Processor Editor XML Tab
Use the XML tab to configure the file parser processor XML settings.
The XML tab is available for file parser processors.
This tab is editable only when Parser Type on the Processor editor Details tab is set to XML.
Field Use
XML Schema
Specify the XML schema and path that validates the parsing of XML files. Click the Select button to open a dialog box from which to choose from available XML schemas. Clicking the XML Schema link opens the selected XML schema in an XML editor.
