Defining Relevant Behavior Properties
When editing order and task data in an editor, you can right-click data node behaviors and select Open Properties View to access the behavior properties.You use the Properties view tabs to model Relevant behaviors.
The level at which you create a behavior (at the data element level, task level, or order level) determines where you access and configure the behavior's properties. See "Creating New Behaviors" for more information.
To define Relevant behavior properties:
                     From the Design perspective, right-click the behavior and select Open Properties View. The Behaviors Properties view is displayed.
                     Click the Details tab. The Behaviors Properties view Details tab is displayed. The Name, Type, and Path field values are read-only, and cannot be modified on this tab. See "Defining Behavior Detail Properties" for more information about the options that you can define on this page.
                     Click the Conditions tab. Use the Conditions tab to add conditional logic to the Relevant behavior. See "Defining Behavior Condition Properties" for more information about defining conditions for behaviors.
                     Click the Notes tab. Use the Notes tab to describe the functionality or include internal documentation about the Relevant behavior.
