Processor Editor Context Parameters Tab
Use the Context Parameters tab to manage input and output parameters for the processor.
The Context Parameters tab is available for assimilation, discovery, discrepancy detection, discrepancy resolution, file transfer, file parser, and import processors.
Input Parameters Area
Field Use
Name
Displays the parameter name.
Type
Displays the parameter type.
Source
Displays the processor from which the parameter is produced.
Description
Displays the parameter description.
Open
Open the Processor editor for the processor from which the parameter is produced.
Remove
Remove the selected input parameter.
Select
Select an existing output parameter from a predecessor processor in the sequence of processors in the action to add as an input parameter to this processor.
Output Parameters Area
Field Use
Name
Displays the parameter name output by the current processor.
Type
Description
Usage
Lists the processors that use the parameter as an input parameter.
Open
Modify the output parameter.
Remove
Removes the selected output parameter.
Add
Create an output parameter to add to the processor.
