- EAGLE Software Upgrade Guide
- Preparations For Upgrade Execution
B Preparations For Upgrade Execution
Target Release Software Download
The following procedure is a reference for the commands that will download an EAGLE software release to the inactive partition group of the TDM from either a remote FTP server or from the thumb drive containing the upgrade target release for the E5-MASP.
The following items are required before the release can be downloaded to the EAGLE from a FTP server:
- E5-IPSM or E5-ENET-B card running IPS application defined, configured, and IS-NR
- DIST application FTP server provisioned
Download Target Software Release and Create USB Upgrade Media
This procedure downloads the target software release and creates the USB upgrade media using a Windows PC.
Should THIS PROCEDURE FAIL, CONTACT My Oracle Support AND ASK FOR UPGRADE ASSISTANCE.
- Using a PC running Windows 7 or later, download the target EAGLE Release from
the Oracle Software Delivery Cloud (OSDC) to a local directory.
- Go to http://edelivery.oracle.com
- Sign In
- Search for the target EAGLE software release
- Accept the Oracle Standard Terms and Restrictions
- Click on the link to the zip file for the target EAGLE software release
- Save the zip file to a local directory, for example
C:\Users\Admin\Desktop\uusb_media - Unzip the
Vxxxxxx-01.zipfile that was downloaded to the same local directory. - This will produce a
<eagle target software release number>.exefile.
- Open a command window as Administrator: on Window 7 go to
Start -> All Programs ->
Accessories, right click on Command
Prompt and select Run as Administrator;
on Windows 8/10, go to Start, type
cmd.exein the search box, right click on Command Prompt and select Run as Administrator; then Change Directory to the path of the local directory.C:\Users\Admin>cd Desktop/uusb_media C:\Users\Admin\Desktop\uusb_media> - Extract the downloaded release in the local directory by entering the name of
the .exe file as seen in step 1 and verify that the directory contains the
following files: the target release file
46.xx.xx.xx.xx-6X.yy.yy.tar.gz,uusb.clf,mkdosfs.exe,pvu.exe,uusb.exe.C:\Users\Admin\Desktop\uusb_media><eagle target software release number> 7-Zip SFX 9.20 Copyright (c) 1999-2010 Igor Pavlov 2010-11-18 Processing archive: C:\Users\Admin\Desktop\uusb_media\46.3.0.0.0-68.12.0.e Extracting 46.3.0.0.0-68.12.0.tar.gz Extracting uusb.clf Extracting mkdosfs.exe Extracting pvu.exe Extracting uusb.exe Everything is Ok - If the target release is 46.3.0.0.0 or later and you need to create USB Upgrade Media, continue with the next step; otherwise stop.
- Insert EAGLE USB media into a PC USB port.
- Goto Start -> Computer and wait for USB drive to be detected. Note its drive letter.
- Enter
uusbcommand with the release filename and drive of the USB media, where46.xx.xx.xx.xx-68.yy.yy.tar.gzis the name of the release file in the directory from step 3 and E: is the USB media drive letter from above step 6.C:\Users\Admin\Desktop\uusb_media>uusb.exe 46.xx.xx.xx.xx-68.yy.yy.tar.gz e: Copyright (c) 1993, 2014, Oracle and/or its affiliates. All rights reserved. Upgrade Media Creator Utility v1_1_0 2016:02:23 15:30:04 Checking whether Disk is present or not: ( e: ) 2016:02:23 15:30:04 Disk is present in Drive: ( e: ) 2016:02:23 15:30:04 Start Building ..... 2016:02:23 15:30:04 Setting drive status: Busy 2016:02:23 15:30:04 Creating Partition .... 2016:02:23 15:30:04 Partitioning Drive: \\.\PHYSICALDRIVE1 , REMOVABLE, USB 2016:02:23 15:30:04 Drive \\.\PHYSICALDRIVE1 . Prepared partitions 2016:02:23 15:30:04 Formatting Partitions: e: , 32 , 1 mkdosfs.exe 2.11 (12 Mar 2005) Win32 port by Jens-Uwe Mager <jum@anubis.han.de> mkdosfs.exe: unable to lock \\.\e: 2016:02:23 15:30:04 Formatted drive e: UPGRADEUSB DISK 2016:02:23 15:30:04 Copying File pvu.exe 2016:02:23 15:30:05 pvu.exe file successfully copied to Drive e: 2016:02:23 15:30:05 Copying File uusb.clf 2016:02:23 15:30:05 uusb.clf file successfully copied to Drive e: 2016:02:23 15:30:05 Copying File 46.3.0.0.0-68.12.0.tar.gz 2016:02:23 15:30:16 46.3.0.0.0-68.12.0.tar.gz file successfully copied to Dr e: 2016:02:23 15:30:16 Validating Disk........ 2016:02:23 15:30:16 Validation Process Completed: e: 2016:02:23 15:30:16 Setting drive status: Ready - Close the Command window and directory folder, properly eject the USB media and remove it from the PC. The USB media is now ready to use for EAGLE upgrade.
