Interfaz de FileProcessor
Esta sección contiene una parte de la interfaz de FileProcessor relacionada con la funcionalidad de análisis de ficheros.
package com.splwg.d1.sgg.osb.common;
public interface FileProcessor {
public enum TransactionType {
USAGE, EVENT
* FileParser usage method
* @return a string containing the name of currently processed inbound file
String getOrigin();
* FileParser usage method Creates a file in the Error Folder and saves
* passed row parameter to it
* @param position
* the number representing the position in file where invalid
* raw data is started
* @param row
* the byte array containing an invalid raw data in vendor
* specific format the same with format of incoming file
* @param failCause
* the string showing the cause of fail It will be used while
* logging the fail message.
void saveInvalidRow(long position, byte[] row, String failCause);
* Returns the current offset in input file
long getCurrentInputPosition();
