Define the External System and Configure the Messages
Define an external system and configure the valid outbound message types and the method of communication for each. You will also need to select the appropriate XSLs to format the request for usage. The external system must also be specified as a BO option on the base C1-CyclicalUsgReqOutMsg and C1-NonCyclicalUsgReqOutMsg business objects so the system knows which external system to use when sending usage requests to Oracle Utilities Meter Data Management.
Fastpath:
Refer to the Oracle Utilities Customer Care and Billing - Meter Data Management Integration Implementation Guide for more information.
