Import Process Summary
The following table summarizes the steps required to complete the import process from start to finish. Note that this section only a summary and assumes that you are familiar with the details described in the previous sections. It highlights what steps are manual and what steps are performed by a batch monitor process. For each step, the table highlights the Next Action sequence that would occur. For the Apply steps, there are two parts where multiple next actions are possible based on whether there are errors and the user’s decision on how to resolve the error. Refer to Resolving Errors for more information. The possible next actions have the same sequence with a letter following the sequence highlighting the action to take based on the results of the previous step.
Note: When running the Apply batch jobs, be sure to set the number of threads to a number that does not exceed the number of threads supported by the thread pool worker.
Also note that a sequence and action marked in bold is considered the “normal path”.
When using separate batch processes for business data any reference to a migration object monitor batch process applies also to the business data related batch controls.
Step Seq Action Manual / Batch Portal - Action Batch Control Record Impacted - Resulting Status Next Action Sequence
Import 10
Create Import record
Manual
Migration Data Set Import - Add
Migration Data Set Import - Pending
11
11
Import file
Batch
F1-MGDIM - Migration Data Set Import Monitor
Migration Data Set Import - Ready to Compare
Migration Transaction - Pending
Migration Object - Pending
20
Compare 20
Migration Object Compare
Batch
F1-MGOPR - Migration Object Monitor
[When using separate business data processes submit also F1-MGOPB (Migration Object Monitor (Business))]
Migration Object - Approved, Needs Review, Rejected, Unchanged or Error Comparing
21
21
Migration Transaction status update
Batch
F1-MGTPR - Migration Transaction Monitor
Migration Transaction - Ready to Apply, Unchanged or Error Comparing
22
22
Migration Data Set Import status update
Batch
Migration Data Set Import - Awaiting Approval, Apply Objects (if configured for Automatic Apply), Unchanged or Error
30
Approval 30
Review comparison results, approve / reject as needed
(This step is skipped if the data set is configured for Automatic Apply)
Manual
Migration Data Set Import, drill in to the Transactions / Objects as necessary.
Migration Object - Approved or Rejected (no records should be in Needs Review)
Migration Data Set Import - Apply Objects
40
Apply 40
Apply Objects
Batch
F1-MGOAP - Migration Object Monitor - Apply
[When using separate business data processes submit also F1-MGOAB (Migration Object Monitor (Business) - Apply) ]
Migration Object - Applied or Error Applying
41
Appropriate next action is based on error review, if applicable.
41a
Migration Data Set Import status update - auto transition to Apply Transactions.
Only applicable if the number of migration objects in Error Applying is below a threshold
Batch
Migration Data Set Import - Apply Transactions
42
41b
Migration Data Set Import status update - manual transition to Apply Transactions.
Occurs if user reviews errors and determines that they may be resolved in the Apply Transaction step.
Manual
Migration Data Set Import - click Apply Transactions
System detects that all the transactions are in the Ready to Apply state and proceeds to the Apply Transactions state.
42
System detects that there are transactions in the Error Applying state and transitions instead to the Retry Transactions state.
Migration Data Set Import - Retry Transactions
45
41c
Migration Data Set Import status update - manual transition to Retry Objects.
Occurs if user reviews errors and decides to fix an external error and wants to try the batch level Apply again at the object level.
Manual
Migration Data Set Import - click Retry Objects
Migration Data Set Import - Retry Objects
44
42
Apply Transactions
Batch
F1-MGTAP - Migration Transaction Monitor - Apply
Migration Transaction - Applied or Error Applying
43
43a
Migration Data Set Import status update - auto transition to Completed
Applicable if all transactions are Applied
Batch
Migration Data Set Import - Completed.
N/A
43b
Occurs if user reviews errors and decides to fix an external error and wants to try the batch level Apply again at the Object level.
Manual
44
43c
Migration Data Set Import status update - manual transition to Retry Transactions.
Occurs if user reviews errors and decides to fix an external error and wants to try the batch level Apply again at the Transaction level.
Manual
Migration Data Set Import - click Retry Transactions
45
44
Migration Objects status update from Error Applying back to Approved.
Occurs if user chose to Retry Objects.
Batch
Migration Data Set Import status update from Retry Objects to Apply Objects
Batch
40
45
Migration Transactions status update from Error Applying back to Ready to Apply.
Occurs if user chose to Retry Transactions or if the user transitions to Apply Transactions and the system detects that there are Transactions in the Error Applying state.
Batch
42
Batch
42
The following table summarizes the batch monitor jobs that are used in the import process. You can see that there are special monitor processes for the Apply step for both the Object and Transaction. However, for all other states that have monitor logic, the standard monitor process for that MO is used.
Batch Control
Description
Comments
F1-MGDIM
Processes data set records in the following states:
  • Pending
  • Ready to Compare
  • Apply Objects
  • Retry Objects
  • Apply Transactions
  • Retry Transactions
F1-MGTPR
Migration Transaction Monitor (Deferred)
Processes transaction records in the following states:
  • Pending
  • Error Applying
F1-MGTAP
Processes transaction records in the Ready to Apply state where the data set is in the Apply Transactions or Canceled state.
Note: Be sure to set the number of threads to a number that does not exceed the number of threads supported by the thread pool worker.
F1-MGOPR
Processes object records in the following states:
  • Pending
  • Needs Review (check for Data Set cancellation)
  • Error Applying
F1-MGOPB
Applicable only when separate business data processing is enabled.
Similar to F1-MGOPR (Migration Object Monitor) but restricted to business data migration objects.
F1-MGOAP
Processes object records in the Approved state where the data set is in the Apply Objects or Canceled state.
F1-MGOAB
Similar to F1-MGOAP (Migration Object Monitor - Apply) but restricted to business data migration objects.
Refer to Running Batch Jobs for more information about managing the batch jobs, including ways to automate the above steps.
