3 MetaSolv Solution System Requirements
This chapter provides the minimum MetaSolv Solution hardware and software requirements. See "Deployment Configuration Examples" for Oracle's recommendations on deploying to small, medium, and large environments for the application server and the database server.
Because each business differs in factors like size, use of the application, and performance desired, each installation of MetaSolv Solution has different hardware and software requirements. For each piece of hardware listed in the requirements, the estimated number of users the hardware can support is listed.
Before you make hardware decisions, contact Oracle to ensure you have the right equipment and software to achieve the system performance required for your business needs.
For a complete list of supported software versions used with MetaSolv Solution, see "MSS Traditional Deployment Software Compatibility" in MSS Compatibility Matrix.
MetaSolv Solution Installation Components
Table 3-1 identifies the required and optional software components of the MetaSolv Solution environment.
Table 3-1 MetaSolv Solution Components
| Component | Required or Optional |
Database Server |
Required |
Application Server |
Required |
MetaSolv Solution Rich Client |
Required |
MetaSolv Solution Utilities |
Required |
Background Processor |
Optional |
Location and Routing Gateway |
Optional |
NPA Split Utility |
Optional |
Data Selection Tool |
Optional |
Recommended Actions for Best Performance
Every MetaSolv Solution environment is different. The environment is affected by the product functionality being used, mix of transactions, API usage, hardware capacity, network speed and capacity, how the servers are tuned, and so on. For best results using each software component, Oracle recommends that you take the following actions:
Stay abreast of notices on products referenced in this section that are no longer supported to ensure your software environment is fully supported.
To upgrade outside the supported versions, contact Oracle Support to determine available options. Recommendations may include migrating to a newer version of MetaSolv Solution.
Database Server
The following provides information on the MetaSolv Solution database server.
Software requirements:
Operating system: See the Oracle Database documentation for information on supported OS versions.
Database: Oracle Database Enterprise Edition. See "MSS Traditional Deployment Software Compatibility" in MSS Compatibility Matrix for information on required software versions.
Storage: A high performance, fault tolerant disk subsystem should be used.
Fault tolerance: Fault tolerance is important when provisioning the database server. If this server fails, the MetaSolv Solution software cannot function. There are several commercial clustering solutions available for Oracle servers. Oracle recommends that you work with its hardware vendor to implement a clustering solution.
Scalability: Scalability is achieved through the use of a server with multiple and/or faster processors.
Sizing for existing customers: See "Deployment Configuration Examples" for sizing information that includes examples for small, medium, and large deployments.
Additional information:
Because disk sizing is approximate, adjust sizing based on your data requirements.
MetaSolv Solution is certified to work with Oracle's Dictionary Managed Storage.
Required tablespaces are DATA and INDEXES, which can be either Dictionary or Locally Managed. These are required as default tablespaces for creating new objects.
This release of MetaSolv Solution is certified to work with the version of Oracle Enterprise Edition listed. Work with Oracle Global Customer Support to determine the recommended patch level for your intended platform/version combination.
Ensure that you set the recommended database initialization parameters for the Oracle Database version that you are using. Table 3-2 lists the recommended initialization parameter settings and these Initialization Parameters ensure that the install script completes successfully.
Table 3-2 Oracle Database Recommended Initialization Parameter Settings
Oracle Database Version Initialization Parameter Recommended Value Example 19c _grant_secure_role
_enable_secure_sub_role
TRUE
TRUE
_grant_secure_role=TRUE
_enable_secure_sub_role=TRUE
Oracle recommends the default values for all other initialization parameters that are not listed.
Application Server
The MetaSolv application server supports the MetaSolv Solution application code running in the middle tier. Clients connect to the application server using HTTP or IIOP (both over TCP/IP), and the application server connects to the database server using JDBC connection pools. The MetaSolv Solution APIs also run on the application server.
Fault Tolerance: Fault tolerance is provided by clustering multiple application servers together. Because the application server is a critical component, Oracle recommends multiple application servers be implemented in a clustered configuration in a production environment. Oracle WebLogic software provides clustering mechanisms, although other load balancing/high availability solutions may be used. Oracle recommends the application servers and database servers run on separate computers in a production environment.
Scalability: Scalability is achieved by running multiple application server processes or using more powerful servers. Performance levels in the application server tier is heavily dependent on tuning the environment and configuring to optimize communication between the database, application server, and client. The sizing numbers shown in this section provide a general guideline for determining hardware requirements. Customers should follow installation and configuration guidelines available from the application server vendor.
Software: See "MSS Traditional Deployment Software Compatibility" in MSS Compatibility Matrix for the list of software that are supported by MetaSolv Solution. MetaSolv Solution supports HTTP(s) and IIOP over TCP/IP
The application server supports 64-bit Java Virtual Machine (JVM). It is possible that 64-bit JVM may support a large number of users per application instance as a sizable amount of memory can be allocated to the java heap. An individual application server instance using the 64-bit JVM can support 80 or 120 users if 8 GB or 12 GB of memory is allocated to the java heap.