Download Target Release to Inactive Partition
This procedure downloads the target release to inactive partition of the TDMs.
- Remove the thumb drives from the E5-MASPs.If downloading the upgrade target release from an FTP server, continue, otherwise go to step 3.
- Issue the command to display the status of the IPSM cards.
rept-stat-card:appl=ipsResponse from the command is displayed.
Verify there is an IPSM card running the IPSHC gpl and that the card is IS-NR. If no such card present in the system this procedure cannot be executed.
eaglestp YY-MM-DD hh:mm:ss TTTT PPP XX.x.x.x.x-YY.y.y CARD VERSION TYPE GPL PST SST AST 1101 XXX-XXX-XXX IPSM IPSHC IS-NR Active ----- ; - Issue the command to display database status of both TDM partitions
act-upgrade:action=dbstatusResponse to the command is displayed.
Record the card locations of the MASPs:
Act MASP _____
Stby MASP ____
Verify if either of the inactive partitions has not been formatted. Mark below. Example shows that inactive partition of 1116 not formatted.
If a database LEVEL, VERSION or STATUS is displayed the inactive partition has been formatted.
Disk formatted.
1114 ______
1116 ______
eaglestp YY-MM-DD hh:mm:ss EST PPP XX.x.x.x.x-YY.y.y Upg Phase x DATABASE STATUS: >> OK << TDM 1114 ( STDBY) TDM 1116 ( ACTV ) C LEVEL TIME LAST BACKUP C LEVEL TIME LAST BACKUP - -------- ---------------------- - -------- ---------------------- FD BKUP Y XXX YY-MM-DD hh:mm:ss TTTT Y XXX YY-MM-DD hh:mm:ss TTTT FD CRNT Y XXX YY-MM-DD hh:mm:ss TTTT Y XXX YY-MM-DD hh:mm:ss TTTT MCAP 1113 MCAP 1115 - -------- - -------- RD BKUP - - - - - - - - USB BKP - - - - - - - - CARD/APPL LOC C T LEVEL TIME LAST UPDATE VERSION STATUS --------- ---- - - ---------- ----------------- ------------------- OAM-RMV 1113 - - - - - - TDM-CRNT 1114 Y N XXX YY-MM-DD hh:mm:ss XXX-XXX-XXX NORMAL TDM-BKUP 1114 Y - XXX YY-MM-DD hh:mm:ss XXX-XXX-XXX NORMAL OAM-RMV 1115 - - - - - - OAM-USB 1115 - - - - - - TDM-CRNT 1116 Y N XXX YY-MM-DD hh:mm:ss XXX-XXX-XXX NORMAL TDM-BKUP 1116 Y - XXX YY-MM-DD hh:mm:ss XXX-XXX-XXX NORMAL INACTIVE PARTITION GROUP CARD/APPL LOC C T LEVEL TIME LAST UPDATE VERSION STATUS --------- ---- - - ---------- ----------------- ------------------- TDM-CRNT 1114 Y - ZZZ YY-MM-DD hh:mm:ss ZZZ-ZZZ-ZZZ UPG 3 TDM-BKUP 1114 Y - ZZZ YY-MM-DD hh:mm:ss ZZZ-ZZZ-ZZZ UPG 3 TDM-CRNT 1116 - - - - - - TDM-BKUP 1116 - - - - - - ;If either of the inactive partitions has not been formatted continue. If the target release is 46.2 or higher, continue. Otherwise go to Step 14.
- Issue the command to retrieve measurement setup.
rtrv-meas-schedResponse to retrieve command is displayed.
