Email Alerts
Email High Bill Alerts AMI are digital messages sent through the email channel to inform customers when they are on track for a high bill or high use for the current period. The user experience can vary widely depending on many factors, such as which fuel/resource types the customer has, whether cost or usage is displayed, and whether the utility or the customer has set up a threshold.
On this page:
  • Recommended module order
  • Email-wide configuration options
  • Module-specific configuration options
  • Default text and options
Recommended Module Order
This table lists the recommended module order for several different types of Email High Bill Alerts AMI:
Email-Wide Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
Configuration Options Input Value
Color Palette Oracle Utilities uses your organization's branding requirements to configure the colors used in the cloud service. You can specify your branding and color requirements in the Oracle Utilities Opower Platform Configuration Guide.
Fonts Oracle Utilities recommends using the default fonts provided by the Business Customer Engagement Digital Self Service - Energy Management cloud service. Non-default fonts requested must meet all applicable font licensing requirements and support any required character sets. Licensing arrangements may require the utility to transfer font license ownership to Oracle Utilities.
Alert Delivery Window
The delivery window refers to the days in the month during which High Bill Alerts (AMI) can be sent to customers. The default window for sending High Bill Alerts (AMI) is seven days after a new bill period starts and seven days before the bill period ends.
Optional
Choose one of the following:
  • Use the default delivery window.
  • Use the following delivery window:
Additional Global Configurations Review all additional configuration options provided in the Oracle Utilities Opower Platform Configuration Guide.
Default Text and Options
Unless otherwise noted, Oracle Utilities recommends that you use the default text and options that are provided. These options have been chosen carefully by our copywriters and have been through user testing to maximize comprehension and effectiveness.
If you must configure an option to use something other than the default, be aware of the following:
  • While you can configure the text that appears, you cannot change the logic behind the text.
  • Using options and text other than the default could impact the effectiveness of your program.
