Process X - Populate Payment Upload Staging
Process X refers to the mechanism used by your organization to populate the various staging tables (shown in the orange section of the following ERD).
Process X refers to the mechanism used by your organization to populate the Deposit Control, Tender Control, Payment Tender, and Payment staging tables
The following topics in this section describe each of these tables:
Deposit Control Staging
You must create a deposit control staging record for each batch of payments to be uploaded into the system. The name of this table is CI_​DEP_​CTL_​ST. The following table describes each column on this table.
Column Name
Length
Req'd
Data Type
Comments
EXT_​SOURCE_​ID
30
Y
A/N
This must correspond with an external source ID on one of the defined tender sources. Refer to Setting Up Tender Sources for more information.
EXT_​TRANSMIT_​ID
50
Y
A/N
This is the unique identifier of the transmission from the external source. This must be a unique value for each transmission from the source.
DEP_​CTL_​STG_​ST_​FLG
2
Y
A/N
This must be set to 20 (20 is the lookup value that corresponds with the Pending state)
DEP_​CTL_​ID
10
N
N
Leave this column blank. It will be assigned by the system when it creates a deposit control record.
TRANSMIT_​DTTM
15
Y
DateTime
Date and time that the file was transmitted.
CURRENCY_​CD
3
Y
A/N
This must be a valid currency code (this would be USD for United States dollars).
TOT_​TNDR_​CTL_​AMT
13.2
Y
N
This column must equal the sum of the payment amounts on the tender control staging records associated with this deposit control staging.
TOT_​TNDR_​CTL_​CNT
10
Y
N
This column must equal the number of tender control staging records associated with this deposit control staging.
LAST_​UPDATE_​INST
10
N
N
This field is populated during the upload. It is the process scheduler instance ID of the process performing the upload.
You must create one or more Tender Control Staging for this deposit control staging record.
Top of Page
You must create at least one tender control staging record for each batch of payments to be uploaded into the system. The name of this table is CI_​TNDR_​CTL_​ST. The following table describes each column on this table.
Column Name
Length
Req'd
Data Type
Comments
EXT_​SOURCE_​ID
30
Y
A/N
This must correspond with the external source ID on the parent deposit control staging record.
EXT_​TRANSMIT_​ID
50
Y
A/N
This must correspond with the external transmission ID on the parent deposit control staging record.
EXT_​BATCH_​ID
30
Y
A/N
This is the unique identifier of the batch of payments in respect of the external transmission ID.
TNDR_​CTL_​STG_​ST_​FLG
2
Y
A/N
This must be set to 20 (20 is the translate value that corresponds with the Pending state)
TNDR_​CTL_​ID
10
N
N
Leave this column blank. It will be assigned by the system when it creates a tender control record.
TOT_​TNDR_​AMT
13.2
Y
N
This column must equal the sum of the payment amounts on the payment tender staging records associated with this tender control staging.
TOT_​TNDR_​CNT
10
Y
N
This column must equal the number of payment tender staging records associated with this tender control staging.
You must create one or more Payment Tender Staging records for this tender control staging record.
Top of Page
You must create at least one payment tender staging record for each payment associated with the tender control staging record. The name of this table is CI_​PAY_​TNDR_​ST. The following table describes each column on this table.
Column Name
Length
Req'd
Data Type
Comments
EXT_​SOURCE_​ID
30
Y
A/N
EXT_​TRANSMIT_​ID
50
Y
A/N
This must correspond with the external transmission ID on the parent tender control staging record.
EXT_​BATCH_​ID
30
Y
A/N
This must correspond with the external batch ID on the parent tender control staging record.
EXT_​REFERENCE_​ID
30
Y
A/N
This is the unique identifier of the payment in respect of the external batch ID.
PAY_​TND_​STG_​ST_​FLG
2
Y
A/N
This must be set to 10 (10 is the translate value that corresponds with the Pending state)
PAY_​TENDER_​ID
12
N
N
Leave this column blank. It will be assigned by the system when it creates a tender record.
TENDER_​AMT
13.2
Y
N
The amount tendered (i.e., the payment amount).
ACCOUNTING_​DT
10
Y
Date
This is the date that should be used for accounting purposes. This should correspond with an open accounting period.
TENDER_​TYPE_​CD
4
Y
A/N
This must correspond with the prime key of one of your tender types. Refer to Setting Up Tender Types for more information.
CUST_​ID
15
Y
A/N
This is the account ID or old account number of the customer tendering the payment. If the system cannot find an account ID or old account number that matches this value, the account ID of the tender source's suspense SA will be used on the corresponding tender and payment.
MICR_​ID
30
N
A/N
This is the MICR ID associated with the payment.
NAME1
40
N
A/N
This is the customer name on the payment.
CHECK_​NBR
10
N
A/N
This is the check number on the payment.
Top of Page
Payment Staging
You need only populate rows on this table if any of the following conditions apply:
  • If you need to distribute a payment tender to an account other than that defined with the CUST_​ID on the payment tender staging record, you must create a payment staging record. You may distribute a tender to multiple accounts by creating multiple payment staging records. Note, if you want to distribute the payment tender to the same account, you do NOT need a payment staging record.
  • If you want to restrict a payment to a specific service agreement, you must insert a row on this table to indicate the specific the service agreement in question. You do this by populating MATCH_​TYPE_​CD with a value that indicates that you are paying for a specific service agreement and MATCH_​VALUE with the unique ID of the service agreement.
  • If you practice open-item accounting, you must insert a row on this table for each to indicate the open-item to which the payment should be matched. Note, because open-item customer typically match payments to bills, you would populate MATCH_​TYPE_​CD with a value to indicate that you are matching by bill ID and MATCH_​VALUE with the unique ID of the bill.
The name of this table is CI_​PAY_​ST. The following table describes each column on this table.
Column Name
Length
Req'd
Data Type
Comments
EXT_​SOURCE_​ID
30
Y
A/N
This must correspond with the external source ID on the parent payment tender staging record.
EXT_​TRANSMIT_​ID
50
Y
A/N
This must correspond with the external transmission ID on the parent payment tender staging record.
EXT_​BATCH_​ID
30
Y
A/N
This must correspond with the external batch ID on the parent payment tender staging record.
EXT_​REFERENCE_​ID
30
Y
A/N
This must correspond with the external reference ID on the parent payment tender staging record.
CUST_​ID
15
Y
A/N
This is the account ID or old account number of the customer to which the payment should be distributed. If the system cannot find an account ID or old account number that matches this value, the account ID of the payor is used on the corresponding payment. If the payor's account ID is invalid, the tender source's suspense SA is used.
PAY_​AMT
13.2
Y
N
MATCH_​TYPE_​CD
8
N
A/N
See the description of the MATCH_​VALUE field below. Refer to Payments And Match Events for more information about the significance of this field.
MATCH_​VALUE
30
N
A/N
MATCH_​VALUE and MATCH_​TYPE_​CD are used in conjunction to indicate that the distribution of the payment should be restricted in some way (i.e., the standard payment distribution algorithm should not be used). MATCH_​TYPE_​CD indicates how the payment should be distributed (e.g., only distribute to a specific service agreement), MATCH_​VALUE contains the ID of the restriction (e.g., the SA ID).
If MATCH_​TYPE_​CD is specified, it must reference a valid Match Type.