Record if collection is on or off:
___________
If COLLECT=ON, continue to next step. Otherwise, go to Step 6.
eaglestp YY-MM-DD hh:mm:ss TTTT PPP XX.x.x.x.x-YY.y.y COLLECT = off SYSTOT-STP = (off) SYSTOT-TT = (off) COMP-LNKSET = (off) COMP-LINK = (off) MTCD-STP = (on) MTCD-LINK = (on) MTCD-LNKSET = (on) ; - Issue the command to turn off measurement collection.
If executed, this step causes the database level to increment.chg-meas:collect=offResponse to the change command is displayed.
eaglestp YY-MM-DD hh:mm:ss TTTT PPP XX.x.x.x.x-YY.y.y CHG-MEAS: MASP A – COMPLTD ; - Issue the command to display security log status.
rept-stat-seculogResponse to the command is displayed.
If the ENTRIES column displays any value other than 0 for the Standby ROLE, proceed to the next step. Otherwise, go to step 10.
eaglestp YY-MM-DD hh:mm:ss TTTT PPP XX.x.x.x.x-YY.y.y rept-stat-seculog Command entered at terminal #10. ; eaglestp YY-MM-DD hh:mm:ss TTTT PPP XX.x.x.x.x-YY.y.y -- SINCE LAST UPLOAD -- OLDEST NEWEST LAST LOC ROLE ENTRIES %FULL OFLO FAIL RECORD RECORD UPLOAD 1114 Active 19 1 No No 99-01-01 99-01-01 00-00-00 13:43:37 14:08:12 00:00:00 1116 Standby 0 0 No No 99-01-01 99-01-01 99-01-01 13:39:39 13:43:10 14:07:59 ; - Issue the command to copy the security log from the standby disk.
copy-seculog:slog=stb:dfile=upg.appBResponse to the copy security log command is displayed.
If this command fails, proceed to next step. Otherwise, go to Step 10.
eaglestp YY-MM-DD hh:mm:ss TTTT PPP XX.x.x.x.x-YY.y.y Security log on TDM 111X copied to file upg.appB on TDM 111Y ; eaglestp YY-MM-DD hh:mm:ss TTTT PPP XX.x.x.x.x-YY.y.y 0468.0177 SECULOG 111X Security log exception cleared ; - Issue the command to display the FTA directory.
disp-fta-dirResponse to the command is displayed.
If there are any files that need to be saved, they need to be removed via a file transfer.
eaglestp YY-MM-DD hh:mm:ss TTTT PPP XX.x.x.x.x-YY.y.y File Transfer Area Directory of fixed disk 1114 FILENAME LENGTH LAST MODIFIED LBA YYMMDDs.log 2560256 99-01-03 10:18:44 388769 YYMMDDa.log 2560256 99-01-03 10:19:20 393770 m60_lnp.csv 0 99-01-03 13:10:38 398771 3 File(s) 21093376 bytes free ; - Issue the command to delete ALL files in the transfer area.
dlt-fta:all=yesResponse to the delete command is displayed.
eaglestp YY-MM-DD hh:mm:ss TTTT PPP XX.x.x.x.x-YY.y.y dlt-fta:all=yes:loc=XXXX Command entered at terminal #10. ; - Issue the command to format the inactive partition of the standby MASP.
format-disk:prtngrp=inactive:type=fixed:force=yes:low=noResponse from the format disk command is displayed.
eaglestp YY-MM-DD hh:mm:ss TTTT PPP XX.x.x.x.x-YY.y.y Format-disk of system fixed disk started. Extended processing required, please wait. eaglestp YY-MM-DD hh:mm:ss TTTT PPP XX.x.x.x.x-YY.y.y Format-disk of system fixed disk complete. ; - Issue the command to display database status of both TDM partitions.
Verify the inactive partition of the standby has been formatted. And the active partition is valid.
If the database LEVEL of the active partition of the active and standby are not the same stop the procedure and contact My Oracle Support [see My Oracle Support (MOS).]
