8 Verifying Recovery
This chapter describes procedures used to verify the status of the LSMS after performing recovery procedures.
Introduction
Verifying that the LSMS Is Fully Functional
Perform the tests in the order shown in Table 8-1 to verify that the LSMS is fully functional following file system restoration. If any of these tests fail, contact My Oracle Support.
Table 8-1 Recovery Acceptance Tests
| Condition to Verify | Test to Perform | |
1 |
One server is in ACTIVE state and the other server is in STANDY state |
2 |
The appropriate software processes are running on the primary server |
3 |
The GUI process can be started on the primary server |
4 |
Switchover can be performed from the active server to the standby server |
Manually Switching Over from the Active Server to the Standby Server |
5 |
The appropriate software processes can be run on the newly active server |
6 |
The GUI process can be started on the newly active server |
7 |
8 |
9 |
Verifying the State of the Servers
Use the TPD High Availability (HA) utility to verify that one server is in ACTIVE state and the other server is in STANDBY state. See Determining the Server Status.
