Review a Broadband Network Interface
You can review settings for a broadband network interface on a Cloud Connector's Network tab. Some values may be editable.
Tab Overview
When you choose a broadband interface on the network tab, Oracle ECP shows the following graphs:
  • Broadband interface bandwidth rate - This graph displays transmitted and received bandwidth over time, in both bits per second (Throughput) and packets per second (Packets). The default display is the last 30 minutes, which can be changed with the period drop-down located above the graph.
    • Latency is also available on this graph by selecting Latency from the drop-down menu, which shows locally-reported latency for this WAN interface.
  • Bandwidth Distribution Chart - This chart displays the bandwidth allocation for the broadband network interface by User Apps, Control Channel, and Devices.
  • Bandwidth Performance Test Graph - If a bandwidth performance test ran during the selected period, this graph displays the download and upload rates over time. The x-axis shows time, and the y-axis shows speed.
Context
From the Network tab, choose an option that lets you check or update a broadband network interface.
Procedure
  1. Log on to Oracle ECP and go to the Inventory page.
  2. Click the first drop-down at the top of the page and click Edge Nodes.
  3. Check for the Cloud Connector by name to choose the row for the equipment that requires network interface setting updates, then click the link in the Name column.
    The Edge Node Details page opens.
  4. Click the drop-down at the top of the Network tab to choose the broadband network interface.
    You can identify a broadband network interface by the range of actions available.
  5. To review the network settings for the broadband interface, click Network Settings.
    The Broadband-WAN1 Network Settings drawer opens.
  6. Oracle ECP displays the following values for your review.
  7. Configure the network information if you disabled the DHCP toggle.
  8. If you have changed any values, click Save to update the settings, otherwise click cancel to return to the Network tab.
