Processor Editor SNMP Tab
Use the SNMP tab to load object IDs (OIDs) for the SNMP processor to poll.
The SNMP tab is available for SNMP processors.
Field Use
SNMP Data Tree area
Lists the MIB files that are loaded into the SNMP processor.
Add
Add the selected OID from the SNMP data tree to the Loaded OID area.
Remove
Remove the selected OID from the Loaded OID area.
Load MIB
Select MIB files to load into the SNMP processor.
Full Name
Displays the full name of the selected MIB object.
OID
Displays the object ID of the selected MIB object.
Description
Displays the description of the selected MIB object.
Loaded OID area
Lists the MIB objects that the SNMP processor will poll for.
