17 Setting Up The STAP Environment
Learn about setting up the Oracle Communications Solution Test Automation Platform (STAP) environment in your system.
Setting Up STAP Configuration
Learn about setting up the configuration for STAP. This includes the config folder that contains the main configuration properties config.properties file. Ensure the attribute home location is set for the config.properties file. For more information on how to set the the attribute home location, see "STAP Synthetic Data Generation".
Using the configuration.properties File
The config folder contains the primary configuration file titled config.properties. This file contains the configurations required to run STAP.
# STAP Environment Configuration
# Version 1.2.0
# Scenarios location
scenarios.home=${WORKSPACE}/scenarios
# Environment configurations location
environments.home=${WORKSPACE}/config/environments
# Execution configurations location
execution.Config.file=${WORKSPACE}/config/execution/execution.config.json
# Actions location
actions.home=LOAD_FROM_LIBRARY
#actions.home=${WORKSPACE}/actions
# Results storage location
#results=results
results.home=${WORKSPACE}/results
results.publish=NO
#results.publish.file=C:\software\Servers\apache-Server-1\webapps\STAPReports\reports\SE2EReports\results.js
# Context Configuration
# Context Storage Location
context.home=${WORKSPACE}/context
# Scenario Context
# Load Context for the test case
# Default NO
context.load=NO
context.save=NO
# Global Context
context.global.load=NO
context.global.save=NO
engine.configuration=${WORKSPACE}/config/engine.config.properties
# JMeter Configuration
# JMeter threads
tools.jmeter.thread=4000
# JMeter rampup(seconds)
tools.jmeter.rampup=150
# JMeter result location
tools.jmeter.results.home=${WORKSPACE}/results/tools/jmeter
# Plugin Configuration : INTERNAL
# List of Supported Plugins : REST,SOAP,SSH,Kafka
plugin.internal=REST,SOAP,SSH,Kafka
# Plugin Configuration : CUSTOM
# Provide plugin configuration in config/plugin folder
#plugin.custom=
# Attribute Home
# Provide location to load attribute data
attributeData.home=${WORKSPACE}/config/attributeDataSetting Up Environments
You can organize environment configurations into distinct folders within the environment_configurations sub directory.environments.home=${WORKSPACE}/config/environmentsIn STAP, environment configuration involves defining and managing the settings and parameters needed to run automation tests across different environments, such as development, testing, and production. This ensures that tests run correctly and produce accurate results across various target systems. Each environment has its own environment.properties file.
Setting Up Execution
The execution folder contains an execution.config.json configuration file. This file contains details of scenarios to run. For more information about scenarios, see "Setting Up Scenarios".
Scenarios are run in various execution groups. You can modify this file to group multiple automation scenarios and run them at the same time. A minimum of one group is required to run a scenario.
The execution.config.json contains these components:
- group
Groups are defined under the group keyword, and each group can contain subgroups or scenario folder entries. Each group has a unique name and its own execution mode. At least one group entry is required to define the scenario list.
- name
Groups can be identified by user-entered names. If no name is provided, a unique group ID is assigned.
- execution (Optional)
Execution can be configured as serial or parallel for each group or subgroup. This parameter controls whether the scenarios within the group run one after another (serial) or at the same time (parallel). If not defined, groups default to serial execution.
- description (Optional):
Provides a textual description of the scenario or group.
- release (Optional):
Indicates the associated release identifier or version, which can help organize or filter results by release.
- milestone (Optional):
Specifies the milestone connected to the group or scenario.
- build (Optional):
Specifies the build ID for the scenarios.
- level (Optional):
Indicates thehierarchy level for the scenarios.
- reportTitle (Optional):
Sets a custom title that will appear in generated reports. If this field is not set, the default report title is Automation Report.
"name": "STAP Sample Tests",
"execution": "serial",
"group" : [
"name" : "STAP Sample Tests",
"scenarios" : [
"1.ABC"
}Creating different groups of scenarios allows independent execution of groups, and the failure of one group does not halt the execution of others.
When grouping multiple scenarios, each group contains a scenarios list, which specifies the parent folder names where .scenario files reside.
