Specification Editor Layouts Tab
Use the Layouts tab to configure which characteristics appear in the Network Integrity UI scan results.
Field Use
Page/Panels
Select the Network Integrity run-time page to lay out.
Available
Lists the characteristics available to be displayed in the Network Integrity UI for the selected page or panel.
Selected
Lists the characteristics to be displayed in the Network Integrity UI for the selected page or panel.
Left Arrow
Right Arrow
Up Arrow
Down Arrow
Move characteristics back and forth between the Selected and Available lists and to reorder the characteristics in the Selected list.
UI Settings area
Displays the available UI settings for the selected characteristic.
Reset
Revert the layout back to the most recently saved version.
