smsTrigDaemon will do nothing. |
| Example: |
extraFIFO
| Syntax: | extraFIFO = [ "dir"
| Description: | The paths that smsTrigDaemon should create for extra FIFOs. |
| Type: | Parameter array |
| Allowed: | |
| Default: | Empty set |
| Notes: | If useFIFO (on page 169) is set to false, this parameter array is ignored. |
| Example: | extraFIFO = [
"/IN/service_packages/SMS/tmp/trg-req-3005"
"/IN/service_packages/SMS/tmp/trg-req-3006"
scps
| Syntax: | scps = [ "ip:port" ... ] |
| Description: | The Internet Protocol (IP) address and port number for each SLC to which the smsTrigDaemon connects. If you specify an IP version 6 (IPv6) address and port combination, then you must enclose the IPv6 address in square brackets [], see example for details. |
| Type: | Array |
| Optionality: |
The scps parameter array is optional. In any row of the array, the :port part is optional. |
| Allowed: |
ip: Any IP address or symbolic host name. port: 0 - 65535 |
| Notes: |
An example of an Internet protocol address is 192.0.2.1. An example of an IPv6 address is 2001:db8:n:n:n:n:n:n where n is a group of 4 hexadecimal digits. The industry standard for omitting zeros is also allowed. An example of an address in symbolic name format is primary_smc. |
| Example: | scps = [ "198.51.100.1"
"192.0.2.1:4000"
"[2001:db8:0000:1050:0005:0600:300c:326b]:3004"
"[2001:db8:0:0:0:500:300a:326f]:1234:SMF" "[2001:db8::c3]:1234:SMF"
"2001:db8:1050:0:0:300a:0300:126c" "primary_smc"
"secondary_smc:3006" |
Failure
If smsTrigDaemon fails, then interaction with the BPL requests from the Java screens and the PI will fail.
Output
smsTrigDaemon writes error messages to the system messages file, and also writes additional output to /IN/service_packages/SMS/tmp/smsTrigDaemon.log.
Control Plan Execution Requests
After receiving a control plan run request the smsTrigDaemon follows a three-stage process:
smsTrigDaemon attempts to connect to one of the SLCs in the following way.
- If a connection to a SLC is established and not in use, that connection is used. smsTrigDaemon maintains a list of currently-open connections.
- If a connection to a SLC is not established, smsTrigDaemon attempts to open one. SLCs are identified by the scps configuration parameter. smsTrigDaemon polls this list until it finds an available connection. If the connection fails, the next SLC in the list is tried.
smsTrigDaemon connects to the SLC using either port 3072 or another port specified by the scps parameter.
- If a connection to an SLC is not established, smsTrigDaemon attempts to open one. SLCs are identified by the scps configuration parameter. smsTrigDaemon polls this list until it finds an available connection. If the connection fails, the next SLC in the list is tried.
- smsTrigDaemon sends an XML message via an HTTP "
POST / HTTP/1.1" request. The syntax of the message is:
At least two extension parameters, id="400" and id="401", will be present. These represent the client's host and user names. Optional additional extension parameters can be included with labels id="402", id="403", etc.<control-plan-exec> <control-plan><name of control plan></control-plan> <service-handle><service handle></service-handle> <cgpn><calling party></cgpn> <cdpn><called party></cdpn> <ext id="400"><host></ext> <ext id="401"><user></ext> <ext id="402"><more extensions></ext> ... </control-plan-exec>
Data Consistency Check
A race condition can occur after the Save & Execute button has been pressed in a Java management screen. The race condition exists between the SMS's replication system and run on the SLCs of an smsTrigDaemon request.
To avoid this possibility, a data consistency check is carried out on the current subscriber before proceeding with the request.
Because it is not possible to know in advance which SLC will be selected by smsTrigDaemon, a data consistency check is performed on all replicated SLCs. A decision to carry on with the request is only made after the check has been completed.
The following steps describe the consistency check process and the criteria used to determine whether the execution will be allowed.
- The Java management screen sends to smsTaskAgent a request for a consistency check on the current subscriber.
- The Java management screen waits until a check report is received from smsTaskAgent. The report is in the form of an HTML file.
The Java management screen extracts relevant information from the report, including:
- The number of nodes checked.
- The number of nodes that failed the check.
- The number of nodes that replied to the check request.
- The number of nodes that reported inconsistent data.
The consistency check:
- succeeds, if:
- at least one node replied without error, and
- no node reported inconsistent data.
- fails, if:
- no nodes replied without error, or
- one or more nodes reported inconsistent data.
- If the check succeeds, the request proceeds.
- If the request fails, steps 1 through 4 are repeated. After three fails, the request is cancelled and the user informed in an SMS message dialogue box.
