About the Characteristics Tab Context Menu for Specifications
The Characteristics tab context menu contains commands specific to specification characteristics. To access the context menu, right-click in the left column of the tab. The context menu options that are available depend on the selection in the editor.
Field Use
Add Characteristic
Create a new characteristic to add to the specification.
Select Characteristic
Add an existing characteristic to the specification.
Delete
Delete a characteristic.
Refactoring
Select to access a menu of options for improving names and locations of the characteristics. See "Refactoring Entities and Data Elements" for more information.
Refresh
Refresh the view.
