Meter Configuration Maintenance
All meters must have an initial configuration that should be effective as of the date the meter was received. If you reconfigure the meter in the future, you must add a new effective-dated configuration to reflect how the meter is configured.
Warning:
Do not attempt to maintain a meter configuration unless you are familiar with the concepts discussed in Changing A Configuration.
