About Design Studio for ASAP Users and Tasks
The following table lists the roles and the tasks each role typically performs in Oracle Communications Design Studio for ASAP.
| Role | Task | Reference |
Cartridge Designer |
Setting up an Activation Network cartridge project |
Defining and editing elements (service actions, atomic actions, action processors) |
Defining relationships between elements |
Solution Designer |
Load (import) cartridge projects |
Solution Designer |
Setting up an Activation Service cartridge project |
Solution Designer |
Designing a service model |
Solution Designer |
Extending user-defined exit types |
See ASAP Cartridge Development Guide |
Solution Designer |
Creating custom action processors |
Solution Designer |
Configuring network elements |
Solution Designer |
Build, deploy, and undeploy to or from development environments |
Developer |
Developing the implementation |
Developer |
Configuring sample network elements |
Developer |
Release Engineer |
Build, deploy, and undeploy to or from test and production environments |