eaglestp YY-MM-DD hh:mm:ss EST PPP XX.x.x.x.x-YY.y.y DATABASE STATUS: >> OK << TDM 1114 ( STDBY ) TDM 1116 ( ACTV ) C LEVEL TIME LAST BACKUP C LEVEL TIME LAST BACKUP - -------- ---------------------- - -------- ---------------------- FD BKUP Y XXX YY-MM-DD hh:mm:ss TTTT Y XXX YY-MM-DD hh:mm:ss TTTT FD CRNT Y XXX YY-MM-DD hh:mm:ss TTTT Y XXX YY-MM-DD hh:mm:ss TTTT MCAP 1113 MCAP 1115 - -------- - -------- RD BKUP - - - - - - - - USB BKP - - - - - - - - CARD/APPL LOC C T LEVEL TIME LAST UPDATE VERSION STATUS --------- ---- - - ---------- ----------------- ------------------- OAM-RMV 1113 - - - - - - TDM-CRNT 1114 Y N XXX YY-MM-DD hh:mm:ss XXX-XXX-XXX NORMAL TDM-BKUP 1114 Y - XXX YY-MM-DD hh:mm:ss XXX-XXX-XXX NORMAL OAM-RMV 1115 - - - - - - OAM-USB 1115 - - - - - - TDM-CRNT 1116 Y N XXX YY-MM-DD hh:mm:ss XXX-XXX-XXX NORMAL TDM-BKUP 1116 Y - XXX YY-MM-DD hh:mm:ss XXX-XXX-XXX NORMAL INACTIVE PARTITION GROUP CARD/APPL LOC C T LEVEL TIME LAST UPDATE VERSION STATUS --------- ---- - - ---------- ----------------- ------------------- TDM-CRNT 1114 N - 1 YY-MM-DD hh:mm:ss ZZZ-ZZZ-ZZZ NORMAL TDM-BKUP 1114 N - 1 YY-MM-DD hh:mm:ss ZZZ-ZZZ-ZZZ NORMAL TDM-CRNT 1116 - - - - - - TDM-BKUP 1116 - - - - - - ;If the inactive partition of the active MASP has not been formatted continue, otherwise go to Step 30.
- Issue the command to boot the Active MASP recorded in Step 3.
init-card:loc=XXXX(Where XXXX is the location of the active MASP record in a previous)
Response to init card command is displayed.
eaglestp YY-MM-DD hh:mm:ss TTTT PPP XX.x.x.x.x-YY.y.y * 0261.0013 * CARD 111X OAMHC Card is isolated from the system ASSY SN: xxxxxxxx ; eaglestp YY-MM-DD hh:mm:ss TTTT PPP XX.x.x.x.x-YY.y.y 5001.0009 CARD 111X OAMHC MASP became active ; eaglestp YY-MM-DD hh:mm:ss TTTT PPP XX.x.x.x.x-YY.y.y 5038.0014 CARD XXXX OAMHC Card is present ASSY SN: xxxxxxxx ; - Issue the command to log back in to the system.
login:uid=XXXXXX(Where XXXXXX is a valid login ID)
Response to login command is displayed.
Ignore any login failure message.
eaglestp YY-MM-DD hh:mm:ss TTTT PPP XX.x.x.x.x-YY.y.y User logged in on terminal 10. ; ? Login failures since last successful LOGIN Last successful LOGIN was on port ? on ??-??-?? @ ??:??:?? - Repeat step 6 – 11.
If downloading the upgrade target release from an FTP server, continue. Otherwise, insert upgrade media into drive slot and go to step 16.
Once inserted, allow time for the upgrade media to be detected by the system.
For E5-MASP systems, the USB drive is inserted in the flush mounted USB port on the active E5-MASP.
- Issue command to retrieve the FTP servers provisioned on the system.
rtrv-ftp-servResponse to the command is displayed.
Verify that a software distribution, DIST, application server has been provisioned.
If the DIST has not been provisioned, contact My Oracle Support for assistance.
eaglestp YY-MM-DD hh:mm:ss TTTT PPP XX.x.x.x.x-YY.y.y APP IPADDR LOGIN PRIO PATH -------- --------------- --------------- ---- ---- DIST XXX.XX.X.XX aaaaaa Z aaaaaaaaaaaaaaaaaaa No entries found ; - Issue command to retrieve the EAGLE target release software.
act-upgrade:action=getrel:release=”xx.xx.xx-yy.yy.yy.tar.gz” :src=server (downloading from the FTP server)or
act-upgrade:action=getrel:release=”xx.xx.xx-yy.yy.yy.tar.gz” :src=usb(downloading from upgrade media)(Where xx.xx.xx-yy.yy.yy is the release-build number of the upgrade target load (ex.
45.0.1-64.70.36.tar.gz).Response to the command is displayed.
Command execution time: approximately 20 – 30 minutes.
