Processor Editor File Transfer Tab
Use the File Transfer tab to configure the file transfer settings for file parser processors.
The File Transfer tab is available for file parser processors.
Field Use
Parameter Source
Specify the parameter source for the file parser processor. Select Scan Parameter Group to allow the user to provide the parameter values using scan parameter groups. Select Context Parameter to allow the processor to inherit parameter values from the output of predecessor processors in the sequence of processors in the action.
Specify the scan parameter group used to pass parameter values to the processor. Clicking Select opens a dialog listing available scan parameter groups. This field is enabled when Parameter Source is set to Scan Parameter Group. Click the Scan Parameter Group link to create a new scan parameter group.
Context Parameter
Specify the processor output from which the file parser processor inherits its parameter values. Click the Select button to open a dialog listing available output. This field is enabled when Parameter Source is set to Context Parameter.
Address Parameter
Specify the address parameter that contains the host and directory to retrieve the files from. Click the Select button to open a dialog box listing available output for the address parameter. Clicking the Address Parameter link opens the Processor editor for the processor that generates the address parameter output.
Use Scope Address
Specify whether to use the discovery scan scope address at run time as the address parameter.
Appears only if the file transfer processor is added to a discovery action.
