Processor Editor Details Tab
Use the Details tab to select the implementation class for the processor and specify other information about the processor.
The Details tab is available for all processor types.
Field Use
Description
Enter a short description of the processor.
Parser Type
Specify the type of files the processor can parse.
Appears for file parser processors only.
File Parameter
Specify the input file parameter generated as output by a predecessor processor in the sequence of processors in the action. The file parameter must be of type java.util.Collection.java.io.File. If there are no available context parameters, an error message appears.
Implementation Class
Specify the Java implementation class for the processor. Design Studio automatically generates an interface class that the implementation class must implement. You can select an existing class, or create a new one by clicking the Implementation Class link.
The implementation class is created to match the processor interface.
This field is read-only for some processor types.
Implementation Prefix
Displays the Java name for the entity.
Documentation
Add other information about the processor.