If the software release has been downloaded from the USB drive, disconnect the drive from the E5-MASP.
eaglestp YY-MM-DD hh:mm:ss TTTT PPP XX.x.x.x.x-YY.y.y Download release from zzzzzzz ; eaglestp YY-MM-DD hh:mm:ss TTTT PPP XX.x.x.x.x-YY.y.y Validate database release xx.xx.xx-yy.yy.yy.tar ; eaglestp YY-MM-DD hh:mm:ss TTTT PPP XX.x.x.x.x-YY.y.y Copy database release to inactive partition ; eaglestp YY-MM-DD hh:mm:ss TTTT PPP XX.x.x.x.x-YY.y.y Eagle Release successfully downloaded ; eaglestp YY-MM-DD hh:mm:ss TTTT PPP XX.x.x.x.x-YY.y.y Command Complete : Upgrade action completed successfully ; - Issue the command to display database status of both TDM partitions.
Verify the inactive partitions of the active & standby have been downloaded with the target release by confirming that database VERSION is the target version. C (coherency), LEVEL, and STATUS will be displayed as shown.
eaglestp YY-MM-DD hh:mm:ss TTTT EAGLE XX.x.x-YY.yy.y DATABASE STATUS: >> OK << TDM 1114 ( ACTV ) TDM 1116 ( STDBY ) C LEVEL TIME LAST BACKUP C LEVEL TIME LAST BACKUP - -------- ---------------------- - -------- ---------------------- FD BKUP Y XXX YY-MM-DD hh:mm:ss TTTT Y XXX YY-MM-DD hh:mm:ss TTTT FD CRNT Y XXX YY-MM-DD hh:mm:ss TTTT Y XXX YY-MM-DD hh:mm:ss TTTT MCAP 1113 MCAP 1115 - -------- - -------- RD BKUP - - - - - - - - USB BKP - - - - - - - - CARD/APPL LOC C T LEVEL TIME LAST UPDATE VERSION STATUS --------- ---- - - ---------- ----------------- ------------------- OAM-RMV 1113 - - - - - - TDM-CRNT 1114 Y N XXX YY-MM-DD hh:mm:ss XXX-XXX-XXX NORMAL TDM-BKUP 1114 Y - XXX YY-MM-DD hh:mm:ss XXX-XXX-XXX NORMAL OAM-RMV 1115 - - - - - - OAM-USB 1115 - - - - - - TDM-CRNT 1116 Y N XXX YY-MM-DD hh:mm:ss XXX-XXX-XXX NORMAL TDM-BKUP 1116 Y - XXX YY-MM-DD hh:mm:ss XXX-XXX-XXX NORMAL INACTIVE PARTITION GROUP CARD/APPL LOC C T LEVEL TIME LAST UPDATE VERSION STATUS --------- ---- - - ---------- ----------------- ------------------- TDM-CRNT 1114 Y - 1 00-00-00 00:00:00 ZZZ-ZZZ-ZZZ NORMAL TDM-BKUP 1114 Y - 1 00-00-00 00:00:00 ZZZ-ZZZ-ZZZ NORMAL TDM-CRNT 1116 Y - 1 00-00-00 00:00:00 ZZZ-ZZZ-ZZZ NORMAL TDM-BKUP 1116 Y - 1 00-00-00 00:00:00 ZZZ-ZZZ-ZZZ NORMAL ; - If step 5 was executed, issue the command to turn the measurements collection
on. Otherwise, go to the end of the procedure.
chg-meas:collect=onResponse to the change command is displayed.
Configuring Card-Set Network Conversion Method
This procedure provides the steps to configure the system to use the card-set method during the network conversion portion (Phase 3) of the upgrade.
The system should be running the target release on MASPs of 46.0 or higher. This procedure should be run after Procedure 29, Step 40 in E54339 OR Before STP Conversion in this document.- Issue the card status command to verify the target release GPL is
running.
rept-stat-gpl:gpl=oamhcResponse from the status command is displayed.
Verify that the version of OAMHC GPL running is 46.0 or later.
eaglestp YY-MM-DD hh:mm:ss TTTT EAGLE XX.x.x-YY.yy.y Upg Phase 0 GPL Auditing ON APPL CARD RUNNING APPROVED TRIAL OAMHC 1113 XXX-XXX-XXX ALM YYY-YYY-YYY ----------- OAMHC 1115 XXX-XXX-XXX ALM YYY-YYY-YYY ----------- Command Completed. ; - Issue the command to retrieve the upgrade configuration.
rtrv-upgrade-configResponse to the retrieve command is displayed.
