ESRI ArcGIS Field Maps Integration to Oracle Field Service Mobile Configuration Guide
Preface
Audience
Documentation and Resources
Updates to Documentation
Documentation Accessibility
Conventions
Acronyms
Introduction
Overview of the Integration
Prerequisites
About Oracle Utilities Work and Asset Cloud Service (WACS)
About ESRI ArcGIS Field Maps (ArcGIS)
About Oracle Field Service (OFS)
About Oracle Integration Cloud (OIC)
Supported Applications
Solution Architecture
Solution Diagram
Business Flows
Process Work Tasks (Oracle Integration Cloud Scheduled Job)
Create Admin Files (Oracle Integration Cloud Scheduled Job)
Delete Activities (Oracle Integration Cloud Scheduled Job)
Activities Sync (Oracle Integration Cloud Scheduled Job)
Configuring Oracle Utilities Work and Asset Cloud Service
Adding Oracle Integration Cloud Certificates
Managing Catalog Services
Configuring Oracle Field Service
Importing, Configuring, and Testing Integration Connections
Importing the Oracle Integration Cloud Project Based Accelerator Package from Oracle Cloud Marketplace
Verifying the Project Import
Configuring Connections in Oracle Integration Cloud
Configuring Oracle Utilities SOAP WACS for ArcGIS-OFS Connection
Configuring Oracle Utilities OFS for ArcGIS-OFS Connection
Configuring Oracle Utilities REST OFS API for ArcGIS-OFS Connection
Configuring Oracle Utilities REST ArcGIS for ArcGIS-OFS Connection
Configuring Oracle Utilities REST ArcGIS Object Storage for ArcGIS-OFS Connection
Configuring Oracle Utilities REST Asset ArcGIS for ArcGIS-OFS Connection
Configuring Agent (if applicable)
Possible Combinations
Creating an Agent Group
Downloading Agent Installer
Installing On-Premises Agent
Setting up Certificates for Security
Configuring Lookups, Error Handling, and Email Notifications
Configuring Lookups
Editing Lookups
Configuration Properties
Error Handling
Summary of Integration Error Handling
Email Notifications
Activating and Testing the Integration Flows
Prerequisites
Activating Integration Flows
Customizations
Monitoring and Troubleshooting
Oracle Utilities Work and Asset Cloud Error Logs
Monitoring Integration Flows
Troubleshooting
Limitations and Workarounds
ESRI ArcGIS Field Maps Integration to Oracle Field Service Mobile Release 24B Configuration Guide