Sizing of the application server should be based on the expected maximum number of requests, or concurrent transactions, sent to the application server at the same time. This number is considerably less than the number of clients using the application server, typically 15-20 percent of the total number of users logged on to the system. For more specific sizing and configuration guidelines, see "MetaSolv Solution System Requirements".
More servers may be employed in a software- or hardware-based cluster. This approach provides more redundancy and reduced impact if a server in the cluster fails. However, the dispatcher functionality should be run on multiple servers to ensure redundancy.
Oracle does not support running the application server on Citrix.
If you plan to use an external load balancing mechanism, it must support sticky sessions, and it cannot modify WebLogic cookies. In addition, the network configuration needs to support requests from the application server to the load balancer.
The application server must be able to obtain graphics settings from the host to provide graphics functionality in the application. Oracle does not endorse or certify the functionality of the third-party packages.
Software: See MSS Compatibility Matrix for information on software that are supported by MetaSolv Solution.
Storage: 0.5 GB. No persistent user data is stored.
Fault Tolerance: No special requirements are needed. Should any client fail, a user may resume work on any client computer.
Scalability: A faster processor in the client computer will improve performance. Increased memory often has a significant improvement on desktop performance, especially if multiple applications are used simultaneously. Additional clients may be added as needed, and the servers may need to be scaled to handle the additional load, as noted in each of the server descriptions. Specific sizing recommendations are shown below.
Sizing (client computer):
CPU:
2.6 GHz (minimum)
3.4 GHz (recommended for Inventory Management users)
Memory: 8 GB
Colors: True color (24 bit)
Resolution: 1024 x 768
Disk: 0.5 GB
CPU and memory requirements assume other applications will be running on the client computer. Client hardware configuration will impact general performance of MetaSolv Solution client applications. If the client hardware has only the minimum configuration, processes may take significantly longer to run than they would on a computer with the higher recommended configuration.
Customers need to determine optimal requirements based on how MetaSolv Solution is used in their business.
Only the Small Fonts setting for Font Size in the Display Properties is supported.
The Text Size setting in the browser must be set to Medium.
Select the following check boxes for the HTTP 1.1 settings on the Advanced tab of the Internet Options window:
Use HTTP 1.1
Use HTTP 1.1 through proxy connections
The Background Processor processes MetaSolv Solution user work in the background when the option is available and a user selects it. Users place tasks in a queue and the background processor pulls requests from it. Results are available to users through another table. There is no direct communication between the users and the Background Processor. The Background Processor runs the same code as the end user clients, but it does not have an interactive user interface.
Storage: Disk requirements are minimal. No persistent user data is stored.
Fault Tolerance: Fault tolerance is achieved with multiple computers. Each computer can process the same work queue, and in the case of a failure, the surviving computer continues processing the work queue.
Scalability: Scalability is achieved with multiple computers (horizontal scaling) or the use of more powerful servers.
Sizing: Table 3-3 describes the background processor sizing requirements:
Table 3-3 Background Processor sizing requirements
| Number of concurrent background jobs | CPU | Memory | Disk |
0-10 |
2.6 GHz (minimum) |
8 GB |
0.5 GB |
Hardware sizing is not directly affected by the number of users. User behavior affects the load placed upon these servers and subsequent hardware requirements.
Citrix
Description: Citrix executes the MetaSolv Solution client software for the end user, transmits screen updates to a thin client, and receives mouse and keyboard data from the thin client. Use of Citrix is recommended for any customer with end users running across a WAN. Citrix minimizes the response time delays caused by network latency. Other benefits include ease of software distribution, reduction of WAN bandwidth requirements, and reduced client specifications.
Sizing: For information on sizing a Citrix configuration, see the Citrix documentation or contact Citrix Systems, Inc.
Fault Tolerance: Fault tolerance is achieved with multiple computers in a farm. Citrix provides the capability to direct client requests to one of many servers in a farm.
Scalability: Scalability is achieved with multiple computers (horizontal scaling), or the use of more powerful servers. Generally, better results are obtained by limiting the server size to two CPUs.
This software runs on Windows platforms only. Other platforms are not supported.
Citrix is optional.
Location and Routing Gateway Client
Description: This is one of three optional peripheral applications that require client computers to execute special activities.
CPU:
2.6 GHz (minimum)
Memory: 8 GB
Colors: 256
Disk: 0.5 GB
MetaSolv Solution Utilities Client
Description: This is one of three optional peripheral applications that require client computers to execute special activities. The MetaSolv Solution Utilities client enables you to do various maintenance and setup activities for MetaSolv Solution.
CPU:
2.6 GHz (minimum)
Memory: 8 GB
Colors: 256
Disk: 0.5 GB
