Interfaz de FileParser
Esta sección proporciona el código de origen de la interfaz de FileParser que utiliza la clase de Java entregada con el paquete de Java descrito con anterioridad en esta sección.
package com.splwg.d1.sgg.osb.common;
import java.io.IOException;
import java.io.InputStream;
/** <p>
* FileParser component is responsible for processing the input
* stream and returning a Plain XML containing all data from
* incoming transaction in a shape expected by the following
* Oracle Service Bus message flow.
* </p>
public interface FileParser {
* Returns the next message in Plain XML format
* or null if there are no more messages
* @return next message as InputStream
InputStream getNextStream() throws IOException;
* Returns the current position in the currently
* parsed source input stream
* @return the position in source input stream after
* last incoming row was read and parsed
long getPosition();
* Sets source stream
* @param input the Input Stream that should be parsed
void setInputStream(InputStream input);
* Sets "owner" FileProcessor
* @param owner the Instance of FileProcessor that will
* be notified about current processing via call to
* utility methods (saveInvalidRow and setParseFinishNote)
void setProcessor(FileProcessor owner);
* Sets the position from which the parsing of source
* stream should be started.
* It is necessary if last time the processing of
* current file has been interrupted
* @param position the starting position
void setStartPosition(long position);
* Returns the byte array that contains a portion of an incoming
* file that most recently has been read and converted to Plain XML.
* It should be in the same format as incoming file. The header and
* tail records, if there are, should be included and updated according
* to the content
byte[] getCurrentInputPortion();
* Returns type of currently generated transaction - USAGE or EVENT
FileProcessor.TransactionType getCurrentTransactionType();
* Returns the number of successfully generated transactions of given type
int getTransactionCount(FileProcessor.TransactionType type);
* Returns the number of expected transactions in input stream
* Returns -1 if information not available
int getTotalExpected();
