Supported Storage Devices
Updated supported drive information is available in the server product notes.
Your server might be equipped with one of the following storage devices:
| Device | Description | Links |
Combination of U.2 small form factor (SFF) hard disk drives (HDDs) and solid state drives (SSDs) controlled by internal Host Bus Adapter (HBA) PCIe card. |
Oracle Storage 12 Gb SAS PCIe RAID Host Bus Adapter, Internal 16 Port manages the server's SSDs and HDDs. |
Instructions to configure RAID on the internal HBA: Configure RAID on Oracle Storage 12 Gb SAS PCIe RAID Host Bus Adapter, Internal 16 Port. |
3.84 TB U.2 NVMe SSDs |
You can install an operating system on 3.84 TB NVMe SSDs without any additional configuration. 6.8 TB and 3.84 TB small form factor (SFF) NVMe solid state drive (SSD) boot devices do not support hardware RAID. |
U.2 NVMe SSD Documentation: Oracle Flash Accelerator F640 PCIe Card and NVMe SSD Documentation. |
480 GB M.2 NVMe SSDs |
The 480 GB M.2 NVMe SSD supports software RAID. |
Instructions to configure RAID on M.2 SATA SSDs: Configure SATA RAID Using VROC. |
Oracle Flash Accelerator F640 PCIe Cards |
You can install an operating system on Oracle Flash Accelerator F640 PCIe Card v3: 6.4 TB, NVMe SSDs without any additional configuration. |
Instructions to identify Oracle Flash Accelerator F640 PCIe Cards: Identifying Installed Oracle Flash Accelerator F640 PCIe Cards in BIOS Setup Utility. |