If the Threshold Type has not already been changed to SET, it will be either GROUP or SYSTEM.
If the SAK is not set, perform Entering Upgrade Software Access Key.
eaglestp YY-MM-DD hh:mm:ss TTTT EAGLE XX.x.x-YY.yy.y Upg Phase x Software Access Key entered on system : vbsevhcea7vy5 Configured Upgrade Threshold Type: GROUP Command Completed. ; - Issue the command to change the upgrade configuration
chg-upgrade-config:threstype=set:srvsets=X:limsets=YResponse to the command is displayed.
eaglestp YY-MM-DD hh:mm:ss TTTT EAGLE XX.x.x-YY.yy.y Upg Phase x chg-upgrade-config:threstype=set:srvsets=X:limsets=Y Command entered at terminal #tt. Command Completed. ; - Issue the command to retrieve the upgrade configuration
eaglestp YY-MM-DD hh:mm:ss TTTT EAGLE XX.x.x-YY.yy.y Upg Phase x Software Access Key entered on system : vbsevhcea7vy5 Configured Upgrade Threshold Type: SET Number of SERVICE Sets: X Number of LINK Sets: Y Command Completed. ; - Issue the command to report the card status.
rept-stat-cardResponse to the command is displayed.
eaglestp YY-MM-DD hh:mm:ss TTTT EAGLE XX.x.x-YY.yy.y Upg Phase x CARD VERSION TYPE GPL PST SST AST 1101 134-076-000 DCM IPGHC IS-NR Active ----- 1102 134-076-000 DCM IPGHC IS-NR Active ----- 1103 134-076-000 DCM IPLHC IS-NR Active ----- 1104 134-076-000 DCM IPLHC IS-NR Active ----- 1105 134-076-000 DSM SCCPHC IS-NR Active ----- 1107 134-076-000 MCPM MCPHC IS-NR Active ----- 1109 134-069-000 HIPR2 HIPR2 IS-NR Active ----- 1110 134-069-000 HIPR2 HIPR2 IS-NR Active ----- 1111 134-076-000 IPSM IPSHC IS-NR Active ----- 1112 134-076-000 TSM GLSHC IS-NR Active ----- 1113 134-076-000 E5MCAP OAMHC IS-NR Standby ----- 1114 ----------- E5TDM IS-NR Active ----- 1115 134-076-000 E5MCAP OAMHC IS-NR Active ----- 1116 ----------- E5TDM IS-NR Active ----- 1117 ----------- E5MDAL IS-NR Active ----- 1201 134-076-000 LIMT1 SS7HC IS-NR Active ----- 1205 134-076-000 DSM SCCPHC IS-NR Active ----- 1207 134-076-000 TSM GLSHC IS-NR Active ----- 1209 134-069-000 HIPR2 HIPR2 IS-NR Active ----- 1210 134-069-000 HIPR2 HIPR2 IS-NR Active ----- 1211 134-076-000 LIMDS0 SS7ML IS-NR Active ----- 1212 134-076-000 LIMDS0 SS7ML IS-NR Active ----- 1213 134-076-000 LIMDS0 SS7ML IS-NR Active ----- 1214 134-076-000 LIMDS0 SS7ML IS-NR Active ----- 1215 134-076-000 LIMDS0 SS7ML IS-NR Active ----- 1216 134-076-000 DCM IPLHC IS-NR Active ----- 1217 134-076-000 DSM SCCPHC IS-NR Active ----- 1301 134-076-000 LIMDS0 SS7ML IS-NR Active ----- 1302 134-076-000 LIMDS0 SS7ML IS-NR Active ----- 1303 134-076-000 LIMDS0 SS7ML IS-NR Active ----- 1304 134-076-000 LIMDS0 SS7ML IS-NR Active ----- 1305 134-076-000 LIMDS0 SS7ML IS-NR Active ----- 1306 134-076-000 LIMDS0 SS7ML IS-NR Active ----- 1307 134-076-000 LIMDS0 SS7ML IS-NR Active ----- 1308 134-076-000 LIMDS0 SS7ML IS-NR Active ----- 1309 134-069-000 HIPR2 HIPR2 IS-NR Active ----- 1310 134-069-000 HIPR2 HIPR2 IS-NR Active ----- 1311 134-076-000 MCPM MCPHC IS-NR Active ----- 1315 134-076-000 IPSM IPSHC IS-NR Active ----- 1316 134-076-000 IPSM IPSHC IS-NR Active ----- 1317 134-076-000 DSM SCCPHC IS-NR Active ----- Command Completed. ; - Issue the upgrade activation command to create card sets.
act-upgrade:action=createsetsResponse to the command is displayed.