If multiple .scenario files exist in a single folder, only the first .scenario file is run.The following is an example of the execution.config.json file when multiple scenarios are run:
"execution" : "parallel",
"group" : [
"name" : "groupOne",
"execution" : "serial",
"scenarios" : [
"ToDo-E2E-Automation",
"ToDo-FunctionsAndOperators"
"name" : "groupTwo",
"group" : [
"name" : "subGroupOne",
"scenarios" : [
"name" : "subGroupTwo",
"scenarios" : [
}Setting Up Scenarios
A scenario outlines the conditions and expected outcomes of a test, focusing on the overall flow and user interactions. The file extension for a scenario in Solution Test Automation Platform is .scenario.
- Author
- Supported product versions
- Revision history
- Exceptions (cases where the scenario may fail)
- FAQ for troubleshooting failures
- Other relevant notes
You can use tags to categorize scenarios for easy identification. For more information, see "Using Tags to Filter Components".
For more information about scenarios in STAP and how to create them, see "Creating Scenarios".
Scenarios Folder
The scenarios folder contains the different scenarios to be run. Each scenario is stored in a separate folder within this folder.
- Header.info: Contains the scenario details in the following
format:
Scenario: Name of the E2E Scenario Description: Description of the E2E Scenario Tags: Tag1, Tag2 - Case files: Each .case file covers a specific logical
step in a scenario. For more information on the contents of the .case
file, see "Creating Scenarios".
You only create a separate .case file if your scenario contains multiple cases. If you have a single case, you can define it within the .scenario file. - scenario.config: Contains the list of .case files to
be merged to create the .scenario file at run time. This is only
applicable for multiple .case files. Use the following format when
creating a scenario configuration
file:
Header.info 1.Launch.case 2.Buying.case 3.fusionCDM.case 4.BRM.case 5.Care.case
scenarios.home=${WORKSPACE}/scenariosFor more information on creating scenarios, see Creating Scenarios.
Setting Up Simulation
Enter a short description of your topic here (optional).
This is the start of your topic.
Setting Up Actions
The Action component provides all input required to the respective plug-in. This input specifies how and with what data the plug-in should run the action. For more information on plug-ins, see "STAP Action Plug-ins".
- Product Folder: The folder for the product containing the respective plug-in.
- Plug-In Folder: The type of plug-in. For example, REST.
- Path Folder: The folder containing it's respective actions. For example, bill.
- Action: The action file. Use lowercase letters with hyphens to separate words in action file names. File names should be self-descriptive and end with the .action.json extension. For example, create-bill-by-ID.json.
Action files contain common information, such as Name, BDD, Type, and Product. For more information on creating an action for a specific plug-in, see "Action Execution".
You can share actions across automation projects as libraries by storing and publishing them as JAR files. For instructions on using action library JARs instead of folders, see "unresolvable-reference.html#GUID-68EC0926-48E6-4FE3-9963-7E832263A86F". Ensure to provide a default request/data for the action.
"path":"subscription/create-new-subscription",
"name":"Create a new subscription",
"bdd":"create a new subscription",
"description":"Create a new subscription in the billing system",
"product":"billing",
"actionType":"REST",
"tags":["billing","subscription","create","new"],
"resource":"subscription",
"method":"POST",
"requestType":"FILE",
"request":"create-new-subscription.request.json",
"expectedStatusCode":201
Setting Up Context
The context folder stores the data of previous steps, enabling the simulation of scenarios where only the current step needs execution. This eliminates the need to repeatedly run prior steps, as the context provides the necessary values for the current step.
You configure the location of the context folder in config.properties. The parameters used in the configuration are described below:
- context.home: Defines the directory where context data is stored.
- context.load: Determines whether to load context data while
running (
YES/NO). - context.save: Specifies whether to save context data for a
scenario, useful for debugging (
YES/NO). - context.global.load: Controls whether global context data (shared across scenarios) should be loaded.
- context.global.save: Controls whether global context data (shared across scenarios) should be saved.
context.load=NO
context.save=NO
context.global.save=NOContext manages two types of variables:
- Local Variables: These are available only during the execution of a single scenario. They are not preserved outside the scenario run.
- Global Variables: Global variables are prefixed with an underscore and exist for the duration of the entire job run, across scenarios and steps.
For more information on variables, see "unresolvable-reference.html#GUID-964C7F5D-F5B7-4597-9C37-FC9F543F0A9E".
Setting Up Reports
Results of the test run are stored in the results folder. The path to this folder can either be relative to your workspace or a direct path to store the results outside your workspace.
The results of each test run are created under this folder with its relative timestamp. The format of this timestamp is $results/<timestamp>. To view the execution report, you open the report.html file.
