Processor Editor Properties Tab
Use the Properties tab to manage property groups and properties for the processor.
The Properties tab is available for assimilation, discovery, discrepancy detection, discrepancy resolution, and import processors.
Property Groups Area
Field Use
Name
Displays the name of the property group.
Managed
Set the property group as managed.
Properties belonging to managed property groups can be set during run time using the MBean interface. A property group must be managed to contain a sensitive property.
Map
Set the property group as a map. Design Studio generates a simplified API for map property groups.
Description
Enter additional information about the property group.
Add
Create a property group.
Remove
Remove a property group.
Properties Area
Field Use
Name
Displays the name of the property.
Value
Edit the property value. The value can be left blank, set to a static value, or assigned a model variable. Properties with model variables as values can be set at deployment time.
Sensitive
Specify whether the property is sensitive. Sensitive properties can only be contained in managed property groups. Sensitive properties values are encrypted and are never displayed to users.
Description
Enter additional information about the property.
Add
Create a property in the selected property group.
Remove
Remove the property from the selected property group.
