Configuring Publication Before data can be published, you must configure the settings that control publishing in P6. Specify the timeframe for which data should be published and the distribution interval for the published data. See Defining Publication Periods. Enable publication and specify how often data will be published. See Enabling Automatic Publishing of P6 Project DataEnabling Automatic Publishing of P6 Project DataEnabling Automatic Publishing of P6 Project Data. Determine the types of enterprise and project data to publish. See Enabling Automatic Publishing of P6 Global DataEnabling Automatic Publishing of P6 Global DataEnabling Automatic Publishing of P6 Global Data. Specify which projects should be published and the relative priorities of projects for publishing. See Configuring Publication Service Settings for Projects. Optionally set up services to publish project data at scheduled intervals. See Creating Project Scheduled Services.