TheCreate Setcommand assigns cards to sets using an optimal distribution, which assumes that the system is stable. If the system’s configuration is such that the distribution of the cards is not desirable, contact My Oracle Support for assistance when uncertain on how to alter the sets of cards. Otherwise, continue to next step if a change to the assignment of cards is necessary.eaglestp YY-MM-DD hh:mm:ss TTTT EAGLE XX.x.x-YY.yy.y Upg Phase x ACT-UPGRADE: Creating card set list... Card set list created. ; eaglestp YY-MM-DD hh:mm:ss TTTT EAGLE XX.x.x-YY.yy.y Upg Phase x Card List: Group = MUX, Set = 1 ==================================== CARD APPL LINKS TPS ------------------------------------ 1209 HIPR2 N/A N/A 1309 HIPR2 N/A N/A 1109 HIPR2 N/A N/A ------------------------------------ MUX= 50% ; eaglestp YY-MM-DD hh:mm:ss TTTT EAGLE XX.x.x-YY.yy.y Upg Phase x Card List: Group = MUX, Set = 2 ==================================== CARD APPL LINKS TPS ------------------------------------ 1210 HIPR2 N/A N/A 1310 HIPR2 N/A N/A 1110 HIPR2 N/A N/A ------------------------------------ MUX= 50% ; eaglestp YY-MM-DD hh:mm:ss TTTT EAGLE XX.x.x-YY.yy.y Upg Phase x Card List: Group = SERVICE, Set = 1 ==================================== CARD APPL LINKS TPS ------------------------------------ 1205 SCCP N/A 1700* 1207 GLS N/A 0 1315 IPS N/A 0 1311 MCP N/A 0 1105 SCCP N/A 1700* 1111 IPS N/A 0 ------------------------------------ GLS= 50% IPS= 66% MCP= 50% SCCP= 50% ; eaglestp YY-MM-DD hh:mm:ss TTTT EAGLE XX.x.x-YY.yy.y Upg Phase x Card List: Group = SERVICE, Set = 2 ==================================== CARD APPL LINKS TPS ------------------------------------ 1217 SCCP N/A 1700* 1316 IPS N/A 0 1317 SCCP N/A 1700* 1107 MCP N/A 0 1112 GLS N/A 0 ------------------------------------ GLS= 50% IPS= 33% MCP= 50% SCCP= 50% ; eaglestp YY-MM-DD hh:mm:ss TTTT EAGLE XX.x.x-YY.yy.y Upg Phase x Card List: Group = LINK, Set = 1 ==================================== CARD APPL LINKS TPS ------------------------------------ 1201 SS7 8 N/A 1213 SS7 2 N/A 1215 SS7 1 N/A 1216 IPLIM 8* N/A 1302 SS7 1 N/A 1304 SS7 1 N/A 1306 SS7 1 N/A 1308 SS7 1 N/A 1101 IPGWY 1* N/A ------------------------------------ ATM= 0% IPGWY= 50% IPLIM=100% SS7= 52% ; eaglestp YY-MM-DD hh:mm:ss TTTT EAGLE XX.x.x-YY.yy.y Upg Phase x Card List: Group = LINK, Set = 2 ==================================== CARD APPL LINKS TPS ------------------------------------ 1211 SS7 4 N/A 1212 SS7 5 N/A 1214 SS7 1 N/A 1301 SS7 1 N/A 1303 SS7 1 N/A 1305 SS7 1 N/A 1307 SS7 1 N/A 1102 IPGWY 1* N/A 1103 IPLIM 0 N/A 1104 IPLIM 0 N/A ------------------------------------ ATM= 0% IPGWY= 50% IPLIM= 0% SS7= 48% ; eaglestp YY-MM-DD hh:mm:ss TTTT EAGLE XX.x.x-YY.yy.y Upg Phase x xxxx is unassigned. End of Card List display. ; eaglestp YY-MM-DD hh:mm:ss TTTT EAGLE XX.x.x-YY.yy.y Upg Phase x Command Complete : Upgrade action completed successfully ; - If cards need to be moved to a different set, issue the command to change the
If card is unassigned, it can also be add to a set with this command. Unassigned cards are usually cards that were not IS-NR when the card sets were created.chg-upgrade-config:loc=XXXX:assignset=NN(Where XXXX is the card to be moved and NN is the set it should move to.)
