Review a LAN-facing Ethernet Interface
Oracle Enterprise Communications Platform (Oracle ECP) lets you check or edit network settings for a LAN-facing Ethernet network interface on the Network tab on the Edge Node Details page.
Tab Overview
When you choose an Ethernet interface that supports LAN connectivity on the network tab, Oracle ECP shows the following graph below the interface chooser.
- Ethernet (LAN) interface bandwidth rate - This graph displays transmitted and received bandwidth over time, in both bits per second and packets per second.
Context
From the Network tab on the Edge Node Details page, choose an option that let you check or update network settings for an Ethernet network interface on a Cloud Connector. The two interface options for Ethernet connectivity are LAN1 and LAN2.
Procedure
Other options for a local LAN-facing Ethernet interface:
