Oracle Utilities Work and Asset Cloud Service Integration to Oracle Supply Chain Management Configuration Guide
Preface
Audience
Documentation and Resources
Documentation Accessibility
Conventions
Acronyms
Overview
Overview of the Integration
About Oracle Supply Chain Management (SCM)
About Oracle Utilities Work and Asset Cloud Service (WACS)
About Oracle Integration Cloud (OIC)
Supported Source Applications
Prerequisites
Solution Architecture
Solution Overview
Business Processes
Storeroom Sync from ERP SCM to WACS
Stock Item Details Sync from ERP SCM to WACS
Material Reservation Integration from WACS to ERP SCM
Material Request Integration from WACS to ERP SCM
Material Issue Integration from ERP SCM to WACS
Material Demand Forecast Integration from WACS to ERP SCM
Integration Flows
OU ERPSCM WACS Active Storeroom Sync
OU ERPSCM WACS Inactive Storeroom Scheduler
OU ERPSCM WACS Inactive Storeroom Sync
OU ERPSCM WACS Storeroom SID Sync
OU ERPSCM WACS Stock Item Detail Bulk Load
OU ERPSCM WACS Stock Item Detail Incremental Sync
OU ERPSCM WACS Stock Item Detail Inv Adj Extract
OU ERPSCM WACS Stock Item Detail Inv Adjustment
OU ERPSCM WACS Zero Item Balances Scheduler
OU ERPSCM WACS Process Zero Item Balances
OU WACS ERPSCM Reservation Process
OU WACS ERPSCM Material Request Process
OU ERPSCM WACS Pick Wave Process
OU WACS ERPSCM Supply Request Monitor
OU ERPSCM WACS Material Issue Process
OU WACS ERPSCM Material Demand FTP Forecast
OU WACS ERPSCM Material Demand OS Forecast
OU WACS ERPSCM Common Error Handler
Configuring Oracle Utilities Work and Asset Cloud Service
One-Time Configuration Setup
Configuring Admin Data
Master Configuration
ERP Admin Record
Outbound Integration BO (W1-OutboundIntegration)
Message Senders
Outbound Message Types
External System
Managing Catalog Services
Seasonal Time Shift
Configuring Oracle Supply Chain Management
Importing, Configuring, and Testing Integration Connections
Importing an Oracle Accelerator Project from Oracle Integration Store
Verifying the Project Import
Configuring Connections in Oracle Integration Cloud
OU BI ERP SCM for WACS-ERPSCM
OU SOAP WACS for WACS-ERPSCM
OU ERPSCM Cloud for WACS-ERPSCM
OU REST ERP for WACS-ERPSCM
OU SOAP UCM Generic Service for WACS-ERPSCM
OU REST WACS for WACS-ERPSCM
OU REST Trigger for WACS-ERPSCM
OU REST WACS OS for WACS-ERPSCM
OU FTP WACS FTP for WACS-ERPSCM
Setting up Certificates for Security
Configuring Lookups, Error Handling, and Email Notifications
Configuring Lookups
Editing Lookups
Configuration Properties
Error Handling
Error Handling Ways
Resubmitting the Error Instances in Oracle Integration Cloud
Email Notifications
Extension Libraries in Oracle Integration Cloud
Customizations
Activating and Testing the Integration Flows
Prerequisites
Activating Integration Flows
Monitoring and Troubleshooting
Monitoring Integration Flows
Troubleshooting
Oracle Utilities Work and Asset Cloud Service Integration to Oracle Supply Chain Management Release 25.4 Configuration Guide