eaglestp YY-MM-DD hh:mm:ss TTTT EAGLE XX.x.x-YY.yy.y Upg Phase x chg-upgrade-config:loc=XXXX:assignset=NN Command entered at terminal #tt. Command Completed. ; - Issue the one of the following commands to retrieve the card-set
configuration
act-upgrade:action=displaysets rtrv-upgrade-config:display=sets rtrv-upgrade-config:display=limsets rtrv-upgrade-config:display=srvsetsResponse to the retrieve command is displayed.
eaglestp YY-MM-DD hh:mm:ss TTTT EAGLE XX.x.x-YY.yy.y Upg Phase x Card List: Group = MUX, Set = 1 ==================================== CARD APPL LINKS TPS ------------------------------------ 1209 HIPR2 N/A N/A 1309 HIPR2 N/A N/A 1109 HIPR2 N/A N/A ------------------------------------ MUX= 50% ; eaglestp YY-MM-DD hh:mm:ss TTTT EAGLE XX.x.x-YY.yy.y Upg Phase x Card List: Group = MUX, Set = 2 ==================================== CARD APPL LINKS TPS ------------------------------------ 1210 HIPR2 N/A N/A 1310 HIPR2 N/A N/A 1110 HIPR2 N/A N/A ------------------------------------ MUX= 50% ; eaglestp YY-MM-DD hh:mm:ss TTTT EAGLE XX.x.x-YY.yy.y Upg Phase x Card List: Group = SERVICE, Set = 1 ==================================== CARD APPL LINKS TPS ------------------------------------ 1205 SCCP N/A 1700* 1207 GLS N/A 0 1315 IPS N/A 0 1311 MCP N/A 0 1105 SCCP N/A 1700* 1111 IPS N/A 0 ------------------------------------ GLS= 50% IPS= 66% MCP= 50% SCCP= 50% ; eaglestp YY-MM-DD hh:mm:ss TTTT EAGLE XX.x.x-YY.yy.y Upg Phase x Card List: Group = SERVICE, Set = 2 ==================================== CARD APPL LINKS TPS ------------------------------------ 1217 SCCP N/A 1700* 1316 IPS N/A 0 1317 SCCP N/A 1700* 1107 MCP N/A 0 1112 GLS N/A 0 ------------------------------------ GLS= 50% IPS= 33% MCP= 50% SCCP= 50% ; eaglestp YY-MM-DD hh:mm:ss TTTT EAGLE XX.x.x-YY.yy.y Upg Phase x Card List: Group = LINK, Set = 1 ==================================== CARD APPL LINKS TPS ------------------------------------ 1201 SS7 8 N/A 1213 SS7 2 N/A 1215 SS7 1 N/A 1216 IPLIM 8* N/A 1302 SS7 1 N/A 1304 SS7 1 N/A 1306 SS7 1 N/A 1308 SS7 1 N/A 1101 IPGWY 1* N/A ------------------------------------ ATM= 0% IPGWY= 50% IPLIM=100% SS7= 52% ; eaglestp YY-MM-DD hh:mm:ss TTTT EAGLE XX.x.x-YY.yy.y Upg Phase x Card List: Group = LINK, Set = 2 ==================================== CARD APPL LINKS TPS ------------------------------------ 1211 SS7 4 N/A 1212 SS7 5 N/A 1214 SS7 1 N/A 1301 SS7 1 N/A 1303 SS7 1 N/A 1305 SS7 1 N/A 1307 SS7 1 N/A 1102 IPGWY 1* N/A 1103 IPLIM 0 N/A 1104 IPLIM 0 N/A ------------------------------------ ATM= 0% IPGWY= 50% IPLIM= 0% SS7= 48% ; eaglestp YY-MM-DD hh:mm:ss TTTT EAGLE XX.x.x-YY.yy.y Upg Phase x xxxx is unassigned. End of Card List display. ; eaglestp YY-MM-DD hh:mm:ss TTTT EAGLE XX.x.x-YY.yy.y Upg Phase x Command Complete : Upgrade action completed successfully ; - Repeat steps 7 – 8 as cards need to be moved.
